Subscribing to Genesys Cloud Streaming Topics and Routing Events in Python
  • A Python service that connects to the Genesys Cloud Streaming API, subscribes to routing and conversation topics, and processes real-time events.
  • The implementation uses the official Genesys Cloud Python SDK alongside the websockets library for atomic WebSocket operations and httpx for REST calls.
  • The code handles OAuth authentication, event filtering, schema validation, exponential backoff retries, consumer backlog tracking, external webhook synchronization, latency monitoring, audit logging, and exposes a reusable GenesysTopicSubscriber class for automated management.
  • OAuth 2.0 Client Credentials grant with scopes: analytics:events:view, integration:webhooks:readwrite
  • Genesys Cloud Python SDK: purecloudplatformclientv2>=2.15.0
  • Python runtime: 3.9 or higher
  • External dependencies: websockets>=12.0, httpx>=0.25.0, pydantic>=2.5.0, tenacity>=8.2.0
  • An active Genesys Cloud organization with API access enabled
Genesys Cloud uses OAuth 2.0 for all API access. The streaming API requires a valid bearer token passed during the WebSocket handshake. The following code demonstrates the client credentials flow with token caching and expiration handling.
import httpx
from typing import Optional
class GenesysAuthManager:
    def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
        self.client_id = client_id
        self.token_url = f"{base_url}/oauth/token"
        self._expires_at: float = 0.0
        if self._token and time.time() < self._expires_at - 60:
            return self._token
        with httpx.Client() as client:
            response = client.post(
                self.token_url,
                auth=(self.client_id, self.client_secret),
                data={"grant_type": "client_credentials"},
                headers={"Content-Type": "application/x-www-form-urlencoded"}
            response.raise_for_status()
            payload = response.json()
            self._token = payload["access_token"]
            self._expires_at = time.time() + payload["expires_in"]
            return self._token
The get_access_token method caches the token and refreshes it sixty seconds before expiration to prevent mid-stream 401 rejections. All subsequent REST and WebSocket calls will consume this token.
Step 1: WebSocket Connection and Topic Subscription
The Genesys Cloud Streaming API uses a WebSocket endpoint at /api/v2/analytics/events/stream. Clients subscribe by sending a JSON payload containing the topics array and optional filter criteria. The following code establishes the connection, validates the subscription count against organizational limits, and sends the attach directive.
import asyncio
import json
import logging
import websockets
class StreamConnection:
    MAX_SUBSCRIPTIONS = 50
    def __init__(self, auth_manager: GenesysAuthManager, topics: List[str], filters: Dict[str, Any]):
        self.auth_manager = auth_manager
        self.topics = topics
        self.filters = filters
        self.ws_url = "wss://api.mypurecloud.com/api/v2/analytics/events/stream"
        self.websocket: Optional[websockets.WebSocketClientProtocol] = None
    async def attach(self) -> None:
        if len(self.topics) > self.MAX_SUBSCRIPTIONS:
            raise ValueError(f"Subscription count {len(self.topics)} exceeds maximum limit {self.MAX_SUBSCRIPTIONS}")
        token = self.auth_manager.get_access_token()
        ws_url_with_token = f"{self.ws_url}?access_token={token}"
        self.websocket = await websockets.connect(ws_url_with_token, ping_interval=20, ping_timeout=10)
        subscription_payload = {
            "topics": self.topics,
            "filter": self.filters
        await self.websocket.send(json.dumps(subscription_payload))
        logger.info("Attached to Genesys Cloud stream with topics: %s", self.topics)
The attach method validates the topic count, appends the bearer token to the WebSocket URL, and transmits the subscription payload. Genesys Cloud responds with a stream-started message upon successful attachment.
Step 2: Event Filtering, Validation, and Retry Policy
Real-time streams require strict format verification and resilient reconnection logic. The following implementation uses Pydantic for malformed-event checking, calculates event-filtering matches, and applies exponential backoff with jitter for atomic WebSocket operations.
import random
from pydantic import BaseModel, ValidationError
from typing import Optional, Literal
class GenesysStreamEvent(BaseModel):
    type: str
    timestamp: str
    topic: str
    data: Optional[Dict[str, Any]] = None
    sequence: Optional[int] = None
class RetryPolicy:
    def __init__(self, max_retries: int = 5, base_delay: float = 2.0, max_delay: float = 60.0):
        self.max_retries = max_retries
        self.base_delay = base_delay
        self.max_delay = max_delay
    def calculate_delay(self, attempt: int) -> float:
        delay = min(self.base_delay * (2 ** attempt), self.max_delay)
        jitter = random.uniform(0, delay * 0.1)
        return delay + jitter
async def process_stream_event(raw_message: str, retry_policy: RetryPolicy) -> Optional[GenesysStreamEvent]:
        payload = json.loads(raw_message)
        event = GenesysStreamEvent(**payload)
        return event
    except ValidationError as e:
        logger.warning("Malformed event detected: %s", e.errors())
        return None
    except json.JSONDecodeError as e:
        logger.error("JSON parsing failed: %s", e)
        return None
async def handle_disconnection(retry_policy: RetryPolicy) -> None:
    for attempt in range(retry_policy.max_retries):
        delay = retry_policy.calculate_delay(attempt)
        logger.info("Connection lost. Retrying in %.2f seconds (attempt %d/%d)", delay, attempt + 1, retry_policy.max_retries)
        await asyncio.sleep(delay)
        break
    else:
        raise RuntimeError("Maximum retry attempts reached. Stream terminated.")
