Synchronizing Genesys Cloud SCIM User Attributes with Active Directory Using Python
- A Python script that queries Active Directory via LDAP for users modified since the last sync, maps attributes to Genesys Cloud SCIM paths, and executes incremental PATCH requests.
- The integration uses the Genesys Cloud SCIM 2.0 API (
/scim/v2/users/{id}) and theldap3library for directory queries. - The implementation runs in Python 3.9+ with
requests,sqlite3, and standard library modules.
- Genesys Cloud OAuth 2.0 client credentials with
scim:writescope - Python 3.9+ runtime environment
ldap3andrequestspackages installed (pip install ldap3 requests)- Read access to Active Directory LDAP endpoint with a service account that can query user objects
The Genesys Cloud platform requires OAuth 2.0 Client Credentials flow. The following function handles token acquisition, caching, and automatic refresh before expiration.
import requests
from typing import Optional
class GenesysAuth:
def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
self.client_id = client_id
self.token_url = f"{base_url}/oauth/token"
self._expires_at: float = 0.0
def _get_token(self) -> dict:
payload = {
"scope": "scim:write"
response = requests.post(
self.token_url,
auth=(self.client_id, self.client_secret),
data=payload,
timeout=10
response.raise_for_status()
return response.json()
def get_bearer_header(self) -> dict:
if self._token and time.time() < self._expires_at:
return {"Authorization": f"Bearer {self._token}"}
token_data = self._get_token()
self._token = token_data["access_token"]
self._expires_at = time.time() + (token_data["expires_in"] - 30)
The get_bearer_header method checks the local cache. If the token is valid, it returns the header immediately. If expired, it requests a new token and subtracts thirty seconds from the expiration window to prevent boundary failures.
Step 1: Query Active Directory for Modified Users
Active Directory stores modification timestamps in the modifyTimestamp attribute. The script queries for users updated after the last recorded sync time. LDAP requires paged results control to handle directories with more than one thousand objects.
import ldap3
def query_modified_users(server: str, bind_dn: str, bind_password: str, base_dn: str, last_sync: datetime, page_size: int = 500) -> list[dict]:
conn = ldap3.Connection(
ldap3.Server(server, get_info=ldap3.ALL),
user=bind_dn,
password=bind_password,
auto_bind=ldap3.AUTO_BIND_READ_ONLY
# LDAP timestamps are in format YYYYMMDDHHmmSS.0Z
ldap_timestamp = last_sync.strftime("%Y%m%d%H%M%S.0Z")
search_filter = f"(&(objectClass=user)(!(objectClass=computer))(modifyTimestamp>={ldap_timestamp}))"
attributes = ["sAMAccountName", "displayName", "givenName", "sn", "mail", "modifyTimestamp"]
users = []
while True:
conn.search(
base_dn,
search_filter,
attributes=attributes,
paged_size=page_size,
paged_critical=False
for entry in conn.entries:
ts_raw = str(entry.modifyTimestamp)
if not ts_raw or ts_raw == "None":
# Parse LDAP timestamp
ts_formatted = ts_raw.replace(".0Z", "")
modify_dt = datetime.strptime(ts_formatted, "%Y%m%d%H%M%S").replace(tzinfo=timezone.utc)
users.append({
"sAMAccountName": str(entry.sAMAccountName),
"displayName": str(entry.displayName) if entry.displayName else "",
"givenName": str(entry.givenName) if entry.givenName else "",
"sn": str(entry.sn) if entry.sn else "",
"mail": str(entry.mail) if entry.mail else "",
"modifyTimestamp": modify_dt
if conn.result["controls"] is None or "1.2.840.113556.1.4.319" not in conn.result["controls"]:
break
conn.search(
base_dn,
search_filter,
paged_cookie=conn.result["controls"]["1.2.840.113556.1.4.319"]["value"]["cookie"]
conn.unbind()
return users
The paged results control (1.2.840.113556.1.4.319) returns a cookie. The loop consumes the cookie until the server stops returning it, ensuring complete directory traversal without hitting the default one thousand object limit.
Step 2: Map AD Attributes to SCIM Schemas
Genesys Cloud SCIM uses standard paths for user attributes. A JSON configuration file maps Active Directory properties to SCIM update paths. The script reads this configuration and builds the PATCH operations array.
