Anyone using Solution in CME to start and stop applications in order in SCI? If so do you have documentation on the proper startup/shutdown order?
Hi !
We are using Solution to stop and start Workforce Manager.
Is there a special solution your looking for or just any ?
WFM Start order:
1: StatServer
2: ScheduleServer
3: DataAggregator
Regards
Mikael Jansson
I would be interested to see how others stop and start an Enterprise Routing solution:
CCPulse
URS
GIS
Custom Server
etc
Graeme
The most interesting is start of CCPulse with SCI ;0)
Perhaps I should turn my brain on before I comment next time…
It is scary but it took me a while to realize it! Superlglide
ice going! ![]()
(skipping backups)
cfg_dbserver
confserv
LogDBServer
MessageServer
SCS <-heck, maybe I am doing it from backup)
TServer
Stat Server
URS
and of course…
CCPulse ![]()
See I was right… Even Vic uses SCI to manage CCPulse… :()
But back to the thread… The operational team here are a bit dubious about the “one click stops all” approach, particulairly with the SQL cluster in the background, which can add complexity to it all (mainly because they are not DBAs). Does anyone actually stop and start a solution such as Vics example using SCI or do they manually do it as our Ops team do (they found a way that works, but is really dependant upon them to come into work and do etc..)
Graeme
We always manage it through cluster management system or if there isn’t cluster then with windoze service or unix autostart scripts after boot. For that is the start through solutions not realy usefull for us.
It’s realy pity that the genesys management solution doesn’t have auto start function (not autorestart). Or has anybody other expriences?
Latest 7.01 SCS server supports auto start .
Check the release notes!
TONY:
I am not sure how the formating will look, but here is how our SCI solutions for a (3) site system. I am not sure I totally agree with the configuration, but this how our vendor set it up and we are living with it.
Reporting
Name Status Mode Startup Type Host
dbserver_log Started PRIMARY 1 DB Server WFM Server
dbserver_ers Started PRIMARY 1 DB Server CCA Server
ETL_Service Started PRIMARY 3 CCAnalyzer Data Mart CCA Server
CCA_DataSourcer Started PRIMARY 4 CC Analyzer
Data Sourcer CCA Server
dbserver_cca Started PRIMARY 1 DB Server CCA Server
statserver_ccpulse Started PRIMARY 4 Stat Server WEB Server
statserver_global Started PRIMARY 4 Stat Server Tacoma CTI
Workforce Management
msgserver_global Started PRIMARY 1 Message Server WFM Server
wfm_da651
Started PRIMARY 3 WFM Data
Aggregator WFM2 Server
wfm_ss651 Started PRIMARY 2 WFM Schedule Server WFM2 Server
statserver_wfm Started PRIMARY 1 Stat Server WFM2 Server
Seattle
statserver_sea Started PRIMARY 4 Stat Server Seattle CTI
statserver_seaR Started PRIMARY 4 Stat Server Seattle CTI
dbserver_ers Started PRIMARY 3 DB Server CCA Server
tserver_seattle_s Started PRIMARY 1 TServer Seattle CTI
ivri_seattle Started PRIMARY 2 IVR Interface Server Seattle CTI
urs_seattle Started PRIMARY 4 Universal Routing Server Seattle CTI
msgserver_sea Started PRIMARY 1 Message Server Seattle CTI
Tacoma
statserver_tac Started PRIMARY 4 Stat Server Tacoma CTI
statserver_tacR Started PRIMARY 4 Stat Server Tacoma CTI
tserver_tacoma_s Started PRIMARY 1 TServer Tacoma CTI
ivri_tacoma Started PRIMARY 2 IVR Interface Server Tacoma CTI
urs_tacoma Started PRIMARY 4 Universal Routing Server Tacoma CTI
msgserver_tac Started PRIMARY 1 Message Server Tacoma CTI
Spokane
statserver_spo Started PRIMARY 4 Stat Server Spokane CTI
statserver_spoR Started PRIMARY 4 Stat Server Spokane CTI
tserver_spokane_s Started PRIMARY 1 TServer Spokane CTI
ivri_spokane Started PRIMARY 2 IVR Interface Server Spokane CTI
urs_spokane Started PRIMARY 4 Universal Routing Server Spokane CTI
msgserver_spo Started PRIMARY 1 Message Server Spokane CTI
We use a batch file in combination with PS Tools a free program. This allows us to start each service in order by executing a batch file. I had our programmer write a nifty little script that will also make sure the service has started before going on to the next.
It is really nice for us since we have about 20 services to start. It works for restarting the whole suite as well.
