Submitting Genesys Cloud Quality Evaluations Programmatically with Python
- A Python module that constructs, validates, and submits Quality evaluation payloads to the Genesys Cloud API with automatic score calculation triggers.
- This tutorial uses the Genesys Cloud Python SDK and REST endpoints for Quality management and platform webhooks.
- The implementation is written in Python 3.9+ with type hints, production-grade error handling, and audit logging.
- OAuth2 client credentials (Client ID and Client Secret) with the following scopes:
quality:evaluation:submit,quality:rater:read,quality:form:read,platform:webhook:write,user:read - Genesys Cloud Python SDK version 1.2.0 or higher (
pip install genesyscloud httpx tenacity) - Python 3.9+ runtime environment
- Active Genesys Cloud organization with Quality forms and configured raters
The Genesys Cloud Python SDK manages OAuth2 client credentials flow internally. You must initialize the ApiClient and OAuthClient before accessing any Quality endpoints. Token caching is handled automatically by the SDK, but you must configure the environment to use a persistent token cache in production to avoid unnecessary token refreshes.
import os
from genesyscloud.rest import Configuration
from genesyscloud.auth import OAuthClient
from genesyscloud.api_client import ApiClient
def initialize_genesys_client() -> ApiClient:
"""Configure and return a fully authenticated Genesys Cloud API client."""
configuration = Configuration()
configuration.host = os.getenv("GENESYS_CLOUD_HOST", "https://api.mypurecloud.com")
configuration.oauth_client_id = os.getenv("GENESYS_CLIENT_ID")
configuration.oauth_client_secret = os.getenv("GENESYS_CLIENT_SECRET")
oauth_client = OAuthClient(configuration=configuration)
api_client = ApiClient(configuration=configuration, oauth_client=oauth_client)
# Force initial token fetch to verify credentials
oauth_client.get_access_token()
return api_client
The oauth_client.get_access_token() call triggers a POST /api/v2/oauth/token request. If the credentials are invalid, the SDK raises a rest.ApiException with status 401. You must catch this exception during initialization to fail fast before attempting evaluation submissions.
Step 1: Construct Evaluation Payload with Form Instance and Score Matrix
The Quality evaluation submission requires a structured JSON payload containing the form instance ID, nested sections, question scores, and comment directives. Genesys Cloud calculates the final evaluation score automatically based on the form configuration when you submit this payload. You must reference the exact formInstanceId from your Quality form, and each question must match the form schema.
from genesyscloud.models import EvaluationSubmission, SectionSubmission, QuestionSubmission
def build_evaluation_submission(
form_instance_id: str,
agent_id: str,
evaluator_id: str,
score_matrix: dict[str, dict[str, float]],
overall_comment: str,
rater_comment: str
) -> EvaluationSubmission:
Construct a fully typed EvaluationSubmission object.
score_matrix format: {section_id: {question_id: score}}
sections = []
for section_id, questions in score_matrix.items():
question_submissions = []
for question_id, score in questions.items():
question_submissions.append(QuestionSubmission(
question_id=question_id,
score=score,
comment="Programmatic assessment entry"
sections.append(SectionSubmission(
section_id=section_id,
questions=question_submissions
return EvaluationSubmission(
form_instance_id=form_instance_id,
agent_id=agent_id,
evaluator_id=evaluator_id,
date=datetime.now(timezone.utc).isoformat(),
sections=sections,
comment=overall_comment,
rater_comment=rater_comment
The score_matrix parameter enforces a deterministic mapping between section IDs and question IDs. The Genesys Cloud evaluation engine validates that every question_id exists in the referenced form instance. If a question ID is missing or the score falls outside the configured range, the API returns a 400 Bad Request with a detailed validation error array.
Step 2: Validate Submit Schema Against Engine Constraints
Before transmitting the payload, you must validate schema compliance, enforce maximum submission size limits, verify rater certification, and check for conflict of interest. Genesys Cloud enforces a practical payload limit of approximately 1 megabyte for POST operations. You must also verify that the evaluator holds an active certification for the target form and does not share a direct reporting relationship with the evaluated agent.
import json
from genesyscloud.api import QualityApi, UserApi
from genesyscloud.models import Rater
MAX_PAYLOAD_BYTES = 1_048_576 # 1 MB
def validate_submission(
api_client: ApiClient,
payload: EvaluationSubmission,
evaluator_id: str,
agent_id: str
) -> tuple[bool, str]:
Validate payload size, rater certification, and conflict of interest.
Returns (is_valid, error_message).
# 1. Payload size validation
payload_json = json.dumps(payload.to_dict(), default=str)
if len(payload_json.encode("utf-8")) > MAX_PAYLOAD_BYTES:
return False, f"Payload exceeds maximum size limit of {MAX_PAYLOAD_BYTES} bytes."
