Submitting Genesys Cloud Agent Assist Post-Call Survey Results with Python
- A Python pipeline that constructs, validates, and submits Agent Assist post-call survey results to Genesys Cloud.
- The implementation uses the Genesys Cloud REST Survey API for atomic submission and the Events WebSocket API for real-time ingestion synchronization.
- The tutorial covers Python 3.9+ with
requests,websockets, andpydantic.
- Genesys Cloud OAuth client credentials (Client ID and Client Secret)
- Required OAuth scopes:
survey:write,events:read,webhook:write - Python 3.9 or higher
- External dependencies:
pip install requests websockets pydantic aiohttp - A Genesys Cloud survey template ID and a configured webhook endpoint for external QA synchronization
Genesys Cloud uses OAuth 2.0 Client Credentials flow for server-to-server API access. The following code fetches a bearer token and implements automatic refresh logic.
import requests
from typing import Optional
class GenesysAuth:
def __init__(self, client_id: str, client_secret: str, org_domain: str):
self.client_id = client_id
self.token_url = f"https://api.{org_domain}/oauth/token"
def get_token(self) -> str:
if self.access_token and time.time() < self.token_expiry - 60:
return self.access_token
payload = {
"client_id": self.client_id,
headers = {"Content-Type": "application/json"}
response = requests.post(self.token_url, json=payload, headers=headers)
response.raise_for_status()
token_data = response.json()
self.token_expiry = time.time() + token_data["expires_in"]
Survey result submissions require a structured payload containing the survey template reference, response value matrices, and explicit timestamp directives. Pydantic enforces the schema against Genesys Cloud assist data constraints.
from pydantic import BaseModel, Field, validator
class SurveyResponseMatrix(BaseModel):
"""Represents a single question response within the survey matrix."""
question_id: str
response_value: Any
response_type: str = Field(..., regex="^(text|numeric|rating|choice)$")
class SurveySubmissionPayload(BaseModel):
"""Validates the complete survey result payload against Genesys Cloud constraints."""
survey_template_id: str
agent_id: str
conversation_id: str
responses: List[SurveyResponseMatrix]
submitted_at: str = Field(default_factory=lambda: datetime.now(timezone.utc).isoformat())
source: str = "agent_assist"
@validator("survey_template_id")
def validate_template_format(cls, v: str) -> str:
if not v.isalnum():
raise ValueError("Survey template ID must be alphanumeric.")
return v
@validator("responses")
def validate_response_completeness(cls, v: List[SurveyResponseMatrix]) -> List[SurveyResponseMatrix]:
if len(v) < 1:
raise ValueError("Submission must contain at least one response entry.")
return v
Step 2: Frequency Limits and Duplicate Verification
Genesys Cloud enforces maximum submission frequency limits per agent and conversation. The following logic maintains a sliding window cache to prevent duplicate submissions and rate-limit violations before the request reaches the API.
from collections import defaultdict
import uuid
class SubmissionGuard:
def __init__(self, max_submissions_per_hour: int = 10):
self.max_per_hour = max_per_hour
self.submission_log: Dict[str, List[float]] = defaultdict(list)
self.processed_correlation_ids: set = set()
def check_frequency_and_duplicates(self, agent_id: str, correlation_id: str) -> bool:
"""Returns True if the submission is allowed. Raises ValueError otherwise."""
if correlation_id in self.processed_correlation_ids:
raise ValueError(f"Duplicate submission detected for correlation ID: {correlation_id}")
current_time = time.time()
window_start = current_time - 3600
# Prune old entries
self.submission_log[agent_id] = [
ts for ts in self.submission_log[agent_id] if ts > window_start
if len(self.submission_log[agent_id]) >= self.max_per_hour:
raise ValueError(f"Maximum submission frequency exceeded for agent: {agent_id}")
# Record attempt
self.submission_log[agent_id].append(current_time)
self.processed_correlation_ids.add(correlation_id)
return True
Step 3: Atomic Submission and WebSocket Event Synchronization
Survey results are submitted via an atomic POST operation to /api/v2/surveys/results. The operation includes an idempotency key to guarantee exactly-once delivery. Immediately after submission, a WebSocket connection subscribes to ingestion events to verify result processing and trigger automatic score calculations.
import websockets
import asyncio
import json
import logging
class SurveySubmitter:
def __init__(self, auth: GenesysAuth, org_domain: str):
self.auth = auth
self.base_url = f"https://api.{org_domain}"
self.ws_url = f"wss://api.{org_domain}/api/v2/events"
self.guard = SubmissionGuard(max_submissions_per_hour=10)
self.audit_log = []
def submit_result(self, payload: SurveySubmissionPayload, correlation_id: str) -> dict:
"""Submits the survey result and returns the API response."""
self.guard.check_frequency_and_duplicates(payload.agent_id, correlation_id)
start_time = time.time()
headers = {
"Authorization": f"Bearer {self.auth.get_token()}",
"Idempotency-Key": correlation_id,
"x-genesys-locale": "en-US"
url = f"{self.base_url}/api/v2/surveys/results"
response = requests.post(url, json=payload.dict(), headers=headers, timeout=10)
retry_after = int(response.headers.get("Retry-After", 2))
logger.warning(f"Rate limited. Retrying in {retry_after} seconds.")
time.sleep(retry_after)
result = response.json()
# Audit logging
self.audit_log.append({
"correlation_id": correlation_id,
"agent_id": payload.agent_id,
"conversation_id": payload.conversation_id,
"status": "success",
"timestamp": datetime.now(timezone.utc).isoformat()
return result
error_response = e.response.json() if e.response.content else {}
raise RuntimeError(f"Submission failed: {error_response}") from e
WebSocket synchronization runs asynchronously to listen for Genesys Cloud ingestion confirmations.
