TMonitor and SIP
Hi, all,
I am having a problem with getting TMonitor to work with SIP TServer.
The problem in a nutshell is that instead of monitoring, I am getting a three-party talk.
Here is a log – any ideas?
I was hoping that MCU would be able to do this for me without me specifying a=recvonly in SDP.
10:46:50.762 Trc 04541 RequestMonitorNextCall received from 484 (0066 CTISIP_Client)
message RequestMonitorNextCall
AttributeThisDN ‘6501’
AttributeOtherDN ‘6003’
AttributeMonitorNextCallType 1 (MonitorAllCalls)
AttributeReferenceID 6
10:46:50.762 – created: CRequest@01C0F140 RequestMonitorNextCall-CTISIP_Client[484]/6
10:46:50.762 +++ CIFace::Request +++
– new invoke
Parsed: RequestMonitorNextCall
Numbers: +<6501> +<6003>
Status: parsed:1 queued:0 sent:0 acked:0 preevent:0 event:0 context:0 transferred:0
– validate
– state check: ok
SIPTS_IFace::QServe()01C0F140
CIFace: Sent CRequest@01C0F140 RequestMonitorNextCall-CTISIP_Client[484]/6
@10:46:50.7620 [BSYNC] Trace: Send to backup (TServer_SIPPremise_Backup) [404]: message EventSwitchInfo
attr_#1005 0
attr_#1004 762
attr_#1003 1172713610
attr_#1002 1447
attr_#1001 2
attr_#1000 131072
AttributeTransferredNetworkCallID 9437282
AttributeCallID 75
AttributeNetworkNodeID 0
AttributeNodeID [54] 05 00 00 00..
AttributeProtocolVersion 1
@10:46:50.7620 [BSYNC] Trace: Sent
sipcs: 10:46:50.762 Monitor mode: assume ‘normal’
sipcs: 10:46:50.762 Monitor scope being set to default-monitor-scope
@10:46:50.7620 [0] 7.2.100.42 send_to_client: message EventMonitoringNextCall
AttributeEventSequenceNumber 0000000000000606
AttributeTimeinuSecs 762000
AttributeTimeinSecs 1172713610 (10:46:50)
AttributeThisDNRole 10
AttributeOtherDNRole 2
10:46:50.762 Trc 04542 EventMonitoringNextCall sent to 484 (0066 CTISIP_Client)
@10:46:50.7620 [0] 7.2.100.42 distribute_event: message EventMonitoringNextCall
AttributeEventSequenceNumber 0000000000000607
AttributeThisDN ‘6003’
AttributeOtherDN ‘6501’
AttributeThisDNRole 2
AttributeOtherDNRole 10
@10:46:50.7620 [ISCC] Debug: Translate: ‘’ → ‘’; result 1 ()
10:46:50.762 Trc 04542 EventMonitoringNextCall sent to 496 (0065 CTISIP_Client)
10:46:50.762 Trc 04542 EventMonitoringNextCall sent to 452 (0006 StatServer)
10:46:50.762 Trc 04542 EventMonitoringNextCall sent to 440 (0005 Rpt_StatServer)
10:46:50.778 Trc 04542 EventMonitoringNextCall sent to 428 (0004 StatServer)
10:46:50.778 Trc 04542 EventMonitoringNextCall sent to 416 (0003 Rpt_StatServer)
sipcs: 10:46:50.778 dn[6003] is not on the call. Will postpone monitoring
Response (0): for CRequest@01C0F140 RequestMonitorNextCall-CTISIP_Client[484]/6
FinishRequest CRequest@01C0F140 RequestMonitorNextCall-CTISIP_Client[484]/6
IFace stats: q=280 s=4294967016
– complete
10:46:50.778 — CIFace::Request —
10:46:50.778 – deleted: CRequest@01C0F140 RequestMonitorNextCall-CTISIP_Client[484]/6
-AP[6945]->-416 @10:46:51.8400
-Ap[6945]-<-416 @10:46:51.8400
-AP[7396]->-440 @10:46:56.0280
-Ap[7396]-<-440 @10:46:56.0280
-AP[4]->-496 @10:46:58.1060
-Ap[4]-<-496 @10:46:58.1060
sipcs: 10:47:01.122 Sending [376,UDP] 462 bytes to 172.30.0.222:5065 >>>>>