# 2. Rater certification check
quality_api = QualityApi(api_client)
rater_response = quality_api.get_quality_rater(rater_id=evaluator_id)
if not rater_response.certified:
return False, f"Evaluator {evaluator_id} is not certified for Quality assessments."
return False, f"Failed to verify rater certification: {str(e)}"
# 3. Conflict of interest verification
user_api = UserApi(api_client)
agent_profile = user_api.get_user(user_id=agent_id)
evaluator_profile = user_api.get_user(user_id=evaluator_id)
# Simple team/supervisor conflict check
if agent_profile.department_id == evaluator_profile.department_id:
if agent_profile.manager_id == evaluator_id:
return False, "Conflict of interest detected: Evaluator is direct supervisor of agent."
return False, f"Conflict of interest check failed: {str(e)}"
return True, "Validation passed."
The validation pipeline runs synchronously before the submission. The get_quality_rater call requires the quality:rater:read scope. The conflict of interest logic checks department alignment and direct manager relationships. You should adjust the conflict rules to match your organizational compliance requirements. If validation fails, the function returns early, preventing unnecessary API calls and preserving audit integrity.
Step 3: Atomic Submission with Retry Logic and Webhook Synchronization
The evaluation commit is an atomic POST /api/v2/quality/evaluations operation. You must implement exponential backoff for 429 Too Many Requests responses to prevent rate-limit cascades. After a successful submission, you trigger a webhook event to synchronize the evaluation status with external coaching platforms.
import httpx
from tenacity import retry, wait_exponential, stop_after_attempt, retry_if_exception_type
@retry(
retry=retry_if_exception_type(ApiException),
wait=wait_exponential(multiplier=1, min=2, max=30),
stop=stop_after_attempt(5)
def submit_evaluation_atomic(api_client: ApiClient, payload: EvaluationSubmission) -> dict:
"""Submit the evaluation with automatic retry on 429 rate limits."""
response = quality_api.post_quality_evaluation(body=payload)
return response.to_dict()
def trigger_coaching_webhook(webhook_url: str, submission_id: str, status: str) -> None:
"""Synchronize submission event with external coaching platform."""
payload = {
"event_type": "quality.evaluation.submitted",
"submission_id": submission_id,
"status": status,
"timestamp": datetime.now(timezone.utc).isoformat()
with httpx.Client() as client:
response = client.post(webhook_url, json=payload, timeout=10.0)
if response.status_code not in (200, 201, 204):
raise RuntimeError(f"Webhook delivery failed with status {response.status_code}")
The tenacity decorator wraps the post_quality_evaluation call. The retry strategy only triggers on ApiException instances, which includes 429 responses. The webhook function uses httpx for synchronous delivery with a strict timeout. External coaching platforms receive the submission ID and status for immediate alignment.
Step 4: Audit Logging and Latency Tracking
Production Quality management requires deterministic audit trails and performance metrics. You must log submission timestamps, calculate network latency, track acceptance success rates, and persist audit records for governance compliance.
import logging
from typing import List
@dataclass
class SubmissionAuditLog:
submission_id: str
evaluator_id: str
agent_id: str
latency_ms: float
success: bool
error_message: str = ""
timestamp: str = field(default_factory=lambda: datetime.now(timezone.utc).isoformat())
class QualitySubmissionTracker:
def __init__(self, audit_log_path: str = "quality_audit.log"):
self.logger = logging.getLogger("QualityAudit")
self.logger.setLevel(logging.INFO)
handler = logging.FileHandler(audit_log_path)
formatter = logging.Formatter("%(asctime)s | %(message)s")
handler.setFormatter(formatter)
self.logger.addHandler(handler)
self.submissions: List[SubmissionAuditLog] = []
def record(self, log: SubmissionAuditLog) -> None:
self.submissions.append(log)
self.logger.info(
f"ID: {log.submission_id} | Latency: {log.latency_ms:.2f}ms | "
f"Success: {log.success} | Agent: {log.agent_id} | Evaluator: {log.evaluator_id}"
def get_success_rate(self) -> float:
if not self.submissions:
return 0.0
successful = sum(1 for s in self.submissions if s.success)
return (successful / len(self.submissions)) * 100.0
The tracker calculates latency by measuring the delta between submission initiation and API response receipt. The success rate metric provides a real-time view of submission efficiency. Audit logs are appended to a dedicated file for compliance review and automated reporting pipelines.
The following module integrates all components into a single executable script. Replace the placeholder environment variables with your Genesys Cloud credentials before execution.
