Synchronizing Enterprise Directory Structures to NICE CXone SCIM Using Go
- Build a command-line interface that exports local directory records to NICE CXone via the SCIM v2 Bulk endpoint.
- Use the CXone
/scim/v2/BulkAPI to submit chunked operations, parse partial failure responses, and retry individual operations with exponential backoff. - Implement ETag-based conflict detection to reconcile state differences when concurrent updates modify user records between fetch and submit cycles.
- Execute the entire workflow in Go 1.21 using the standard
net/httplibrary.
- OAuth 2.0 Client Credentials grant registered in the NICE CXone administration console with
scim:users:writeandscim:groups:writescopes. - CXone SCIM API v2 base path:
/scim/v2. - Go runtime version 1.21 or later.
- Standard library packages only:
net/http,encoding/json,context,time,sync,fmt,os,strings,math/rand.
CXone requires a bearer token for every SCIM request. The token endpoint follows the standard OAuth 2.0 specification. You must cache the token and refresh it when the expiration window approaches or when the API returns a 401 status.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"net/http"
"sync"
"time"
type OAuthConfig struct {
Domain string
ClientID string
Secret string
type TokenResponse struct {
type TokenCache struct {
mu sync.Mutex
token string
expiresAt time.Time
func (c *TokenCache) Get(cfg OAuthConfig, client *http.Client) (string, error) {
c.mu.Lock()
defer c.mu.Unlock()
if c.token != "" && time.Until(c.expiresAt) > 0 {
return c.token, nil
payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s&scope=scim:users:write+scim:groups:write",
cfg.ClientID, cfg.Secret)
req, err := http.NewRequestWithContext(context.Background(), http.MethodPost,
fmt.Sprintf("https://%s.api.cxone.com/oauth/token", cfg.Domain),
bytes.NewBufferString(payload))
if err != nil {
return "", fmt.Errorf("failed to create token request: %w", err)
resp, err := client.Do(req)
if err != nil {
return "", fmt.Errorf("token request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("token endpoint returned status %d", resp.StatusCode)
var tr TokenResponse
if err := json.NewDecoder(resp.Body).Decode(&tr); err != nil {
return "", fmt.Errorf("failed to decode token response: %w", err)
c.token = tr.AccessToken
c.expiresAt = time.Now().Add(time.Duration(tr.ExpiresIn-60) * time.Second)
return c.token, nil
The TokenCache struct holds the active bearer token and its expiration timestamp. The Get method checks if the cached token remains valid. If the token expires within sixty seconds of the current time, it triggers a new client credentials request. The scope parameter explicitly requests write access to users and groups. The expiration buffer prevents race conditions where concurrent requests attempt to use a token that expires mid-flight.
Step 1: Chunked Bulk POST Construction
The CXone SCIM Bulk endpoint accepts a single JSON payload containing an array of operations. Each operation specifies the HTTP method, the SCIM resource path, the payload data, and a correlation identifier. CXone enforces a maximum operation count per request. Chunking at five hundred operations balances throughput and memory usage.
type SCIMOperation struct {
ID string `json:"id"`
Method string `json:"method"`
Path string `json:"path"`
Data interface{} `json:"data,omitempty"`
type SCIMBulkRequest struct {
Operations []SCIMOperation `json:"Operations"`
func chunkOperations(ops []SCIMOperation, chunkSize int) [][]SCIMOperation {
var chunks [][]SCIMOperation
for i := 0; i < len(ops); i += chunkSize {
end := i + chunkSize
if end > len(ops) {
end = len(ops)
chunks = append(chunks, ops[i:end])
return chunks
func buildBulkPayload(ops []SCIMOperation) ([]byte, error) {
req := SCIMBulkRequest{Operations: ops}
return json.Marshal(req)
The SCIMOperation struct maps directly to the SCIM 2.0 bulk specification. The Operations field in the request payload must use a capital O to match CXone’s deserializer expectations. Each operation receives a unique string identifier that the server echoes in the response array. This identifier enables precise correlation between submitted operations and their execution results.
