Simulating NICE CXone IVR Flow Execution with Python via the Flow Debug API
- You will build a Python script that simulates NICE CXone IVR flows by sending HTTP POST requests to the Flow Debug API.
- You will inject mock DTMF sequences and speech inputs to trigger specific routing paths.
- You will capture node execution traces, validate variable states, detect infinite loops through state machine analysis, and export structured debug reports for quality assurance.
- OAuth Client Credentials grant with
flow:debugandflow:readscopes - NICE CXone API v2
- Python 3.9+
requests(v2.28+),pyyaml(v6.0+)- Active CXone organization with at least one published IVR flow ID
- Network access to your regional CXone API gateway (e.g.,
api-us-1.cxone.com)
CXone uses standard OAuth 2.0 Client Credentials flow. You must exchange your client ID and secret for a bearer token before calling the Flow Debug API. The token expires after 60 minutes, so you must implement refresh logic for long-running automation.
import requests
from typing import Optional
BASE_URL = "https://api-us-1.cxone.com"
OAUTH_ENDPOINT = f"{BASE_URL}/oauth2/token"
def get_access_token(client_id: str, client_secret: str) -> str:
"""Exchange client credentials for a CXone OAuth bearer token."""
payload = {
"client_id": client_id,
"client_secret": client_secret,
"scope": "flow:debug flow:read"
response = requests.post(OAUTH_ENDPOINT, data=payload, timeout=10)
response.raise_for_status()
token_data = response.json()
if "access_token" not in token_data:
raise ValueError("OAuth response missing access_token field")
return token_data["access_token"]
The request targets /oauth2/token with application/x-www-form-urlencoded content. The response returns a JSON object containing access_token, expires_in, and token_type. You must cache the token and regenerate it when expires_in is reached. The flow:debug scope grants permission to execute the simulation endpoint. The flow:read scope allows you to fetch flow metadata if you need to validate node definitions before simulation.
Step 1: Construct Debug Payload & Execute Simulation
The Flow Debug API accepts a single HTTP POST request that simulates an entire IVR execution path. You must provide the flow identifier, input vectors (DTMF or speech), and initial variables. The API returns the complete execution trace, final variable state, and exit node.
import json
from typing import Dict, Any
def simulate_flow(token: str, flow_id: str, dtmf_sequence: str = "",
speech_input: str = "", initial_variables: Optional[Dict[str, Any]] = None) -> Dict[str, Any]:
"""Execute the CXone Flow Debug API with mock inputs."""
endpoint = f"{BASE_URL}/api/v2/flows/debug"
headers = {
"Accept": "application/json"
body = {
"flowId": flow_id,
"input": {
"dtmf": dtmf_sequence,
"speech": speech_input
"options": {
"trace": True,
"includeVariables": True,
"maxLoops": 50
if initial_variables:
body["variables"] = initial_variables
response = requests.post(endpoint, json=body, headers=headers, timeout=30)
retry_after = int(response.headers.get("Retry-After", 2))
time.sleep(retry_after)
return response.json()
# Expected Request:
# POST /api/v2/flows/debug
# Headers: Authorization: Bearer <token>, Content-Type: application/json
# Body: {"flowId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890", "input": {"dtmf": "123", "speech": ""}, "options": {"trace": true, "includeVariables": true, "maxLoops": 50}}
# Expected Response:
# "path": ["node_start", "node_menu_1", "node_route_sales", "node_exit"],
# "variables": {"customer_id": "CUST-998", "selected_option": "1", "attempt_count": 1},
# "exitNode": "node_exit",
# "duration": 145,
# "trace": [
# {"nodeId": "node_start", "type": "Start", "timestamp": 0},
# {"nodeId": "node_menu_1", "type": "GatherInput", "timestamp": 45, "input": "123"},
# {"nodeId": "node_route_sales", "type": "Route", "timestamp": 90, "target": "queue_sales"},
# {"nodeId": "node_exit", "type": "Exit", "timestamp": 145, "status": "Completed"}
The maxLoops parameter prevents the API from hanging on malformed flows. The trace option enables node-by-node execution logging. The response contains a path array representing the routing sequence, a variables object with final state, and a trace array with timestamps and node metadata. You must validate that response.raise_for_status() catches 4xx and 5xx errors before parsing JSON.
