Streaming NICE CXone Voice IVR Audio Prompts via Voice API with Python
- A Python module that constructs, validates, and streams IVR audio prompts to active CXone Voice sessions using the Voice API.
- This implementation uses the CXone Voice REST API with
httpxfor async HTTP operations andpydanticfor strict schema validation. - The code is written in Python 3.9+ and handles authentication, payload construction, atomic transmission, callback synchronization, and audit logging.
- OAuth Client Type: Confidential client with
client_credentialsgrant - Required Scopes:
voice:streams:write,voice:streams:read,media:prompts:read,voice:metrics:read - SDK/API Version: CXone Platform API v2, Voice API v2
- Language/Runtime: Python 3.9+
- External Dependencies:
httpx>=0.25.0,pydantic>=2.5.0,python-dotenv>=1.0.0,structlog>=24.1.0
CXone uses OAuth 2.0 for API authentication. The following implementation fetches an access token, caches it, and handles expiration. The token endpoint requires client credentials and returns a JWT valid for approximately one hour.
import httpx
from typing import Optional
import os
load_dotenv()
class ConeAuthManager:
def __init__(self, client_id: str, client_secret: str, base_url: str):
self.client_id = client_id
self._expires_at: float = 0.0
self._http = httpx.Client(timeout=15.0)
def _fetch_token(self) -> str:
url = f"{self.base_url}/api/oauth2/token"
payload = {
"client_id": self.client_id,
"scope": "voice:streams:write voice:streams:read media:prompts:read voice:metrics:read"
response = self._http.post(url, data=payload)
response.raise_for_status()
data = response.json()
self._token = data["access_token"]
self._expires_at = time.time() + (data["expires_in"] - 30)
return self._token
def get_token(self) -> str:
if not self._token or time.time() >= self._expires_at:
return self._fetch_token()
return self._token
Step 1: Stream Payload Construction and Schema Validation
The Voice API requires strict payload formatting. You must define prompt URLs, playback speed matrices, DTMF collection directives, and duration limits. The following Pydantic models enforce media engine constraints before transmission.
from pydantic import BaseModel, Field, field_validator
from enum import Enum
class PlaybackSpeedProfile(str, Enum):
STANDARD = "1.0"
SLOW = "0.75"
FAST = "1.25"
VERY_FAST = "1.5"
class DTMFDirective(BaseModel):
enabled: bool = True
max_digits: int = Field(default=4, ge=1, le=10)
terminator: str = Field(default="#", pattern=r"^[\d#*]$")
timeout_ms: int = Field(default=5000, ge=1000, le=30000)
class StreamPayload(BaseModel):
stream_id: str
prompt_url: str = Field(..., pattern=r"^https?://")
playback_speed: PlaybackSpeedProfile = PlaybackSpeedProfile.STANDARD
dtmf: DTMFDirective = Field(default_factory=DTMFDirective)
max_duration_seconds: int = Field(default=300, ge=1, le=600)
codec: str = Field(default="G711ULAW", pattern=r"^(G711ULAW|G711ALAW|OPUS|AAC)$")
jitter_buffer_ms: int = Field(default=40, ge=20, le=200)
callback_url: Optional[str] = Field(None, pattern=r"^https?://")
@field_validator("max_duration_seconds")
@classmethod
def validate_duration_limit(cls, v: int) -> int:
if v > 600:
raise ValueError("CXone media engine enforces a 600-second maximum stream duration.")
return v
@field_validator("jitter_buffer_ms")
@classmethod
def validate_jitter_pipeline(cls, v: int) -> int:
if v < 20 or v > 200:
raise ValueError("Jitter buffer must be between 20ms and 200ms to prevent audio distortion.")
return v
Step 2: Atomic PUT Transmission with Format Verification and Buffer Flush
Audio transmission uses an atomic PUT operation to the Voice API. The implementation verifies the response format, triggers an automatic buffer flush when required, and implements retry logic for 429 rate limits.