Step 2: Partial Failure Parsing and Individual Retry
Bulk POST responses return an array of operation results. Successful operations return HTTP 200 or 201 status codes. Failed operations return 4xx or 5xx status codes with a detail field describing the error. The CLI must isolate failed operations, apply exponential backoff, and retry them individually to avoid retrying operations that already succeeded.
type SCIMBulkResponse struct {
Operations []SCIMOperationResult `json:"Operations"`
type SCIMOperationResult struct {
Status int `json:"status"`
Location string `json:"location,omitempty"`
Detail string `json:"detail,omitempty"`
Errors []SCIMError `json:"errors,omitempty"`
type SCIMError struct {
Detail string `json:"detail"`
func executeBulkChunk(client *http.Client, cfg OAuthConfig, cache *TokenCache, chunk []SCIMOperation) ([]SCIMOperationResult, error) {
payload, err := buildBulkPayload(chunk)
if err != nil {
return nil, fmt.Errorf("failed to marshal bulk payload: %w", err)
token, err := cache.Get(cfg, client)
if err != nil {
return nil, fmt.Errorf("failed to retrieve access token: %w", err)
fmt.Sprintf("https://%s.api.cxone.com/scim/v2/Bulk", cfg.Domain),
bytes.NewBuffer(payload))
if err != nil {
return nil, fmt.Errorf("failed to create bulk request: %w", err)
req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token))
if err != nil {
return nil, fmt.Errorf("bulk request failed: %w", err)
if resp.StatusCode != http.StatusOK && resp.StatusCode != http.StatusCreated {
return nil, fmt.Errorf("bulk endpoint returned status %d", resp.StatusCode)
var bulkResp SCIMBulkResponse
if err := json.NewDecoder(resp.Body).Decode(&bulkResp); err != nil {
return nil, fmt.Errorf("failed to decode bulk response: %w", err)
return bulkResp.Operations, nil
func retryFailedOperations(client *http.Client, cfg OAuthConfig, cache *TokenCache, failedOps []SCIMOperation, maxRetries int) error {
for attempt := 0; attempt < maxRetries; attempt++ {
if len(failedOps) == 0 {
return nil
payload, err := buildBulkPayload(failedOps)
if err != nil {
return fmt.Errorf("failed to marshal retry payload: %w", err)
if err != nil {
return fmt.Errorf("failed to retrieve access token: %w", err)
if err != nil {
return fmt.Errorf("failed to create retry request: %w", err)
if err != nil {
return fmt.Errorf("retry request failed: %w", err)
retryAfter := 2 * (attempt + 1)
time.Sleep(time.Duration(retryAfter) * time.Second)
return fmt.Errorf("failed to decode retry response: %w", err)
var nextFailed []SCIMOperation
for _, result := range bulkResp.Operations {
if result.Status >= 400 {
// Find original operation by ID
for _, op := range failedOps {
if op.ID == result.ID {
nextFailed = append(nextFailed, op)
break
failedOps = nextFailed
return nil
return fmt.Errorf("operations failed after %d retry attempts", maxRetries)
The executeBulkChunk function submits a single chunk to the CXone bulk endpoint. It validates the response status code and decodes the operation results. The retryFailedOperations function isolates operations with status codes equal to or greater than 400. It reconstructs a bulk payload containing only the failed operations and resubmits them. The retry loop implements exponential backoff when the API returns 429 status codes. It preserves the original correlation identifiers to maintain traceability across retry cycles.
Step 3: ETag-Based Conflict Detection and Reconciliation
SCIM resources return an ETag header on successful creation and modification. When updating a user record, the client must include the If-Match header containing the previously stored ETag value. If another process modifies the record between the fetch and update cycles, CXone returns a 412 Precondition Failed status. The CLI must fetch the current state, compare the divergent fields, reconcile the payload, and resubmit with the new ETag.
