Stabilizing WebSocket Audio Streams in Genesys Cloud AppFoundry NICE Cognigy Integrations
- A robust WebSocket client wrapper that maintains persistent connections to the Genesys Cloud AppFoundry platform, specifically handling audio stream interruptions during NICE Cognigy bot interactions.
- This tutorial uses the Genesys Cloud AppFoundry WebSocket API and the
PureCloudPlatformClientV2Python SDK for authentication management. - The code is written in Python 3.9+ using the
websocketslibrary for real-time communication andhttpxfor OAuth token management.
- OAuth Client Type: Public or Confidential Client with the
appfoundry:agent:connectscope. - SDK Version: Genesys Cloud Python SDK (
genesys-cloud-sdk) v2.10.0 or later. - Runtime Requirements: Python 3.9+, Node.js 18+ (if adapting to JavaScript), and a running Genesys Cloud organization with AppFoundry enabled.
- External Dependencies:
pip install genesys-cloud-sdk websockets httpx pydantic- A deployed AppFoundry application with a WebSocket endpoint configured to accept inbound connections.
- NICE Cognigy Studio environment with a skill configured to handle WebSocket inbound events.
Genesys Cloud AppFoundry WebSocket connections require a valid access token passed via the Authorization header during the initial WebSocket handshake. Unlike REST APIs, the WebSocket connection itself does not handle token refresh. If the token expires while the WebSocket is open, the connection will drop with a 401 Unauthorized error.
To prevent this, you must implement a background token refresh mechanism that updates the token before expiration. The following code demonstrates a robust OAuth2 client credential flow manager.
import httpx
import asyncio
from typing import Optional
class GenesysOAuthManager:
def __init__(self, client_id: str, client_secret: str, org_id: str, environment: str = "mypurecloud.com"):
self.client_id = client_id
self.org_id = org_id
self.environment = environment
self.token_url = f"https://api.{environment}/oauth/token"
self.refresh_time: float = 0
self.token_expiry_seconds = 3600 # Standard Genesys token life
Retrieves a new access token if the current one is expired or does not exist.
Uses client credentials flow.
current_time = time.time()
# Check if token is still valid (add 5-minute buffer for safety)
if self.access_token and (current_time - self.refresh_time) < (self.token_expiry_seconds - 300):
return self.access_token
async with httpx.AsyncClient() as client:
response = await client.post(
self.token_url,
headers={"Content-Type": "application/x-www-form-urlencoded"},
data={
"client_id": self.client_id,
"org_id": self.org_id
response.raise_for_status()
data = response.json()
self.access_token = data["access_token"]
self.refresh_time = current_time
raise RuntimeError(f"Failed to obtain OAuth token: {e.response.status_code} {e.response.text}") from e
async def keep_alive_loop(self):
Background task to ensure the token is refreshed before it expires.
while True:
await self.get_token()
await asyncio.sleep(self.token_expiry_seconds - 300) # Refresh 5 mins before expiry
print(f"Token refresh error: {e}")
await asyncio.sleep(10) # Backoff on error
Step 1: Establishing the WebSocket Connection with Retry Logic
WebSocket connections to AppFoundry are stateful. When a connection drops due to network instability or server-side timeouts, the client must reconnect. A naive reconnection strategy can cause thundering herd problems or hit rate limits. You must implement exponential backoff.
The AppFoundry WebSocket endpoint follows this pattern: wss://api.{environment}/v2/appfoundry/apps/{appId}/websockets/{websocketId}.
import websockets
import json
import uuid
import logging
class AppFoundryWebSocketClient:
def __init__(self, oauth_manager: GenesysOAuthManager, app_id: str, websocket_id: str, environment: str = "mypurecloud.com"):
self.oauth_manager = oauth_manager
self.app_id = app_id
self.websocket_id = websocket_id
self.ws_url = f"wss://api.{environment}/v2/appfoundry/apps/{app_id}/websockets/{websocket_id}"
self.ws = None
self.is_connected = False
self.max_retries = 10
self.base_delay = 2
async def connect(self):
Initiates the WebSocket connection with OAuth headers.