Step 2: Parse Execution Trace & Validate Routing Logic
You must compare the actual execution path against an expected routing sequence. This validates that DTMF or speech inputs trigger the correct conditional branches. You will also extract variable states to verify data persistence across nodes.
from typing import List, Tuple
def validate_routing(actual_path: List[str], expected_path: List[str]) -> Tuple[bool, List[str]]:
"""Compare actual flow execution against expected routing sequence."""
mismatches = []
if len(actual_path) != len(expected_path):
mismatches.append(f"Path length mismatch: expected {len(expected_path)}, got {len(actual_path)}")
min_len = min(len(actual_path), len(expected_path))
for idx in range(min_len):
if actual_path[idx] != expected_path[idx]:
mismatches.append(f"Node mismatch at step {idx}: expected {expected_path[idx]}, got {actual_path[idx]}")
return len(mismatches) == 0, mismatches
def extract_variable_states(trace_data: Dict[str, Any]) -> Dict[str, Any]:
"""Extract and flatten variable states from the debug response."""
variables = trace_data.get("variables", {})
trace_entries = trace_data.get("trace", [])
variable_history = {}
for entry in trace_entries:
node_id = entry.get("nodeId", "unknown")
if "variables" in entry:
variable_history[node_id] = entry["variables"]
"final_state": variables,
"node_history": variable_history
The validate_routing function performs a strict sequential comparison. IVR flows often use parallel branches or skip logic, so you must define the expected path based on your test case. The extract_variable_states function captures how variables mutate at each node. This is critical for verifying that DTMF parsing, speech recognition confidence scores, and custom script outputs persist correctly.
Step 3: Detect Infinite Loops via State Machine Analysis
CXone flows can enter infinite loops when conditional logic creates circular references. The debug API returns a path array that repeats node identifiers when a loop occurs. You must analyze this sequence to detect cycles before they cause production call grid exhaustion.
def detect_infinite_loops(execution_path: List[str], max_repeat_threshold: int = 3) -> Dict[str, Any]:
"""Analyze execution path for circular routing patterns."""
node_counts: Dict[str, int] = {}
first_occurrence: Dict[str, int] = {}
for idx, node_id in enumerate(execution_path):
if node_id not in first_occurrence:
first_occurrence[node_id] = idx
node_counts[node_id] = node_counts.get(node_id, 0) + 1
loop_candidates = [node for node, count in node_counts.items() if count > max_repeat_threshold]
loops_detected = []
for candidate in loop_candidates:
start_idx = first_occurrence[candidate]
# Find the range where the node repeats
occurrences = [i for i, n in enumerate(execution_path) if n == candidate]
if len(occurrences) >= 2:
segment = execution_path[occurrences[0]:occurrences[-1]+1]
loops_detected.append({
"nodeId": candidate,
"occurrences": len(occurrences),
"loop_segment": segment,
"start_index": occurrences[0],
"end_index": occurrences[-1]
"has_loops": len(loops_detected) > 0,
"loop_details": loops_detected,
"total_nodes_executed": len(execution_path),
"unique_nodes": len(node_counts)
The state machine analysis counts node frequency and identifies segments where execution revisits the same identifier. The max_repeat_threshold parameter defines how many repetitions constitute a loop. Standard IVR menus may repeat for input retries, so you set the threshold to 3 to distinguish between valid retry logic and broken circular routing. The function returns structured loop details that you can attach to quality assurance reports.
Step 4: Export Debug Reports for Quality Assurance
You must consolidate simulation results, validation outcomes, and loop analysis into a structured report. YAML provides human-readable formatting for QA teams, while JSON enables programmatic ingestion into CI/CD pipelines.
import yaml
from datetime import datetime
def generate_debug_report(flow_id: str, simulation_result: Dict[str, Any],
routing_validation: Tuple[bool, List[str]],
loop_analysis: Dict[str, Any],
variable_states: Dict[str, Any]) -> str:
"""Export complete debug session to YAML format."""
report = {
"report_metadata": {
"generated_at": datetime.utcnow().isoformat() + "Z",
"flow_id": flow_id,
"api_version": "v2",
"simulation_duration_ms": simulation_result.get("duration", 0)
"execution_summary": {
"exit_node": simulation_result.get("exitNode", "Unknown"),
"total_nodes": len(simulation_result.get("path", [])),
"routing_valid": routing_validation[0],
"routing_mismatches": routing_validation[1]
"state_machine_analysis": loop_analysis,
"variable_states": variable_states,
"raw_trace": simulation_result.get("trace", [])
return yaml.dump(report, default_flow_style=False, sort_keys=False)
The report structure groups metadata, execution summary, loop analysis, and variable states. You can pipe this output to a file or HTTP POST it to a logging service. The raw_trace field preserves the full API response for deep inspection. YAML serialization handles nested dictionaries cleanly without requiring external schema validation.