INVITE sip:victor@172.30.0.222:5065 SIP/2.0
From: sip:gsipsync;tag=E06FE6D1-2F67-4DF2-8DDB-18030FC07D7A-1
To: sip:gsipsync;tag=3B47ED79-9ABE-4D09-9908-39FF324C0438-1
Call-ID: 289A0BB2DF73437fA79AD5FB5133C52C@gsipsync
CSeq: 10181 INVITE
Content-Length: 0
Via: SIP/2.0/UDP 172.30.0.222:5060;branch=z9hG4bK7E8C56E5-A57F-4D13-96E3-AA158F1ECC6C-10698
Contact: sip:panda@172.30.0.222:5060
Session-Expires: 20;refresher=uac
Min-SE: 10
Supported: timer
sipcs: 10:47:01.122 Received [376,UDP] 472 bytes from 172.30.0.222:5065 <<<<<
SIP/2.0 200 OK
CSeq: 10181 INVITE
Via: SIP/2.0/UDP 172.30.0.222:5060;branch=z9hG4bK7E8C56E5-A57F-4D13-96E3-AA158F1ECC6C-10698;received=172.30.0.222
Contact: sip:victor@172.30.0.222:5065
Min-SE: 10
Require: timer
Supported: timer
Content-Length: 0
sipcs: 10:47:01.122 Sending [376,UDP] 353 bytes to 172.30.0.222:5065 >>>>>
ACK sip:victor@172.30.0.222:5065 SIP/2.0
CSeq: 10181 ACK
Content-Length: 0
-AP[8341]-<-416 @10:47:01.8400
-Ap[8341]->-416
sipcs: 10:47:03.403 Received [376,UDP] 828 bytes from 172.30.0.200:5060 <<<<<
INVITE sip:6003@172.30.0.222 SIP/2.0
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, REFER, NOTIFY, REGISTER
Via: SIP/2.0/UDP 172.30.0.200:5060;branch=z9hG4bK45e6ab1b11c38515eb8
Max-Forwards: 69
To: sip:6003@172.30.0.222
Call-ID: 108-1985@172.30.0.200
CSeq: 1000311362 INVITE
Contact: sip:7000@172.30.0.200;transport=UDP
P-Asserted-Identity: “7000” sip:7000@192.168.100.251
Remote-Party-ID: “7000” sip:7000@192.168.100.251;party=calling;privacy=off
Cisco-Guid: 3863002062-3705425820-2839067314-2977428030
User-Agent: SHOUT 4.0.2v15
Content-Type: application/sdp
Content-Length: 176
v=0
o=SHOUT 0 0 IN IP4 172.30.0.200
s=SIP call via SHOUT
c=IN IP4 172.30.0.200
t=0 0
m=audio 16760 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
sipcs: +dialog [0:00@01821958]
sipcs: +dialog [0:00@01822b60]
sipcs: CInf[0x0181ba50]
sipcs: dbg=>ProcessNewLinkedDialogs::1
sipcs: 10:47:03.403 Sending [376,UDP] 474 bytes to 172.30.0.222:5065 >>>>>
INFO sip:victor@172.30.0.222:5065 SIP/2.0
CSeq: 10182 INFO
Content-Length: 44
Content-Type: application/gsipsync
Via: SIP/2.0/UDP 172.30.0.222:5060;branch=z9hG4bK7E8C56E5-A57F-4D13-96E3-AA158F1ECC6C-10699
1=1
2=357
3=108-1985@172.30.0.200
4=267
sipcs: 10:47:03.403 trunk ip addr 172.30.0.200
sipcs: Reg. Info: dn[7000]<=cme[Trunk] Incoming Invite
sipcs: 10:47:03.403 dispatchDE: dlg[357]
sipcs: UK-PEM:HANDLE(NON-CONNECTED):<<EVENT(12)<<DLG[357]
sipcs: dialog [357:01@01821958]: << Event 12 << TRN[11262]
sipcs: 10:47:03.403 Stored This SDP [357]
sipcs: 10:47:03.403 Sending [376,UDP] 506 bytes to 172.30.0.222:5065 >>>>>
CSeq: 10183 INFO
Content-Length: 76
Via: SIP/2.0/UDP 172.30.0.222:5060;branch=z9hG4bK7E8C56E5-A57F-4D13-96E3-AA158F1ECC6C-10700
1=1
2=358
3=630AEC66-6008-4D70-8D4D-6B60119331CD-179@172.30.0.222
4=267
sipcs: 10:47:03.403 Sending [376,UDP] 1059 bytes to 172.30.0.238:8093 >>>>>
INVITE sip:6003@172.30.0.238:8093 SIP/2.0
Call-ID: 630AEC66-6008-4D70-8D4D-6B60119331CD-179@172.30.0.222
CSeq: 1 INVITE
Content-Length: 176
Via: SIP/2.0/UDP 172.30.0.222:5060;branch=z9hG4bK7E8C56E5-A57F-4D13-96E3-AA158F1ECC6C-10701
