Hi, I am trying to create a strategy that says:
If ExpectecWaitingTime >60 Play xxxxxx
My problem is that
SData([email removed],StatExpectedWaitingTime)
always returns the value 10800
53416 is the Routing point in which i load the strategy. I’ve tried to use the Group of Agents instead of the RP:
But It returns an error.
Also I’ve tried to use the queue
SData(210@StatServer.Q,StatExpectedWaitingTime)
And it always returns 0.
My PBX is a Lucent G3, and StatExpectedWaitingTime is a predefined statistic in IR.
Try logging an agent in that has valid skills to receive a call and see if the value changes. I have had this problem before, and I think that if the target list has no agents logged in, then the value of the stat is 10800…
Thanks everybody for your help, When I tried i had one agent logged and ready, this agent doesn’t have any special skills.
By now i think that i’ve solved the problem creating a new statistic by myself that have the same MainMask and RelativeMask as the ExpectedWaitingTime statistic. It seems that work rigth but i cannot be sure.
