Hi..
Im realizing tests with SIPServer 7.6, with Genesys Agent Desktop and X ???lite, my problem happens when im called one an internal annex, this is my test:
It is generated called an annex from GAD or of X-lite from the Place 1000 (I Annex 1000) the Place 1002 (attached 1002), as soon as the call is answered for the annex 1002 for Xlite or GAD this produce an event of “Hung Up” of the so called one.
Check the used audio codec list in all server&client properties. An it’s support on workstation. I think the general problem in this waring what came from 1002 DN:
Thanks very much for you helpme, Exactly the problem was happening for the codecs of the prompt. Good Eye.
I change the codecs and test y all worked very fine.
