Submit and Manage Genesys Cloud Recording Transcriptions via Python SDK
A production-ready Python module that submits transcription jobs for Genesys Cloud recordings, validates media constraints, processes diarization and confidence scores, tracks latency, generates audit logs, and syncs results via webhooks. This uses the Genesys Cloud Media API and the official genesyscloud Python SDK. The tutorial covers Python 3.9+.
- OAuth2 Client Credentials flow with scopes:
media:recording:read,media:recording:transcribe,webhook:manage genesyscloudSDK >= 2.40.0- Python 3.9+
- External dependencies:
pip install httpx pydantic python-dotenv
The Genesys Cloud Python SDK handles token caching and automatic refresh when initialized with client credentials. You must configure the environment variables for your OAuth client.
import os
from genesyscloud.platform_client_v2 import PureCloudPlatformClientV2
def init_genesys_client() -> PureCloudPlatformClientV2:
"""Initialize the Genesys Cloud platform client with automatic token refresh."""
client = PureCloudPlatformClientV2()
client.set_access_token(os.getenv("GENESYS_ACCESS_TOKEN"))
return client
For client credentials flow, generate the initial token using the SDK or a separate OAuth script. The SDK maintains the token in memory and refreshes it automatically before expiration.
Step 1: Fetch Recording Metadata and Validate Constraints
Before submitting a transcription job, you must verify the recording meets format requirements and duration limits. Genesys Cloud enforces a maximum duration of 240 minutes for transcription jobs. You must also check for corrupted audio markers by comparing declared duration against file size and verifying the recording status.
import httpx
from typing import Dict, Any
from datetime import datetime
MAX_DURATION_MINUTES = 240
SUPPORTED_FORMATS = {"wav", "mp3"}
def validate_recording(client: PureCloudPlatformClientV2, recording_id: str) -> Dict[str, Any]:
"""Fetch recording metadata and validate against transcription constraints."""
media_api = client.media_api
response = media_api.get_media_recordings_recording_id(recording_id)
recording = response.to_dict()
if recording["status"] != "ready":
raise ValueError(f"Recording status is {recording['status']}. Must be ready.")
duration_ms = recording.get("durationMs", 0)
duration_min = duration_ms / 60000
if duration_min > MAX_DURATION_MINUTES:
raise ValueError(f"Duration {duration_min:.2f} min exceeds {MAX_DURATION_MINUTES} min limit.")
file_format = recording.get("fileFormat", "").lower()
if file_format not in SUPPORTED_FORMATS:
raise ValueError(f"Unsupported format: {file_format}. Supported: {SUPPORTED_FORMATS}")
file_size = recording.get("fileSize", 0)
if duration_ms > 0 and file_size < (duration_ms * 0.001):
raise ValueError("Potential corrupted audio: file size is too small for declared duration.")
return recording
Step 2: Construct Transcription Payload and Submit Atomic POST
The transcription request requires a recordingRef object, a languageCode, and a process directive. You will map a language-matrix to a primary code and fallback list, then submit the payload via an atomic HTTP POST. This ensures format verification and triggers automatic storage upon success.
import json
from httpx import HTTPError
def build_transcription_payload(
recording_id: str,
primary_language: str,
language_matrix: list[str],
enable_diarization: bool = True,
confidence_threshold: float = 0.75
"""Construct the transcription request body with schema validation."""
if not primary_language or len(primary_language) < 2:
raise ValueError("Invalid primary language code.")
"recordingRef": {
"id": recording_id,
"type": "recording"
"languageCode": primary_language,
"process": "start",
"speakerDiarization": enable_diarization,
"confidenceThreshold": confidence_threshold,
"customData": {
"languageMatrix": language_matrix,
"submittedAt": datetime.utcnow().isoformat(),
"auditId": f"tx_{int(time.time())}"
def submit_transcription_job(
payload: Dict[str, Any],
base_url: str
"""Submit transcription job via atomic HTTP POST with retry logic for 429."""
token = client.get_access_token()
headers = {
"Accept": "application/json"
url = f"{base_url}/api/v2/media/recording/transcribe"
max_retries = 3
with httpx.Client(timeout=30.0) as http_client:
response = http_client.post(url, headers=headers, json=payload)
response.raise_for_status()
return response.json()
except HTTPError as e:
if response.status_code == 429 and attempt < max_retries - 1:
retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
print(f"Rate limited. Retrying in {retry_after}s...")
time.sleep(retry_after)
else:
raise RuntimeError(f"HTTP {response.status_code}: {response.text}") from e
Step 3: Process Results, Diarization, and Confidence Evaluation
After submission, the API returns a transcriptionId. You must poll the result endpoint, extract speaker segments, evaluate confidence scores against your threshold, and trigger an automatic store webhook for external search synchronization.
def evaluate_transcription_result(result: Dict[str, Any], confidence_threshold: float) -> Dict[str, Any]:
"""Process diarization segments and filter by confidence score."""
segments = result.get("segments", [])
filtered_segments = []
total_confidence = 0.0
for seg in segments:
conf = seg.get("confidence", 0.0)
speaker = seg.get("speaker", "unknown")
text = seg.get("text", "")
if conf >= confidence_threshold:
filtered_segments.append({
"speaker": speaker,
"text": text,
"confidence": conf,
"startMs": seg.get("startMs"),
"endMs": seg.get("endMs")
total_confidence += conf
avg_confidence = total_confidence / len(filtered_segments) if filtered_segments else 0.0
"acceptedSegments": filtered_segments,
"rejectedSegmentsCount": len(segments) - len(filtered_segments),
"averageConfidence": round(avg_confidence, 4)
def trigger_store_webhook(webhook_url: str, transcription_id: str, processed_data: Dict[str, Any]) -> None:
"""Send completed transcription to external search via webhook."""
