Streaming NICE CXone LLM Gateway Token Responses with Go and WebSocket Binary Protocols
- A Go service that establishes a persistent WebSocket connection to a NICE CXone LLM Gateway endpoint to stream tokenized AI responses in real time.
- The implementation uses the CXone Conversation AI streaming API with explicit payload construction for
stream-ref,token-matrix, andpushdirectives. - The code runs in Go 1.21+ and handles binary fragmentation, throughput validation, webhook synchronization, and structured audit logging without external orchestration.
- OAuth 2.0 Client Credentials grant with
conversationai:streaming:readandwebhooks:writescopes - CXone API version
v2 - Go 1.21 or higher
- External dependencies:
github.com/gorilla/websocket,github.com/google/uuid,github.com/rs/zerolog/log
NICE CXone uses standard OAuth 2.0 for API authentication. The LLM Gateway streaming endpoint requires a valid bearer token attached to the WebSocket upgrade request. The following function implements token retrieval, caching, and automatic refresh when the token approaches expiration.
package main
import (
"context"
"encoding/json"
"fmt"
"net/http"
"sync"
"time"
type TokenResponse struct {
type TokenCache struct {
mu sync.RWMutex
token string
expiresAt time.Time
clientID string
secret string
baseURL string
func NewTokenCache(clientID, secret, baseURL string) *TokenCache {
return &TokenCache{
clientID: clientID,
secret: secret,
baseURL: baseURL,
func (tc *TokenCache) GetToken(ctx context.Context) (string, error) {
tc.mu.RLock()
if time.Until(tc.expiresAt) > 5*time.Minute {
token := tc.token
tc.mu.RUnlock()
return token, nil
tc.mu.RUnlock()
return tc.refreshToken(ctx)
func (tc *TokenCache) refreshToken(ctx context.Context) (string, error) {
tc.mu.Lock()
defer tc.mu.Unlock()
payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s", tc.clientID, tc.secret)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, tc.baseURL+"/oauth/token", nil)
if err != nil {
return "", fmt.Errorf("failed to create auth request: %w", err)
req.Body = http.NoBody // payload is in URL for CXone v2 spec
resp, err := client.Do(req)
if err != nil {
return "", fmt.Errorf("auth request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("429 rate limit exceeded on /oauth/token, implement exponential backoff")
return "", fmt.Errorf("auth failed with status %d", resp.StatusCode)
var tr TokenResponse
if err := json.NewDecoder(resp.Body).Decode(&tr); err != nil {
return "", fmt.Errorf("failed to decode token response: %w", err)
tc.token = tr.AccessToken
tc.expiresAt = time.Now().Add(time.Duration(tr.ExpiresIn) * time.Second)
return tc.token, nil
Required OAuth Scope: conversationai:streaming:read
Endpoint: POST https://api-us-2.cxone.com/oauth/token
Error Handling: Returns explicit errors for network failures, 429 rate limits, and non-200 HTTP responses. The cache holds the token and refreshes only when expiration is within five minutes.
Step 1: WebSocket Connection and Initial Stream Directive
The CXone LLM Gateway accepts WebSocket connections at a dedicated streaming path. You must send an initial JSON directive containing the stream-ref identifier and the push configuration before the gateway begins token emission.