The process_stream_event function validates incoming payloads against the expected Genesys Cloud schema. Invalid or malformed events are logged and discarded to prevent pipeline corruption. The handle_disconnection function implements the retry-policy evaluation logic with exponential backoff and jitter to avoid thundering herd scenarios during scaling events.
Step 3: Backlog Verification, Webhook Sync, and Latency Tracking
Consumer-backlog verification ensures no routing changes are lost during scaling. The following code tracks sequence numbers, synchronizes validated events to an external queue service via webhooks, measures attach success rates, and generates audit logs.
import httpx
from typing import Set, Dict, Any
class AuditLogger:
    def __init__(self, log_file: str = "stream_audit.log"):
        self.log_file = log_file
    def log(self, event_type: str, details: Dict[str, Any]) -> None:
        timestamp = datetime.now(timezone.utc).isoformat()
        log_entry = json.dumps({"timestamp": timestamp, "type": event_type, "details": details})
        with open(self.log_file, "a", encoding="utf-8") as f:
            f.write(log_entry + "\n")
class StreamProcessor:
    def __init__(self, webhook_url: str, auth_manager: GenesysAuthManager, audit_logger: AuditLogger):
        self.audit_logger = audit_logger
        self.processed_sequences: Set[int] = set()
        self.attach_success_count: int = 0
        self.attach_attempt_count: int = 0
        self.latency_samples: list[float] = []
    def verify_backlog(self, sequence: int) -> bool:
        if sequence in self.processed_sequences:
            return False
        self.processed_sequences.add(sequence)
        return True
    def calculate_attach_success_rate(self) -> float:
        if self.attach_attempt_count == 0:
            return 0.0
        return (self.attach_success_count / self.attach_attempt_count) * 100.0
    async def sync_to_external_queue(self, event: GenesysStreamEvent) -> None:
            async with httpx.AsyncClient() as client:
                response = await client.post(
                    self.webhook_url,
                    json=event.model_dump(),
                    headers={"Authorization": f"Bearer {token}", "Content-Type": "application/json"}
                logger.info("Event synced to external queue successfully")
            logger.error("Webhook sync failed: %s", e.response.text)
            self.audit_logger.log("webhook_failure", {"status": e.response.status_code, "event_type": event.type})
            logger.error("External queue sync error: %s", str(e))
    def track_latency(self, start_time: float) -> None:
        latency = time.time() - start_time
        self.latency_samples.append(latency)
        if len(self.latency_samples) > 100:
            self.latency_samples.pop(0)
        avg_latency = sum(self.latency_samples) / len(self.latency_samples)
        logger.info("Current average latency: %.3f ms", avg_latency * 1000)
The StreamProcessor class maintains a set of processed sequence numbers for consumer-backlog verification, preventing duplicate processing during reconnects. The sync_to_external_queue method pushes validated events to an external service via HTTP POST, simulating webhook alignment. Latency tracking uses a rolling window to report subscribe efficiency, while the AuditLogger writes structured JSON lines for governance compliance.
The following module combines authentication, WebSocket attachment, event validation, retry logic, backlog verification, webhook synchronization, latency tracking, and audit logging into a single production-ready subscriber class.
