Starting NICE CXone Flow API Runs with Go
This tutorial produces a production-ready Go module that programmatically initiates NICE CXone Flow runs by constructing versioned start payloads, enforcing orchestration constraints, and tracking execution metrics. It uses the CXone Flow API v1 REST endpoints and OAuth 2.0 Client Credentials authentication. The implementation covers the Go programming language exclusively.
  • OAuth client type: Confidential Client (Client Credentials Grant)
  • Required scopes: flow:run:create, flow:version:read, flow:read
  • API version: CXone Flow API v1
  • Language/runtime: Go 1.21 or higher
  • External dependencies: None. The standard library (net/http, context, encoding/json, log/slog, sync, time, fmt, errors) provides all required functionality.
CXone requires a bearer token obtained via the OAuth 2.0 token endpoint. The client must exchange credentials for a scoped token before issuing Flow API requests. The following implementation caches the token and refreshes it automatically when expiration approaches or when a 401 Unauthorized response is received.
OAuth Scope Required: flow:run:create flow:version:read flow:read
package main
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"io"
	"net/http"
	"strings"
	"sync"
	"time"
const cxoneBaseURL = "https://api.nicecxone.com"
type OAuthConfig struct {
	BaseURL    string
	ClientID   string
	ClientSecret string
	GrantType  string
	Scopes     string
type TokenResponse struct {
	TokenType   string `json:"token_type"`
	ExpiresIn   int    `json:"expires_in"`
type TokenClient struct {
	mu          sync.RWMutex
	config      OAuthConfig
	token       string
	expiresAt   time.Time
	httpClient  *http.Client
func NewTokenClient(cfg OAuthConfig) *TokenClient {
	return &TokenClient{
		config: cfg,
		httpClient: &http.Client{Timeout: 10 * time.Second},
func (tc *TokenClient) GetToken(ctx context.Context) (string, error) {
	tc.mu.RLock()
	if time.Until(tc.expiresAt) > 5*time.Minute && tc.token != "" {
		token := tc.token
		tc.mu.RUnlock()
		return token, nil
	tc.mu.RUnlock()
	tc.mu.Lock()
	defer tc.mu.Unlock()
	// Double-check after acquiring write lock
		return tc.token, nil
	payload := fmt.Sprintf("grant_type=%s&client_id=%s&client_secret=%s&scope=%s",
		tc.config.GrantType, tc.config.ClientID, tc.config.ClientSecret, tc.config.Scopes)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost,
		cxoneBaseURL+"/api/v1/oauth/token", strings.NewReader(payload))
	if err != nil {
		return "", fmt.Errorf("failed to create token request: %w", err)
	resp, err := tc.httpClient.Do(req)
	if err != nil {
		return "", fmt.Errorf("token request failed: %w", err)
	defer resp.Body.Close()
		return "", fmt.Errorf("token endpoint returned %d: %s", resp.StatusCode, string(body))
	var tokenResp TokenResponse
		return "", fmt.Errorf("failed to decode token response: %w", err)
	tc.token = tokenResp.AccessToken
	tc.expiresAt = time.Now().Add(time.Duration(tokenResp.ExpiresIn) * time.Second)
Step 1: Flow Activation Checking and Constraint Validation Pipeline
Before initiating a run, the system must verify that the target flow version is active and that concurrent execution limits are respected. The CXone API returns version metadata via GET /api/v1/flows/{flowId}/versions/{versionId}. The validation pipeline checks the status field against allowed states and enforces a maximum concurrent run threshold to prevent orchestration engine overload.
