Terminating NICE CXone Web Messaging Sessions Programmatically with Node.js
  • A Node.js module that gracefully terminates active CXone Web Messaging sessions by constructing validated close payloads, verifying pending data, executing atomic WebSocket teardown, and emitting audit and metrics events.
  • This implementation uses the CXone Web Messaging WebSocket protocol and the REST API for session state retrieval.
  • The tutorial covers JavaScript/Node.js with modern async/await, ws, ajv, and node-fetch.
  • OAuth 2.0 client credentials with scopes: webchat:read, webchat:write
  • CXone Web Messaging tenant URL and WebSocket endpoint pattern
  • Node.js 18 or later
  • External dependencies: npm install ws ajv node-fetch uuid
CXone Web Messaging authenticates WebSocket connections via a bearer token passed in the connection query string. You obtain the token through the CXone OAuth 2.0 client credentials flow or a pre-provisioned session token. The following code retrieves a valid access token and establishes the WebSocket connection.
import https from 'https';
import WebSocket from 'ws';
const CXONE_TENANT = 'your-tenant';
const CXONE_CLIENT_ID = process.env.CXONE_CLIENT_ID;
const CXONE_CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET;
const CXONE_TOKEN_URL = `https://${CXONE_TENANT}.cxone.com/oauth/token`;
const CXONE_WS_URL = `wss://${CXONE_TENANT}.cxone.com/api/v2/webchat/ws`;
 * Fetches an OAuth 2.0 bearer token from CXone.
 * Scopes required: webchat:read webchat:write
async function getCxoToken() {
  const params = new URLSearchParams({
    client_id: CXONE_CLIENT_ID,
    client_secret: CXONE_CLIENT_SECRET,
    scope: 'webchat:read webchat:write'
  const response = await fetch(CXONE_TOKEN_URL, {
    method: 'POST',
    body: params
  if (!response.ok) {
    const errorBody = await response.text();
    throw new Error(`OAuth token fetch failed ${response.status}: ${errorBody}`);
  const data = await response.json();
  return data.access_token;
 * Establishes a WebSocket connection to CXone Web Messaging.
export async function createWebMessagingConnection(token) {
  const wsUrl = `${CXONE_WS_URL}?access_token=${encodeURIComponent(token)}`;
  const ws = new WebSocket(wsUrl);
  return new Promise((resolve, reject) => {
    ws.on('open', () => resolve(ws));
    ws.on('error', (err) => reject(new Error(`WebSocket connection failed: ${err.message}`)));
    ws.on('close', (code, reason) => {
      if (ws.readyState !== WebSocket.OPEN) {
        reject(new Error(`WebSocket closed unexpectedly with code ${code}: ${reason.toString()}`));
Step 1: Schema Validation and Payload Construction
The termination payload must contain a session-ref, a state-matrix, and a close directive. You validate the payload against a strict JSON Schema before transmission to prevent protocol rejection. The schema enforces connection constraints and maximum idle time limits.
import Ajv from 'ajv';
import addFormats from 'ajv-formats';
const ajv = new Ajv();
addFormats(ajv);
const TERMINATE_SCHEMA = {
  type: 'object',
  required: ['session-ref', 'state-matrix', 'close'],
  properties: {
    'session-ref': { type: 'string', format: 'uuid' },
    'state-matrix': {
      type: 'object',
      required: ['current', 'allowed_transitions', 'idle_seconds'],
      properties: {
        current: { type: 'string', enum: ['active', 'idle', 'paused'] },
        allowed_transitions: { type: 'array', items: { type: 'string' } },
        idle_seconds: { type: 'integer', minimum: 0, maximum: 1800 }
    close: {
      type: 'object',
      required: ['reason', 'initiated_by', 'timestamp'],
      properties: {
        reason: { type: 'string', enum: ['agent_initiated', 'system_timeout', 'customer_disconnect', 'api_terminate'] },
        initiated_by: { type: 'string' },
        timestamp: { type: 'string', format: 'date-time' }
    archive_trigger: { type: 'boolean', default: true },
    pending_check: { type: 'boolean', default: true }
  additionalProperties: false
const validateTerminatePayload = ajv.compile(TERMINATE_SCHEMA);
 * Constructs and validates the termination payload.
export function buildTerminatePayload(sessionId, currentState, idleDuration) {
  const payload = {
    'session-ref': sessionId,
    'state-matrix': {
      current: currentState,
      allowed_transitions: ['closing', 'terminated'],
      idle_seconds: idleDuration
    close: {
      reason: 'api_terminate',
      initiated_by: 'automated_terminator',
    archive_trigger: true,
    pending_check: true
  const valid = validateTerminatePayload(payload);
  if (!valid) {
    throw new Error(`Payload validation failed: ${JSON.stringify(validateTerminatePayload.errors)}`);
  return payload;
Step 2: Pre-Termination Validation Pipeline
Before sending the close directive, you must verify pending messages and attachment downloads. You also enforce maximum idle time limits to prevent terminating failure. This step queries the CXone REST API for session state and validates constraints.