import asyncio
import json
import logging
import random
from typing import List, Dict, Any, Optional, Set
import httpx
import websockets
            return self._token
                self.token_url,
            return self._token
    type: str
    timestamp: str
    topic: str
class GenesysTopicSubscriber:
    def __init__(self, client_id: str, client_secret: str, topics: List[str], filters: Dict[str, Any], webhook_url: str):
        self.auth_manager = GenesysAuthManager(client_id, client_secret)
        self.audit_log_file = "stream_audit.log"
    def _log_audit(self, event_type: str, details: Dict[str, Any]) -> None:
        with open(self.audit_log_file, "a", encoding="utf-8") as f:
    def _calculate_backoff(self, attempt: int) -> float:
        delay = min(2.0 * (2 ** attempt), 60.0)
    def _track_latency(self, start_time: float) -> None:
        avg = sum(self.latency_samples) / len(self.latency_samples)
        logger.info("Average listening latency: %.3f ms", avg * 1000)
    async def _sync_event(self, event: GenesysStreamEvent) -> None:
                resp = await client.post(
                    self.webhook_url,
                resp.raise_for_status()
            self._log_audit("webhook_failure", {"status": e.response.status_code, "topic": event.topic})
            logger.error("Queue sync error: %s", str(e))
    async def run(self) -> None:
            raise ValueError(f"Topic count {len(self.topics)} exceeds limit {self.MAX_SUBSCRIPTIONS}")
        while True:
            self.attach_attempt_count += 1
            ws_url = f"{self.ws_url}?access_token={token}"
            connect_start = time.time()
                async with websockets.connect(ws_url, ping_interval=20, ping_timeout=10) as websocket:
                    payload = json.dumps({"topics": self.topics, "filter": self.filters})
                    await websocket.send(payload)
                    self.attach_success_count += 1
                    self._track_latency(connect_start)
                    self._log_audit("attach_success", {"topics": self.topics, "success_rate": f"{(self.attach_success_count/self.attach_attempt_count)*100:.1f}%"})
                    logger.info("Stream attached successfully")
                    async for raw_message in websocket:
                            event = GenesysStreamEvent(**json.loads(raw_message))
                        except (ValidationError, json.JSONDecodeError) as e:
                            logger.warning("Malformed event skipped: %s", str(e))
                            self._log_audit("malformed_event", {"error": str(e)})
                        if event.sequence is not None and not self._verify_backlog(event.sequence):
                            logger.info("Duplicate sequence %d skipped", event.sequence)
                        await self._sync_event(event)
                        logger.info("Processed event: %s on topic: %s", event.type, event.topic)
            except websockets.ConnectionClosed as e:
                logger.warning("WebSocket closed: %s", e)
                self._log_audit("connection_closed", {"code": e.code, "reason": e.reason})
                logger.error("Unexpected stream error: %s", str(e))
                self._log_audit("stream_error", {"error": str(e)})
            delay = self._calculate_backoff(self.attach_attempt_count)
            logger.info("Reconnecting in %.2f seconds", delay)
    def _verify_backlog(self, sequence: int) -> bool:
            return False
        return True
    SUBSCRIBER = GenesysTopicSubscriber(
        client_id="YOUR_CLIENT_ID",
        client_secret="YOUR_CLIENT_SECRET",
        topics=["routing/queues/all", "routing/conversations/all"],
        filters={"type": "conversation-update"},
        webhook_url="https://your-external-queue.example.com/api/v1/ingest"
    asyncio.run(SUBSCRIBER.run())
The script validates the topic count against MAX_SUBSCRIPTIONS, establishes the WebSocket connection with the bearer token, and sends the subscription payload. It processes incoming messages, validates them against the Pydantic schema, skips duplicates via sequence tracking, pushes valid events to the external queue, logs latency metrics, and writes structured audit entries. On disconnection, it applies exponential backoff and reconnects automatically.
  • Cause: The OAuth token expired during the WebSocket handshake or the client credentials are invalid.
  • Fix: Verify the client_id and client_secret in the Genesys Cloud admin console. Ensure the get_access_token method refreshes the token before the expires_in timestamp. Add a sixty-second buffer to prevent mid-stream expiration.
  • Code Fix: The GenesysAuthManager implementation already includes the time.time() < self._expires_at - 60 check. If errors persist, force a refresh by clearing self._token and calling get_access_token again.
Error: 403 Forbidden
  • Cause: The OAuth client lacks the analytics:events:view scope, or the organization has restricted streaming access.
  • Fix: Navigate to the Genesys Cloud admin console, locate the API client, and add analytics:events:view to the authorized scopes. Restart the application to generate a new token with the updated permissions.
  • Cause: The client exceeded the Genesys Cloud rate limit for WebSocket connections or webhook POST requests.
  • Fix: Implement request throttling. The retry policy in GenesysTopicSubscriber uses exponential backoff. Increase the base_delay and max_delay parameters if 429 responses cascade during scaling events.
  • Code Fix: Adjust _calculate_backoff to start at 5.0 seconds instead of 2.0 and cap jitter at 0.2 of the base delay.
Error: MalformedEvent / ValidationError
  • Cause: Genesys Cloud occasionally sends internal control messages that do not match the standard event schema.
  • Fix: The Pydantic validation catches these payloads and logs them without crashing the stream. Ensure your external queue service can handle partial or control-type messages if you remove the validation filter.
  • Code Fix: The try/except (ValidationError, json.JSONDecodeError) block safely continues the loop. Add a dedicated handler for type == "stream-ack" if you require acknowledgment tracking.
Error: Consumer Backlog Stagnation
  • Cause: Sequence numbers are not incrementing, or the external queue is rejecting events, causing the backlog set to grow indefinitely.
  • Fix: Implement a sliding window for processed_sequences to prevent memory exhaustion. Add health checks to the external queue endpoint before pushing events.
  • Code Fix: Replace self.processed_sequences: Set[int] = set() with an OrderedDict or deque(maxlen=10000) to automatically drop old sequence numbers.
