Good morning,
I just managed to use correctly the sip endpoint with sdk 8.1.
I want to enable sip endpoint configuration with config manager, however sip endpoint config is on an xml file so to possiblities:
[] Create as many key values in an annex object and rebuild on the fly xml file before passing it to constroctor : it makes me afraid
[] Passing xml file content in the config server side : how can I do this since as I understand the key values to store data only seem to be able to store single line data
Thierry Brémard
[email removed]
