Toggling Genesys Cloud Recording States via Node.js REST SDK with Compliance Validation and Audit Logging
  • A Node.js module that programmatically starts and stops Genesys Cloud conversation recordings with strict compliance validation, state tracking, and audit logging.
  • It uses the @genesyscloud/genesyscloud Node.js SDK and the /api/v2/conversations/{conversationId}/recordings REST endpoint.
  • The implementation covers JavaScript (ES Modules) with async/await, native fetch, Zod schema validation, and EventEmitter-based callback routing.
  • OAuth 2.0 Client Credentials grant with recording:read, recording:write, and conversation:read scopes
  • @genesyscloud/genesyscloud v4.x
  • Node.js 18+ (native fetch support)
  • External dependencies: npm install @genesyscloud/genesyscloud zod events
  • Environment variables: GENESYS_REGION, GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET
Genesys Cloud requires OAuth 2.0 for all API interactions. The Client Credentials flow returns a bearer token that expires after one hour. The following implementation caches the token and refreshes it automatically when expiration approaches.
import { readFileSync } from 'node:fs';
import { join } from 'node:path';
const GENESYS_REGION = process.env.GENESYS_REGION || 'mypurecloud.com';
const CLIENT_ID = process.env.GENESYS_CLIENT_ID;
const CLIENT_SECRET = process.env.GENESYS_CLIENT_SECRET;
const AUTH_URL = `https://api.${GENESYS_REGION}/oauth/token`;
let tokenCache = { accessToken: null, expiresAt: 0 };
export async function getAccessToken() {
  const now = Date.now();
  if (tokenCache.accessToken && now < tokenCache.expiresAt - 60000) {
    return tokenCache.accessToken;
  const response = await fetch(AUTH_URL, {
    method: 'POST',
    body: new URLSearchParams({
      client_id: CLIENT_ID,
      client_secret: CLIENT_SECRET,
      scope: 'recording:read recording:write conversation:read'
  if (!response.ok) {
    const errorBody = await response.text();
    throw new Error(`OAuth token request failed with ${response.status}: ${errorBody}`);
  const data = await response.json();
  tokenCache.accessToken = data.access_token;
  tokenCache.expiresAt = now + (data.expires_in * 1000);
  return data.access_token;
The scope string explicitly requests recording:read and recording:write. The cache checks for a sixty-second buffer before expiration to prevent mid-request token invalidation.
Step 1: Schema Validation and Compliance Pipeline
Before sending a toggle request, the payload must pass structural validation and compliance checks. Genesys Cloud enforces maximum recording durations (typically 720 minutes), requires explicit consent flags for regulated regions, and validates storage destinations against configured matrices. The following Zod schema and validation function enforce these constraints.
import { z } from 'zod';
const RecordingToggleSchema = z.object({
  conversationId: z.string().uuid(),
  state: z.enum(['started', 'stopped']),
  recordingMode: z.enum(['all', 'agent', 'customer', 'supervisor']).optional(),
  storageDestination: z.string().max(255).optional(),
  consentStatus: z.enum(['granted', 'denied', 'pending']).default('granted'),
  maxDurationMinutes: z.number().min(1).max(720).default(60)
export async function validateTogglePayload(payload, licenseCheckFn, privacyCheckFn) {
  const parsed = RecordingToggleSchema.safeParse(payload);
  if (!parsed.success) {
    throw new Error(`Schema validation failed: ${parsed.error.flatten().fieldErrors}`);
  const data = parsed.data;
  if (data.consentStatus === 'denied') {
    throw new Error('Recording toggle rejected: consent status is denied');
  const licenseValid = await licenseCheckFn();
  if (!licenseValid) {
    throw new Error('Recording toggle rejected: insufficient license entitlement for recording controls');
  const privacyCompliant = await privacyCheckFn(data.conversationId, data.consentStatus);
  if (!privacyCompliant) {
    throw new Error('Recording toggle rejected: privacy regulation verification failed');
  return data;
The schema rejects invalid UUIDs, out-of-range durations, and missing consent directives. The pipeline delegates license and privacy checks to asynchronous functions that query internal entitlement services or regional compliance databases.
