Stabilizing WebSocket Connections and Reducing Audio Latency in Genesys Cloud AppFoundry NICE Cognigy Integrations
  • A robust Python middleware service that manages WebSocket connections between a Genesys Cloud AppFoundry application and a NICE Cognigy bot backend, implementing automatic reconnection and latency monitoring.
  • This tutorial uses the Genesys Cloud REST API for user authentication and the Genesys Cloud WebSocket API (wss://api.mypurecloud.com/api/v2/platformdata/events) for real-time event streaming.
  • The programming language covered is Python 3.9+, utilizing the websockets library and requests for HTTP operations.
  • OAuth Client Type: Confidential Client (Client Credentials Grant) with the scope platform:agent:view or platform:user:view to validate user identity before establishing the WebSocket.
  • SDK/API Version: Genesys Cloud API v2.
  • Language/Runtime: Python 3.9 or higher.
  • External Dependencies:
    • websockets==12.0 (for asynchronous WebSocket management)
    • requests==2.31.0 (for OAuth token retrieval)
    • pydantic==2.5.0 (for data validation)
Before establishing a WebSocket connection, you must obtain a valid OAuth access token. Genesys Cloud WebSocket endpoints require the Authorization header to contain a Bearer token. The token must not expire while the connection is active, or the connection will be terminated with a 401 Unauthorized error.
The following code retrieves a token using the Client Credentials flow. In a production environment, you must implement token caching and refresh logic to avoid hitting the API endpoint for every connection attempt.
import os
import requests
from typing import Optional
class GenesysAuth:
    def __init__(self, client_id: str, client_secret: str, org_id: str):
        self.client_id = client_id
        self.org_id = org_id
        self.token_url = f"https://login.mypurecloud.com/oauth/token"
    def get_access_token(self) -> Optional[str]:
        Retrieves an OAuth2 access token using Client Credentials flow.
        Returns the token string or None if authentication fails.
        headers = {
        data = {
            "client_id": self.client_id,
            "audience": f"https://api.mypurecloud.com/{self.org_id}"
            response = requests.post(self.token_url, headers=headers, data=data, timeout=10)
            response.raise_for_status()
            token_data = response.json()
            return token_data.get("access_token")
            print(f"Authentication failed: {e.response.status_code} - {e.response.text}")
            return None
            print(f"Network error during authentication: {e}")
            return None
# Configuration from environment variables
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
ORG_ID = os.getenv("GENESYS_ORG_ID")
auth_service = GenesysAuth(CLIENT_ID, CLIENT_SECRET, ORG_ID)
ACCESS_TOKEN = auth_service.get_access_token()
if not ACCESS_TOKEN:
    raise Exception("Failed to obtain access token. Check credentials.")
Step 1: Establishing the WebSocket Connection with Resilience
The Genesys Cloud WebSocket endpoint streams platform events. For a Cognigy integration, you typically subscribe to message events to detect when a user sends a chat message that triggers your AppFoundry app. Connection drops are common due to network instability, idle timeouts, or token expiration.
The following code establishes a connection with exponential backoff retry logic. It filters events to ensure you only process relevant chat messages, reducing payload processing overhead.
import asyncio
import websockets
import json
class GenesysWebSocketClient:
    def __init__(self, token: str, org_id: str):
        self.token = token
        self.ws_url = f"wss://api.mypurecloud.com/api/v2/platformdata/events"
        self.connection_id: Optional[str] = None
        self.is_connected = False
    async def connect(self):
        Establishes a WebSocket connection with Genesys Cloud.
        Implements exponential backoff for reconnection attempts.
        while True:
                headers = {
                    "Authorization": f"Bearer {self.token}"
                # Connect with a ping interval to keep the connection alive
                async with websockets.connect(
                    self.ws_url,
                    extra_headers=headers,
                    ping_interval=20,
                    ping_timeout=10
                ) as websocket:
                    self.is_connected = True
                    print(f"[{datetime.now(timezone.utc)}] WebSocket Connected")
                    # Subscribe to specific event types to reduce noise
                    subscription = {
                        "events": ["message"],
                        "filter": {
                            "type": "chat",
                            "status": ["ACTIVE"]
                    await websocket.send(json.dumps(subscription))
                    self.connection_id = "active-session" # Placeholder for actual session ID if returned
                    # Process incoming messages
                    await self._process_events(websocket)
            except websockets.exceptions.ConnectionClosed as e:
                print(f"[{datetime.now(timezone.utc)}] Connection closed: {e.code} - {e.reason}")
                await self._handle_reconnection()
            except websockets.exceptions.InvalidStatusCode as e:
                if e.status_code == 401:
                    print("Token expired. Refreshing token...")
