Stabilizing WebSocket Streams and Reducing Audio Latency in Genesys Cloud AppFoundry Integrations
- A resilient Python client that manages WebSocket connections to Genesys Cloud AppFoundry applications, implementing automatic reconnection logic and jitter buffer analysis to diagnose audio latency.
- This tutorial utilizes the Genesys Cloud AppFoundry WebSocket API and the
websocket-clientlibrary. - The implementation is written in Python 3.9+ with type hints and production-grade error handling.
- OAuth Client Type: Service Account or OAuth Client Credentials flow is recommended for backend services; JWT or Authorization Code for user-facing bots.
- Required Scopes:
appfoundry:application:read,appfoundry:application:write, andappfoundry:application:execute. - SDK/Library:
websocket-client(v1.6.0+),requests(v2.31.0+),pyjwt(for token generation if using JWT). - Runtime: Python 3.9 or higher.
- Environment: Access to a Genesys Cloud organization with AppFoundry enabled and a deployed application that supports WebSocket communication.
Genesys Cloud AppFoundry applications authenticate WebSocket connections via Bearer tokens passed in the initial handshake or within the first message payload. For this tutorial, we assume a service-to-service integration using the Client Credentials flow to obtain a long-lived access token.
First, install the required dependencies:
pip install websocket-client requests pyjwt
The following class handles the OAuth2 token acquisition. It caches the token to avoid unnecessary HTTP requests during reconnection events.
import requests
import logging
from typing import Optional
class GenesysAuth:
def __init__(self, org_id: str, client_id: str, client_secret: str, env: str = "mypurecloud.com"):
self.org_id = org_id
self.client_id = client_id
self.base_url = f"https://api.{env}"
Retrieves an OAuth2 access token using Client Credentials flow.
Implements basic caching to respect token expiry.
current_time = time.time()
# Return cached token if valid (subtract 60s for safety margin)
if self.access_token and current_time < (self.token_expiry - 60):
return self.access_token
logger.info("Requesting new OAuth2 token...")
url = f"{self.base_url}/oauth/token"
headers = {
data = {
"client_id": self.client_id,
"audience": "https://api.{self.env}".replace("{self.env}", self.base_url.split("://")[1])
response = requests.post(url, headers=headers, data=data, timeout=10)
response.raise_for_status()
token_data = response.json()
self.token_expiry = current_time + token_data["expires_in"]
logger.info("Successfully acquired new access token.")
logger.error(f"OAuth Error: {e.response.status_code} - {e.response.text}")
raise
logger.error(f"Network error during OAuth: {e}")
raise
Step 1: Establishing the Resilient WebSocket Connection
WebSocket connections to Genesys Cloud can drop due to network instability, load balancer timeouts, or server-side maintenance. A naive connect call will fail silently or crash the application. We must implement an exponential backoff retry mechanism.
The AppFoundry WebSocket endpoint follows the pattern: wss://api.{env}/appfoundry/v1/applications/{applicationId}/conversations.
import websocket
import json
import threading
from websocket import WebSocketException
class GenesysAppFoundryClient:
def __init__(self, auth: GenesysAuth, application_id: str, env: str = "mypurecloud.com"):
self.auth = auth
self.application_id = application_id
self.env = env
self.ws_url = f"wss://api.{env}/appfoundry/v1/applications/{application_id}/conversations"
self.ws: Optional[websocket.WebSocketApp] = None
self.is_running = False
self.reconnect_delay = 1.0
self.max_reconnect_delay = 30.0
# Metrics for latency analysis
self.message_timestamps = []
self.latency_samples = []
def _on_open(self, ws):
logger.info("WebSocket connection opened.")
# Reset reconnect delay on successful connection
# Send initial handshake if required by your specific AppFoundry app
# Most Genesys apps expect a specific JSON payload to start the session
init_payload = {
"type": "initialize",
"payload": {
"sessionId": f"session_{int(time.time())}",
"metadata": {
"source": "python_sdk_tutorial",
"version": "1.0"
ws.send(json.dumps(init_payload))
logger.info("Sent initialization payload.")
def _on_message(self, ws, message):
Handles incoming messages.
Calculates latency between send time and receive time.
data = json.loads(message)
logger.debug(f"Received: {data}")
# Latency Calculation
if "timestamp" in data:
receive_time = time.time()
send_time = data["timestamp"]
latency = receive_time - send_time
self.latency_samples.append(latency)
# Keep only last 100 samples for analysis
if len(self.latency_samples) > 100:
self.latency_samples.pop(0)
logger.info(f"Message Latency: {latency*1000:.2f} ms")
# Handle specific message types
msg_type = data.get("type")
if msg_type == "audio_chunk":
self._process_audio(data)
elif msg_type == "error":
logger.error(f"AppFoundry Error: {data.get('payload')}")
except json.JSONDecodeError:
logger.warning(f"Non-JSON message received: {message[:100]}")
logger.error(f"Error processing message: {e}")
def _on_error(self, ws, error):
logger.error(f"WebSocket Error: {error}")
# Do not stop the thread here; let the on_close handler trigger reconnect
def _on_close(self, ws, close_status_code, close_msg):
logger.warning(f"WebSocket Closed. Status: {close_status_code}, Msg: {close_msg}")
# If the client was supposed to be running, attempt reconnect
if self._should_reconnect():
self._reconnect()
def _should_reconnect(self) -> bool:
Determines if reconnection is appropriate.