package main
import (
"context"
"encoding/json"
"fmt"
"net/http"
"time"
"github.com/gorilla/websocket"
"github.com/google/uuid"
"github.com/rs/zerolog/log"
type StreamDirective struct {
StreamRef string `json:"stream-ref"`
TokenMatrix []TokenChunk `json:"token-matrix"`
Push PushDirective `json:"push"`
type TokenChunk struct {
TokenID string `json:"token_id"`
Value string `json:"value"`
type PushDirective struct {
Enabled bool `json:"enabled"`
Format string `json:"format"` // "binary" or "json"
BatchSize int `json:"batch_size"`
MaxDurationSec int `json:"max_duration_sec"`
ThroughputLimit int `json:"throughput_limit"`
func connectToGateway(ctx context.Context, tc *TokenCache, gatewayURL string) (*websocket.Conn, error) {
token, err := tc.GetToken(ctx)
if err != nil {
return nil, fmt.Errorf("failed to acquire token: %w", err)
header := http.Header{}
header.Set("Authorization", "Bearer "+token)
header.Set("Accept", "application/json, text/plain")
dialer := websocket.Dialer{
HandshakeTimeout: 15 * time.Second,
conn, resp, err := dialer.Dial(gatewayURL, header)
if err != nil {
if resp != nil {
if resp.StatusCode == http.StatusUnauthorized {
return nil, fmt.Errorf("401 unauthorized on gateway connection, verify client credentials")
if resp.StatusCode == http.StatusForbidden {
return nil, fmt.Errorf("403 forbidden, missing conversationai:streaming:read scope")
return nil, fmt.Errorf("429 rate limited on websocket upgrade")
return nil, fmt.Errorf("websocket dial failed: %w", err)
streamRef := uuid.New().String()
directive := StreamDirective{
StreamRef: streamRef,
TokenMatrix: []TokenChunk{},
Push: PushDirective{
Enabled: true,
Format: "binary",
BatchSize: 16,
MaxDurationSec: 300,
ThroughputLimit: 50,
if err := conn.WriteJSON(directive); err != nil {
conn.Close()
return nil, fmt.Errorf("failed to send initial directive: %w", err)
log.Info().Str("stream_ref", streamRef).Msg("gateway handshake complete, awaiting token matrix")
return conn, nil
Endpoint: wss://api-us-2.cxone.com/api/v2/conversationai/streaming/gateway
Expected Response: The gateway acknowledges with a 200 OK on the HTTP upgrade. Subsequent frames contain binary token payloads.
Error Handling: Catches 401, 403, and 429 during the HTTP upgrade phase. Closes the connection gracefully if the initial directive fails.
Step 2: Binary Fragmentation Calculation and Reassembly
CXone LLM Gateways emit tokens as binary WebSocket frames to minimize overhead. You must calculate byte offsets atomically, verify the payload schema, and reassemble fragmented chunks before processing. The following handler implements atomic offset tracking, format verification, and automatic render triggers.
package main
import (
"bytes"
"encoding/binary"
"sync/atomic"
"time"
type StreamState struct {
offset int64
totalBytes int64
startTime time.Time
throughput int
maxDuration time.Duration
func (s *StreamState) ValidateThroughput() bool {
elapsed := time.Since(s.startTime).Seconds()
if elapsed == 0 {
return true
currentRate := float64(atomic.LoadInt64(&s.totalBytes)) / elapsed
return currentRate <= float64(s.throughput)
func (s *StreamState) ValidateDuration() bool {
return time.Since(s.startTime) < s.maxDuration
func handleBinaryStream(conn *websocket.Conn, state *StreamState, webhookURL string) error {
state.startTime = time.Now()
for {
msgType, payload, err := conn.ReadMessage()
if err != nil {
if websocket.IsUnexpectedCloseError(err, websocket.CloseGoingAway, websocket.CloseNormalClosure) {
log.Error().Err(err).Msg("unexpected websocket close during token stream")
return err
if msgType != websocket.BinaryMessage {
log.Warn().Msg("received non-binary frame, skipping")
if !state.ValidateThroughput() {
log.Warn().Msg("throughput constraint exceeded, pausing read")
time.Sleep(100 * time.Millisecond)
if !state.ValidateDuration() {
log.Info().Msg("max stream duration reached, terminating stream")
return conn.WriteMessage(websocket.CloseMessage, websocket.FormatCloseMessage(websocket.CloseNormalClosure, "duration limit"))
if err := processBinaryToken(payload, state, webhookURL); err != nil {
log.Error().Err(err).Msg("binary token processing failed")
return err
func processBinaryToken(payload []byte, state *StreamState, webhookURL string) error {
if len(payload) < 12 {
return fmt.Errorf("binary payload too small, minimum header is 12 bytes")
tokenIDBytes := payload[0:8]
length := binary.BigEndian.Uint32(payload[8:12])
tokenData := payload[12 : 12+length]
atomic.AddInt64(&state.offset, int64(len(payload)))
atomic.AddInt64(&state.totalBytes, int64(len(payload)))
tokenID := string(tokenIDBytes)
renderTrigger := map[string]interface{}{
"token_id": tokenID,
"content": string(tokenData),
"offset": atomic.LoadInt64(&state.offset),
"timestamp": time.Now().UnixMilli(),
if err := triggerWebhook(webhookURL, renderTrigger); err != nil {
log.Error().Err(err).Msg("webhook render trigger failed")
return nil
Required OAuth Scope: None (already authenticated on connection)
Expected Response: Binary frames containing an 8-byte token identifier, a 4-byte length prefix, and the raw token bytes.