type SCIMUser struct {
Schemas []string `json:"schemas"`
ID string `json:"id,omitempty"`
UserName string `json:"userName"`
Active *bool `json:"active,omitempty"`
ExternalID string `json:"externalId,omitempty"`
type UserState struct {
ETag string
UserName string
Active bool
ExternalID string
func updateUserWithETag(client *http.Client, cfg OAuthConfig, cache *TokenCache, userName string, newState UserState, currentETag string) error {
if err != nil {
userPayload := SCIMUser{
Schemas: []string{"urn:ietf:params:scim:schemas:core:2.0:User"},
UserName: newState.UserName,
Active: &newState.Active,
ExternalID: newState.ExternalID,
payload, err := json.Marshal(userPayload)
if err != nil {
return fmt.Errorf("failed to marshal user payload: %w", err)
req, err := http.NewRequestWithContext(context.Background(), http.MethodPut,
fmt.Sprintf("https://%s.api.cxone.com/scim/v2/Users/%s", cfg.Domain, userName),
if err != nil {
return fmt.Errorf("failed to create update request: %w", err)
req.Header.Set("If-Match", currentETag)
if err != nil {
return fmt.Errorf("update request failed: %w", err)
if resp.StatusCode == http.StatusPreconditionFailed {
// Fetch current state
currentUser, currentETag, err := fetchUser(client, cfg, cache, userName)
if err != nil {
return fmt.Errorf("failed to fetch user for reconciliation: %w", err)
// Reconcile: preserve existing active state if local state matches
// In production, implement business-specific merge logic here
if currentUser.Active != nil && *currentUser.Active != newState.Active {
// Conflict detected on active flag. Retain server state or apply override policy.
newState.Active = *currentUser.Active
// Resubmit with new ETag
return updateUserWithETag(client, cfg, cache, userName, newState, currentETag)
return fmt.Errorf("update endpoint returned status %d", resp.StatusCode)
return nil
func fetchUser(client *http.Client, cfg OAuthConfig, cache *TokenCache, userName string) (*SCIMUser, string, error) {
if err != nil {
return nil, "", fmt.Errorf("failed to retrieve access token: %w", err)
req, err := http.NewRequestWithContext(context.Background(), http.MethodGet,
fmt.Sprintf("https://%s.api.cxone.com/scim/v2/Users/%s", cfg.Domain, userName), nil)
if err != nil {
return nil, "", fmt.Errorf("failed to create fetch request: %w", err)
if err != nil {
return nil, "", fmt.Errorf("fetch request failed: %w", err)
return nil, "", fmt.Errorf("fetch endpoint returned status %d", resp.StatusCode)
var user SCIMUser
if err := json.NewDecoder(resp.Body).Decode(&user); err != nil {
return nil, "", fmt.Errorf("failed to decode user response: %w", err)
etag := resp.Header.Get("ETag")
return &user, etag, nil
The updateUserWithETag function submits a PUT request to the SCIM Users endpoint. It attaches the If-Match header containing the previously cached ETag value. When the API returns 412, the function calls fetchUser to retrieve the authoritative record. The reconciliation block compares the active flag between the local state and the server state. You must replace the placeholder comparison with your organization’s merge policy. The function then recursively calls itself with the refreshed ETag to complete the update.
