Synchronizing Genesys Cloud SCIM Users with External HR Systems Using Python
  • A Python service that polls an external HR API for employee lifecycle events and maps them to Genesys Cloud SCIM schema fields.
  • The code constructs standard SCIM PATCH payloads, resolves manager relationships and department codes, and executes bulk operations to minimize API calls.
  • The implementation uses Python 3.9+ with the requests library, handles SCIM 409 conflicts via ETag optimistic locking, and generates CSV reconciliation reports for sync drift detection.
  • Genesys Cloud OAuth 2.0 client credentials with scim:write and scim:read scopes
  • Genesys Cloud SCIM API v2 enabled for your organization
  • Python 3.9 or higher
  • requests library (pip install requests)
  • Access to an HR system REST API that supports timestamp-based delta queries and pagination
Genesys Cloud uses OAuth 2.0 Client Credentials flow for server-to-server integrations. You must cache the access token and refresh it before expiration to avoid 401 errors during batch operations.
import requests
from typing import Optional
GENESYS_BASE_URL = "https://api.mypurecloud.com"
HR_BASE_URL = "https://hr-api.yourcompany.com"
def get_access_token(client_id: str, client_secret: str) -> str:
    url = f"{GENESYS_BASE_URL}/oauth/token"
    data = {
        "client_id": client_id,
        "client_secret": client_secret,
        "scope": "scim:write scim:read"
    response = requests.post(url, headers=headers, data=data, timeout=10)
    response.raise_for_status()
    return response.json()["access_token"]
class TokenManager:
    def __init__(self, client_id: str, client_secret: str):
        self.client_id = client_id
        self._expires_at: float = 0.0
    def get_token(self) -> str:
        if self._token and time.time() < self._expires_at - 60:
            return self._token
        raw = get_access_token(self.client_id, self.client_secret)
        # Genesys tokens typically expire in 3600 seconds. We cache with a 60s buffer.
        self._token = raw
        self._expires_at = time.time() + 3540
        return self._token
The TokenManager class prevents redundant token requests during bulk operations. Genesys Cloud returns a JWT that expires in one hour. The sixty-second buffer accounts for clock skew and ensures the token remains valid throughout the entire sync cycle.
Step 1: Polling the HR API and Mapping Attributes
The HR API returns employee records updated after a specific timestamp. You must handle pagination and map HR fields to the SCIM User schema. Genesys Cloud SCIM expects specific paths like name.givenName, emails[0].value, and groups[0].value.
import json
from typing import Dict, List, Any
def poll_hr_employees(last_sync_timestamp: str, page_size: int = 100) -> List[Dict[str, Any]]:
    all_employees = []
    cursor = None
    while True:
        params = {
            "updated_after": last_sync_timestamp,
            "page_size": page_size,
            "cursor": cursor
        response = requests.get(f"{HR_BASE_URL}/api/v1/employees", params=params, timeout=30)
        payload = response.json()
        all_employees.extend(payload.get("data", []))
        cursor = payload.get("next_cursor")
        if not cursor:
            break
    return all_employees
def map_hr_to_scim(hr_employee: Dict[str, Any], user_id_map: Dict[str, str]) -> Dict[str, Any]:
    Maps HR payload to SCIM Operations format for PATCH.
    user_id_map: {hr_employee_id: genesys_user_id}
    genesys_id = user_id_map.get(hr_employee["id"])
    if not genesys_id:
        return None  # New user handling omitted for brevity; focus is on PATCH
    operations = [
        {"op": "replace", "path": "name.givenName", "value": hr_employee["first_name"]},
        {"op": "replace", "path": "name.familyName", "value": hr_employee["last_name"]},
        {"op": "replace", "path": "emails[0].value", "value": hr_employee["email"]},
        {"op": "replace", "path": "department", "value": hr_employee["department_code"]},
    # Manager relationship mapping
    manager_hr_id = hr_employee.get("manager_employee_id")
    if manager_hr_id and manager_hr_id in user_id_map:
        operations.append({
            "op": "replace",
            "path": "manager.value",
            "value": user_id_map[manager_hr_id]
    elif manager_hr_id is None:
        operations.append({"op": "remove", "path": "manager"})
    # Group membership mapping based on department
    dept_groups_map = {
        "SUPPORT": ["GenesysSupportAgents"],
        "SALES": ["GenesysSalesTeam"],
        "ADMIN": ["GenesysAdministrators"]
    target_groups = dept_groups_map.get(hr_employee["department_code"], [])
    if target_groups:
        operations.append({
            "op": "replace",
            "path": "groups",
            "value": [{"value": gid} for gid in target_groups]
        "genesys_user_id": genesys_id,
        "operations": operations,
        "hr_record": hr_employee
The map_hr_to_scim function translates HR attributes into SCIM Operations payloads. Genesys Cloud SCIM PATCH expects an array of operations. Each operation specifies op (replace, remove, add), path (dot-notation or JSON pointer), and value. Manager relationships require the target Genesys user ID. Group memberships are derived from department codes. The function returns None for HR records without a matching Genesys user ID, allowing you to route new hires to a separate creation flow.