 * Checks pending messages and attachment downloads via CXone REST API.
 * Endpoint: GET /api/v2/webchat/sessions/{sessionId}/messages
 * Scope: webchat:read
export async function validateSessionState(sessionId, token, maxIdleSeconds = 1800) {
  const messagesUrl = `https://${CXONE_TENANT}.cxone.com/api/v2/webchat/sessions/${sessionId}/messages`;
  const stateUrl = `https://${CXONE_TENANT}.cxone.com/api/v2/webchat/sessions/${sessionId}`;
  const [stateRes, messagesRes] = await Promise.all([
    fetch(stateUrl, { headers: { Authorization: `Bearer ${token}` } }),
    fetch(messagesUrl, { headers: { Authorization: `Bearer ${token}` } })
  if (!stateRes.ok || !messagesRes.ok) {
    throw new Error(`State validation failed: Session ${stateRes.status}, Messages ${messagesRes.status}`);
  const stateData = await stateRes.json();
  const messagesData = await messagesRes.json();
  // Enforce maximum idle time constraint
  if (stateData.idle_time_seconds > maxIdleSeconds) {
    throw new Error(`Session idle time ${stateData.idle_time_seconds}s exceeds maximum ${maxIdleSeconds}s. Termination blocked.`);
  // Check for pending messages or incomplete attachments
  const pendingMessages = messagesData.items?.filter(m => m.status === 'pending' || m.status === 'sending') || [];
  const pendingAttachments = messagesData.items?.filter(m => m.attachments?.some(a => a.download_status === 'in_progress')) || [];
  if (pendingMessages.length > 0 || pendingAttachments.length > 0) {
    throw new Error(`Cannot terminate session. Pending messages: ${pendingMessages.length}, Pending attachments: ${pendingAttachments.length}`);
    currentState: stateData.state,
    idleSeconds: stateData.idle_time_seconds,
    isClean: true
Step 3: Atomic WebSocket Teardown and Resource Cleanup
You execute the termination via an atomic WebSocket text operation. The client calculates teardown timing, verifies format, and triggers history archive events. You implement retry logic for 429 rate limits on external webhook synchronization.
 * Sends the terminate payload over WebSocket and handles teardown.
export async function executeAtomicTeardown(ws, payload) {
    const message = JSON.stringify(payload);
    const startTime = Date.now();
    // Format verification before send
      JSON.parse(message);
    } catch (err) {
      reject(new Error(`Format verification failed: ${err.message}`));
      return;
    ws.send(message, (err) => {
      if (err) {
        reject(new Error(`WebSocket send failed: ${err.message}`));
        return;
      const teardownLatency = Date.now() - startTime;
      // Wait for server acknowledgment or close frame
      const closeHandler = (code, reason) => {
        ws.removeListener('close', closeHandler);
        ws.removeListener('error', errorHandler);
        if (code === 1000 || code === 1001) {
          resolve({ success: true, latency: teardownLatency, closeCode: code });
        } else {
          reject(new Error(`Abnormal teardown: code ${code}, reason ${reason.toString()}`));
      const errorHandler = (err) => {
        reject(new Error(`Teardown error: ${err.message}`));
      ws.on('close', closeHandler);
      ws.on('error', errorHandler);
      // Force cleanup after timeout to prevent hanging connections
      setTimeout(() => {
        if (ws.readyState === WebSocket.OPEN || ws.readyState === WebSocket.CONNECTING) {
          ws.close(1001, 'Terminator timeout cleanup');
      }, 5000);
 * Syncs termination event with external analytics webhook.
 * Implements retry logic for 429 responses.
export async function syncTerminationWebhook(webhookUrl, eventPayload, maxRetries = 3) {
  let attempt = 0;
  while (attempt < maxRetries) {
      const res = await fetch(webhookUrl, {
        method: 'POST',
        headers: { 'Content-Type': 'application/json', 'X-Webhook-Source': 'cxone-terminator' },
        body: JSON.stringify(eventPayload)
      if (res.status === 429) {
        const retryAfter = parseInt(res.headers.get('Retry-After') || '2', 10);
        await new Promise(r => setTimeout(r, retryAfter * 1000));
        attempt++;
        continue;
      if (!res.ok) {
        throw new Error(`Webhook sync failed: ${res.status}`);
      return { success: true, statusCode: res.status };
    } catch (err) {
      if (attempt === maxRetries - 1) throw err;
      attempt++;
      await new Promise(r => setTimeout(r, 1000 * Math.pow(2, attempt)));
The following module exposes a CxoSessionTerminator class that orchestrates authentication, validation, teardown, metrics tracking, and audit logging. You can instantiate it and call terminateSession(sessionId).
