Synchronizing Genesys Cloud Web Messaging Multi-Device Sessions via WebSocket API with Python
A production-grade Python session synchronizer that maintains state alignment across multiple devices using the Genesys Cloud Web Chat WebSocket protocol, implementing sequence validation, automatic deduplication, conflict resolution, and external registry webhooks. This tutorial uses the Genesys Cloud Web Chat WebSocket API and REST endpoints. The programming language covered is Python 3.9+.
- OAuth client type and required scopes: REST API Client Credentials flow. Required scopes:
webchat:read,webchat:write. WebSocket connections use session-based authentication, not OAuth. - SDK version or API version: Genesys Cloud Web Chat WebSocket protocol v1.0, REST API v2.
- Language/runtime requirements: Python 3.9+ with async/await support.
- External dependencies:
websockets>=12.0,httpx>=0.25.0,pydantic>=2.0,aiofiles>=23.0. Install viapip install websockets httpx pydantic aiofiles.
Genesys Cloud Web Chat WebSocket connections do not use OAuth tokens. The WebSocket channel authenticates via a sessionId and deviceFingerprint pair. You must first retrieve the Web Chat deployment configuration via REST using OAuth, then establish the WebSocket connection. The following code demonstrates the OAuth token acquisition and REST configuration fetch.
import httpx
import asyncio
import json
from typing import Optional
class GenesysOAuthClient:
def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
self.client_id = client_id
self.base_url = base_url
self.token_url = f"{base_url}/api/v2/oauth/token"
self._access_token: Optional[str] = None
self._refresh_task: Optional[asyncio.Task] = None
async def get_access_token(self) -> str:
if self._access_token:
return self._access_token
async with httpx.AsyncClient() as client:
response = await client.post(
self.token_url,
headers={"Content-Type": "application/x-www-form-urlencoded"},
content={"grant_type": "client_credentials", "scope": "webchat:read webchat:write"}
response.raise_for_status()
data = response.json()
self._access_token = data["access_token"]
async def fetch_webchat_config(self, deployment_id: str) -> dict:
token = await self.get_access_token()
url = f"{self.base_url}/api/v2/webchat/deployments/{deployment_id}"
response = await client.get(
url,
headers={"Authorization": f"Bearer {token}", "Content-Type": "application/json"}
await asyncio.sleep(float(response.headers.get("Retry-After", 2)))
return await self.fetch_webchat_config(deployment_id)
return response.json()
HTTP Request/Response Cycle for OAuth:
POST /api/v2/oauth/token HTTP/1.1
Host: api.mypurecloud.com
Authorization: Basic base64(client_id:client_secret)
grant_type=client_credentials&scope=webchat:read%20webchat:write
HTTP/1.1 200 OK
"token_type": "bearer",
"expires_in": 1800,
Step 1: WebSocket Connection and Session Initialization
The Genesys Cloud Web Chat WebSocket endpoint follows the pattern wss://webchat-{region}.genesyscloud.com:443/{orgId}/{chatId}/ws. You must send a SESSION_INIT message immediately after connection. The server responds with SESSION_STATUS containing the session state. You then request historical messages using SESSION_SYNC.
import websockets
from typing import List, Dict, Any, Set
@dataclass
class SyncMetrics:
messages_received: int = 0
messages_deduplicated: int = 0
sync_latency_ms: float = 0.0
sequence_gaps: int = 0
active_devices: int = 0
last_sync_time: float = 0.0
class WebChatWebSocket:
def __init__(self, org_id: str, chat_id: str, region: str = "eu01"):
self.ws_url = f"wss://webchat-{region}.genesyscloud.com:443/{org_id}/{chat_id}/ws"
self.session_id: str = ""
self.device_fingerprint: str = ""
self.metrics = SyncMetrics()
self._seen_message_ids: Set[str] = set()
self._last_sequence: int = 0
self._message_buffer: List[Dict[str, Any]] = []
async def connect_and_init(self, device_fingerprint: str) -> str:
async with websockets.connect(self.ws_url, ping_interval=20, ping_timeout=10) as ws:
init_payload = {
"type": "SESSION_INIT",
"sessionId": "",
"deviceFingerprint": device_fingerprint,
"platform": "web",
"version": "1.0"
await ws.send(json.dumps(init_payload))
response = await ws.recv()
data = json.loads(response)
if data.get("type") != "SESSION_STATUS":
raise ValueError(f"Invalid init response: {data}")
self.session_id = data["sessionId"]
self.device_fingerprint = device_fingerprint
self.metrics.active_devices = data.get("activeDevices", 1)
return self.session_id
The SESSION_INIT response includes activeDevices. Genesys Cloud enforces a maximum of three concurrent devices per session by default. You must validate this constraint before proceeding with sync operations.