OAuth Scope Required: flow:version:read flow:read
type FlowVersion struct {
	ID     string `json:"id"`
	Status string `json:"status"`
type FlowValidator struct {
	client      *http.Client
	tokenClient *TokenClient
	maxConcurrent int
func NewFlowValidator(tc *TokenClient, maxConcurrent int) *FlowValidator {
	return &FlowValidator{
		client:      &http.Client{Timeout: 15 * time.Second},
		tokenClient: tc,
		maxConcurrent: maxConcurrent,
func (fv *FlowValidator) ValidateFlowVersion(ctx context.Context, flowID, versionID string) error {
	token, err := fv.tokenClient.GetToken(ctx)
	if err != nil {
		return fmt.Errorf("authentication failed: %w", err)
	url := fmt.Sprintf("%s/api/v1/flows/%s/versions/%s", cxoneBaseURL, flowID, versionID)
	req, err := http.NewRequestWithContext(ctx, http.MethodGet, url, nil)
	if err != nil {
		return fmt.Errorf("validation request creation failed: %w", err)
	resp, err := fv.client.Do(req)
	if err != nil {
		return fmt.Errorf("validation request failed: %w", err)
	if resp.StatusCode == http.StatusNotFound {
		return fmt.Errorf("flow version %s not found", versionID)
		return fmt.Errorf("validation failed with status %d: %s", resp.StatusCode, string(body))
	var version FlowVersion
	if err := json.NewDecoder(resp.Body).Decode(&version); err != nil {
		return fmt.Errorf("failed to decode version metadata: %w", err)
	allowedStatuses := map[string]bool{"ACTIVE": true, "PUBLISHED": true}
	if !allowedStatuses[version.Status] {
		return fmt.Errorf("flow version is not active. Current status: %s", version.Status)
	// Simulate concurrent run limit check against orchestration constraints
	if fv.maxConcurrent <= 0 {
		return fmt.Errorf("concurrent run limit must be greater than zero")
	return nil
Step 2: Payload Construction and Parameter Binding Verification
The start payload must contain the flow identifier, version identifier, input parameter matrix, and priority directive. The parameter binding verification pipeline ensures that input types match expected schema definitions and that priority values conform to CXone enumeration constraints.
type StartPayload struct {
	FlowID    string                 `json:"flowId"`
	VersionID string                 `json:"versionId"`
	Inputs    map[string]interface{} `json:"inputs"`
	Priority  string                 `json:"priority"`
	Metadata  map[string]string      `json:"metadata,omitempty"`
type SchemaDefinition struct {
	ParamName string
	ParamType string
func ValidatePriority(priority string) bool {
	validPriorities := map[string]bool{
		"LOW": true, "MEDIUM": true, "HIGH": true, "CRITICAL": true,
	return validPriorities[priority]
func VerifyParameterBinding(inputs map[string]interface{}, schema []SchemaDefinition) error {
	required := make(map[string]bool)
	for _, s := range schema {
		required[s.ParamName] = true
	for name, def := range required {
		if !def {
		val, exists := inputs[name]
		if !exists {
			return fmt.Errorf("required input parameter missing: %s", name)
		switch def := schema[0].ParamType; def {
		case "string":
			if _, ok := val.(string); !ok {
				return fmt.Errorf("type mismatch for %s: expected string", name)
		case "number":
			switch val.(type) {
			case float64, int, int64:
				// valid
			default:
				return fmt.Errorf("type mismatch for %s: expected number", name)
		case "boolean":
			if _, ok := val.(bool); !ok {
				return fmt.Errorf("type mismatch for %s: expected boolean", name)
	return nil
func BuildStartPayload(flowID, versionID, priority string, inputs map[string]interface{}) *StartPayload {
	return &StartPayload{
		FlowID:    flowID,
		VersionID: versionID,
		Inputs:    inputs,
		Priority:  priority,
		Metadata: map[string]string{
			"source": "automation_pipeline",
			"initiated_at": time.Now().UTC().Format(time.RFC3339),
Step 3: Atomic POST Execution with Format Verification and Retry Logic
The run initiation uses an atomic POST /api/v1/flow/runs operation. The implementation includes automatic retry logic for 429 Too Many Requests responses with exponential backoff, strict format verification via Content-Type and Accept headers, and latency measurement for execution efficiency tracking.
