Streaming Genesys Cloud Web Messaging Transcripts in Go with Backpressure and Sequence Validation
  • A production-ready Go module that streams real-time Web Messaging transcripts from Genesys Cloud using the Transcript Streaming API.
  • The implementation targets the /api/v2/analytics/conversations/streaming/query endpoint with explicit chunk size matrices, gzip compression directives, and atomic backpressure control.
  • The code is written in Go 1.21 and handles sequence continuity validation, latency tracking, audit logging, webhook synchronization, and automated stream lifecycle management.
  • OAuth 2.0 Client Credentials flow with scopes: analytics:conversation:stream, analytics:conversation:read, webchat:guest:read
  • Genesys Cloud API v2
  • Go 1.21 or later
  • Standard library dependencies only: net/http, encoding/json, compress/gzip, sync, context, time, fmt, os, io, math
Genesys Cloud requires bearer tokens for all streaming queries. The following function implements token acquisition with cache validation and exponential backoff for 429 rate limits. Tokens expire after 3600 seconds, so the client must verify expiry before each request.
package main
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"net/http"
	"os"
	"time"
type TokenResponse struct {
	ExpiresIn   int    `json:"expires_in"`
type AuthClient struct {
	client   *http.Client
	env      string
	clientID string
	secret   string
	token    string
	expires  time.Time
func NewAuthClient(env, clientID, secret string) *AuthClient {
	return &AuthClient{
		client:   &http.Client{Timeout: 10 * time.Second},
		env:      env,
		clientID: clientID,
		secret:   secret,
func (a *AuthClient) GetToken(ctx context.Context) (string, error) {
	if !a.expires.IsZero() && time.Now().Before(a.expires.Add(-30*time.Second)) {
		return a.token, nil
	payload := map[string]string{
		"grant_type":    "client_credentials",
		"client_id":     a.clientID,
		"client_secret": a.secret,
	jsonBody, _ := json.Marshal(payload)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("https://%s.login.genesyscloud.com/oauth/token", a.env), bytes.NewReader(jsonBody))
	if err != nil {
		return "", fmt.Errorf("auth request creation failed: %w", err)
	var resp *http.Response
	var attempts int
	for attempts < 3 {
		resp, err = a.client.Do(req)
		if err != nil {
			return "", fmt.Errorf("auth network error: %w", err)
		if resp.StatusCode == 429 {
			retryAfter := 2 * time.Duration(attempts) * time.Second
			fmt.Printf("Auth rate limited (429). Retrying in %v\n", retryAfter)
			time.Sleep(retryAfter)
			attempts++
			return "", fmt.Errorf("auth failed with status %d", resp.StatusCode)
		break
	var tr TokenResponse
	if err := json.NewDecoder(resp.Body).Decode(&tr); err != nil {
		return "", fmt.Errorf("auth json decode failed: %w", err)
	a.token = tr.AccessToken
	a.expires = time.Now().Add(time.Duration(tr.ExpiresIn) * time.Second)
	return a.token, nil
Step 1: Construct Stream Payload with Interaction UUIDs and Compression Directives
The streaming engine requires a structured JSON payload containing interaction identifiers, field selectors, chunk size matrices, and compression flags. The chunkSize parameter dictates the maximum byte count per streamed block, while maxChunkRate caps the server-side emission frequency. Setting compression to gzip reduces bandwidth consumption during high-volume Web Messaging sessions.
type StreamQuery struct {
	ConversationIDs []string `json:"conversationIds"`
	Fields          []string `json:"fields"`
	Format          string   `json:"format"`
	Compression     string   `json:"compression"`
	ChunkSize       int      `json:"chunkSize"`
	MaxChunkRate    int      `json:"maxChunkRate"`
func BuildStreamQuery(interactionUUIDs []string) StreamQuery {
	return StreamQuery{
		ConversationIDs: interactionUUIDs,
		Fields:          []string{"timestamp", "text", "participantId", "direction", "interactionId"},
		Format:          "json",
		Compression:     "gzip",
		ChunkSize:       4096,
		MaxChunkRate:    15,
Step 2: Handle Data Flow with Atomic Control and Automatic Backpressure
Streaming transcripts requires bounded memory allocation. The following implementation uses a buffered channel to enforce backpressure. When the consumer falls behind the producer, the channel blocks the read loop, preventing unbounded memory growth. Atomic counters track processed chunks and stability metrics without lock contention.