async def listen_for_ingestion_events(self, target_conversation_id: str, callback_url: str):
"""Connects to the Genesys Cloud Events WebSocket and syncs ingestion results."""
auth_token = self.auth.get_token()
headers = {"Authorization": f"Bearer {auth_token}"}
async with websockets.connect(self.ws_url, extra_headers=headers) as ws:
# Subscribe to survey result events
subscription = {
"type": "subscribe",
"topics": ["survey:result:created", "survey:result:updated"]
await ws.send(json.dumps(subscription))
logger.info("WebSocket subscribed to survey ingestion events.")
while True:
message = await asyncio.wait_for(ws.recv(), timeout=30.0)
event_data = json.loads(message)
if event_data.get("type") == "event":
event_body = event_data.get("event", {})
conversation_id = event_body.get("conversationId")
if conversation_id == target_conversation_id:
logger.info(f"Ingestion confirmed for conversation: {conversation_id}")
await self._trigger_qa_webhook(event_body, callback_url)
except asyncio.TimeoutError:
except websockets.exceptions.ConnectionClosed:
logger.warning("WebSocket connection closed. Reconnecting...")
break
Step 4: Webhook Synchronization, Latency Tracking, and Audit Export
The pipeline exposes a method to push validated ingestion events to external quality assurance platforms. It also provides a structured audit export for feedback governance.
async def _trigger_qa_webhook(self, event_data: dict, webhook_url: str):
"""Synchronizes ingestion events with external QA platforms."""
webhook_payload = {
"source": "genesys_cloud_survey",
"event_type": "survey_ingested",
"data": event_data,
"sync_timestamp": datetime.now(timezone.utc).isoformat()
async with aiohttp.ClientSession() as session:
async with session.post(webhook_url, json=webhook_payload, timeout=5) as resp:
if resp.status != 200:
logger.error(f"Webhook sync failed: {resp.status}")
else:
logger.info("QA platform synchronized successfully.")
logger.error(f"Webhook delivery failed: {e}")
def get_audit_report(self) -> list:
"""Returns the complete audit log for governance compliance."""
return self.audit_log
def calculate_response_rate(self, total_expected: int) -> float:
"""Calculates submission success rate based on audit logs."""
if total_expected == 0:
return 0.0
successful = len([log for log in self.audit_log if log["status"] == "success"])
return (successful / total_expected) * 100.0
The following script integrates all components into a single executable module. Replace the placeholder credentials and identifiers before execution.
import asyncio
import logging
import sys
# Configure logging
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
# Initialize authentication
AUTH = GenesysAuth(
client_id="YOUR_CLIENT_ID",
client_secret="YOUR_CLIENT_SECRET",
org_domain="mypurecloud.com"
# Initialize submitter
SUBMITTER = SurveySubmitter(auth=AUTH, org_domain="mypurecloud.com")
def run_submission_pipeline():
correlation_id = str(uuid.uuid4())
# Construct payload
payload = SurveySubmissionPayload(
survey_template_id="8f3a9b2c-1d4e-5f6a-7b8c-9d0e1f2a3b4c",
agent_id="agent-10293847",
conversation_id="conv-5566778899",
responses=[
SurveyResponseMatrix(question_id="q1_satisfaction", response_value=4, response_type="rating"),
SurveyResponseMatrix(question_id="q2_resolution", response_value="Yes", response_type="choice"),
SurveyResponseMatrix(question_id="q3_comments", response_value="Call handled efficiently.", response_type="text")
result = SUBMITTER.submit_result(payload, correlation_id)
print(f"Submission successful. Result ID: {result.get('id')}")
# Trigger async WebSocket listener and webhook sync
asyncio.run(SUBMITTER.listen_for_ingestion_events(
target_conversation_id=payload.conversation_id,
callback_url="https://qa-platform.example.com/api/v1/survey-sync"
# Export audit and metrics
audit = SUBMITTER.get_audit_report()
print(f"Audit log entries: {len(audit)}")
print(f"Response rate: {SUBMITTER.calculate_response_rate(1):.2f}%")
except (ValueError, RuntimeError, requests.exceptions.RequestException) as e:
logging.error(f"Pipeline execution failed: {e}")
sys.exit(1)
- Cause: The OAuth token has expired or the client credentials are invalid.
- Fix: Verify the
client_idandclient_secret. Ensure theGenesysAuthclass refreshes the token before each request. The implementation includes a 60-second buffer before expiry to prevent mid-request failures.
Error: 403 Forbidden
- Cause: The OAuth client lacks the
survey:writeorevents:readscope. - Fix: Navigate to the Genesys Cloud Admin console, locate the OAuth client configuration, and append the missing scopes. Regenerate the token after scope modification.
Error: 409 Conflict or Duplicate Key
- Cause: The
Idempotency-Keyheader was reused with a different payload, or the guard logic detected a duplicate correlation ID. - Fix: Generate a fresh UUID for each submission attempt. If retrying after a timeout, reuse the exact same
Idempotency-Keyand payload to guarantee exactly-once processing.
- Cause: The submission frequency exceeded Genesys Cloud rate limits or the local
SubmissionGuardthreshold. - Fix: The code automatically extracts the
Retry-Afterheader and pauses execution. For high-volume environments, increase themax_submissions_per_hourparameter inSubmissionGuardor implement exponential backoff.
Error: WebSocket Connection Refused
- Cause: The tenant does not have the Events API enabled, or the
events:readscope is missing. - Fix: Verify feature entitlements in the Genesys Cloud portal. Ensure the WebSocket connection string matches the tenant domain exactly.