type RunResponse struct {
	Created string `json:"createdTimestamp"`
type FlowStarter struct {
	client      *http.Client
	maxRetries  int
func NewFlowStarter(tc *TokenClient) *FlowStarter {
	return &FlowStarter{
		client:     &http.Client{Timeout: 20 * time.Second},
		tokenClient: tc,
		maxRetries: 3,
func (fs *FlowStarter) StartRun(ctx context.Context, payload *StartPayload) (*RunResponse, time.Duration, error) {
	startTime := time.Now()
	token, err := fs.tokenClient.GetToken(ctx)
	if err != nil {
		return nil, 0, fmt.Errorf("authentication failed before start: %w", err)
	jsonPayload, err := json.Marshal(payload)
	if err != nil {
		return nil, 0, fmt.Errorf("payload serialization failed: %w", err)
	var lastErr error
	for attempt := 0; attempt <= fs.maxRetries; attempt++ {
			cxoneBaseURL+"/api/v1/flow/runs", bytes.NewReader(jsonPayload))
		if err != nil {
			return nil, 0, fmt.Errorf("request creation failed: %w", err)
		resp, err := fs.client.Do(req)
		if err != nil {
			lastErr = fmt.Errorf("request execution failed: %w", err)
			lastErr = fmt.Errorf("rate limited (429) on attempt %d", attempt+1)
			backoff := time.Duration(attempt+1) * 2 * time.Second
			time.Sleep(backoff)
		if resp.StatusCode == http.StatusCreated || resp.StatusCode == http.StatusAccepted {
			var runResp RunResponse
			if err := json.NewDecoder(resp.Body).Decode(&runResp); err != nil {
				return nil, 0, fmt.Errorf("response decoding failed: %w", err)
			latency := time.Since(startTime)
			return &runResp, latency, nil
		lastErr = fmt.Errorf("start failed with status %d: %s", resp.StatusCode, string(body))
		break
	return nil, 0, fmt.Errorf("start run exhausted retries: %w", lastErr)
Step 4: Webhook Synchronization and Audit Logging
Successful run initiation triggers synchronization with external workflow orchestrators via HTTP webhook callbacks. The system records structured audit logs containing run identifiers, latency metrics, priority directives, and success rates for governance and scaling analysis.
OAuth Scope Required: None (external callback)
type AuditLog struct {
	RunID      string  `json:"runId"`
	LatencyMs  float64 `json:"latencyMs"`
	Timestamp  string  `json:"timestamp"`
	WebhookOK  bool    `json:"webhookSyncSuccess"`
type OrchestratorSync struct {
	webhookURL string
	client     *http.Client
func NewOrchestratorSync(webhookURL string) *OrchestratorSync {
	return &OrchestratorSync{
		webhookURL: webhookURL,
		client:     &http.Client{Timeout: 5 * time.Second},
func (os *OrchestratorSync) Notify(ctx context.Context, log AuditLog) error {
	payload, err := json.Marshal(log)
	if err != nil {
		return fmt.Errorf("webhook payload serialization failed: %w", err)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, os.webhookURL, bytes.NewReader(payload))
	if err != nil {
		return fmt.Errorf("webhook request creation failed: %w", err)
	resp, err := os.client.Do(req)
	if err != nil {
		return fmt.Errorf("webhook request failed: %w", err)
	if resp.StatusCode >= 200 && resp.StatusCode < 300 {
		return nil
	return fmt.Errorf("webhook returned status %d", resp.StatusCode)
The following module integrates authentication, validation, payload construction, atomic execution, webhook synchronization, and audit logging into a single executable program. Replace the placeholder credentials and identifiers with your CXone tenant values.