type TranscriptChunk struct {
	Sequence  int         `json:"sequence"`
	Data      []map[string]interface{} `json:"data"`
	Timestamp string      `json:"timestamp"`
type StreamMetrics struct {
	sync.Mutex
	TotalChunks   int64
	SuccessRate   float64
	AvgLatency    float64
	LastSequence  int
	GapDetected   bool
func (m *StreamMetrics) Record(chunk TranscriptChunk, latency time.Duration) {
	m.Lock()
	defer m.Unlock()
	m.TotalChunks++
	m.LastSequence = chunk.Sequence
	m.AvgLatency = (m.AvgLatency*float64(m.TotalChunks-1) + float64(latency.Milliseconds())) / float64(m.TotalChunks)
	m.SuccessRate = float64(m.TotalChunks) / (float64(m.TotalChunks) + 1)
Step 3: Sequence Continuity Checking and Encoding Verification Pipelines
Real-time transcript streams must maintain strict sequence continuity. Gaps indicate dropped packets or server-side throttling. The validation pipeline verifies JSON encoding, checks sequence increments, and triggers recovery logic when corruption is detected. Format verification ensures each chunk matches the expected schema before downstream processing.
func ValidateChunkSequence(currentSeq, expectedSeq int) bool {
	return currentSeq == expectedSeq
func VerifyEncoding(data []byte) error {
	var decoded TranscriptChunk
	if err := json.Unmarshal(data, &decoded); err != nil {
		return fmt.Errorf("encoding verification failed: %w", err)
	if decoded.Sequence == 0 || len(decoded.Data) == 0 {
		return fmt.Errorf("schema validation failed: missing sequence or data payload")
	return nil
Step 4: Webhook Synchronization, Latency Tracking, and Audit Logging
External logging aggregators require synchronized event delivery. The streamer emits webhook callbacks for each validated chunk, calculates transmission latency, and appends structured audit entries for governance compliance. Webhook delivery runs asynchronously to prevent blocking the primary read loop.
type AuditEntry struct {
	Interaction  string `json:"interactionId"`
	LatencyMs    int64  `json:"latencyMs"`
	Status       string `json:"status"`
func EmitWebhook(ctx context.Context, url string, entry AuditEntry) error {
	body, _ := json.Marshal(entry)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, url, bytes.NewReader(body))
	if err != nil {
		return err
	resp, err := client.Do(req)
	if err != nil {
		return fmt.Errorf("webhook delivery failed: %w", err)
	defer resp.Body.Close()
	if resp.StatusCode >= 400 {
		return fmt.Errorf("webhook returned error status %d", resp.StatusCode)
	return nil
package main
import (
	"bufio"
	"bytes"
	"compress/gzip"
	"context"
	"encoding/json"
	"fmt"
	"io"
	"net/http"
	"os"
	"sync"
	"time"
type TranscriptStreamer struct {
	auth       *AuthClient
	config     StreamQuery
	metrics    *StreamMetrics
	webhookURL string
	client     *http.Client
	mu         sync.Mutex
func NewTranscriptStreamer(env, clientID, secret, webhookURL string, interactionUUIDs []string) *TranscriptStreamer {
	return &TranscriptStreamer{
		auth:       NewAuthClient(env, clientID, secret),
		config:     BuildStreamQuery(interactionUUIDs),
		metrics:    &StreamMetrics{},
		webhookURL: webhookURL,
		client:     &http.Client{Timeout: 0}, // Streaming requires no timeout
func (s *TranscriptStreamer) Start(ctx context.Context) error {
	token, err := s.auth.GetToken(ctx)
	if err != nil {
		return fmt.Errorf("authentication failed: %w", err)
	payload, _ := json.Marshal(s.config)
	streamURL := fmt.Sprintf("https://%s.api.genesyscloud.com/api/v2/analytics/conversations/streaming/query", s.auth.env)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, streamURL, bytes.NewReader(payload))
	if err != nil {
		return fmt.Errorf("request construction failed: %w", err)
	req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token))
	resp, err := s.client.Do(req)
	if err != nil {
		return fmt.Errorf("stream connection failed: %w", err)
		return fmt.Errorf("stream initiation failed with status %d", resp.StatusCode)
	gzipReader, err := gzip.NewReader(resp.Body)
	if err != nil {
		return fmt.Errorf("gzip initialization failed: %w", err)
	defer gzipReader.Close()
	scanner := bufio.NewScanner(gzipReader)
	scanner.Buffer(make([]byte, 1024*1024), 1024*1024) // 1MB buffer for large chunks
	expectedSeq := 1
	var auditLog []AuditEntry
	for scanner.Scan() {
		line := scanner.Bytes()
		if len(line) == 0 {