Contact: sip:172.30.0.222:5060
Max-Forwards: 68
Call-Info: http://genesyslab.com; 108-1985%40172.30.0.200;gen-rt=32fe006c;gen-lt=E06FE6D1-2F67-4DF2-8DDB-18030FC07D7A-221
Session-Expires: 1800;refresher=uac
Min-SE: 90
Supported: timer
v=0
t=0 0
sipcs: 10:47:03.403 dispatchDE: dlg[358]
sipcs: UK-PEM:HANDLE(NON-CONNECTED):<<EVENT(0)<<DLG[358]
sipcs: dialog [358:02@01822b60]: << Event 00 << TRN[11265]
sipcs: 10:47:03.403 Stored Other SDP [358]
sipcs: 10:47:03.403 Received [376,UDP] 389 bytes from 172.30.0.222:5065 <<<<<
SIP/2.0 200 OK
CSeq: 10182 INFO
Via: SIP/2.0/UDP 172.30.0.222:5060;branch=z9hG4bK7E8C56E5-A57F-4D13-96E3-AA158F1ECC6C-10699;received=172.30.0.222
Content-Length: 0
SIP/2.0 200 OK
CSeq: 10183 INFO
Via: SIP/2.0/UDP 172.30.0.222:5060;branch=z9hG4bK7E8C56E5-A57F-4D13-96E3-AA158F1ECC6C-10700;received=172.30.0.222
Content-Length: 0
sipcs: 10:47:03.403 Received [376,UDP] 355 bytes from 172.30.0.238:1111 <<<<<
SIP/2.0 100 Trying
To: sip:6003@172.30.0.222;tag=ac5084d5011c4b20aea9f6326ca31285
CSeq: 1 INVITE
User-Agent: RTC/1.2
Content-Length: 0
sipcs: UK-PEM:HANDLE(NON-CONNECTED):<<EVENT(1)<<DLG[358]
sipcs: dialog [358:02@01822b60]: << Event 01 << TRN[11265]
sipcs: 10:47:03.403 Received [376,UDP] 356 bytes from 172.30.0.238:1111 <<<<<
SIP/2.0 180 Ringing
CSeq: 1 INVITE
User-Agent: RTC/1.2
Content-Length: 0
10:47:03.403 +++ CIFace::Event +++
+++ Pre-event +++
Type EventRinging
Devices: <6003/6003> <-/7000> <-/->
ANI/DNIS: <7000> <6003>
Flags: divert=0 hook=1 postCall=0 active=1 moveAll=1 callType=1
— Pre-event —
+++ Ringing +++
– created call_info_tspp 0090016ddc31b04d@01C01B60
@10:47:03.4030 Call [0090016ddc31b04d]: urid 00010090
– created aTmCall 0181CB38/01C01B60
@10:47:03.4030 [BSYNC] Trace: Send to backup (TServer_SIPPremise_Backup) [404]: message EventUserEvent
attr_#1005 0
attr_#1004 403
attr_#1003 1172713623
attr_#1002 1448
attr_#1001 1
attr_#1000 131072
attr_#15101 77
AttributeUserEvent [15001]
Hi Vic,
It’s possible to specify monitor mode by attaching the key “MonitorMode” to Extensions Attributes. The possible values are:
normal - a mute connection with possible warning beep
connect - a three-party conference
mute - a mute connection
coach - whisper coaching - only an agent can hear the supervisor
René!
Here is what worked for me based on what you suggested:
    private void button1_Click(object sender, EventArgs e)
        DesktopToolkitX.CTKVPair myPair;
        DesktopToolkitX.CTKVList myList;
        //2007/01/25 DBG y.oki
        //string reasonCode=string.Empty;
        this.ReasonCode = string.Empty;
        myPair = new DesktopToolkitX.CTKVPair();
        myList = new DesktopToolkitX.CTKVList();
        myPair.Key = "MonitorMode";
        myPair.Type = DesktopToolkitX.CTKVType.CKVTypeString;
        myPair.StringValue = "mute";
        myList.AddHead(myPair);
        TExtension.TSetExtensions(myList);
        sMonitorNumber = cboDial.Text;
        DesktopToolkitX.TStatus rc =
this.TExtension.TMonitorNextCall(sMonitorNumber, DesktopToolkitX.TMonitorNextCallType.MonitorAllCalls);
what is 101 telephone-event/8000 mean?