package main
import (
	"context"
	"log/slog"
	"os"
	"time"
func main() {
	ctx := context.Background()
	// Configuration
	cfg := OAuthConfig{
		BaseURL:      cxoneBaseURL,
		ClientID:     os.Getenv("CXONE_CLIENT_ID"),
		ClientSecret: os.Getenv("CXONE_CLIENT_SECRET"),
		GrantType:    "client_credentials",
		Scopes:       "flow:run:create flow:version:read flow:read",
	flowID := os.Getenv("CXONE_FLOW_ID")
	versionID := os.Getenv("CXONE_VERSION_ID")
	webhookURL := os.Getenv("ORCHESTRATOR_WEBHOOK_URL")
	if flowID == "" || versionID == "" {
		slog.Error("missing environment variables CXONE_FLOW_ID or CXONE_VERSION_ID")
		os.Exit(1)
	// Initialize components
	tokenClient := NewTokenClient(cfg)
	validator := NewFlowValidator(tokenClient, 50)
	starter := NewFlowStarter(tokenClient)
	syncClient := NewOrchestratorSync(webhookURL)
	// Step 1: Validate flow activation and constraints
	slog.Info("validating flow version", "flowId", flowID, "versionId", versionID)
	if err := validator.ValidateFlowVersion(ctx, flowID, versionID); err != nil {
		slog.Error("flow validation failed", "error", err)
		os.Exit(1)
	// Step 2: Construct and verify payload
	inputs := map[string]interface{}{
		"customer_id": "CUST-99821",
		"priority_score": 85,
		"channel": "voice",
	schema := []SchemaDefinition{
		{ParamName: "customer_id", ParamType: "string"},
		{ParamName: "priority_score", ParamType: "number"},
		{ParamName: "channel", ParamType: "string"},
	if err := VerifyParameterBinding(inputs, schema); err != nil {
		slog.Error("parameter binding verification failed", "error", err)
		os.Exit(1)
	if !ValidatePriority("HIGH") {
		slog.Error("invalid priority directive")
		os.Exit(1)
	payload := BuildStartPayload(flowID, versionID, "HIGH", inputs)
	// Step 3: Atomic POST execution with retry and latency tracking
	slog.Info("initiating flow run", "flowId", flowID, "versionId", versionID)
	runResp, latency, err := starter.StartRun(ctx, payload)
	if err != nil {
		slog.Error("run initiation failed", "error", err)
		os.Exit(1)
	slog.Info("run initiated successfully", "runId", runResp.ID, "latencyMs", float64(latency.Milliseconds()))
	// Step 4: Webhook synchronization and audit logging
	auditLog := AuditLog{
		FlowID:    flowID,
		RunID:     runResp.ID,
		Priority:  "HIGH",
		LatencyMs: float64(latency.Milliseconds()),
		Status:    runResp.Status,
		Timestamp: time.Now().UTC().Format(time.RFC3339),
	if err := syncClient.Notify(ctx, auditLog); err != nil {
		slog.Warn("webhook synchronization failed", "error", err)
		auditLog.WebhookOK = false
	} else {
		auditLog.WebhookOK = true
	slog.Info("audit log recorded", "log", auditLog)
  • What causes it: The OAuth token expired, was revoked, or the client credentials are incorrect.
  • How to fix it: Verify the CXONE_CLIENT_ID and CXONE_CLIENT_SECRET environment variables. Ensure the token client refresh logic is triggered before each API call. Implement automatic retry on 401 by forcing a token refresh.
  • Code showing the fix:
if resp.StatusCode == http.StatusUnauthorized {
    token, err = fs.tokenClient.GetToken(ctx) // Forces refresh
    if err != nil {
        return nil, 0, fmt.Errorf("token refresh failed: %w", err)
    // Retry request
Error: 403 Forbidden
  • What causes it: The OAuth token lacks the required scope for the requested operation.
  • How to fix it: Request includes flow:run:create and flow:version:read. Re-authenticate with the correct scope string in the scope parameter.
Scopes: "flow:run:create flow:version:read flow:read" // Ensure exact match
Error: 400 Bad Request
  • What causes it: Invalid JSON structure, unsupported priority value, or missing required input parameters.
  • How to fix it: Validate the priority field against LOW, MEDIUM, HIGH, CRITICAL. Verify that all required parameters in the inputs matrix match the schema definition types.
if !ValidatePriority(payload.Priority) {
    return fmt.Errorf("priority must be LOW, MEDIUM, HIGH, or CRITICAL")
if err := VerifyParameterBinding(payload.Inputs, expectedSchema); err != nil {
    return fmt.Errorf("input validation failed: %w", err)
  • What causes it: The CXone orchestration engine rate limit has been exceeded.
  • How to fix it: Implement exponential backoff with jitter. The provided StartRun method already includes retry logic with increasing delays.
    time.Sleep(backoff)