Step 2: Atomic Toggle Execution with Retry and State Control
The /api/v2/conversations/{conversationId}/recordings endpoint accepts a POST request to start a recording and a PATCH request to stop it. Genesys Cloud returns a 409 Conflict if the recording state already matches the requested state. The following function handles atomic execution, exponential backoff for 429 Rate Limit responses, and format verification.
import { getAccessToken } from './auth.js';
const API_BASE = `https://api.${GENESYS_REGION}`;
export async function executeToggle(validatedPayload, retryCount = 0) {
  const token = await getAccessToken();
  const { conversationId, state, recordingMode, storageDestination, maxDurationMinutes } = validatedPayload;
  const endpoint = `${API_BASE}/api/v2/conversations/${conversationId}/recordings`;
  const body = {
    state,
    recordingMode,
    storageDestination,
    maxDuration: maxDurationMinutes * 60,
    format: 'wav',
    includeMetadata: true
  const response = await fetch(endpoint, {
    method: state === 'stopped' ? 'PATCH' : 'POST',
    headers: {
      'Content-Type': 'application/json'
    body: JSON.stringify(body)
  if (response.status === 429 && retryCount < 3) {
    const retryAfter = parseInt(response.headers.get('Retry-After') || '2', 10);
    await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
    return executeToggle(validatedPayload, retryCount + 1);
  if (response.status === 409) {
    const existing = await response.json();
    return { success: true, message: 'State already matches', recordingId: existing.id };
  if (!response.ok) {
    const errorText = await response.text();
    throw new Error(`Toggle failed with ${response.status}: ${errorText}`);
  const result = await response.json();
  return { success: true, recordingId: result.id, state: result.state };
The function switches HTTP methods based on the target state. It converts duration from minutes to seconds for the API. It implements a three-attempt retry loop for rate limits, reading the Retry-After header when available. A 409 response is treated as an idempotent success rather than a failure.
Step 3: Metrics Collection, Audit Logging, and Callback Routing
Production recording togglers must track latency, success rates, and generate immutable audit trails. The following class wraps the validation and execution steps, exposes EventEmitter-style callbacks for external archive synchronization, and maintains internal metrics.
import { EventEmitter } from 'node:events';
export class RecordingToggler extends EventEmitter {
  constructor(licenseCheckFn, privacyCheckFn) {
    super();
    this.licenseCheckFn = licenseCheckFn;
    this.privacyCheckFn = privacyCheckFn;
    this.metrics = { attempts: 0, successes: 0, failures: 0, totalLatencyMs: 0 };
    this.auditLog = [];
  async toggle(payload) {
    const startTime = Date.now();
    this.metrics.attempts++;
    const auditEntry = { timestamp: new Date().toISOString(), payload: { ...payload }, status: 'pending' };
      const validated = await validateTogglePayload(payload, this.licenseCheckFn, this.privacyCheckFn);
      const result = await executeToggle(validated);
      const latency = Date.now() - startTime;
      this.metrics.successes++;
      this.metrics.totalLatencyMs += latency;
      auditEntry.status = 'success';
      auditEntry.recordingId = result.recordingId;
      auditEntry.latencyMs = latency;
      this.auditLog.push(auditEntry);
      this.emit('stateChanged', { conversationId: payload.conversationId, state: payload.state, latencyMs: latency, auditEntry });
      this.emit('archiveSyncTrigger', { recordingId: result.recordingId, conversationId: payload.conversationId });
      return result;
    } catch (error) {
      this.metrics.failures++;
      auditEntry.status = 'failed';
      auditEntry.error = error.message;
      this.emit('toggleFailed', { conversationId: payload.conversationId, error: error.message, latencyMs: latency, auditEntry });
      throw error;
  getMetrics() {
    const avgLatency = this.metrics.successes > 0 ? this.metrics.totalLatencyMs / this.metrics.successes : 0;
    const successRate = this.metrics.attempts > 0 ? (this.metrics.successes / this.metrics.attempts) * 100 : 0;
    return { attempts: this.metrics.attempts, successes: this.metrics.successes, failures: this.metrics.failures, avgLatencyMs: avgLatency.toFixed(2), successRate: successRate.toFixed(2) };
  getAuditLog() {
    return [...this.auditLog];
The class tracks four core metrics: attempts, successes, failures, and average latency. It calculates success rate on demand. Every toggle attempt generates an audit entry with timestamps, payloads, latency, and outcome. The archiveSyncTrigger event allows external systems to pull recording files as soon as the state changes.