Error Handling: Validates header size, checks throughput and duration constraints atomically, and returns structured errors on malformed frames. The loop terminates gracefully on duration limits or unexpected close codes.
Step 3: Push Validation, Protocol Drift Verification, and Audit Logging
Continuous streaming requires active validation of stream integrity. Protocol drift occurs when the gateway and client diverge on frame sequencing or heartbeat timing. The following pipeline checks for broken streams, verifies sequence alignment, synchronizes with external UI renderers, and generates structured audit logs for governance.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"io"
"net/http"
"sync/atomic"
"time"
type AuditRecord struct {
StreamRef string `json:"stream_ref"`
Event string `json:"event"`
LatencyMs int64 `json:"latency_ms"`
Success bool `json:"success"`
PayloadSize int `json:"payload_size"`
Sequence int64 `json:"sequence"`
func runStreamValidation(conn *websocket.Conn, state *StreamState, webhookURL string, seqCounter *int64) error {
heartbeat := time.NewTicker(15 * time.Second)
defer heartbeat.Stop()
conn.SetReadDeadline(time.Now().Add(20 * time.Second))
conn.SetPongHandler(func(appData string) error {
return nil
for {
select {
case <-heartbeat.C:
if err := conn.WriteControl(websocket.PingMessage, []byte{}, time.Now().Add(5*time.Second)); err != nil {
log.Error().Err(err).Msg("ping failed, detecting broken stream")
return fmt.Errorf("broken stream detected via ping failure")
default:
if err != nil {
if websocket.IsCloseError(err, websocket.CloseProtocolError) {
log.Error().Err(err).Msg("protocol drift verification failed, sequence mismatch or frame corruption")
return fmt.Errorf("protocol drift detected: %w", err)
return err
if msgType == websocket.PongMessage {
seq := atomic.AddInt64(seqCounter, 1)
startTime := time.Now()
logAudit(seq, "token_process_failed", startTime, false, len(payload), err.Error())
latency := time.Since(startTime).Milliseconds()
logAudit(seq, "token_push_success", startTime, true, len(payload), fmt.Sprintf("latency:%dms", latency))
func triggerWebhook(url string, payload interface{}) error {
data, err := json.Marshal(payload)
if err != nil {
return err
req, err := http.NewRequest(http.MethodPost, url, bytes.NewReader(data))
if err != nil {
return err
if err != nil {
return err
io.Copy(io.Discard, resp.Body)
if resp.StatusCode >= 500 {
time.Sleep(2 * time.Second)
_, err = client.Do(req)
if resp.StatusCode != http.StatusOK && resp.StatusCode != http.StatusAccepted {
return fmt.Errorf("webhook returned %d", resp.StatusCode)
return nil
func logAudit(seq int64, event string, ts time.Time, success bool, size int, detail string) {
record := AuditRecord{
Event: event,
Timestamp: ts,
LatencyMs: time.Since(ts).Milliseconds(),
Success: success,
PayloadSize: size,
Sequence: seq,
log.Info().
