Stuck on OAuth Token Refresh Rate Limits in Load Test
Stuck on a 429 Too Many Requests error when simulating 500 concurrent user logins via the API. The JMeter script hits /api/v2/oauth/token and fails after ~50 requests/sec.
“The OAuth token endpoint enforces strict rate limits to prevent brute force attacks.”
Is there a specific header or parameter to bypass this for valid load testing? We need to validate session handling at scale. Using SDK 1.15.2.
If I remember correctly… this limit is hard-coded at the API gateway level for security. You cannot bypass it with a header. In Zendesk, we often just fired off concurrent ticket updates, but Genesys Cloud OAuth is strictly guarded to prevent brute force.
For load testing, do not simulate real-time logins for every virtual user. Instead, pre-generate a pool of valid tokens and rotate them. This mimics the session behavior without hitting the auth endpoint repeatedly.
# Pseudo-code for token rotation in JMeter/Python
token_pool = [gen_token() for _ in range(1000)]
current_idx = 0
def get_token():
 global current_idx
 token = token_pool[current_idx]
 current_idx = (current_idx + 1) % len(token_pool)
 return token
This approach keeps your test focused on downstream interaction handling rather than auth infrastructure. It aligns better with how Genesys Cloud manages session persistence compared to the stateless nature of some Zendesk API calls. Try pooling tokens to see if the 429s disappear.
I think the rate limiting on the OAuth endpoint is indeed strict to prevent brute force attacks, as noted in the previous post. However, for legal discovery workflows involving bulk data extraction, we often face similar constraints when automating credential rotation for secure S3 uploads. The key is to decouple authentication from the main data transfer loop.
Here is a safer approach for your load test:
  • Generate a pool of long-lived access tokens using the client credentials flow beforehand.
  • Store these tokens in a secure, in-memory cache or a local file within your test environment.
  • Configure your JMeter script to pick tokens from this pool randomly or in round-robin fashion.
  • Implement a simple renewal job that refreshes only 10-20% of the pool every hour, rather than refreshing per request.
This method maintains session validity without triggering the 429 errors. It also mirrors how production systems should handle token management for bulk export jobs, ensuring the audit trail remains intact while reducing load on the authentication service.