payload = {
"transcriptionId": transcription_id,
"status": "completed",
"processedAt": datetime.utcnow().isoformat(),
"data": processed_data
with httpx.Client(timeout=15.0) as client:
resp = client.post(webhook_url, json=payload, headers={"Content-Type": "application/json"})
if resp.status_code not in (200, 202):
print(f"Webhook sync failed: {resp.status_code} {resp.text}")
Step 4: Latency Tracking, Audit Logging, and Process Validation
You must track submission-to-completion latency, log governance data, and expose a unified transcriber class for automated management. The class below orchestrates validation, submission, polling, and auditing.
class RecordingTranscriber:
def __init__(self, client: PureCloudPlatformClientV2, base_url: str, webhook_url: str):
self.client = client
self.base_url = base_url
self.audit_log = []
def transcribe(self, recording_id: str, primary_lang: str, lang_matrix: list[str], threshold: float = 0.75) -> Dict[str, Any]:
start_time = time.time()
audit_entry = {
"recordingId": recording_id,
"action": "transcription_started",
"timestamp": datetime.utcnow().isoformat(),
"status": "pending"
# Step 1: Validate
validate_recording(self.client, recording_id)
audit_entry["status"] = "validated"
# Step 2: Submit
payload = build_transcription_payload(recording_id, primary_lang, lang_matrix, confidence_threshold=threshold)
job = submit_transcription_job(self.client, payload, self.base_url)
transcription_id = job.get("transcriptionId")
audit_entry["transcriptionId"] = transcription_id
audit_entry["status"] = "submitted"
# Step 3: Poll and Process
result = self._poll_transcription(transcription_id)
processed = evaluate_transcription_result(result, threshold)
latency = time.time() - start_time
audit_entry["latencyMs"] = round(latency * 1000, 2)
audit_entry["status"] = "completed"
audit_entry["success"] = True
# Step 4: Sync and Store
trigger_store_webhook(self.webhook_url, transcription_id, processed)
self.audit_log.append(audit_entry)
"latencyMs": audit_entry["latencyMs"],
"processedData": processed,
"auditEntry": audit_entry
audit_entry["status"] = "failed"
audit_entry["error"] = str(e)
audit_entry["success"] = False
raise
def _poll_transcription(self, transcription_id: str, max_wait: int = 300, interval: int = 5) -> Dict[str, Any]:
"""Poll transcription status until complete or timeout."""
token = self.client.get_access_token()
url = f"{self.base_url}/api/v2/media/recording/transcribe/{transcription_id}"
headers = {"Authorization": f"Bearer {token}", "Accept": "application/json"}
elapsed = 0
while elapsed < max_wait:
resp = client.get(url, headers=headers)
resp.raise_for_status()
data = resp.json()
if data.get("status") in ("completed", "failed"):
return data
time.sleep(interval)
elapsed += interval
raise TimeoutError("Transcription job did not complete within timeout.")
import os
load_dotenv()
def main():
client = init_genesys_client()
base_url = os.getenv("GENESYS_ENVIRONMENT", "https://api.mypurecloud.com")
webhook_url = os.getenv("EXTERNAL_SEARCH_WEBHOOK")
recording_id = os.getenv("TARGET_RECORDING_ID")
transcriber = RecordingTranscriber(client, base_url, webhook_url)
result = transcriber.transcribe(
recording_id=recording_id,
primary_lang="en-US",
lang_matrix=["en-GB", "en-AU"],
threshold=0.80
print("Transcription successful.")
print(f"Latency: {result['latencyMs']}ms")
print(f"Average Confidence: {result['processedData']['averageConfidence']}")
print(f"Accepted Segments: {len(result['processedData']['acceptedSegments'])}")
print(f"Transcription failed: {e}")
finally:
# Export audit logs for media governance
with open("transcription_audit.json", "w") as f:
import json
json.dump(transcriber.audit_log, f, indent=2)
print("Audit log exported.")
main()
Error: 400 Bad Request
- What causes it: Invalid
languageCode, missingrecordingRef.id, orprocessdirective mismatch. - How to fix it: Verify the language code matches BCP 47 standards. Ensure
processis exactly"start". Validate the recording exists and is inreadystatus before submission. - Code showing the fix: The
build_transcription_payloadfunction validates the primary language length and structure. Thevalidate_recordingfunction checks status and format before payload generation.
- What causes it: Exceeding Genesys Cloud API rate limits for transcription submissions.
- How to fix it: Implement exponential backoff. The
submit_transcription_jobfunction reads theRetry-Afterheader and delays subsequent attempts up to three times. - Code showing the fix: See the retry loop in
submit_transcription_jobwhich catchesHTTPErrorand sleeps based onRetry-After.
Error: 404 Not Found
- What causes it: The
recordingIddoes not exist in the tenant or the user lacksmedia:recording:readscope. - How to fix it: Verify the recording ID via the Genesys Cloud admin console or
GET /api/v2/media/recordings. Ensure the OAuth token includesmedia:recording:read. - Code showing the fix: The
validate_recordingmethod fetches the recording first. If the ID is invalid, the SDK raises a404exception immediately before payload construction.
Error: 500 Internal Server Error or Corrupted Audio
- What causes it: The media file is malformed, or the transcription engine fails to decode the audio stream.
- How to fix it: Check the
fileSizeagainstdurationMs. If the file size is disproportionately small, the recording is likely corrupted. Re-download or regenerate the recording. - Code showing the fix: The validation step compares
file_size < (duration_ms * 0.001)to detect truncated files. The audit log recordsstatus: failedwith the specific error payload.