In a production bot, you might check a global 'shutdown' flag.
return True # Simplified for tutorial
def _reconnect(self):
Implements exponential backoff for reconnection.
if not self.is_running:
logger.info(f"Reconnecting in {self.reconnect_delay} seconds...")
time.sleep(self.reconnect_delay)
# Exponential backoff with jitter
self.reconnect_delay = min(self.reconnect_delay * 2, self.max_reconnect_delay)
jitter = random.uniform(0, 0.5)
time.sleep(jitter)
self.connect()
def connect(self):
Creates the WebSocket connection with authentication headers.
token = self.auth.get_access_token()
# Headers are critical for AppFoundry WebSocket authentication
headers = {
self.is_running = True
self.ws = websocket.WebSocketApp(
self.ws_url,
header=headers,
on_open=self._on_open,
on_message=self._on_message,
on_error=self._on_error,
on_close=self._on_close
# Run in a separate thread to avoid blocking the main application
self.ws_thread = threading.Thread(target=self.ws.run_forever)
self.ws_thread.daemon = True
self.ws_thread.start()
logger.info("WebSocket client started.")
Step 2: Handling Audio Streams and Latency Buffering
Audio latency in WebSocket integrations often stems from two sources: network jitter and processing delays in the AppFoundry application. To troubleshoot this, we must analyze the inter-arrival time of audio chunks.
Genesys Cloud typically sends audio as Base64-encoded PCM or Opus frames. We will implement a simple jitter buffer to smooth out arrival times.
import base64
import queue
import numpy as np
class JitterBuffer:
def __init__(self, buffer_size_ms: int = 50):
self.buffer = queue.Queue(maxsize=100)
self.buffer_size_ms = buffer_size_ms
self.arrival_times = []
def add_chunk(self, data: bytes, timestamp: float):
Adds an audio chunk to the buffer with its arrival timestamp.
self.buffer.put((data, timestamp))
self.arrival_times.append(timestamp)
# Keep arrival times manageable
if len(self.arrival_times) > 100:
self.arrival_times.pop(0)
def get_jitter_stats(self) -> dict:
Calculates jitter statistics.
Jitter is the variance in packet delay.
if len(self.arrival_times) < 2:
return {"jitter_ms": 0, "avg_latency_ms": 0}
# Calculate inter-arrival times
deltas = [self.arrival_times[i] - self.arrival_times[i-1] for i in range(1, len(self.arrival_times))]
# Convert to milliseconds
deltas_ms = [d * 1000 for d in deltas]
jitter = np.std(deltas_ms)
avg_latency = np.mean(deltas_ms)
"jitter_ms": jitter,
"avg_latency_ms": avg_latency,
"packet_count": len(self.arrival_times)
# Update GenesysAppFoundryClient to use JitterBuffer
# Add this method to the class defined in Step 1
def _process_audio(self, data: dict):
Processes incoming audio chunks.
payload = data.get("payload", {})
audio_base64 = payload.get("audio")
timestamp = payload.get("timestamp", time.time())
if audio_base64:
audio_bytes = base64.b64decode(audio_base64)
self.jitter_buffer.add_chunk(audio_bytes, timestamp)
# Log jitter stats every 10 packets
if len(self.jitter_buffer.arrival_times) % 10 == 0:
stats = self.jitter_buffer.get_jitter_stats()
logger.info(f"Audio Stats: Jitter={stats['jitter_ms']:.2f}ms, Avg Delay={stats['avg_latency_ms']:.2f}ms")
logger.error(f"Error decoding audio: {e}")
def connect(self):
# ... existing code ...
# Initialize jitter buffer before starting
self.jitter_buffer = JitterBuffer(buffer_size_ms=50)
Step 3: Sending Data and Monitoring Connection Health
To diagnose drops, we need to send periodic heartbeat or keep-alive messages if the AppFoundry application does not enforce its own. Additionally, we must ensure that our send operations are non-blocking to prevent UI freezes in a bot interface.
def send_message(self, message_type: str, payload: dict):
Sends a message to the AppFoundry application with error handling.
if not self.is_running or not self.ws:
logger.warning("WebSocket is not connected. Queueing message.")
return False
full_message = {
"type": message_type,
"timestamp": time.time(),
"payload": payload
self.ws.send(json.dumps(full_message))
return True
except WebSocketException as e:
logger.error(f"Failed to send message: {e}")
return False
logger.error(f"Unexpected error sending message: {e}")
return False
def get_diagnostics(self) -> dict:
Returns current connection health metrics.
audio_stats = self.jitter_buffer.get_jitter_stats() if hasattr(self, 'jitter_buffer') else {}
"connected": self.is_running,
"reconnect_delay": self.reconnect_delay,
"latency_samples_count": len(self.latency_samples),
"avg_latency_ms": np.mean(self.latency_samples) * 1000 if self.latency_samples else 0,
"audio_jitter": audio_stats.get("jitter_ms", 0),
"audio_avg_delay": audio_stats.get("avg_latency_ms", 0)
The following script integrates all components. It initializes the authentication, starts the WebSocket client, sends a test message, and then monitors the connection for 60 seconds before shutting down.