Implements exponential backoff for reconnection attempts.
retry_count = 0
while retry_count < self.max_retries:
# Get fresh token for handshake
token = await self.oauth_manager.get_token()
# Construct headers required by Genesys Cloud AppFoundry
headers = {
logger.info(f"Attempting to connect to {self.ws_url}")
# Connect with timeout settings to prevent hanging
self.ws = await websockets.connect(
self.ws_url,
additional_headers=headers,
ping_interval=20, # Send ping every 20s to keep connection alive
ping_timeout=10, # Wait 10s for pong before assuming dead
close_timeout=5 # Time to wait for close handshake
self.is_connected = True
logger.info("WebSocket connected successfully.")
return True
except websockets.exceptions.InvalidStatusCode as e:
if e.code == 401:
logger.warning("Authentication failed. Token may have expired. Refreshing...")
# Force token refresh
elif e.code == 403:
logger.error("Forbidden. Check AppFoundry permissions and scopes.")
return False
elif e.code == 404:
logger.error(f"App or WebSocket ID not found: {self.ws_url}")
return False
else:
logger.error(f"Unexpected status code: {e.code}")
return False
except (ConnectionRefusedError, OSError, websockets.exceptions.ConnectionClosed) as e:
logger.warning(f"Connection failed: {e}. Retrying in {self.base_delay ** retry_count} seconds...")
await asyncio.sleep(self.base_delay ** retry_count)
retry_count += 1
logger.error(f"Unexpected error during connection: {e}")
return False
logger.error("Max retries reached. Giving up.")
return False
async def send_message(self, message: dict):
Sends a JSON message to the WebSocket.
Handles connection drops gracefully.
if not self.is_connected or self.ws is None:
logger.warning("Not connected. Attempting to reconnect...")
if not await self.connect():
raise ConnectionError("Failed to reconnect.")
await self.ws.send(json.dumps(message))
except websockets.exceptions.ConnectionClosed as e:
logger.error(f"Connection closed during send: {e}")
# Trigger reconnection logic in the main loop
raise
Step 2: Handling Audio Stream Interruptions and Latency
In NICE Cognigy integrations, audio is often streamed via WebSocket frames. High latency or dropped packets can cause the bot to miss speech recognition events. The key to mitigating this is not just keeping the connection alive, but ensuring that the application layer detects “silence” or “stale” connections even if the TCP layer remains open.
Genesys Cloud AppFoundry supports custom payload types. For audio integrations, you typically send audio frames and receive transcript or intent events.
class AudioStreamHandler:
def __init__(self, ws_client: AppFoundryWebSocketClient):
self.ws_client = ws_client
self.last_activity_time = time.time()
self.inactivity_timeout = 30 # Seconds before considering stream dead
async def listen_for_messages(self):
Continuously listens for incoming WebSocket messages.
Detects inactivity to trigger proactive reconnection.
if not await self.ws_client.connect():
return
async for message in self.ws_client.ws:
data = json.loads(message)
await self.process_inbound_message(data)
except json.JSONDecodeError:
logger.warning(f"Received non-JSON message: {message[:100]}")
# Check for inactivity
if time.time() - self.last_activity_time > self.inactivity_timeout:
logger.warning("No activity detected for 30s. Assuming stale connection.")
await self.handle_stale_connection()
logger.error(f"WebSocket closed unexpectedly: {e.code} {e.reason}")
await self.handle_connection_drop()
logger.error(f"Error in listen loop: {e}")
async def process_inbound_message(self, data: dict):
Processes incoming messages from Genesys Cloud/Cognigy.
msg_type = data.get("type")
if msg_type == "audio":
# Handle audio chunk (typically base64 encoded PCM)
logger.debug("Received audio chunk")
elif msg_type == "transcript":
logger.info(f"Transcript received: {data.get('text')}")
elif msg_type == "intent":
logger.info(f"Intent matched: {data.get('intent')}")
elif msg_type == "error":
logger.error(f"Genesys Error: {data.get('message')}")
else:
logger.debug(f"Unknown message type: {msg_type}")
async def handle_stale_connection(self):
Proactively closes and reconnects if the connection appears stale.
logger.info("Proactively resetting connection due to inactivity.")
await self.ws_client.ws.close()
self.ws_client.is_connected = False
# The main loop should catch this and reconnect via connect()
raise websockets.exceptions.ConnectionClosed(1001, "Stale connection reset")
async def handle_connection_drop(self):
Handles unexpected drops by scheduling an immediate reconnect attempt.
logger.info("Connection dropped. Scheduling reconnect...")