import logging
import random
from typing import Dict, Any
logger = logging.getLogger("cone_voice_streamer")
class ConeVoiceStreamer:
def __init__(self, auth: ConeAuthManager):
self.auth = auth
self.base_url = auth.base_url
self._http = httpx.Client(timeout=30.0)
def _retry_on_rate_limit(self, method: str, url: str, json_data: Dict[str, Any]) -> httpx.Response:
max_retries = 3
token = self.auth.get_token()
headers = {
"Accept": "application/json"
response = self._http.request(method, url, json=json_data, headers=headers)
retry_after = int(response.headers.get("Retry-After", 2))
logger.warning(f"Rate limit hit. Retrying in {retry_after}s (attempt {attempt + 1}/{max_retries})")
time.sleep(retry_after + random.uniform(0.1, 0.5))
return response
raise RuntimeError("Maximum retry attempts exceeded due to rate limiting.")
def transmit_stream(self, payload: StreamPayload) -> Dict[str, Any]:
url = f"{self.base_url}/api/v2/voice/streams/{payload.stream_id}"
logger.info(f"Initiating atomic PUT to {url}")
response = self._retry_on_rate_limit("PUT", url, payload.model_dump())
result = response.json()
if result.get("status") != "streaming":
raise ValueError(f"Stream initialization failed with status: {result.get('status')}")
return result
def trigger_buffer_flush(self, stream_id: str) -> Dict[str, Any]:
url = f"{self.base_url}/api/v2/voice/streams/{stream_id}/flush"
logger.info(f"Triggering automatic buffer flush for stream {stream_id}")
response = self._retry_on_rate_limit("POST", url, {})
return response.json()
Step 3: TTS Callback Synchronization, Metrics Tracking, and Audit Logging
The final component handles external TTS provider synchronization via callback handlers, tracks streaming latency and completion success rates, and generates structured audit logs for prompt governance.
import structlog
structlog.configure(
processors=[
structlog.processors.add_log_level,
structlog.processors.TimeStamper(fmt="iso"),
structlog.processors.JSONRenderer()
logger_factory=structlog.PrintLoggerFactory(),
class PromptStreamerOrchestrator:
self.auth = auth
self.streamer = ConeVoiceStreamer(auth)
self.audit_log = structlog.get_logger()
self.metrics_store: List[Dict[str, Any]] = []
def _record_metric(self, stream_id: str, event_type: str, latency_ms: float, success: bool) -> None:
metric = {
"stream_id": stream_id,
"event_type": event_type,
"latency_ms": latency_ms,
"success": success,
"timestamp": datetime.now(timezone.utc).isoformat()
self.metrics_store.append(metric)
self.audit_log.info("stream_metric_recorded", **metric)
def _sync_tts_callback(self, stream_id: str, callback_url: Optional[str]) -> bool:
if not callback_url:
return True
response = httpx.post(
callback_url,
json={"stream_id": stream_id, "status": "synced", "timestamp": datetime.now(timezone.utc).isoformat()},
timeout=5.0
return True
self.audit_log.error("tts_callback_failed", stream_id=stream_id, error=str(e))
return False
def stream_prompt(self, payload: StreamPayload) -> Dict[str, Any]:
start_time = time.time()
self.audit_log.info("stream_operation_start", stream_id=payload.stream_id, prompt_url=payload.prompt_url)
transmission_result = self.streamer.transmit_stream(payload)
transmission_latency = (time.time() - start_time) * 1000
self._record_metric(payload.stream_id, "transmission", transmission_latency, True)
flush_start = time.time()
flush_result = self.streamer.trigger_buffer_flush(payload.stream_id)
flush_latency = (time.time() - flush_start) * 1000
self._record_metric(payload.stream_id, "buffer_flush", flush_latency, True)
tts_synced = self._sync_tts_callback(payload.stream_id, payload.callback_url)
final_result = {
"transmission": transmission_result,
"flush": flush_result,
"tts_synced": tts_synced,
"total_latency_ms": transmission_latency + flush_latency
self.audit_log.info("stream_operation_complete", stream_id=payload.stream_id, **final_result)
return final_result
failure_latency = (time.time() - start_time) * 1000
self._record_metric(payload.stream_id, "failure", failure_latency, False)
self.audit_log.error("stream_operation_failed", stream_id=payload.stream_id, error=str(e))
raise
def get_completion_success_rate(self) -> float:
if not self.metrics_store:
return 0.0
transmissions = [m for m in self.metrics_store if m["event_type"] == "transmission"]
if not transmissions:
return 0.0
successful = sum(1 for m in transmissions if m["success"])
return (successful / len(transmissions)) * 100.0
The following script demonstrates the full workflow from authentication to prompt streaming, metrics retrieval, and audit log generation. Replace the environment variables with your CXone tenant credentials.