Step 2: Constructing SCIM PATCH Requests with ETag Handling
SCIM 2.0 uses ETags for optimistic locking. Genesys Cloud returns an ETag header on GET and PATCH responses. You must send the ETag in the If-Match header. If the server returns 409 Conflict, the record was modified by another process. You must fetch the latest state, merge your changes, and retry.
import requests
from requests import Response
def patch_user_with_etag_retry(
    token: str,
    user_id: str,
    operations: List[Dict[str, Any]],
    max_retries: int = 3
) -> Response:
    url = f"{GENESYS_BASE_URL}/scim/v2/Users/{user_id}"
    headers = {
        "Content-Type": "application/scim+json",
        "Authorization": f"Bearer {token}"
    body = {"Operations": operations}
    etag = None
        if etag:
            headers["If-Match"] = etag
        else:
            headers.pop("If-Match", None)
        response = requests.patch(url, headers=headers, json=body, timeout=30)
        if response.status_code == 409:
            # Optimistic locking conflict. Fetch current ETag.
            get_resp = requests.get(url, headers=headers, timeout=30)
            get_resp.raise_for_status()
            etag = get_resp.headers.get("ETag")
            if not etag:
                raise RuntimeError(f"ETag missing on GET for user {user_id}")
        elif response.status_code == 429:
            # Rate limit handling with exponential backoff
            retry_after = int(response.headers.get("Retry-After", 2))
            time.sleep(retry_after * (attempt + 1))
        else:
            return response
    raise RuntimeError(f"ETag conflict persists after {max_retries} retries for user {user_id}")
The retry loop handles two distinct failure modes. A 409 response triggers an ETag refresh cycle. A 429 response triggers exponential backoff. Genesys Cloud SCIM endpoints enforce strict rate limits per tenant. The If-Match header ensures you do not overwrite concurrent updates from the Genesys admin console or other provisioning systems.
Step 3: Executing Bulk Operations for Large Batches
Individual PATCH calls scale poorly for thousands of employees. Genesys Cloud SCIM supports bulk operations via POST /scim/v2/Bulk. The API accepts up to 1,000 operations per request. You must chunk your operations and track the bulkId for response correlation.
def execute_bulk_sync(
    token: str,
    sync_payloads: List[Dict[str, Any]],
    chunk_size: int = 500
    bulk_results = []
    for i in range(0, len(sync_payloads), chunk_size):
        chunk = sync_payloads[i:i + chunk_size]
        operations = []
        for idx, payload in enumerate(chunk):
            operations.append({
                "method": "PATCH",
                "path": f"/Users/{payload['genesys_user_id']}",
                "bulkId": str(i + idx + 1),
                "data": {"Operations": payload["operations"]}
        url = f"{GENESYS_BASE_URL}/scim/v2/Bulk"
        headers = {
        # Retry logic for bulk endpoint
        retries = 0
        while retries < 3:
            response = requests.post(url, headers=headers, json={"Operations": operations}, timeout=60)
                time.sleep(int(response.headers.get("Retry-After", 2)) * (retries + 1))
                retries += 1
            break
        bulk_response = response.json()
        for op_result in bulk_response.get("Operations", []):
            bulk_results.append({
                "bulkId": op_result.get("bulkId"),
                "status": op_result.get("status"),
                "response": op_result.get("response")
    return bulk_results
The bulk endpoint returns an Operations array where each item contains a status code and optional response body. A 200 status indicates success. A 409 or 400 status indicates a conflict or validation error for that specific operation. The bulkId correlates the result back to your original payload index. Chunking at 500 operations balances throughput with payload size limits and reduces the probability of partial failures.
Step 4: Generating Reconciliation Reports
Sync drift occurs when HR state diverges from Genesys Cloud state. You must compare the expected SCIM attributes against the actual Genesys Cloud user profiles and output a structured report.
import csv
def generate_reconciliation_report(
    token: str,
    bulk_results: List[Dict[str, Any]],
    original_payloads: List[Dict[str, Any]],
    output_path: str = "sync_drift_report.csv"
) -> None:
    headers = ["genesys_user_id", "hr_email", "hr_department", "sync_status", "error_detail", "drift_detected"]
    rows = []
    for result in bulk_results:
        bulk_id = int(result["bulkId"])
        payload = original_payloads[bulk_id - 1]
        genesys_id = payload["genesys_user_id"]
        hr_record = payload["hr_record"]
        status_code = result["status"]
        error_detail = ""
        drift = False
        if status_code != 200:
            error_detail = result["response"].get("detail", "Unknown error")
            drift = True
        else:
            # Verify critical fields match HR source of truth
            user_resp = requests.get(
                f"{GENESYS_BASE_URL}/scim/v2/Users/{genesys_id}",
                headers={"Authorization": f"Bearer {token}"},
                timeout=30
            user_data = user_resp.json()
            actual_dept = user_data.get("department", "")
            if actual_dept != hr_record["department_code"]:
                drift = True
                error_detail = f"Department mismatch: expected {hr_record['department_code']}, got {actual_dept}"
        rows.append([
            genesys_id,
            hr_record["email"],
            hr_record["department_code"],
            status_code,
            error_detail,
            drift
    with open(output_path, "w", newline="", encoding="utf-8") as f:
        writer = csv.writer(f)
        writer.writerow(headers)
        writer.writerows(rows)
The reconciliation step performs a post-sync verification. It reads the bulk operation status, checks for non-200 responses, and performs a lightweight GET on successful records to verify field parity. The output CSV enables audit trails and automated alerting when drift exceeds a defined threshold.