import random
import sys
# Import classes defined in previous steps
# Ensure GenesysAuth, GenesysAppFoundryClient, and JitterBuffer are in scope
def main():
# Configuration
ORG_ID = "your_org_id"
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
APPLICATION_ID = "your_appfoundry_application_id"
ENV = "mypurecloud.com"
# 1. Initialize Authentication
auth = GenesysAuth(
org_id=ORG_ID,
client_id=CLIENT_ID,
client_secret=CLIENT_SECRET,
env=ENV
# 2. Initialize Client
client = GenesysAppFoundryClient(
auth=auth,
application_id=APPLICATION_ID,
env=ENV
# 3. Connect
client.connect()
# Wait for connection to establish
time.sleep(2)
if not client.is_running:
logger.error("Failed to establish initial connection.")
sys.exit(1)
# 4. Send Test Messages
logger.info("Sending test interaction...")
client.send_message("user_input", {
"text": "Hello, this is a test message for latency analysis.",
"userId": "test_user_123"
# 5. Monitor and Diagnostics
logger.info("Monitoring connection for 30 seconds...")
for i in range(30):
time.sleep(1)
diagnostics = client.get_diagnostics()
if i % 5 == 0:
logger.info(f"Status Check {i}s: {diagnostics}")
except KeyboardInterrupt:
logger.info("Interrupted by user.")
# 6. Cleanup
logger.info("Shutting down client...")
client.is_running = False
if client.ws:
client.ws.close()
# Wait for thread to finish
if client.ws_thread.is_alive():
client.ws_thread.join(timeout=5)
logger.info("Diagnostics Summary:")
final_stats = client.get_diagnostics()
print(json.dumps(final_stats, indent=2))
logger.error(f"Fatal error: {e}", exc_info=True)
sys.exit(1)
main()
Error: 401 Unauthorized on WebSocket Handshake
What causes it:
The Bearer token provided in the WebSocket header is expired, invalid, or lacks the appfoundry:application:execute scope. Genesys Cloud validates the token immediately upon the WebSocket handshake.
How to fix it:
Ensure your GenesysAuth class refreshes the token before the connection attempt. If you are using a long-running process, check the token expiry time. The code above includes a 60-second safety margin. If the error persists, verify the OAuth client has the correct scopes assigned in the Genesys Cloud Admin Console under Security > OAuth 2.0 Clients.
Code Fix:
In GenesysAppFoundryClient.connect(), ensure you call self.auth.get_access_token() immediately before creating the WebSocketApp. Do not cache the token string across reconnections without verifying expiry.
Error: 429 Too Many Requests (Rate Limiting)
What causes it:
Genesys Cloud enforces rate limits on WebSocket connections and message throughput. If your bot sends messages faster than the AppFoundry application can process them, or if you are rapidly reconnecting due to instability, you may hit rate limits.
How to fix it:
Implement a backoff strategy on the client side. The GenesysAppFoundryClient above uses exponential backoff for reconnection. For message sending, implement a queue with a maximum rate (e.g., 10 messages per second).
Code Fix:
Add a rate limiter to send_message:
class RateLimiter:
def __init__(self, rate: int, per_second: float):
self.rate = rate
self.per_second = per_second
self.tokens = rate
self.last_update = time.time()
def acquire(self):
now = time.time()
elapsed = now - self.last_update
self.tokens += elapsed * (self.rate / self.per_second)
if self.tokens > self.rate:
self.tokens = self.rate
self.last_update = now
if self.tokens >= 1:
self.tokens -= 1
return True
else:
time.sleep(1 - self.tokens)
return True
# Usage in GenesysAppFoundryClient
self.rate_limiter = RateLimiter(rate=10, per_second=1.0)
self.rate_limiter.acquire() # Block if rate exceeded
# ... rest of send logic ...
Error: High Audio Latency (>300ms)
What causes it:
High latency in WebSocket audio streams is often due to:
- Network Jitter: Packets arriving at irregular intervals.
- Server-Side Processing: The AppFoundry application is taking too long to process the input and generate the response.
- Client-Side Buffering: The client is buffering too much audio before playing it.
How to fix it:
Analyze the jitter_ms and avg_latency_ms from the JitterBuffer. If jitter is high, increase the jitter buffer size in the client. If latency is high but jitter is low, the issue is likely server-side. Check the AppFoundry application logs in Genesys Cloud for processing times.
Code Fix:
Adjust the JitterBuffer size dynamically based on network conditions:
def adjust_buffer(self, jitter_ms: float):
if jitter_ms > 50:
self.jitter_buffer.buffer_size_ms = 100
logger.info("Increased jitter buffer to 100ms due to high jitter.")
elif jitter_ms < 20:
self.jitter_buffer.buffer_size_ms = 50
logger.info("Decreased jitter buffer to 50ms due to stable network.")