#!/usr/bin/env python3
import os
from genesyscloud.rest import Configuration, ApiException
import httpx
import logging
# --- Configuration ---
GENESYS_HOST = os.getenv("GENESYS_CLOUD_HOST", "https://api.mypurecloud.com")
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
WEBHOOK_URL = os.getenv("COACHING_WEBHOOK_URL", "https://your-coaching-platform.com/api/webhooks/quality")
AUDIT_LOG_PATH = "quality_submissions_audit.log"
# --- Setup ---
logging.basicConfig(level=logging.INFO, format="%(asctime)s | %(levelname)s | %(message)s")
def init_client() -> ApiClient:
config = Configuration()
config.host = GENESYS_HOST
config.oauth_client_id = CLIENT_ID
config.oauth_client_secret = CLIENT_SECRET
oauth = OAuthClient(configuration=config)
api = ApiClient(configuration=config, oauth_client=oauth)
oauth.get_access_token()
return api
def build_payload(form_id: str, agent_id: str, evaluator_id: str) -> EvaluationSubmission:
sections = [
SectionSubmission(
section_id="sec_compliance_01",
questions=[
QuestionSubmission(question_id="q_call_opening", score=4),
QuestionSubmission(question_id="q_solution_delivery", score=5)
form_instance_id=form_id,
agent_id=agent_id,
sections=sections,
comment="Automated quality assessment",
rater_comment="System generated evaluation"
@retry(
def submit_payload(api: ApiClient, payload: EvaluationSubmission) -> dict:
quality_api = QualityApi(api)
return quality_api.post_quality_evaluation(body=payload).to_dict()
def send_webhook(submission_id: str, success: bool) -> None:
resp = client.post(
WEBHOOK_URL,
json={
"status": "accepted" if success else "rejected",
timeout=10.0
if resp.status_code not in (200, 201, 204):
logger.warning(f"Webhook delivery failed: {resp.status_code}")
def run_evaluation_workflow():
api_client = init_client()
form_id = os.getenv("TARGET_FORM_INSTANCE_ID")
agent_id = os.getenv("TARGET_AGENT_ID")
evaluator_id = os.getenv("TARGET_EVALUATOR_ID")
if not all([form_id, agent_id, evaluator_id]):
raise ValueError("Missing required environment variables for workflow execution.")
payload = build_payload(form_id, agent_id, evaluator_id)
success = False
submission_id = "unknown"
error_msg = ""
result = submit_payload(api_client, payload)
submission_id = result.get("id", "unknown")
success = True
logger.info(f"Evaluation submitted successfully. ID: {submission_id}")
except ApiException as e:
error_msg = str(e.body)
logger.error(f"Evaluation submission failed: {error_msg}")
finally:
logger.info(f"Submission latency: {latency_ms:.2f}ms")
send_webhook(submission_id, success)
# Audit log entry
audit_entry = (
f"{datetime.now(timezone.utc).isoformat()} | "
f"ID: {submission_id} | Latency: {latency_ms:.2f}ms | "
f"Success: {success} | Agent: {agent_id} | Evaluator: {evaluator_id} | "
f"Error: {error_msg}\n"
with open(AUDIT_LOG_PATH, "a", encoding="utf-8") as f:
f.write(audit_entry)
This script initializes the OAuth client, constructs the evaluation payload, submits it with exponential backoff, calculates latency, delivers a webhook notification, and writes a structured audit log entry. Execute the script after setting the required environment variables. The script handles authentication, payload construction, submission, error recovery, and audit persistence in a single execution cycle.
- Cause: Invalid Client ID, expired Client Secret, or missing OAuth scopes in the registered application.
- Fix: Verify the credentials in your Genesys Cloud Developer Console. Ensure the application has the
quality:evaluation:submitscope assigned. Restart the script to trigger a fresh token acquisition. - Code Fix: Add explicit scope validation during initialization:
if not CLIENT_ID or not CLIENT_SECRET:
raise EnvironmentError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set.")
Error: 403 Forbidden
- Cause: The OAuth token lacks the required scopes, or the evaluator user does not have Quality rater permissions in the organization.
- Fix: Grant the
quality:evaluation:submitscope to the OAuth application. Assign the evaluator to a Quality rater group with form access. Verify the evaluator is certified for the target form instance. - Code Fix: The validation function in Step 2 catches certification failures. Ensure the
quality:rater:readscope is present.
Error: 400 Bad Request (Validation Failed)
- Cause: Mismatched
formInstanceId, invalidquestionIdreferences, scores outside configured ranges, or payload size exceeding platform limits. - Fix: Cross-reference the form schema using
GET /api/v2/quality/forms/{formId}/instances/{instanceId}. Validate that everyquestionIdexists in the form structure. Ensure scores are integers or floats matching the question configuration. - Code Fix: The
validate_submissionfunction enforces size limits. Add explicit question ID verification by fetching the form instance schema before payload construction.
- Cause: Exceeding the Genesys Cloud Quality API rate limits (typically 50 requests per second per organization).
- Fix: The
tenacitydecorator implements exponential backoff. If failures persist, reduce submission concurrency or implement a queue-based throttling mechanism. - Code Fix: The retry configuration in Step 3 handles 429 responses automatically. Monitor the
Retry-Afterheader in production deployments for dynamic backoff adjustments.
Error: 5xx Server Error
- Cause: Temporary Genesys Cloud platform outage or evaluation engine processing failure.
- Fix: Implement idempotent submission tracking using the
submission_idreturned on success. Retry the submission after 30 seconds if the platform status page indicates recovery. - Code Fix: Wrap the submission call in a try/except block that captures
ApiExceptionwith status codes 500-599 and triggers a delayed retry or manual alert.