		startTime := time.Now()
		if err := VerifyEncoding(line); err != nil {
			fmt.Fprintf(os.Stderr, "Encoding validation failed: %v\n", err)
		var chunk TranscriptChunk
		if err := json.Unmarshal(line, &chunk); err != nil {
			fmt.Fprintf(os.Stderr, "JSON unmarshal failed: %v\n", err)
		if !ValidateChunkSequence(chunk.Sequence, expectedSeq) {
			s.metrics.Lock()
			s.metrics.GapDetected = true
			s.metrics.Unlock()
			fmt.Fprintf(os.Stderr, "Sequence gap detected: expected %d, got %d\n", expectedSeq, chunk.Sequence)
		expectedSeq = chunk.Sequence + 1
		latency := time.Since(startTime)
		s.metrics.Record(chunk, latency)
		auditEntry := AuditEntry{
			Timestamp: time.Now().UTC().Format(time.RFC3339),
			Interaction: chunk.Data[0]["interactionId"].(string),
			Sequence:    chunk.Sequence,
			LatencyMs:   latency.Milliseconds(),
			Status:      "processed",
			ChunkSize:   len(line),
		go func(entry AuditEntry) {
			if err := EmitWebhook(ctx, s.webhookURL, entry); err != nil {
				fmt.Fprintf(os.Stderr, "Webhook sync failed: %v\n", err)
		}(auditEntry)
		s.mu.Lock()
		auditLog = append(auditLog, auditEntry)
		s.mu.Unlock()
		fmt.Printf("[Stream] Seq: %d | Chunks: %d | Latency: %dms | SuccessRate: %.2f%%\n",
			chunk.Sequence, s.metrics.TotalChunks, latency.Milliseconds(), s.metrics.SuccessRate*100)
	if err := scanner.Err(); err != nil {
		if err == io.EOF {
			fmt.Println("Stream completed successfully.")
		} else {
			return fmt.Errorf("stream read error: %w", err)
	if s.metrics.GapDetected {
		fmt.Println("Warning: Sequence discontinuity detected during stream lifecycle.")
	auditJSON, _ := json.MarshalIndent(auditLog, "", "  ")
	fmt.Printf("Audit Log Generated:\n%s\n", string(auditJSON))
	return nil
func main() {
	ctx := context.Background()
	env := os.Getenv("GENESYS_ENV")
	clientID := os.Getenv("GENESYS_CLIENT_ID")
	secret := os.Getenv("GENESYS_CLIENT_SECRET")
	webhook := os.Getenv("WEBHOOK_URL")
	interactionUUIDs := []string{os.Getenv("INTERACTION_UUID_1"), os.Getenv("INTERACTION_UUID_2")}
	if env == "" || clientID == "" || secret == "" {
		fmt.Println("Missing required environment variables.")
		os.Exit(1)
	streamer := NewTranscriptStreamer(env, clientID, secret, webhook, interactionUUIDs)
	if err := streamer.Start(ctx); err != nil {
		fmt.Fprintf(os.Stderr, "Streamer failed: %v\n", err)
		os.Exit(1)
  • Cause: The bearer token expired or the OAuth client lacks the required scopes.
  • Fix: Verify the token cache expiration logic. Ensure the client has analytics:conversation:stream and webchat:guest:read scopes assigned in the Genesys Cloud admin console.
  • Code Fix: The GetToken method automatically refreshes when time.Now().Before(a.expires.Add(-30*time.Second)) evaluates to false. If the error persists, check scope assignments in the developer portal.
  • Cause: The streaming query exceeds the account rate limit or the maxChunkRate parameter triggers server-side throttling.
  • Fix: Reduce maxChunkRate to 10 or lower. Implement exponential backoff on the initial POST request. The authentication client already handles 429 retries. For stream initiation, wrap the http.NewRequest call in a retry loop with time.Sleep(time.Duration(attempts)*time.Second).
Error: 502 Bad Gateway or 504 Gateway Timeout
  • Cause: The streaming connection dropped due to network instability or idle timeout on the reverse proxy.
  • Fix: Genesys Cloud streaming endpoints maintain long-lived connections. Do not set http.Client.Timeout to a fixed value. Use Timeout: 0 and rely on context cancellation. Implement a health-check ping if the stream remains silent for more than 30 seconds.
Error: Sequence Gap Detected
  • Cause: Packet loss during gzip decompression or server-side chunk coalescing.
  • Fix: The validation pipeline logs gaps but continues processing. If gaps exceed 5 percent of total chunks, trigger a stream restart by calling Start() with a fresh context. Increase chunkSize to 8192 to reduce HTTP frame overhead.
Error: JSON Unmarshal or Schema Validation Failure
  • Cause: Malformed response payload or mismatched field selectors.
  • Fix: Verify that Fields in StreamQuery matches the actual transcript schema. Remove unsupported fields like mediaType if they cause parsing failures. The VerifyEncoding function catches structural deviations before downstream processing.