Configuration file (mapping.json):
"attributes": [
{"ad_field": "givenName", "scim_path": "name.givenName"},
{"ad_field": "sn", "scim_path": "name.familyName"},
{"ad_field": "mail", "scim_path": "emails[type eq \"work\"].value"}
Mapping function:
import json
from typing import Any
def build_scim_patch_operations(user_data: dict, mapping_config: dict[str, Any]) -> list[dict]:
operations = []
for mapping in mapping_config["attributes"]:
ad_value = user_data.get(mapping["ad_field"], "")
if ad_value:
operations.append({
"op": "replace",
"path": mapping["scim_path"],
"value": ad_value
return operations
The function filters out empty values. Genesys Cloud SCIM rejects PATCH requests with null or empty string values for required fields. Filtering at the source prevents 400 Bad Request responses.
Step 3: Construct and Execute SCIM PATCH Requests
The SCIM API endpoint for user updates is PATCH https://api.mypurecloud.com/scim/v2/users/{id}. The script wraps the HTTP call with explicit 429 rate limit handling. The Retry-After header specifies seconds to wait. If missing, the script applies exponential backoff.
import requests
def patch_genesis_user(auth: GenesysAuth, scim_base: str, user_id: str, operations: list[dict], max_retries: int = 3) -> requests.Response:
url = f"{scim_base}/users/{user_id}"
payload = {"Operations": operations}
headers = {
**auth.get_bearer_header(),
"Content-Type": "application/scim+json",
"Accept": "application/scim+json"
retries = 0
while retries <= max_retries:
response = requests.patch(url, json=payload, headers=headers, timeout=15)
if response.status_code == 200:
return response
elif response.status_code == 429:
retry_after = response.headers.get("Retry-After")
if retry_after:
wait_time = int(retry_after)
else:
wait_time = 2 ** retries
print(f"Rate limited. Waiting {wait_time} seconds. Retry {retries + 1}/{max_retries}")
time.sleep(wait_time)
retries += 1
elif response.status_code in (401, 403):
print(f"Authentication failure: {response.status_code}. Refreshing token.")
# Force token refresh on next auth call
auth._token = None
auth._expires_at = 0.0
time.sleep(1)
retries += 1
else:
print(f"SCIM PATCH failed for {user_id}: {response.status_code} {response.text}")
raise requests.HTTPError(response.text, response=response)
raise requests.HTTPError("Max retries exceeded for 429 rate limiting", response=response)
The function parses the Retry-After header directly. It falls back to exponential backoff when the header is absent. It clears the cached token on 401 or 403 to force a fresh OAuth request on the next iteration.
Step 4: Maintain Sync State in SQLite
Tracking the last modified timestamp prevents reprocessing unchanged users. The script uses SQLite to store the highest modifyTimestamp encountered during each run.
import sqlite3
def init_sync_db(db_path: str) -> sqlite3.Connection:
conn = sqlite3.connect(db_path)
conn.execute("""
CREATE TABLE IF NOT EXISTS sync_state (
directory_dn TEXT PRIMARY KEY,
last_sync_timestamp TEXT NOT NULL
conn.commit()
return conn
def get_last_sync(db_conn: sqlite3.Connection, base_dn: str) -> datetime:
cursor = db_conn.execute("SELECT last_sync_timestamp FROM sync_state WHERE directory_dn = ?", (base_dn,))
row = cursor.fetchone()
if row:
return datetime.fromisoformat(row[0])
return datetime(1970, 1, 1, tzinfo=timezone.utc)
def update_last_sync(db_conn: sqlite3.Connection, base_dn: str, timestamp: datetime) -> None:
db_conn.execute("""
INSERT INTO sync_state (directory_dn, last_sync_timestamp)
VALUES (?, ?)
ON CONFLICT(directory_dn) DO UPDATE SET last_sync_timestamp = ?
""", (base_dn, timestamp.isoformat(), timestamp.isoformat()))
db_conn.commit()
The ON CONFLICT clause updates the timestamp if the directory already exists. The initial fallback timestamp (1970-01-01) ensures the first run processes all users.
The following script combines all components into a single executable module. Replace the configuration values with your environment credentials.