Step 2: Payload Construction and Schema Validation
Multi-device synchronization requires strict payload construction. You must send a SESSION_SYNC request with the current sequence number. The response contains a message state matrix, conflict markers, and updated sequence pointers. You validate the payload against session management constraints to prevent sync failure.
import pydantic
from pydantic import BaseModel, field_validator
class SessionSyncPayload(BaseModel):
type: str = "SESSION_SYNC"
sessionId: str
sequenceNumber: int = 0
deviceFingerprint: str
conflictResolution: str = "last_write_wins"
maxActiveDevices: int = 3
@field_validator("sequenceNumber")
@classmethod
def validate_sequence(cls, v: int) -> int:
if v < 0:
raise ValueError("Sequence number must be non-negative")
return v
@field_validator("maxActiveDevices")
@classmethod
def validate_device_limit(cls, v: int) -> int:
if v > 3:
raise ValueError("Genesys Cloud limits sessions to 3 active devices")
return v
async def request_sync(ws, sync_payload: SessionSyncPayload) -> Dict[str, Any]:
start_time = time.time()
await ws.send(json.dumps(sync_payload.model_dump()))
elapsed = (time.time() - start_time) * 1000
return data, elapsed
async def validate_sync_response(data: Dict[str, Any], metrics: SyncMetrics) -> bool:
if data.get("type") != "SESSION_SYNC":
return False
current_seq = data.get("sequenceNumber", 0)
if current_seq < metrics.last_sync_time:
metrics.sequence_gaps += 1
active = data.get("activeDevices", 0)
if active > 3:
raise RuntimeError("Session exceeded maximum active device limit")
return True
The validation logic enforces the three-device constraint and tracks sequence gaps. The conflictResolution directive tells the server how to handle overlapping edits. Genesys Cloud supports last_write_wins and manual_review. You must include this directive in every sync request to prevent silent overwrites.
Step 3: Message Processing, Deduplication, and Sequence Validation
Atomic SEND operations require format verification and automatic deduplication triggers. You process the message array from the sync response, verify message schemas, filter duplicates, and update the sequence cursor. This ensures consistent user experience during messaging scaling.
class WebMessage(BaseModel):
messageId: str
sequenceNumber: int
timestamp: str
direction: str
content: str
status: str = "delivered"
conflictMarker: Optional[str] = None
async def process_sync_messages(
metrics: SyncMetrics,
offline_queue: List[Dict[str, Any]]
) -> List[WebMessage]:
messages = data.get("messages", [])
validated: List[WebMessage] = []
for msg_data in messages:
msg_id = msg_data.get("messageId")
if msg_id in metrics._seen_message_ids:
metrics.messages_deduplicated += 1
metrics._seen_message_ids.add(msg_id)
msg = WebMessage(**msg_data)
validated.append(msg)
metrics.messages_received += 1
except pydantic.ValidationError as e:
offline_queue.append({"message": msg_data, "error": str(e), "timestamp": time.time()})
new_seq = data.get("sequenceNumber", 0)
metrics.last_sync_time = new_seq
return validated
The deduplication logic uses a set of observed messageId values. The offline queue captures malformed messages for retry processing. Sequence validation ensures monotonic progression. You must reset the deduplication set only when the session expires or rotates.
Step 4: External Registry Sync and Audit Logging
You synchronize sync events with external device registries via webhook callbacks. You track sync latency and convergence rates for session efficiency. You generate sync audit logs for experience governance. The following code exposes the session synchronizer interface.
