Terraform Import Fails for Architect Flow - 409 Conflict on External ID
Need some troubleshooting help with a persistent 409 Conflict error when importing an existing Architect flow into the state file. The environment is AU-1, provider version genesyscloud v1.68.4. The flow was originally created via the GUI, but we are migrating to IaC. When running terraform import genesyscloud_architect_flow.main <flow_id>, the apply succeeds initially, but the subsequent refresh fails with Error refreshing state: 409 Conflict. The response body indicates external_id is not unique. I have verified the external_id is set to flow-customer-interaction-v2 in the HCL block. The flow exists in Genesys Cloud with ID a1b2c3d4-e5f6-7890-abcd-ef1234567890. Checking the REST API directly via GET /api/v2/flows confirms the flow has no external_id assigned in the cloud. However, the Terraform import command does not seem to accept an external_id argument to map to the cloud resource during the import phase. Is there a way to inject the external_id during the import step, or do I need to manually patch the flow via the API before importing? Current HCL looks like this: resource "genesyscloud_architect_flow" "main" { name = "Customer Interaction" description = "Main IVR flow" external_id = "flow-customer-interaction-v2" ... }. The pipeline is using GitHub Actions with OIDC authentication. This blockage prevents the state from syncing, causing the next terraform plan to want to destroy and recreate the flow, which is not acceptable for production. Any workaround for mapping external_id on import?