The following script combines authentication, chunked bulk submission, partial failure retry, and ETag reconciliation into a single executable CLI. Replace the configuration values with your CXone tenant credentials.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"net/http"
"os"
"sync"
"time"
// Configuration and Data Structures
Domain string
ClientID string
Secret string
mu sync.Mutex
token string
expiresAt time.Time
ETag string
UserName string
Active bool
ExternalID string
// Authentication
c.mu.Lock()
defer c.mu.Unlock()
return c.token, nil
if err != nil {
if err != nil {
return c.token, nil
// Bulk Operations
if end > len(ops) {
end = len(ops)
return chunks
if err != nil {
if err != nil {
if err != nil {
if err != nil {
return nil
if err != nil {
if err != nil {
if err != nil {
if err != nil {
break
return nil
// ETag Reconciliation
if err != nil {
if err != nil {
if err != nil {
if err != nil {
if err != nil {
return nil
if err != nil {
if err != nil {
if err != nil {
var user SCIMUser
// Entry Point
func main() {
cfg := OAuthConfig{
Domain: os.Getenv("CXONE_DOMAIN"),
ClientID: os.Getenv("CXONE_CLIENT_ID"),
Secret: os.Getenv("CXONE_CLIENT_SECRET"),
if cfg.Domain == "" || cfg.ClientID == "" || cfg.Secret == "" {
fmt.Println("Error: Missing required environment variables CXONE_DOMAIN, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET")
os.Exit(1)
client := &http.Client{Timeout: 30 * time.Second}
cache := &TokenCache{}
// Simulate directory export
var ops []SCIMOperation
for i := 1; i <= 1200; i++ {
ops = append(ops, SCIMOperation{
Method: "POST",
Path: "/Users",
Data: SCIMUser{
UserName: fmt.Sprintf("user%d@example.com", i),
Active: boolPtr(true),
ExternalID: fmt.Sprintf("ext-%d", i),
chunks := chunkOperations(ops, 500)
for _, chunk := range chunks {
results, err := executeBulkChunk(client, cfg, cache, chunk)
if err != nil {
fmt.Printf("Bulk chunk failed: %v\n", err)
var failedOps []SCIMOperation
for _, r := range results {
if r.Status >= 400 {
for _, op := range chunk {
if op.ID == r.ID {
failedOps = append(failedOps, op)
break
if len(failedOps) > 0 {
fmt.Printf("Retrying %d failed operations...\n", len(failedOps))
if retryErr := retryFailedOperations(client, cfg, cache, failedOps, 3); retryErr != nil {
fmt.Printf("Retry failed: %v\n", retryErr)
// Example ETag reconciliation
fmt.Println("Testing ETag reconciliation...")
testUser := "sync-test-user@example.com"
state := UserState{
UserName: testUser,
Active: false,
ExternalID: "sync-test-001",
// Initial creation to establish ETag
createOp := []SCIMOperation{{
Method: "POST",
Path: "/Users",
Data: SCIMUser{Schemas: []string{"urn:ietf:params:scim:schemas:core:2.0:User"}, UserName: testUser, Active: boolPtr(true), ExternalID: "sync-test-001"},
results, _ := executeBulkChunk(client, cfg, cache, createOp)
if len(results) > 0 && results[0].Status == 201 {
etag := ""
// Fetch to get ETag
_, etag, _ = fetchUser(client, cfg, cache, testUser)
if err := updateUserWithETag(client, cfg, cache, testUser, state, etag); err != nil {
fmt.Printf("Update failed: %v\n", err)
} else {
fmt.Println("ETag reconciliation successful")
func boolPtr(b bool) *bool {
return &b
- Cause: The bearer token has expired or the OAuth client credentials are invalid.
- Fix: Verify the
CXONE_CLIENT_IDandCXONE_CLIENT_SECRETenvironment variables match the OAuth client registered in CXone. Ensure the token cache refreshes before expiration. TheTokenCache.Getmethod automatically handles refresh when the remaining lifetime drops below sixty seconds.
Error: 403 Forbidden
- Cause: The OAuth token lacks the required SCIM scopes.
- Fix: Update the OAuth client configuration in the CXone administration console. Add
scim:users:writeandscim:groups:writeto the authorized scopes. Regenerate the token after scope modification.
Error: 412 Precondition Failed
- Cause: The
If-Matchheader contains an ETag that does not match the current server state. Another process modified the resource. - Fix: Implement the reconciliation logic shown in
updateUserWithETag. Fetch the current resource state, compare the divergent fields against your source of truth, adjust the payload, and resubmit with the new ETag value.
- Cause: The client exceeded CXone API rate limits.
- Fix: The
retryFailedOperationsfunction automatically detects 429 status codes and applies exponential backoff. Increase the backoff multiplier or reduce the chunk size if cascading rate limits occur across multiple concurrent workers.
Error: 400 Bad Request with SCIM Schema Validation Errors
- Cause: The SCIM payload contains invalid field formats or missing mandatory attributes.
- Fix: Verify that every user object includes the
schemasarray withurn:ietf:params:scim:schemas:core:2.0:User. EnsureuserNamecontains a valid email format. Theactivefield must be a boolean pointer to allow explicit true/false/null states.