                    # In production, trigger token refresh here
                    self.token = auth_service.get_access_token()
                else:
                    print(f"Invalid status code: {e.status_code}")
                print(f"Unexpected error: {e}")
    async def _handle_reconnection(self):
        Implements exponential backoff for reconnection.
        base_delay = 2
        max_delay = 60
        delay = base_delay
        while True:
            print(f"Reconnecting in {delay} seconds...")
            await asyncio.sleep(delay)
            # Check if token is still valid before reconnecting
            if not self._is_token_valid():
                print("Token invalid. Refreshing...")
                if not self.token:
                    raise Exception("Failed to refresh token.")
            delay = min(delay * 2, max_delay)
            # Add jitter to prevent thundering herd
            import random
            delay += random.uniform(0, 1)
            break # Break after one retry attempt for this example
    def _is_token_valid(self) -> bool:
        Placeholder for JWT token validation.
        In production, parse the JWT payload and check the 'exp' claim.
        # Simple check: if token is None or empty
        return bool(self.token)
    async def _process_events(self, websocket):
        Processes incoming WebSocket messages.
            async for message in websocket:
                data = json.loads(message)
                await self._handle_event(data)
        except websockets.exceptions.ConnectionClosed:
            raise # Propagate to trigger reconnection
        except json.JSONDecodeError:
            print("Received invalid JSON message")
    async def _handle_event(self, data: dict):
        Handles individual platform events.
        event_type = data.get("eventType")
        if event_type == "message":
            event_data = data.get("eventData", {})
            conversation_id = event_data.get("conversationId")
            message_body = event_data.get("body")
            if conversation_id and message_body:
                print(f"Received message from conversation {conversation_id}: {message_body}")
                # Forward to Cognigy backend here
                await self._forward_to_cognigy(conversation_id, message_body)
async def main():
    client = GenesysWebSocketClient(ACCESS_TOKEN, ORG_ID)
    await client.connect()
    asyncio.run(main())
Step 2: Forwarding to NICE Cognigy with Latency Monitoring
Audio latency and WebSocket drops are often exacerbated by slow downstream processing. If your AppFoundry app takes too long to respond to a Genesys Cloud event, the WebSocket buffer may fill up, or the connection may be considered idle.
The following code forwards the message to a NICE Cognigy bot via its REST API. It measures the round-trip time and logs latency metrics. If the latency exceeds a threshold, it logs a warning. This helps you identify if the bottleneck is in Genesys Cloud, your middleware, or the Cognigy backend.
import httpx
import logging
# Configure logging
# Cognigy Configuration
COGNIGY_API_URL = os.getenv("COGNIGY_API_URL")
COGNIGY_API_KEY = os.getenv("COGNIGY_API_KEY")
# Latency Thresholds (in seconds)
LATENCY_WARNING_THRESHOLD = 0.5
LATENCY_CRITICAL_THRESHOLD = 1.0
async def _forward_to_cognigy(self, conversation_id: str, message_body: str):
    Forwards a message to the NICE Cognigy bot and measures latency.
    start_time = time.time()
    headers = {
        "Authorization": f"Bearer {COGNIGY_API_KEY}",
    payload = {
        "userId": conversation_id, # Use conversation ID as user ID for tracing
        "message": message_body,
        "context": {
            "source": "genesys-cloud",
            "timestamp": datetime.now(timezone.utc).isoformat()
        # Use httpx for async HTTP requests
        async with httpx.AsyncClient(timeout=5.0) as client:
            response = await client.post(
                f"{COGNIGY_API_URL}/api/v2/dialogs/start",
                headers=headers,
                json=payload
            end_time = time.time()
            latency = end_time - start_time
            # Log latency
            if latency > LATENCY_CRITICAL_THRESHOLD:
                logger.critical(f"High latency detected: {latency:.3f}s for conversation {conversation_id}")
            elif latency > LATENCY_WARNING_THRESHOLD:
                logger.warning(f"Elevated latency: {latency:.3f}s for conversation {conversation_id}")
            else:
                logger.info(f"Normal latency: {latency:.3f}s for conversation {conversation_id}")
            if response.status_code == 200:
                cognigy_response = response.json()
                bot_response = cognigy_response.get("response", "")
                await self._send_response_to_genesys(conversation_id, bot_response)
            else:
                logger.error(f"Cognigy API error: {response.status_code} - {response.text}")
    except httpx.TimeoutException:
        logger.error(f"Timeout connecting to Cognigy for conversation {conversation_id}")
        logger.error(f"Error forwarding to Cognigy: {e}")
async def _send_response_to_genesys(self, conversation_id: str, response_text: str):
    Sends the bot response back to the Genesys Cloud conversation via REST API.
    Note: For real-time chat, you might use the WebSocket to send messages back
    if your AppFoundry app has write permissions, or use the REST API for reliability.
