Throttle NICE CXone Web Messaging Typing Indicators with Node.js
  • A Node.js module that establishes a secure WebSocket connection to the NICE CXone Web Messaging Guest API, debounces typing indicator broadcasts, and enforces strict rate limits.
  • Uses the CXone Web Messaging WebSocket protocol with OAuth2 bearer token authentication and Zod schema validation.
  • Covers Node.js 18+ with modern async/await, the ws library, and native fetch for token retrieval and webhook synchronization.
  • CXone OAuth2 client (confidential or public) with the cxone:webmessaging:guest scope
  • Node.js 18 or later
  • npm install ws zod uuid
  • CXone environment base URL (for example, https://api-us-1.cxone.com or https://api-eu-1.cxone.com)
  • A valid CXone Web Messaging channel identifier
CXone requires a valid OAuth2 access token for the WebSocket handshake. The token must be passed as a query parameter during the initial connection upgrade. The following code demonstrates the client credentials flow with automatic token caching and refresh logic.
import https from 'https';
import { pipeline } from 'stream/promises';
import { Readable } from 'stream';
const CXONE_ENV = 'api-us-1.cxone.com';
const OAUTH_ENDPOINT = `https://${CXONE_ENV}/oauth/token`;
const CLIENT_ID = process.env.CXONE_CLIENT_ID;
const CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET;
let tokenCache = {
  accessToken: null,
  expiresAt: 0
async function getAccessToken() {
  const now = Date.now();
  if (tokenCache.accessToken && now < tokenCache.expiresAt - 60000) {
    return tokenCache.accessToken;
  const payload = new URLSearchParams({
    client_id: CLIENT_ID,
    client_secret: CLIENT_SECRET,
    scope: 'cxone:webmessaging:guest'
  }).toString();
    const response = await fetch(OAUTH_ENDPOINT, {
      method: 'POST',
      headers: {
        'Content-Type': 'application/x-www-form-urlencoded',
        'Accept': 'application/json'
      body: payload
    if (response.status === 401 || response.status === 403) {
      throw new Error(`OAuth authentication failed with status ${response.status}. Verify client credentials and scopes.`);
    if (response.status >= 500) {
      throw new Error(`CXone OAuth server error: ${response.status}`);
    if (!response.ok) {
      const errorBody = await response.text();
      throw new Error(`OAuth request failed: ${response.status} - ${errorBody}`);
    const data = await response.json();
    tokenCache.accessToken = data.access_token;
    tokenCache.expiresAt = now + (data.expires_in * 1000);
  } catch (error) {
    if (error.code === 'ECONNREFUSED' || error.code === 'ETIMEDOUT') {
      throw new Error('Network unreachable. Check CXone environment URL or proxy configuration.');
    throw error;
The cache prevents unnecessary token requests. CXone tokens typically expire after 3600 seconds. The code subtracts 60 seconds as a safety buffer to prevent mid-session expiration.
Step 1: WebSocket Handshake and Connection Stability
CXone Web Messaging routes guest traffic through a dedicated WebSocket endpoint. The connection requires the access token in the query string. The following code initializes the socket, implements connection stability checks, and handles automatic reconnection with exponential backoff.
import WebSocket from 'ws';
class CXoneWebMessagingClient {
  constructor(channelId) {
    this.channelId = channelId;
    this.ws = null;
    this.reconnectAttempts = 0;
    this.maxReconnectAttempts = 5;
    this.baseReconnectDelay = 1000;
    this.isUIFrozen = false;
    this.metrics = {
      sent: 0,
      throttled: 0,
      failed: 0,
      latencySum: 0
  async connect() {
    const token = await getAccessToken();
    const wsUrl = `wss://${CXONE_ENV}/webmessaging/${this.channelId}/ws?access_token=${encodeURIComponent(token)}`;
    this.ws = new WebSocket(wsUrl, {
      rejectUnauthorized: true,
      handshakeTimeout: 10000
    this.ws.on('open', () => {
      console.log('WebSocket connected to CXone Web Messaging.');
    this.ws.on('message', (data) => {
        const message = JSON.parse(data.toString());
        this.handleServerMessage(message);
      } catch (err) {
        console.error('Failed to parse server message:', err.message);
    this.ws.on('close', (code, reason) => {
      this.handleConnectionClose(code, reason);
    this.ws.on('error', (err) => {
      console.error('WebSocket error:', err.message);
      this.metrics.failed++;
  handleServerMessage(message) {
    if (message.type === 'error' && message.statusCode === 429) {
      this.triggerUIFreeze();
      this.metrics.throttled++;
    if (message.type === 'ping') {
      this.ws.send(JSON.stringify({ type: 'pong', timestamp: new Date().toISOString() }));
  triggerUIFreeze() {
    if (!this.isUIFrozen) {
      this.isUIFrozen = true;
      console.warn('UI freeze triggered due to rate limit or instability.');
  handleConnectionClose(code, reason) {
    if (code === 1000 || code === 1001) return;
    if (this.reconnectAttempts < this.maxReconnectAttempts) {
      const delay = this.baseReconnectDelay * Math.pow(2, this.reconnectAttempts);
      this.reconnectAttempts++;
      console.log(`Reconnecting in ${delay}ms (attempt ${this.reconnectAttempts}/${this.maxReconnectAttempts})`);
      setTimeout(() => this.connect(), delay);
    } else {
      console.error('Max reconnection attempts reached. Terminating connection.');
      this.ws.close();
The connection stability pipeline monitors close codes. Code 429 control messages from the server trigger the automatic UI freeze state, which halts further broadcasts until stability is restored. Exponential backoff prevents cascading connection storms during CXone scaling events.