import requests
import csv
from typing import Dict, List, Any, Optional
    data = {
class TokenManager:
            return self._token
        self._token = raw
        return self._token
    all_employees = []
    cursor = None
    while True:
        params = {"updated_after": last_sync_timestamp, "page_size": page_size, "cursor": cursor}
        if not cursor:
            break
def map_hr_to_scim(hr_employee: Dict[str, Any], user_id_map: Dict[str, str]) -> Optional[Dict[str, Any]]:
    if not genesys_id:
        return None
    operations = [
        operations.append({"op": "replace", "path": "manager.value", "value": user_id_map[manager_hr_id]})
    dept_groups_map = {"SUPPORT": ["GenesysSupportAgents"], "SALES": ["GenesysSalesTeam"], "ADMIN": ["GenesysAdministrators"]}
    if target_groups:
        operations.append({"op": "replace", "path": "groups", "value": [{"value": gid} for gid in target_groups]})
    return {"genesys_user_id": genesys_id, "operations": operations, "hr_record": hr_employee}
def execute_bulk_sync(token: str, sync_payloads: List[Dict[str, Any]], chunk_size: int = 500) -> List[Dict[str, Any]]:
    bulk_results = []
        operations = []
            operations.append({
                "method": "PATCH",
        headers = {"Content-Type": "application/scim+json", "Authorization": f"Bearer {token}"}
        retries = 0
        while retries < 3:
                retries += 1
            break
            bulk_results.append({"bulkId": op_result.get("bulkId"), "status": op_result.get("status"), "response": op_result.get("response")})
    return bulk_results
def generate_reconciliation_report(token: str, bulk_results: List[Dict[str, Any]], original_payloads: List[Dict[str, Any]], output_path: str = "sync_drift_report.csv") -> None:
    rows = []
        error_detail = ""
        drift = False
            drift = True
        else:
            user_resp = requests.get(f"{GENESYS_BASE_URL}/scim/v2/Users/{genesys_id}", headers={"Authorization": f"Bearer {token}"}, timeout=30)
                drift = True
        rows.append([genesys_id, hr_record["email"], hr_record["department_code"], status_code, error_detail, drift])
    CLIENT_ID = "your_client_id"
    CLIENT_SECRET = "your_client_secret"
    LAST_SYNC = "2024-01-01T00:00:00Z"
    # Pre-populate with actual HR-to-Genesys ID mapping from your database
    USER_ID_MAP = {"hr-101": "genesys-uuid-1", "hr-102": "genesys-uuid-2"}
    manager = TokenManager(CLIENT_ID, CLIENT_SECRET)
    token = manager.get_token()
    employees = poll_hr_employees(LAST_SYNC)
    sync_payloads = [p for p in (map_hr_to_scim(e, USER_ID_MAP) for e in employees) if p is not None]
    if sync_payloads:
        results = execute_bulk_sync(token, sync_payloads)
        generate_reconciliation_report(token, results, sync_payloads)
        print(f"Sync complete. Processed {len(results)} users. Report saved.")
    else:
        print("No employees to sync.")
  • Cause: Expired access token or invalid client credentials.
  • Fix: Verify the TokenManager refresh logic. Ensure the OAuth client has the scim:write and scim:read scopes assigned in the Genesys Cloud administration console.
  • Code: The TokenManager class automatically refreshes tokens sixty seconds before expiry. If you bypass this class, implement a cache check before every HTTP call.
Error: 403 Forbidden
  • Cause: Missing SCIM scopes or the OAuth application lacks API access permissions.
  • Fix: Navigate to Admin > Integrations > OAuth Applications. Edit your client and add scim:write and scim:read to the scopes list. Ensure the application is enabled.
  • Code: No code change required. The scope parameter in get_access_token must match the console configuration exactly.
Error: 409 Conflict
  • Cause: ETag mismatch during PATCH operations. Another process modified the user record after your initial read.
  • Fix: Implement optimistic locking retry logic. Fetch the current record, extract the ETag header, and resend the PATCH with If-Match: <etag>.
  • Code: The patch_user_with_etag_retry function handles this by issuing a GET on 409, updating the ETag, and retrying the PATCH up to three times.
  • Cause: Exceeding Genesys Cloud SCIM rate limits (typically 100 requests per second per endpoint).
  • Fix: Respect the Retry-After header. Implement exponential backoff. Use bulk operations instead of individual PATCH calls.
  • Code: The execute_bulk_sync function checks for 429 status codes, parses Retry-After, and sleeps before retrying. Chunking at 500 operations reduces per-second request volume.
