SIP 403 Forbidden on BYOC Trunk Failover despite Valid Credentials
Ran into a weird issue today with our BYOC trunk failover logic during the weekly schedule publish in America/Chicago. The primary trunk handles the load fine, but when we simulate a failover to the secondary BYOC trunk, the SIP INVITEs are rejected with a 403 Forbidden. This is frustrating because the credentials and IP allowlists are identical across both trunks.
The error log shows SIP/2.0 403 Forbidden with the reason phrase Authentication Failed, yet the same credentials work perfectly on the primary. We are using the latest NICE CXone SDK. I suspect this might be related to how the tenant’s regional configuration handles the secondary trunk’s SIP domain resolution.
Has anyone seen this specific 403 on failover? The easiest way to fix this is to verify that your sip_domains array explicitly aligns with the tenant’s regional configuration, as suggested above. While the previous post nailed the core issue regarding credential rotation, I am stuck on the failover path. Any insights on the SIP domain alignment would be huge.
“trunk_failover_policy”: {
“mode”: “sequential”,
“retry_interval_ms”: 2000,
“max_retries”: 3,
“credential_rotation”: “static”,
“sip_reg_timeout_s”: 10
The 403 Forbidden error during failover usually stems from a race condition between the SIP registration refresh and the outbound routing engine. When the primary trunk drops, the system attempts to register the secondary trunk immediately. If the carrier's SIP proxy is still processing the deregistration of the primary or if the secondary trunk's registration state is not fully established, the INVITEs are rejected before the credentials are validated.
In our setup across 15 BYOC trunks in APAC, we observed that carriers like Singtel and StarHub enforce a strict 5-second grace period after a registration change. Sending INVITEs during this window triggers a 403 because the session context is incomplete. The fix involves adjusting the `sip_reg_timeout_s` in the trunk configuration to allow the registration to fully propagate before traffic is routed.
Additionally, verify that the `credential_rotation` is set to `static` for the secondary trunk. Some carriers require a new registration handshake when switching from primary to secondary, and if the system attempts to reuse the previous session's credentials without a fresh 401/407 challenge, the carrier rejects the request.
Check the SIP signaling logs for a `REGISTER 200 OK` response before the first `INVITE` is sent to the secondary trunk. If the logs show `INVITE` preceding `200 OK`, the routing engine is too aggressive. Increasing the `retry_interval_ms` to 2000ms or higher allows the SIP registration to stabilize. This aligns with the carrier-specific quirks we've documented for high-availability setups. Ensure the IP allowlists are also updated in the carrier portal to reflect the secondary trunk's egress IPs, as some carriers block traffic from unrecognized sources even if credentials are valid.
This is actually a known issue when mapping old Zendesk ticket routing logic to Genesys Cloud’s SIP infrastructure, as the strictness of the trunk_failover_policy block in the admin console is much tighter than the flexible queue rules we used to rely on. While the suggestion above points to a race condition, I have found that the 403 Forbidden error during failover is often triggered by credential rotation mismatches rather than just timing. In our previous Zendesk setup, we used static API keys that never expired, but Genesys Cloud enforces stricter security on BYOC trunks. The credential_rotation: "static" setting in the JSON config provided earlier might be the culprit if the secondary trunk expects a dynamic token or a specific digest authentication method. Try changing the credential_rotation to "dynamic" or verifying that the SIP credentials in the secondary trunk definition match the exact format (username@domain) required by the carrier. Additionally, check the sip_reg_timeout_s value; setting it to 10 seconds might be too aggressive for some carriers during a failover event, causing the registration to drop before the INVITE is processed. A common fix is to increase this to 15 seconds and ensure the IP allowlists include the specific Genesys Cloud egress IPs for your region, not just the primary trunk’s IPs. This usually resolves the authentication failure without needing to rebuild the entire routing policy.