import { getCxoToken, createWebMessagingConnection } from './auth.js';
import { buildTerminatePayload, validateSessionState, executeAtomicTeardown, syncTerminationWebhook } from './terminator.js';
class CxoSessionTerminator {
  constructor(config) {
    this.tenant = config.tenant;
    this.webhookUrl = config.analyticsWebhookUrl;
    this.maxIdleSeconds = config.maxIdleSeconds || 1800;
    this.metrics = {
      totalTerminations: 0,
      successfulTerminations: 0,
      averageLatency: 0,
      latencySum: 0
    this.auditLog = [];
  async terminateSession(sessionId) {
    const traceId = crypto.randomUUID();
    this.auditLog.push({
      trace_id: traceId,
      session_ref: sessionId,
      action: 'terminate_initiated',
      // 1. Authentication
      const token = await getCxoToken();
      // 2. Pre-termination validation
      const state = await validateSessionState(sessionId, token, this.maxIdleSeconds);
      // 3. Build and validate payload
      const payload = buildTerminatePayload(sessionId, state.currentState, state.idleSeconds);
      // 4. Establish WebSocket connection
      const ws = await createWebMessagingConnection(token);
      // 5. Execute atomic teardown
      const teardownResult = await executeAtomicTeardown(ws, payload);
      // 6. Trigger history archive and sync analytics
      const archivePayload = {
        trace_id: traceId,
        archive_triggered: true,
        close_reason: payload.close.reason,
        latency_ms: teardownResult.latency
      await syncTerminationWebhook(this.webhookUrl, archivePayload);
      // 7. Update metrics
      this.metrics.totalTerminations++;
      this.metrics.successfulTerminations++;
      this.metrics.latencySum += teardownResult.latency;
      this.metrics.averageLatency = this.metrics.latencySum / this.metrics.successfulTerminations;
        trace_id: traceId,
        action: 'terminate_completed',
        latency_ms: teardownResult.latency,
        close_code: teardownResult.closeCode,
        success: true,
        trace_id: traceId,
    } catch (err) {
        trace_id: traceId,
        action: 'terminate_failed',
        error: err.message,
      throw err;
  getMetrics() {
    return { ...this.metrics };
  getAuditLog() {
    return [...this.auditLog];
export { CxoSessionTerminator };
Usage example:
import { CxoSessionTerminator } from './CxoSessionTerminator.js';
async function runTermination() {
  const terminator = new CxoSessionTerminator({
    tenant: 'your-tenant',
    analyticsWebhookUrl: 'https://your-analytics-endpoint.com/webhooks/cxone-termination',
    maxIdleSeconds: 1200
    const result = await terminator.terminateSession('a1b2c3d4-e5f6-7890-g1h2-i3j4k5l6m7n8');
    console.log('Termination result:', result);
    console.log('Metrics:', terminator.getMetrics());
    console.log('Audit Log:', terminator.getAuditLog());
  } catch (err) {
    console.error('Termination failed:', err.message);
runTermination();
Error: WebSocket closed unexpectedly with code 1006
  • Cause: The CXone server forcefully closed the connection due to an invalid payload format, missing authentication token, or network interruption during the teardown calculation.
  • Fix: Verify the OAuth token is active and appended correctly to the WebSocket URL. Ensure the JSON payload passes ajv validation before transmission. Add connection keep-alive pings if the session remains open longer than 30 seconds.
  • Code showing the fix:
// Add heartbeat to prevent idle disconnects
setInterval(() => {
  if (ws.readyState === WebSocket.OPEN) {
    ws.ping();
}, 15000);
Error: Session idle time exceeds maximum. Termination blocked.
  • Cause: The state-matrix.idle_seconds exceeds the maxIdleSeconds threshold enforced in validateSessionState. CXone prevents termination of severely stale sessions to preserve conversation context.
  • Fix: Adjust the maxIdleSeconds configuration parameter or implement a re-engagement flow before termination. Review the session lifecycle policy in the CXone administration console.
// Increase threshold or implement graceful warning
const state = await validateSessionState(sessionId, token, 2400);
Error: Webhook sync failed: 429
  • Cause: The external analytics endpoint is rate-limiting webhook ingestion during high-volume termination events.
  • Fix: The syncTerminationWebhook function already implements exponential backoff and respects the Retry-After header. Ensure your analytics pipeline can handle burst traffic or implement a message queue buffer.
// The retry logic is already embedded in syncTerminationWebhook
// Verify Retry-After header parsing and backoff multiplier
Error: Cannot terminate session. Pending messages or attachments
  • Cause: The pre-termination validation pipeline detected messages in pending or sending state, or attachments with download_status: in_progress. Terminating now would corrupt the conversation archive.
  • Fix: Implement a wait-and-retry loop that polls the messages endpoint until pending_check returns clean. Enforce a maximum wait time to prevent indefinite blocking.
let retries = 0;
while (retries < 5) {
  if (state.isClean) break;
  await new Promise(r => setTimeout(r, 2000));
  retries++;
