I’ve defined a range of extensions in the configuration manager. That was easy and fast.
The hard part is defining the “places” that refer to them. I can’t find any way to create these except individually: create each place, then right-click on it, create new shortcut to DN, drill down through the switch, the DNs, the extensions, and scroll down to the extension I want it to point to. And “View > Options > Make new in properties of existing objects” doesn’t work here.
Since I have hundreds of these to create, it’s a giant pain in the ass, not to mention a huge waste of time. I should send Genesys a bill for the time I’m spending on this. It’s sysadmin with crayons.
Interesting notion, but we don’t use XML. We use a SQLServer database. Also, when working in “places”, there’s nowhere to do an import – i.e., the CME doesn’t offer an import function.
It’s not obvious how to do this, because I had already dug around and looked for it. The wizard doesn’t do this, either for “install” or “configure” in “places”. Maybe it’s somewhere else altogether. If so, that isn’t obvious, either, because I looked for it, too. It’s nowhere in the GUI that I can find.
You can create place and extension at the same time by using wizard, only at that time that you can create the association between the two automatically. If it’s possible, I will try to recreate extension again.
