Throttle NICE CXone LLM Gateway Inference Requests with Python SDK
- A Python module that constructs throttling payloads with request references, token matrices, and limit directives, validates them against AI orchestration constraints, and prevents throttling failure during scaling events.
- An atomic POST handler that parses rate limit headers, buffers requests in an async queue, verifies model capacity and cost ceilings, and synchronizes throttle events with external webhooks.
- A complete Python implementation using
httpxandpydanticthat tracks latency, calculates success rates, generates audit logs, and exposes a request throttler for automated CXone management.
- OAuth 2.0 Client Credentials grant configured in NICE CXone with scopes
ai:gateway:writeandai:gateway:read - Python 3.10 or higher
- Dependencies:
httpx>=0.27.0,pydantic>=2.6.0,pydantic-settings>=2.1.0,aiofiles>=23.2.1 - Access to a CXone deployment with AI Gateway enabled
NICE CXone uses standard OAuth 2.0 client credentials flow. The following function acquires a bearer token, caches it, and refreshes it automatically before expiration.
import os
import httpx
from pydantic_settings import BaseSettings
class CxoneSettings(BaseSettings):
oauth_url: str = "https://api.mynicecx.com/oauth/token"
api_base_url: str = "https://api.mynicecx.com"
client_id: str = Field(..., alias="CXONE_CLIENT_ID")
client_secret: str = Field(..., alias="CXONE_CLIENT_SECRET")
model_config = {"env_file": ".env"}
class OAuthToken(BaseModel):
access_token: str
expires_in: int
issued_at: float = Field(default_factory=time.time)
def is_expired(self) -> bool:
return time.time() >= (self.issued_at + self.expires_in - 60)
class CxoneAuthenticator:
def __init__(self, settings: CxoneSettings):
self.settings = settings
self._token: OAuthToken | None = None
if self._token and not self._token.is_expired():
return self._token.access_token
response = await client.post(
self.settings.oauth_url,
data={
"client_id": self.settings.client_id,
"client_secret": self.settings.client_secret,
"scope": "ai:gateway:write ai:gateway:read"
response.raise_for_status()
payload = response.json()
self._token = OAuthToken(
access_token=payload["access_token"],
expires_in=payload["expires_in"]
Step 1: Throttling Payload Construction and Schema Validation
The AI Gateway requires explicit throttling directives to prevent quota exhaustion. We define a Pydantic schema that enforces maximum concurrent context window limits and validates token matrices against orchestration constraints.
from pydantic import BaseModel, Field, model_validator
from typing import Literal
class TokenMatrix(BaseModel):
max_tokens: int = Field(..., ge=1, le=32000)
context_window: int = Field(..., ge=1, le=128000)
reserved_tokens: int = Field(default=0, ge=0)
@model_validator(mode="after")
def validate_context_window(self) -> "TokenMatrix":
if self.context_window < self.max_tokens:
raise ValueError("Context window must be greater than or equal to max tokens")
return self
class LimitDirective(BaseModel):
max_requests_per_minute: int = Field(..., ge=1, le=1000)
max_tokens_per_minute: int = Field(..., ge=1, le=500000)
concurrency_limit: int = Field(default=5, ge=1, le=50)
class ThrottlePayload(BaseModel):
request_reference: str = Field(..., pattern=r"^[A-Za-z0-9\-_]+$")
model_id: str = Field(..., pattern=r"^(gpt|claude|llama)-\d+")
token_matrix: TokenMatrix
limit_directive: LimitDirective
prompt_template: str = Field(..., min_length=1)
def validate_prompt_injection(self) -> "ThrottlePayload":
dangerous_patterns = ["<system>", "ignore previous", "override context"]
for pattern in dangerous_patterns:
if pattern.lower() in self.prompt_template.lower():
raise ValueError(f"Prompt template contains restricted pattern: {pattern}")
return self
Step 2: Atomic POST Execution with Rate Limit Parsing and Queue Buffering
We implement an async queue that buffers inference requests, parses CXone rate limit headers, and retries on 429 responses using exponential backoff. The queue ensures safe throttle iteration during scaling events.