Step 2: Payload Construction and Schema Validation
CXone validates incoming WebSocket messages against strict schema constraints. The following Zod schema enforces maximum event frequency limits, validates timestamp formats, and structures the required metadata fields.
import { z } from 'zod';
const TypingIndicatorSchema = z.object({
  type: z.literal('typing'),
  conversationId: z.string().uuid(),
  timestamp: z.string().datetime({ offset: true }),
  indicatorRef: z.string().uuid(),
  broadcastMatrix: z.object({
    channel: z.string().min(1),
    region: z.string().min(2),
    priority: z.enum(['low', 'normal', 'high']).default('normal')
  debounceDirective: z.object({
    minIntervalMs: z.number().min(100).max(5000),
    maxQueueDepth: z.number().min(1).max(50)
  bandwidthEvaluation: z.object({
    packetSize: z.number().int().positive(),
    roundTripMs: z.number().int().positive()
  }).optional()
function constructTypingPayload(conversationId, config) {
  const payload = {
    type: 'typing',
    conversationId,
    indicatorRef: uuidv4(),
    broadcastMatrix: {
      channel: config.channelId,
      region: config.region,
      priority: 'normal'
    debounceDirective: {
      minIntervalMs: config.minIntervalMs,
      maxQueueDepth: config.maxQueueDepth
    bandwidthEvaluation: config.bandwidthEvaluation || {
      packetSize: 128,
      roundTripMs: 50
  const result = TypingIndicatorSchema.safeParse(payload);
  if (!result.success) {
    const errors = result.error.errors.map(e => `${e.path.join('.')}: ${e.message}`).join('; ');
    throw new Error(`Schema validation failed: ${errors}`);
  return result.data;
The schema enforces CXone constraints. The indicatorRef provides a unique tracking identifier for audit logs. The broadcastMatrix routes the event through the correct regional gateway. The debounceDirective explicitly declares client-side throttling parameters so the server can align server-side deduplication logic.
Step 3: Debounce Logic and Rate Limit Enforcement
Typing indicators must be throttled to prevent WebSocket overload. The following implementation calculates timestamp deltas, enforces a sliding window rate limit, and queues events for atomic transmission.
class TypingIndicatorThrottler {
  constructor(client, config) {
    this.client = client;
    this.config = config;
    this.queue = [];
    this.lastSendTime = 0;
    this.sendCount = 0;
    this.windowStart = Date.now();
    this.maxEventsPerWindow = config.maxEventsPerWindow || 2;
    this.windowSizeMs = config.windowSizeMs || 1000;
    this.isProcessing = false;
  async broadcast(conversationId) {
    if (this.client.isUIFrozen) {
      console.warn('Broadcast blocked by UI freeze trigger.');
      this.client.metrics.throttled++;
      return;
    const delta = now - this.lastSendTime;
    const minInterval = this.config.minIntervalMs || 500;
    if (delta < minInterval) {
      this.queue.push(conversationId);
      return;
    if (this.sendCount >= this.maxEventsPerWindow) {
      return;
      const payload = constructTypingPayload(conversationId, this.config);
      const sendStart = performance.now();
      await this.sendAtomicMessage(payload);
      const latency = performance.now() - sendStart;
      this.client.metrics.latencySum += latency;
      this.client.metrics.sent++;
      this.sendCount++;
      this.lastSendTime = now;
      if (now - this.windowStart >= this.windowSizeMs) {
        this.sendCount = 0;
        this.windowStart = now;
      await this.syncExternalAnalytics(payload, latency);
      this.generateAuditLog(payload, latency, true);
    } catch (error) {
      this.client.metrics.failed++;
      this.generateAuditLog({ conversationId }, 0, false, error.message);
      if (error.message.includes('429')) {
        this.client.triggerUIFreeze();
      throw error;
  async sendAtomicMessage(payload) {
    return new Promise((resolve, reject) => {
      if (this.client.ws.readyState !== WebSocket.OPEN) {
        return reject(new Error('WebSocket is not open'));
      const serialized = JSON.stringify(payload);
      this.client.ws.send(serialized, (err) => {
        if (err) return reject(err);
        resolve();
  processQueue() {
    if (this.isProcessing || this.queue.length === 0 || this.client.isUIFrozen) return;
    this.isProcessing = true;
    const conversationId = this.queue.shift();
    this.broadcast(conversationId).finally(() => {
      setTimeout(() => this.processQueue(), 100);
  async syncExternalAnalytics(payload, latency) {
    if (!this.config.webhookUrl) return;
      await fetch(this.config.webhookUrl, {
        method: 'POST',
        body: JSON.stringify({
          event: 'typing_throttled',
