I am trying to install Platform SDK version 8.5.201.4. I downloaded and installed the corresponding file from the Genesys website. However, I am missing two JARs:
appblocks-bom.jar
protocols-bom.jar
These two files were not generated when I installed the API, instead I only got the POM files.
My projects do not compile without those files. I get the following error:
Failed to read artifact descriptor for com.genesyslab.platform:comappblock:jar:852.1.4: Could not find artifact com.genesyslab.platform:appblocks-bom:pom:852.1.4
Can you explain more about how you installed PSDK Java?
Did you follow the instructions in the readme.txt file?
In the lib\pom folder you should have a number of .pom files such as āappblocks-bom.pomā and āprotocol.bomā
To build the project, follow one of the next instructions.
Build with Maven.
Install parent pom files to the local repo (or upload to your company repository manager, for example Nexus):
mvn org.apache.maven.plugins:maven-install-plugin:2.5.2:install-file -Dfile=\lib\pom\appblocks-bom.pom -DpomFile=\lib\pom\appblocks-bom.pom
mvn org.apache.maven.plugins:maven-install-plugin:2.5.2:install-file -Dfile=\lib\pom\protocols-bom.pom -DpomFile=\lib\pom\protocols-bom.pom
Install all Platform SDK libraries from \lib to maven local repository.
For example:
mvn org.apache.maven.plugins:maven-install-plugin:2.5.2:install-file -Dfile=\lib\kvlists.jar -DpomFile=\lib\pom\kvlists.pom
Import Maven project from \applicationblocks\com to you IDE.
Pay attention, that āgeneratedā folder should be added to Source Path in you IDE to avoid errors highlighting.
However, during Maven build, āgeneratedā folder will be automatically attached to source path
with build-helper-maven-plugin, defined in the pom file.
To build the project from command line, run āmvn clean installā command under the
\applicationblocks\com directory. It will build and install
Configuration Object Model Application Block artifact to the local Maven repository.
I installed them to my local repository following the instructions on the readme file.
I ran:
ā¦and likewise for all the others, but I got an error with the two files listed above because the .jar files were not present in the lib folder.
Edit: I just tried adding the comappblock IDE (I picked that one because it was the first one), and I got the following error:
Project build error: Non-resolvable import POM: Failure to find com.genesyslab.platform:appblocks-bom:pom:852.1.4 in https://repo.maven.apache.org/maven2 was cached in the local repository, resolution will not be reattempted until the update interval of central has elapsed or updates are forced