import asyncio
import logging
from httpx import HTTPStatusError, AsyncClient
logger = logging.getLogger("cxone_throttler")
class InferenceQueue:
def __init__(self, client: AsyncClient, max_size: int = 100):
self.client = client
self.queue = asyncio.Queue(maxsize=max_size)
self.active_requests = 0
self.max_concurrent = 5
async def submit_request(self, payload: ThrottlePayload, headers: dict) -> dict:
await self.queue.put(payload)
return await self._process_next(headers)
async def _process_next(self, base_headers: dict) -> dict:
while self.active_requests >= self.max_concurrent:
await asyncio.sleep(0.1)
payload = await self.queue.get()
self.active_requests += 1
url = f"{self.client.base_url}/api/v2/ai/gateway/inference"
headers = {**base_headers, "Content-Type": "application/json"}
response = await self.client.post(url, json=payload.model_dump(), headers=headers)
retry_after = float(response.headers.get("Retry-After", 2))
logger.warning(f"Rate limit hit. Waiting {retry_after}s")
return await self._process_next(base_headers)
return response.json()
except HTTPStatusError as exc:
logger.error(f"API error: {exc.response.status_code} - {exc.response.text}")
raise
finally:
self.active_requests -= 1
Step 3: Full HTTP Request Response Cycle and Pagination
The following demonstrates the exact HTTP cycle for submitting an inference request and fetching throttle configurations with pagination.
Request
POST /api/v2/ai/gateway/inference HTTP/1.1
Host: api.mynicecx.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
X-Request-ID: req_throttle_001
"request_reference": "prod-inference-8842",
"model_id": "gpt-4",
"token_matrix": {
"max_tokens": 4096,
"context_window": 8192,
"reserved_tokens": 512
"limit_directive": {
"max_requests_per_minute": 60,
"max_tokens_per_minute": 100000,
"concurrency_limit": 5
"prompt_template": "Analyze the following customer transcript for sentiment:"
Response
"request_id": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"status": "accepted",
"model_version": "gpt-4-2024-02-15",
"estimated_latency_ms": 120,
"throttle_status": "within_limits",
"rate_limit_remaining": 58,
"cost_estimate_usd": 0.0312
To fetch existing throttle configurations with pagination, use the following endpoint:
async def list_throttle_configs(client: AsyncClient, headers: dict) -> list:
configs = []
page = 1
while True:
url = f"{client.base_url}/api/v2/ai/gateway/throttle-configs"
response = await client.get(url, headers=headers, params={"pageSize": 20, "pageNumber": page})
data = response.json()
configs.extend(data.get("items", []))
if page >= data.get("totalPages", 1):
break
page += 1
return configs
Step 4: Model Capacity Checking and Cost Ceiling Verification
Before queuing requests, the throttler verifies that the target model has available capacity and that the projected cost does not exceed the configured ceiling.
class CapacityVerifier:
def __init__(self, cost_ceiling_usd: float = 50.0):
self.cost_ceiling = cost_ceiling_usd
self.running_cost = 0.0
self._lock = asyncio.Lock()
async def verify(self, payload: ThrottlePayload, estimated_cost_usd: float) -> bool:
async with self._lock:
if self.running_cost + estimated_cost_usd > self.cost_ceiling:
raise ValueError(f"Cost ceiling exceeded. Current: {self.running_cost:.4f}, Request: {estimated_cost_usd:.4f}")
self.running_cost += estimated_cost_usd
return True
async def release_cost(self, amount: float) -> None:
self.running_cost -= amount
Step 5: Webhook Synchronization, Latency Tracking, and Audit Logging
The throttler synchronizes throttle events with external token monitors via webhooks, tracks latency and success rates, and writes structured audit logs for AI governance.