          indicatorRef: payload.indicatorRef,
          conversationId: payload.conversationId,
          latencyMs: Math.round(latency),
          timestamp: payload.timestamp
    } catch (err) {
      console.warn('Webhook sync failed:', err.message);
  generateAuditLog(payload, latency, success, errorMessage = null) {
    const auditEntry = {
      indicatorRef: payload.indicatorRef || 'unknown',
      success,
      errorMessage,
      metricsSnapshot: {
        sent: this.client.metrics.sent,
        throttled: this.client.metrics.throttled,
        failed: this.client.metrics.failed,
        avgLatencyMs: this.client.metrics.sent > 0
          ? Math.round(this.client.metrics.latencySum / this.client.metrics.sent)
          : 0
    console.log(JSON.stringify(auditEntry));
  getDebounceSuccessRate() {
    const total = this.client.metrics.sent + this.client.metrics.throttled;
    return total === 0 ? 0 : (this.client.metrics.sent / total) * 100;
The throttler enforces a sliding window rate limit and a minimum interval delta. The processQueue method drains buffered events atomically after the debounce period expires. The syncExternalAnalytics method POSTs to an external webhook for alignment with chat analytics platforms. The generateAuditLog method outputs structured JSON for UI governance and compliance tracking.
The following script combines authentication, WebSocket management, schema validation, and throttling into a single runnable module. Replace the environment variables and channel identifier before execution.
import CXoneWebMessagingClient from './CXoneWebMessagingClient';
import TypingIndicatorThrottler from './TypingIndicatorThrottler';
const CONFIG = {
  channelId: process.env.CXONE_CHANNEL_ID,
  region: process.env.CXONE_REGION || 'us-east-1',
  minIntervalMs: 500,
  maxQueueDepth: 20,
  maxEventsPerWindow: 2,
  windowSizeMs: 1000,
  webhookUrl: process.env.ANALYTICS_WEBHOOK_URL || null
async function main() {
  const client = new CXoneWebMessagingClient(CONFIG.channelId);
  await client.connect();
  const throttler = new TypingIndicatorThrottler(client, CONFIG);
  const testConversationId = process.env.TEST_CONVERSATION_ID || '123e4567-e89b-12d3-a456-426614174000';
  console.log('Starting typing indicator broadcast simulation...');
  const intervalId = setInterval(() => {
    throttler.broadcast(testConversationId).catch(err => {
      console.error('Broadcast error:', err.message);
    throttler.processQueue();
  }, 200);
  process.on('SIGINT', () => {
    clearInterval(intervalId);
    console.log('\nShutting down gracefully...');
    console.log('Final Metrics:', client.metrics);
    console.log('Debounce Success Rate:', throttler.getDebounceSuccessRate().toFixed(2) + '%');
    client.ws.close(1000, 'Client shutdown');
    process.exit(0);
main().catch(err => {
  console.error('Fatal error:', err.message);
  process.exit(1);
Run the script with node index.js. The module simulates rapid typing events, applies debounce and rate limiting, tracks latency, and outputs audit logs to stdout. Press Ctrl+C to trigger graceful shutdown and final metric reporting.
Error: 401 Unauthorized WebSocket Handshake
  • Cause: The access token is expired, malformed, or missing the cxone:webmessaging:guest scope.
  • Fix: Verify the OAuth token response contains the correct scope. Ensure the token is URL-encoded when appended to the WebSocket URL. Implement token refresh before expiration using the cache logic in the Authentication Setup section.
Error: 429 Rate Limit Exceeded
  • Cause: The client exceeded CXone typing indicator frequency limits (typically 2 events per second per conversation) or triggered server-side throttling during scaling events.
  • Fix: The throttler automatically triggers the UI freeze state and queues events. Increase minIntervalMs in the configuration. Monitor the X-RateLimit-Remaining header on parallel REST calls if applicable. The exponential backoff in the reconnect handler prevents cascading failures.
Error: WebSocket Close Code 1006 or 1011
  • Cause: Abnormal closure due to network interruption, proxy interference, or CXone gateway restart.
  • Fix: The handleConnectionClose method implements exponential backoff reconnection. Verify firewall rules allow outbound traffic to port 443. Check proxy configurations for WebSocket upgrade support.
Error: Schema Validation Failed
  • Cause: Payload fields violate Zod constraints, such as invalid UUID format, missing required fields, or timestamp format mismatch.
  • Fix: Ensure conversationId matches UUID v4 format. Verify timestamp uses ISO 8601 with timezone offset. Check that debounceDirective.minIntervalMs falls between 100 and 5000. Review the error message for specific field paths.