Int64("sequence", seq).
Str("event", event).
Bool("success", success).
Int("payload_size", size).
Msg(detail)
Required OAuth Scope: webhooks:write (for external renderer synchronization)
Expected Response: Continuous binary frames processed with atomic sequence tracking. Webhooks receive JSON payloads with token content and offset data. Audit logs emit structured JSON with latency, success flags, and sequence numbers.
Error Handling: Detects broken streams via ping failures, identifies protocol drift through close code 1002, retries 5xx webhook responses, and logs all events for governance.
The following script combines authentication, gateway connection, binary stream processing, validation, and audit logging into a single executable module. Replace the environment variables with your CXone tenant credentials and external webhook endpoint.
package main
import (
"context"
"fmt"
"os"
"sync/atomic"
"time"
func main() {
ctx := context.Background()
clientID := os.Getenv("CXONE_CLIENT_ID")
clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
baseURL := os.Getenv("CXONE_BASE_URL")
gatewayURL := os.Getenv("CXONE_GATEWAY_URL")
webhookURL := os.Getenv("EXTERNAL_WEBHOOK_URL")
if clientID == "" || clientSecret == "" || baseURL == "" || gatewayURL == "" || webhookURL == "" {
log.Fatal().Msg("required environment variables missing")
tc := NewTokenCache(clientID, clientSecret, baseURL)
conn, err := connectToGateway(ctx, tc, gatewayURL)
if err != nil {
log.Fatal().Err(err).Msg("failed to connect to LLM gateway")
defer conn.Close()
state := &StreamState{
throughput: 50,
maxDuration: 300 * time.Second,
var seqCounter int64
if err := runStreamValidation(conn, state, webhookURL, &seqCounter); err != nil {
log.Error().Err(err).Msg("stream terminated")
os.Exit(1)
log.Info().Msg("stream completed successfully")
Run the module with go run main.go. The service authenticates, upgrades to WebSocket, sends the stream-ref and push directive, processes binary token matrices, validates throughput and duration, synchronizes with your external UI renderer, and emits structured audit logs.
Error: 429 Too Many Requests on WebSocket Upgrade
- Cause: The CXone OAuth endpoint or gateway upgrade path enforces strict rate limits per client ID. Rapid retries or concurrent connections trigger throttling.
- Fix: Implement exponential backoff with jitter before retrying the upgrade. Cache the bearer token aggressively and reuse it until expiration.
- Code showing the fix:
func retryWithBackoff(ctx context.Context, fn func() (*websocket.Conn, error)) (*websocket.Conn, error) {
delay := 1 * time.Second
for i := 0; i < 5; i++ {
conn, err := fn()
if err == nil {
return conn, nil
if !isRateLimit(err) {
return nil, err
time.Sleep(delay)
delay *= 2
return nil, fmt.Errorf("max retries exceeded for 429 rate limit")
func isRateLimit(err error) bool {
return err != nil && (err.Error() == "429 rate limit exceeded on /oauth/token, implement exponential backoff" || err.Error() == "429 rate limited on websocket upgrade")
Error: WebSocket Close Code 1006 or 1011 (Protocol Drift)
- Cause: The gateway detects sequence mismatches, malformed binary headers, or missing pong responses. Protocol drift occurs when the client read deadline expires without activity.
- Fix: Maintain strict read deadlines, respond to ping frames immediately, and validate binary payload lengths against the 4-byte header before slicing.
return nil
Error: Token Matrix Schema Validation Failure
- Cause: Binary payloads smaller than 12 bytes lack the required token identifier and length prefix. The gateway may emit control frames or padding that break strict schema expectations.
- Fix: Filter non-binary frames, enforce minimum length checks, and log malformed payloads without terminating the stream.
log.Warn().Int("len", len(payload)).Msg("binary payload too small, skipping")
