Trying to hit the softphone token endpoint. Documentation clearly states: “The mediaServerToken is required for establishing WebRTC connections and must be obtained via the telephony edges media server token endpoint.”
Java SDK 2024.10.0. Spring Boot service. Passing the X-Genesys-Application header. It’s still throwing 403. ApiClient configured with client credentials flow. Scope matches docs. Token request keeps failing.
The 403 hits because of a scope mismatch. X-Genesys-Application just tags the request. It doesn’t grant permissions. You’ll need telephony:edges:read on the OAuth token itself. The Java SDK 2024.10.0 also expects the applicationId in the request builder, not just via headers.
Check the app registration in GC admin. If it’s still sitting in sandbox mode, production tokens will bounce immediately. What’s the exact applicationId format you’re using? Also, are you routing through api.au.genesys.cloud? Sydney endpoints sometimes default to US if the base URL isn’t explicit. Mismatched region throws a 403 before it even checks scopes. Just make sure the cache isn’t holding onto an old bearer string.
The platform documentation explicitly states that the mediaServerToken endpoint requires telephony:edges:read on the bearer token, but there’s a hidden routing gotcha when you pass X-Genesys-Application without matching the regional edge cluster. The problem happens because the token service validates the application ID against the physical edge location, and a mismatch triggers a silent 403 before the SDK even parses the response.
// TS equivalent for your Spring service config
const token = await platformClient.AuthenticationApi.postOAuth2Token({
body: { grant_type: "client_credentials", scope: "telephony:edges:read telephony:softphone" }
const edgesApi = platformClient.TelephonyProvidersEdgesApi();
const response = await edgesApi.getTelephonyProvidersEdgesMediaServerToken({
applicationId: "your-app-id",
xGenesysApplication: "com.yourcompany.softphone"
You’ll hit a 401 UNAUTHORIZED if the scope string misses telephony:softphone, and a 403 FORBIDDEN usually means the application ID isn’t registered in the target region’s edge manifest. The error payload rarely shows the actual cluster mismatch, just a generic forbidden response. Has anyone else seen the edge manifest cache delay cause this exact behavior after deploying a new app version. The cache usually clears in about ten minutes anyway. Pretty annoying when it hangs.
403 Forbidden: {“code”:“FORBIDDEN”,“message”:“Access denied. Application ID validation failed.”}
The scope isn’t the only culprit here. The Java SDK 2024.10.0 drops the applicationId if you don’t bind it to the request object explicitly. Headers get ignored for the token endpoint validation. You’ll get a silent 403 even with telephony:edges:read if the ID is missing.
TelephonyEdgesApi edgesApi = client.getTelephonyEdgesApi();
GetTelephonyEdgesMediaServerTokenRequest request = new GetTelephonyEdgesMediaServerTokenRequest();
request.setApplicationId("your-app-guid"); // Required
request.setEdgeId("us-east-1"); // Match your cluster
MediaServerTokenResponse token = edgesApi.getTelephonyEdgesMediaServerToken(request);
Also check your timeout settings. Token generation hits the edge cluster directly and can lag on cold starts. The default SDK timeout might cut the connection before the response arrives. Set it to 5000ms minimum. This kills the request mid-stream.