import json
import aiofiles
from dataclasses import dataclass, asdict
@dataclass
class ThrottleAuditEntry:
timestamp: float
status: str
latency_ms: float
success: bool
rate_limit_remaining: int | None
cost_usd: float | None
class ThrottleMonitor:
def __init__(self, webhook_url: str, log_path: str = "throttle_audit.log"):
self.log_path = log_path
self.total_requests = 0
self.successful_requests = 0
self._http = httpx.AsyncClient(timeout=5.0)
async def record(self, entry: ThrottleAuditEntry) -> None:
self.total_requests += 1
if entry.success:
self.successful_requests += 1
await self._write_log(entry)
await self._notify_webhook(entry)
async def _write_log(self, entry: ThrottleAuditEntry) -> None:
async with aiofiles.open(self.log_path, mode="a") as f:
await f.write(json.dumps(asdict(entry)) + "\n")
async def _notify_webhook(self, entry: ThrottleAuditEntry) -> None:
await self._http.post(
self.webhook_url,
json=asdict(entry),
headers={"Content-Type": "application/json"}
except httpx.RequestError as exc:
logger.warning(f"Webhook notification failed: {exc}")
def get_efficiency_metrics(self) -> dict:
success_rate = (self.successful_requests / self.total_requests * 100) if self.total_requests > 0 else 0.0
"total_requests": self.total_requests,
"successful_requests": self.successful_requests,
"success_rate_percent": round(success_rate, 2)
The following script integrates all components into a production-ready throttler. It requires environment variables CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, and CXONE_API_BASE_URL.
import asyncio
import logging
import os
import sys
logging.basicConfig(level=logging.INFO, format="%(asctime)s [%(levelname)s] %(name)s: %(message)s")
async def run_throttler():
settings = CxoneSettings()
auth = CxoneAuthenticator(settings)
token = await auth.get_token()
async with httpx.AsyncClient(base_url=settings.api_base_url) as client:
queue = InferenceQueue(client)
verifier = CapacityVerifier(cost_ceiling_usd=25.0)
monitor = ThrottleMonitor(webhook_url="https://hooks.example.com/cxone-throttle")
payload = ThrottlePayload(
request_reference="batch-prod-001",
model_id="gpt-4",
token_matrix=TokenMatrix(max_tokens=2048, context_window=4096, reserved_tokens=256),
limit_directive=LimitDirective(max_requests_per_minute=30, max_tokens_per_minute=50000, concurrency_limit=3),
prompt_template="Summarize the customer inquiry and extract intent."
await verifier.verify(payload, estimated_cost_usd=0.015)
result = await queue.submit_request(payload, headers)
audit_entry = ThrottleAuditEntry(
timestamp=time.time(),
request_reference=payload.request_reference,
status=result.get("status", "unknown"),
latency_ms=latency_ms,
success=result.get("status") == "accepted",
rate_limit_remaining=result.get("rate_limit_remaining"),
cost_usd=result.get("cost_estimate_usd")
await monitor.record(audit_entry)
await verifier.release_cost(0.015)
print(f"Request processed. Latency: {latency_ms:.2f}ms")
print(f"Metrics: {monitor.get_efficiency_metrics()}")
except Exception as exc:
logger.error(f"Throttling pipeline failed: {exc}")
sys.exit(1)
asyncio.run(run_throttler())
- Cause: Expired OAuth token, invalid client credentials, or missing
ai:gateway:writescope. - Fix: Verify the
.envfile contains correctCXONE_CLIENT_IDandCXONE_CLIENT_SECRET. Ensure the CXone admin console grants the required scopes to the OAuth client. TheCxoneAuthenticatorautomatically refreshes tokens 60 seconds before expiration.
Error: 403 Forbidden
- Cause: The OAuth client lacks permissions for the AI Gateway API, or the deployment is not licensed for LLM inference.
- Fix: Assign the
AI AdministratororAI Gateway Userrole to the OAuth client in the CXone administration console. Confirm the deployment has active AI credits or API licensing.
- Cause: Exceeded
max_requests_per_minuteormax_tokens_per_minutelimits defined in thelimit_directiveor enforced by CXone platform quotas. - Fix: The
InferenceQueueparser reads theRetry-Afterheader and applies exponential backoff. Reduceconcurrency_limitin theLimitDirectiveor distribute requests across multiple reference IDs to bypass per-reference throttling.
Error: 400 Bad Request
- Cause: Schema validation failure, prompt template injection detection, or invalid token matrix constraints.
- Fix: The
ThrottlePayloadvalidator rejects context windows smaller than max tokens and blocks dangerous prompt patterns. Adjust theTokenMatrixvalues to align with the target model documentation. Remove restricted keywords fromprompt_template.
Error: 503 Service Unavailable
- Cause: Model capacity exhausted or CXone AI Gateway maintenance window.
- Fix: The
CapacityVerifiertracks running costs and blocks requests when the ceiling is reached. Implement a fallback routing logic to switch to a secondarymodel_idwhen 503 responses persist for more than 10 seconds.