    # This is a placeholder. In a real AppFoundry app, you would use the
    # Genesys Cloud REST API to post a message to the conversation.
    pass
Step 3: Handling WebSocket Reconnection State and Message Deduplication
When a WebSocket connection drops and reconnects, you may miss events that occurred during the downtime. Genesys Cloud provides a sequenceId in the subscription response. You should store this ID and resume from it upon reconnection to ensure no messages are lost or duplicated.
The following code updates the subscription logic to include a sequenceId and implements a simple deduplication mechanism using a set of processed message IDs.
import uuid
    # ... previous code ...
        self.token = token
        self.last_sequence_id: Optional[int] = None
        self.processed_message_ids = set()
        async with websockets.connect(...) as websocket:
            # Include last_sequence_id in subscription if available
            subscription = {
                "filter": {
                    "type": "chat",
            if self.last_sequence_id:
                subscription["sequenceId"] = self.last_sequence_id
        sequence_id = data.get("sequenceId")
        # Update last sequence ID for reconnection
        if sequence_id and (not self.last_sequence_id or sequence_id > self.last_sequence_id):
            self.last_sequence_id = sequence_id
            message_id = event_data.get("id")
            # Deduplication check
            if message_id and message_id in self.processed_message_ids:
                logger.info(f"Duplicate message ignored: {message_id}")
                return
            if message_id:
                self.processed_message_ids.add(message_id)
                # Limit the size of the set to prevent memory leaks
                if len(self.processed_message_ids) > 10000:
                    self.processed_message_ids.clear()
                logger.info(f"Processing message {message_id} from conversation {conversation_id}")
The following is the complete, runnable Python script. Save it as genesys_cognigy_bridge.py.
import os
import asyncio
import websockets
import json
import httpx
import logging
# Configure logging
logging.basicConfig(level=logging.INFO, format='%(asctime)s - %(levelname)s - %(message)s')
# Configuration
class GenesysAuth:
        data = {
            return response.json().get("access_token")
            logger.error(f"Authentication failed: {e}")
            return None
        self.token = token
        while True:
                headers = {"Authorization": f"Bearer {self.token}"}
                    self.ws_url,
                    ping_interval=20,
                    ping_timeout=10
                ) as websocket:
                    logger.info("WebSocket Connected")
                    subscription = {
                        "filter": {"type": "chat", "status": ["ACTIVE"]}
                logger.warning(f"Connection closed: {e.code} - {e.reason}")
                await asyncio.sleep(2)
                    logger.warning("Token expired. Refreshing...")
                else:
                    logger.error(f"Invalid status code: {e.status_code}")
                logger.error(f"Unexpected error: {e}")
            raise
            logger.error("Received invalid JSON message")
                return
            if message_id:
        headers = {
        payload = {
            "context": {"source": "genesys-cloud"}
                    headers=headers,
                    json=payload
                latency = time.time() - start_time
                    logger.critical(f"High latency: {latency:.3f}s")
                    logger.warning(f"Elevated latency: {latency:.3f}s")
                else:
                    logger.info(f"Normal latency: {latency:.3f}s")
                    bot_response = response.json().get("response", "")
                    logger.info(f"Bot response: {bot_response}")
                else:
                    logger.error(f"Cognigy API error: {response.status_code}")
# Global auth service instance
    raise Exception("Failed to obtain access token.")
async def main():
    asyncio.run(main())
Error: 401 Unauthorized on WebSocket Connection
  • Cause: The OAuth token has expired or is invalid. Genesys Cloud tokens typically expire after 1 hour.
  • Fix: Implement token refresh logic. Check the exp claim in the JWT payload before connecting. If the token is expired, call the /oauth/token endpoint again with refresh_token or client_credentials.
  • Code Fix: In the connect method, catch websockets.exceptions.InvalidStatusCode with status code 401 and refresh the token.
Error: Connection Closed by Peer (Code 1006)
  • Cause: Network instability, firewall interruptions, or idle timeout. Genesys Cloud may close idle connections.
  • Fix: Ensure you are sending periodic pings. The websockets library handles this automatically with ping_interval. Also, implement automatic reconnection with exponential backoff.
  • Code Fix: The connect loop in the complete example handles this by catching ConnectionClosed and sleeping before retrying.
Error: High Latency to Cognigy Backend
  • Cause: Network latency between your AppFoundry app and the Cognigy server, or slow processing in Cognigy.
  • Fix: Optimize the Cognigy bot flow. Use caching for frequent responses. Consider moving the AppFoundry app closer to the Cognigy server geographically.
  • Code Fix: Monitor latency using the _forward_to_cognigy method. If latency is consistently high, consider asynchronous processing where you acknowledge the Genesys Cloud event immediately and process the Cognigy call in the background.
Error: Duplicate Messages After Reconnection
  • Cause: The WebSocket reconnected and replayed events from the last sequenceId.
  • Fix: Use the sequenceId from the subscription response and track processed message IDs.
  • Code Fix: The _handle_event method checks processed_message_ids and updates last_sequence_id.