# In a production app, you would signal the main event loop to restart the listener
await asyncio.sleep(1)
Step 3: Integrating with NICE Cognigy via Outbound Events
When using NICE Cognigy as the bot engine, the AppFoundry application often acts as a bridge. You may need to send user input to Cognigy and receive responses. The following code demonstrates how to structure outbound messages to trigger Cognigy skills via the AppFoundry platform.
async def trigger_cognigy_skill(ws_client: AppFoundryWebSocketClient, user_text: str, session_id: str):
Sends a text input event to the Genesys Cloud AppFoundry endpoint,
which routes it to the configured NICE Cognigy skill.
payload = {
"type": "event",
"event": "userInput",
"data": {
"text": user_text,
"sessionId": session_id,
"timestamp": time.time()
await ws_client.send_message(payload)
logger.info(f"Sent userInput to Cognigy: {user_text}")
except ConnectionError as e:
logger.error(f"Failed to send message: {e}")
The following script combines all components into a runnable application. It initializes the OAuth manager, starts the background token refresh, connects to the WebSocket, and begins listening for audio/transcript events.
import asyncio
import argparse
import sys
# Import classes defined in previous sections
# from auth_manager import GenesysOAuthManager
# from ws_client import AppFoundryWebSocketClient
# from audio_handler import AudioStreamHandler
async def main(client_id: str, client_secret: str, org_id: str, app_id: str, websocket_id: str):
# 1. Initialize OAuth Manager
oauth_manager = GenesysOAuthManager(
client_id=client_id,
client_secret=client_secret,
org_id=org_id
# 2. Start Token Refresh Background Task
refresh_task = asyncio.create_task(oauth_manager.keep_alive_loop())
# 3. Initialize WebSocket Client
ws_client = AppFoundryWebSocketClient(
oauth_manager=oauth_manager,
app_id=app_id,
websocket_id=websocket_id
# 4. Initialize Audio/Message Handler
handler = AudioStreamHandler(ws_client)
# 5. Start Listening Loop
# This loop will continuously try to reconnect if the connection drops
while True:
await handler.listen_for_messages()
logger.warning("Connection lost. Reconnecting in 5 seconds...")
await asyncio.sleep(5)
except KeyboardInterrupt:
logger.info("Shutting down...")
finally:
refresh_task.cancel()
await refresh_task
except asyncio.CancelledError:
pass
parser = argparse.ArgumentParser(description="Genesys Cloud AppFoundry WebSocket Client for Cognigy")
parser.add_argument("--client-id", required=True)
parser.add_argument("--client-secret", required=True)
parser.add_argument("--org-id", required=True)
parser.add_argument("--app-id", required=True)
parser.add_argument("--websocket-id", required=True)
args = parser.parse_args()
asyncio.run(main(
client_id=args.client_id,
client_secret=args.client_secret,
org_id=args.org_id,
app_id=args.app_id,
websocket_id=args.websocket_id
Error: 401 Unauthorized on WebSocket Handshake
- Cause: The OAuth token provided in the
Authorizationheader is expired or invalid. - Fix: Ensure your
GenesysOAuthManageris refreshing the token before expiration. The WebSocket handshake does not support token negotiation; it must be valid at the moment of connection. Check that your client credentials have theappfoundry:agent:connectscope.
Error: Connection Closed by Peer (Code 1000)
- Cause: The server intentionally closed the connection, often due to idle timeout or a protocol error.
- Fix: Verify that you are sending periodic pings. Genesys Cloud may close idle connections. Ensure your
ping_intervalis set to less than the server’s idle timeout (typically 60 seconds). Setping_interval=20inwebsockets.connect.
Error: High Audio Latency or Choppy Audio
- Cause: Network jitter or large message batches causing queueing delays.
- Fix: Reduce the size of audio chunks sent over the WebSocket. Instead of sending large buffers, send smaller, more frequent chunks (e.g., 20ms of PCM data). Ensure your client is processing inbound messages asynchronously to prevent blocking the receive loop.
Error: 403 Forbidden
- Cause: The OAuth client lacks the necessary permissions to access the specific AppFoundry application or WebSocket endpoint.
- Fix: Verify that the client ID is associated with an agent or system user that has access to the AppFoundry application. Check the “Scopes” tab in the Genesys Cloud Admin console for the OAuth client.
