hi guys i’m new at this hope you guys can help out with a script.
i would like to have my agent’s name highlighted in red if their status is not ready/after call work for x number of minutes. how can i do this?
lastdance,
Here is a script that you can apply to CurrentAgentState. Simply change the stat value to the number of seconds that you want.
if Threshold.StatValue >= 240 then
Threshold.Result = true
end if
We have several scripts like this applied to CurrentAgentState to tell us when agents have been sitting in one state too long.
Here is the script for the “Action” that will be applied to the previous script.
CCPulseNotifier.SetColor( Color.Red )
mike,
can this be done on “objects tab”?
i would like the agents name to be highlighted in red when their after call work reaches like 60secs. i tried the following script but ain’t working.
if StatAction.SDNAAfterCallWork >= 60 then
StatAction.Result = true
end if
pls advise. thx
Looks like your syntax might be off. Try this.
if Threshold.StatValue = StatAction.SDNAAfterCallWork then
end if
