time problem in reporting?
Hi guys,
I am having problems related to historical reporting in CCPUlse. I have some diferences between the values that i save at the end of the business day (at 20:00 the business day ends but i save the reports an 21:00) from realtime reporting and the values that I get from historical reports . I checked all the statistics and they are the same.
The only thing that I could find in the statserver logs is this:
[i]Detecting system time changing to 2 seconds (for the statserver used in realtime reporting)
Detecting system time changing to -72 seconds (for the statserver used for historical reporting)
[/i]
So I thing that some values are not increased in historical because of time adjustments. The historical statserver is on a different machine than realtime statserver .
Do you have any ideas regarding this time adjustment ? Both machines get the time by synchronizing the vm clock with the esx host clock
Thank you
We had similar issue on AHT, and the reason was insensitivity setting, if you put it low enough, they will match.
JAG
