Hi guys,
I’m testing the example of this platform trying to use applications blocks, however in the code it references to a using Genesyslab.Platform.ApplicationBlocks.Commons.Broker however I can’t find this…does anybody knows where to find it? Or anyone has a simple code example on how to connect, retrieve and handle events for StatServer?
Hi Cav,
MessageBroker block is part of Platform SDK. Once you install it you can find source codes of that block in “ApplicationBlocks/MessageBroker” folder.
There are several samples available on documentation CD/DVD. It is possible to download these for DevZone website as well.
:-[ :-[ Thanks René…missed that one…
I added the references however still getting
Error 1 The name 'BrokerServiceFactory' does not exist in the current context f:\LapTop Vista\Productos\Genesys\SDK\sdk_code_platform_stat-net\StatisticsPlatformSDKExample\StatisticsPlatformSDKExample\Form1.cs 104 34 StatisticsPlatformSDKExample
I don’t see in the example where is BrokerServiceFactory initialized. Help please.
The specific code line is:
eventBrokerService = BrokerServiceFactory.CreateEventBroker(protocolManagementService.Receiver);