import os
import logging
load_dotenv()
def main():
client_id = os.getenv("CXONE_CLIENT_ID")
client_secret = os.getenv("CXONE_CLIENT_SECRET")
tenant_url = os.getenv("CXONE_TENANT_URL", "https://api.us-east-1.my.niceincontact.com")
raise ValueError("CXONE_CLIENT_ID and CXONE_CLIENT_SECRET must be set in environment.")
auth = ConeAuthManager(client_id, client_secret, tenant_url)
orchestrator = PromptStreamerOrchestrator(auth)
prompt_config = StreamPayload(
stream_id="ivr-main-menu-stream-001",
prompt_url="https://secure-storage.nicecxone.com/prompts/main-menu-welcome.wav",
playback_speed=PlaybackSpeedProfile.STANDARD,
dtmf=DTMFDirective(enabled=True, max_digits=3, terminator="#", timeout_ms=4000),
max_duration_seconds=120,
codec="G711ULAW",
jitter_buffer_ms=40,
callback_url="https://my-tts-provider.com/webhook/cxone-sync"
result = orchestrator.stream_prompt(prompt_config)
print(f"Stream initiated successfully. Total latency: {result['total_latency_ms']:.2f}ms")
print(f"TTS Provider Synced: {result['tts_synced']}")
print(f"Streaming failed: {e}")
success_rate = orchestrator.get_completion_success_rate()
print(f"Current transmission success rate: {success_rate:.2f}%")
main()
- Cause: Expired OAuth token or invalid client credentials.
- Fix: Verify
CXONE_CLIENT_IDandCXONE_CLIENT_SECRETmatch a confidential client registered in CXone. Ensure theConeAuthManagerrefreshes the token before expiration. The implementation automatically refetches whentime.time() >= self._expires_at.
Error: 403 Forbidden
- Cause: Missing OAuth scopes or insufficient API permissions on the client.
- Fix: Add
voice:streams:writeandvoice:streams:readto the client scope configuration in the CXone admin console. The token request explicitly requests these scopes.
Error: 422 Unprocessable Entity
- Cause: Payload violates media engine constraints (duration over 600s, invalid codec, malformed DTMF terminator).
- Fix: Review the
StreamPayloadvalidation errors. Thefield_validatormethods enforce limits before the HTTP request is sent. Adjustmax_duration_secondsto 600 or less and ensurecodecmatchesG711ULAW,G711ALAW,OPUS, orAAC.
- Cause: Exceeding CXone API rate limits during high-volume IVR scaling.
- Fix: The
_retry_on_rate_limitmethod implements exponential backoff with jitter. If failures persist, implement client-side request queuing or reduce concurrent stream initiation frequency.
- Cause: Media engine buffer corruption or unsupported audio format at the prompt URL.
- Fix: Verify the
prompt_urlreturns a valid WAV or MP3 file with headers matching the declaredcodec. Use thetrigger_buffer_flushmethod to clear stale media buffers before retrying.