import aiohttp
import logging
logger = logging.getLogger("genesys_sync")
class SessionSynchronizer:
def __init__(self, org_id: str, chat_id: str, webhook_url: str, region: str = "eu01"):
self.ws_client = WebChatWebSocket(org_id, chat_id, region)
self.offline_queue: List[Dict[str, Any]] = []
self._convergence_window: List[float] = []
async def _send_webhook(self, payload: Dict[str, Any]) -> None:
async with aiohttp.ClientSession() as session:
await session.post(
self.webhook_url,
json=payload,
headers={"Content-Type": "application/json"},
timeout=aiohttp.ClientTimeout(total=5)
logger.error("Webhook delivery failed: %s", e)
async def _record_audit_log(self, event_type: str, details: Dict[str, Any]) -> None:
log_entry = {
"timestamp": time.time(),
"eventType": event_type,
"sessionId": self.ws_client.session_id,
"deviceFingerprint": self.ws_client.device_fingerprint,
"metrics": self.metrics.__dict__,
"details": details
logger.info("SYNC_AUDIT: %s", json.dumps(log_entry))
await self._send_webhook({"audit": log_entry})
async def run_sync_loop(self, device_fingerprint: str, interval_seconds: int = 5) -> None:
await self.ws_client.connect_and_init(device_fingerprint)
async with websockets.connect(self.ws_client.ws_url, ping_interval=20) as ws:
while True:
sync_payload = SessionSyncPayload(
sessionId=self.ws_client.session_id,
sequenceNumber=int(self.metrics.last_sync_time),
deviceFingerprint=device_fingerprint,
conflictResolution="last_write_wins"
data, latency = await request_sync(ws, sync_payload)
self._convergence_window.append(latency)
self.metrics.sync_latency_ms = sum(self._convergence_window[-10:]) / len(self._convergence_window[-10:])
if await validate_sync_response(data, self.metrics):
messages = await process_sync_messages(data, self.metrics, self.offline_queue)
await self._record_audit_log("SYNC_COMPLETE", {
"messagesProcessed": len(messages),
"deduplicated": self.metrics.messages_deduplicated,
"latencyMs": self.metrics.sync_latency_ms
if messages:
"type": "DEVICE_REGISTRY_UPDATE",
"messages": [m.model_dump() for m in messages],
"syncLatencyMs": self.metrics.sync_latency_ms
except websockets.ConnectionClosed as e:
logger.warning("WebSocket closed: %s. Reconnecting in 2s", e)
await asyncio.sleep(2)
logger.error("Sync loop error: %s", e)
await self._record_audit_log("SYNC_ERROR", {"error": str(e)})
await asyncio.sleep(5)
await asyncio.sleep(interval_seconds)
The synchronizer calculates a rolling convergence rate from the latency window. The audit log captures sequence gaps, deduplication counts, and device limits. Webhook callbacks align external registries with the current session state.
The following script combines all components into a runnable module. You must provide your organization ID, chat deployment ID, and webhook URL before execution.
import asyncio
import sys
import logging
async def main():
ORG_ID = "your-org-id"
CHAT_ID = "your-chat-id"
WEBHOOK_URL = "https://your-registry.example.com/api/sync"
DEVICE_FINGERPRINT = "device-uuid-12345"
REGION = "eu01"
synchronizer = SessionSynchronizer(
org_id=ORG_ID,
chat_id=CHAT_ID,
webhook_url=WEBHOOK_URL,
region=REGION
await synchronizer.run_sync_loop(device_fingerprint=DEVICE_FINGERPRINT, interval_seconds=5)
except KeyboardInterrupt:
logging.info("Sync loop terminated by user")
sys.exit(0)
asyncio.run(main())
Common Errors and Debugging
Error: 401 Unauthorized on REST Configuration Fetch
- What causes it: Invalid client credentials or expired token.
- How to fix it: Verify the client ID and secret. Ensure the token refresh logic runs before expiration.
- Code showing the fix: The
GenesysOAuthClientclass implements a synchronous token fetch with retry logic for 429 responses. Add token expiration tracking and refresh before REST calls.
Error: WebSocket Connection Refused or 1006 Abnormal Closure
- What causes it: Incorrect region endpoint, invalid org ID, or server-side rate limiting.
- How to fix it: Validate the region string matches your Genesys Cloud deployment. Implement exponential backoff for reconnection attempts.
async def connect_with_backoff(ws_url: str, max_retries: int = 5):
return await websockets.connect(ws_url, ping_interval=20)
wait_time = min(2 ** attempt, 30)
logging.warning("Connection failed (attempt %d/%d). Retrying in %ds", attempt + 1, max_retries, wait_time)
raise RuntimeError("Max reconnection attempts exceeded")
Error: Sequence Number Regression or Gap Detection
- What causes it: Network partition, server restart, or concurrent device conflict.
- How to fix it: Reset the sequence cursor to zero and request a full sync. The validation logic increments
sequence_gapsfor monitoring. - Code showing the fix: The
validate_sync_responsefunction detects non-monotonic sequences. Add a fallback tosequenceNumber=0when gaps exceed a threshold.
Error: Maximum Active Device Limit Exceeded
- What causes it: More than three devices registered to the same session ID.
- How to fix it: Terminate stale device sessions or generate a new session ID. The
SessionSyncPayloadvalidator enforces the limit. - Code showing the fix: The
field_validatoronmaxActiveDevicesraises aValueErrorif the payload exceeds three. Implement session rotation logic in your application layer.
