Got couple of questions related to SIP DN’s
RM and MCP call id’s
If a call passes through different Route points under one switch, will sip create new call id for each route point?
example : if a call lands on say route point 1, will there be a invite to that DN and a call id and same to route point 2.
- No, never, connID is unique
And that is quite easy to test on an environment
Thanks for the response, this is what i am seeing
call comes into gvp: there is a conn id
Immediately there is a Call id created for RP under this GVP (as it is SIP)
Call ID1 is created in the RM
Call ID2 is created in the RM
Call ID 1 appears in the MCP logs
What? Show logs pls.
Each SIP invite call will have a unique identifier as it is jumping. If you need a unique ID use CONNID.