import json
import sqlite3
import requests
import ldap3
class GenesysAuth:
payload = {
self.token_url,
data=payload,
timeout=10
user=bind_dn,
users = []
while True:
conn.search(base_dn, search_filter, attributes=attributes, paged_size=page_size, paged_critical=False)
users.append({
break
conn.search(base_dn, search_filter, attributes=attributes, paged_size=page_size, paged_cookie=conn.result["controls"]["1.2.840.113556.1.4.319"]["value"]["cookie"])
conn.unbind()
return users
def build_scim_patch_operations(user_data: dict, mapping_config: dict) -> list[dict]:
operations = []
if ad_value:
operations.append({"op": "replace", "path": mapping["scim_path"], "value": ad_value})
return operations
headers = {**auth.get_bearer_header(), "Content-Type": "application/scim+json", "Accept": "application/scim+json"}
retries = 0
return response
wait_time = int(retry_after) if retry_after else 2 ** retries
retries += 1
auth._token = None
time.sleep(1)
retries += 1
else:
conn.execute("CREATE TABLE IF NOT EXISTS sync_state (directory_dn TEXT PRIMARY KEY, last_sync_timestamp TEXT NOT NULL)")
conn.commit()
return conn
return datetime.fromisoformat(row[0]) if row else datetime(1970, 1, 1, tzinfo=timezone.utc)
db_conn.execute("INSERT INTO sync_state (directory_dn, last_sync_timestamp) VALUES (?, ?) ON CONFLICT(directory_dn) DO UPDATE SET last_sync_timestamp = ?", (base_dn, timestamp.isoformat(), timestamp.isoformat()))
db_conn.commit()
def main():
# Configuration
AD_SERVER = "ldap://dc01.corp.local"
AD_BIND_DN = "CN=svc_sync,OU=ServiceAccounts,DC=corp,DC=local"
AD_PASSWORD = "SecurePassword123"
AD_BASE_DN = "DC=corp,DC=local"
GENESYS_CLIENT_ID = "your_client_id"
GENESYS_CLIENT_SECRET = "your_client_secret"
SCIM_BASE = "https://api.mypurecloud.com/scim/v2"
DB_PATH = "sync_state.db"
MAPPING_PATH = "mapping.json"
with open(MAPPING_PATH, "r") as f:
mapping_config = json.load(f)
db_conn = init_sync_db(DB_PATH)
last_sync = get_last_sync(db_conn, AD_BASE_DN)
print(f"Querying AD for users modified after {last_sync.isoformat()}")
auth = GenesysAuth(GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET)
modified_users = query_modified_users(AD_SERVER, AD_BIND_DN, AD_PASSWORD, AD_BASE_DN, last_sync)
max_timestamp = last_sync
success_count = 0
failure_count = 0
for user in modified_users:
# In production, query Genesys SCIM GET /users?userName={sAMAccountName} to resolve SCIM ID
# For this tutorial, we assume the sAMAccountName matches the SCIM userName
scim_user_id = user["sAMAccountName"]
operations = build_scim_patch_operations(user, mapping_config)
if operations:
patch_genesis_user(auth, SCIM_BASE, scim_user_id, operations)
success_count += 1
if user["modifyTimestamp"] > max_timestamp:
max_timestamp = user["modifyTimestamp"]
print(f"Failed to sync user {user['sAMAccountName']}: {e}")
failure_count += 1
update_last_sync(db_conn, AD_BASE_DN, max_timestamp)
print(f"Sync complete. Success: {success_count}, Failures: {failure_count}")
db_conn.close()
main()
- Cause: Expired OAuth token, missing
scim:writescope, or client credentials revoked in the Genesys Cloud admin console. - Fix: Verify the OAuth client has the
scim:writescope assigned. Ensure the client credentials match the environment. The script automatically clears the cached token on401/403and requests a fresh token. If the error persists, regenerate the client secret. - Code fix: The
patch_genesis_userfunction resetsauth._tokenandauth._expires_aton authentication failures to force a new token fetch.
- Cause: Exceeding Genesys Cloud SCIM API rate limits (typically 100 requests per minute for SCIM endpoints).
- Fix: The script parses the
Retry-Afterheader and sleeps accordingly. If the header is missing, it applies exponential backoff. Reduce batch size or add a fixed delay between PATCH calls if rate limits trigger frequently. - Code fix: Implement the
Retry-Afterparsing logic shown in Step 3. Add atime.sleep(0.5)between user iterations to distribute load.
Error: 400 Bad Request on SCIM PATCH
- Cause: Invalid SCIM path, empty string values, or unsupported operations. Genesys Cloud rejects
replaceoperations on read-only attributes likeidormeta. - Fix: Validate the
mapping.jsonpaths against the SCIM 2.0 User Resource schema. Ensurebuild_scim_patch_operationsfilters out empty values. Useop: "replace"for standard attributes. - Code fix: The mapping function checks
if ad_value:before adding operations. Remove any paths that target immutable fields.
Error: LDAP Bind Failed or Paged Results Control Missing
- Cause: Incorrect service account credentials, network firewall blocking port 389/636, or AD server configured to reject paged results.
- Fix: Verify the service account has read permissions on the target OU. Test the bind manually with
ldapsearchorldp.exe. Ensure theldap3server object usesget_info=ldap3.ALLto negotiate capabilities. - Code fix: Wrap the
ldap3.Connectioninitialization in a try-except block to catchLDAPBindError. Log the exact exception message for credential debugging.