Step 4: External Archive Synchronization Handler
External storage systems require a callback mechanism to align local toggle events with remote archive ingestion. The following handler demonstrates how to attach to the archiveSyncTrigger event and push recording metadata to a hypothetical S3-compatible archive service.
export function attachArchiveSync(toggler, archiveEndpoint) {
  toggler.on('archiveSyncTrigger', async ({ recordingId, conversationId }) => {
      const response = await fetch(`${archiveEndpoint}/ingest`, {
        method: 'POST',
        body: JSON.stringify({ recordingId, conversationId, syncedAt: new Date().toISOString() })
      if (!response.ok) {
        console.error(`Archive sync failed for ${recordingId}: ${response.statusText}`);
    } catch (err) {
      console.error(`Archive sync network error: ${err.message}`);
The handler runs asynchronously and does not block the main toggle flow. It captures network failures and logs them without interrupting recording state management.
The following script assembles all components into a runnable module. Replace the placeholder compliance functions with your internal entitlement and privacy verification services.
import { RecordingToggler } from './toggler.js';
import { attachArchiveSync } from './archive.js';
// Mock compliance checks - replace with actual API calls to your entitlement/privacy services
const checkLicense = async () => true;
const checkPrivacy = async (conversationId, consentStatus) => {
  // Example: query regional GDPR/CCPA database
  return consentStatus !== 'denied';
const toggler = new RecordingToggler(checkLicense, checkPrivacy);
attachArchiveSync(toggler, 'https://archive.yourdomain.com/api');
// Track toggle failures for alerting
toggler.on('toggleFailed', (data) => {
  console.log(`[AUDIT] Toggle failed: ${data.error} | Latency: ${data.latencyMs}ms`);
  console.log(data.auditEntry);
async function run() {
  const targetConversation = '550e8400-e29b-41d4-a716-446655440000';
    console.log('Starting recording...');
    const startResult = await toggler.toggle({
      conversationId: targetConversation,
      state: 'started',
      recordingMode: 'all',
      storageDestination: 's3://gen-recordings/prod',
      consentStatus: 'granted',
      maxDurationMinutes: 45
    console.log('Recording started:', startResult);
    console.log('Stopping recording...');
    const stopResult = await toggler.toggle({
      state: 'stopped',
    console.log('Recording stopped:', stopResult);
    console.log('Metrics:', toggler.getMetrics());
    console.log('Audit Log:', JSON.stringify(toggler.getAuditLog(), null, 2));
  } catch (err) {
    console.error('Toggle workflow failed:', err.message);
run();
The script starts a recording, stops it, and prints metrics and audit logs. The compliance functions return true for demonstration. In production, they must query your license management system and regional privacy database.
  • Cause: OAuth token expired, missing, or generated without recording:write scope.
  • Fix: Verify the scope parameter in the token request. Ensure the token cache refreshes before expiration. Check that the OAuth client ID and secret match a valid Genesys Cloud application.
Error: 403 Forbidden
  • Cause: The OAuth application lacks the required recording permissions, or the user context does not have entitlement for recording controls.
  • Fix: Navigate to the Genesys Cloud admin console, open the OAuth application, and grant recording:read and recording:write. Verify that the calling identity has the Recording Manager or Administrator role.
Error: 409 Conflict
  • Cause: The recording state already matches the requested state, or a recording is already active for the conversation.
  • Fix: The executeToggle function treats 409 as an idempotent success. If you require strict state transitions, parse the 409 response body to extract the existing recordingId and skip the toggle.
  • Cause: Exceeded Genesys Cloud rate limits for the /api/v2/conversations namespace.
  • Fix: The implementation includes a three-attempt exponential backoff loop that reads the Retry-After header. For high-volume environments, implement a token bucket rate limiter before invoking toggler.toggle().
Error: Schema Validation Failed
  • Cause: Payload contains invalid UUIDs, duration exceeding 720 minutes, or missing consent directives.
  • Fix: Review the Zod error output in the catch block. Ensure conversationId is a valid UUID and maxDurationMinutes falls within the 1 to 720 range. Verify consentStatus matches the allowed enum values.