The following script combines authentication, simulation, validation, loop detection, and report generation into a single executable module. Replace the placeholder credentials and flow ID before execution.
import requests
import yaml
import json
from typing import Dict, Any, List, Optional, Tuple
DEBUG_ENDPOINT = f"{BASE_URL}/api/v2/flows/debug"
payload = {
return response.json()["access_token"]
def simulate_flow(token: str, flow_id: str, dtmf: str = "", speech: str = "",
body = {
"flowId": flow_id,
"input": {"dtmf": dtmf, "speech": speech},
"options": {"trace": True, "includeVariables": True, "maxLoops": 50}
if variables:
body["variables"] = variables
for attempt in range(3):
response = requests.post(DEBUG_ENDPOINT, json=body, headers=headers, timeout=30)
retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
print(f"Rate limited. Retrying in {retry_after}s...")
raise RuntimeError("Max retries exceeded for Flow Debug API")
def validate_routing(actual: List[str], expected: List[str]) -> Tuple[bool, List[str]]:
mismatches = []
if len(actual) != len(expected):
mismatches.append(f"Length mismatch: expected {len(expected)}, got {len(actual)}")
for i in range(min(len(actual), len(expected))):
if actual[i] != expected[i]:
mismatches.append(f"Step {i}: expected {expected[i]}, got {actual[i]}")
def detect_infinite_loops(path: List[str], threshold: int = 3) -> Dict[str, Any]:
first: Dict[str, int] = {}
for idx, node in enumerate(path):
if node not in first:
first[node] = idx
counts[node] = counts.get(node, 0) + 1
candidates = [n for n, c in counts.items() if c > threshold]
loops = []
for cand in candidates:
occ = [i for i, n in enumerate(path) if n == cand]
if len(occ) >= 2:
loops.append({
"nodeId": cand,
"occurrences": len(occ),
"segment": path[occ[0]:occ[-1]+1]
return {"has_loops": len(loops) > 0, "details": loops, "total_nodes": len(path)}
def run_simulation():
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
FLOW_ID = "a1b2c3d4-e5f6-7890-abcd-ef1234567890"
EXPECTED_PATH = ["node_start", "node_gather_menu", "node_route_support", "node_exit"]
print("Authenticating...")
token = get_access_token(CLIENT_ID, CLIENT_SECRET)
print("Executing flow simulation...")
result = simulate_flow(token, FLOW_ID, dtmf="2", speech="", variables={"test_mode": True})
print("Validating routing logic...")
is_valid, mismatches = validate_routing(result.get("path", []), EXPECTED_PATH)
print("Analyzing state machine for loops...")
loop_analysis = detect_infinite_loops(result.get("path", []))
print("Exporting debug report...")
report = {
"metadata": {"generated": datetime.utcnow().isoformat() + "Z", "flow_id": FLOW_ID},
"execution": {"exit_node": result.get("exitNode"), "valid": is_valid, "mismatches": mismatches},
"loop_analysis": loop_analysis,
"variables": result.get("variables", {}),
"trace": result.get("trace", [])
output = yaml.dump(report, default_flow_style=False, sort_keys=False)
with open("cxone_flow_debug_report.yaml", "w") as f:
f.write(output)
print("Report saved to cxone_flow_debug_report.yaml")
run_simulation()
The script handles token acquisition, simulation execution with retry logic for 429 responses, routing validation, loop detection, and YAML export. You must replace CLIENT_ID, CLIENT_SECRET, and FLOW_ID with your organization values. The run_simulation function demonstrates the complete workflow in a single execution path.
- What causes it: Expired or invalid OAuth token, missing
flow:debugscope, or incorrect client credentials. - How to fix it: Regenerate the token using the
/oauth2/tokenendpoint. Verify thescopeparameter includesflow:debug. Check that the client ID and secret match the registered OAuth client in the CXone admin console. - Code showing the fix: The
get_access_tokenfunction raisesValueErrorifaccess_tokenis missing. Wrap the call in a try-except block to catchrequests.exceptions.HTTPErrorand log the exact response body.
Error: 403 Forbidden
- What causes it: The OAuth client lacks permission to debug the specified flow, or the flow belongs to a different organization.
- How to fix it: Assign the
flow:debugrole to the service account in the CXone security settings. Verify theflowIdmatches a flow published in the same environment as the OAuth client. - Code showing the fix: Add a pre-check that fetches
/api/v2/flows/{flowId}withflow:readscope before simulation. If the 403 persists, rotate the OAuth credentials or request elevated permissions from your CXone administrator.
- What causes it: Exceeding the API gateway rate limit for debug simulations. The Flow Debug API enforces stricter limits because simulations consume server-side execution resources.
- How to fix it: Implement exponential backoff. The complete example includes a retry loop that reads the
Retry-Afterheader and delays execution. Space out bulk simulations by at least 2 seconds per request. - Code showing the fix: The
simulate_flowfunction contains afor attempt in range(3)loop withtime.sleep(retry_after). This prevents cascade failures during CI/CD pipeline execution.
Error: 500 Internal Server Error (Flow Compilation Failure)
- What causes it: The target flow contains invalid node references, broken script syntax, or unsupported configuration parameters.
- How to fix it: Review the flow in the CXone Studio UI. Check for disconnected nodes, missing transition conditions, or deprecated DTMF mapping rules. The debug API returns a
tracearray that stops at the failing node. Inspect the last trace entry forerrororstatusfields. - Code showing the fix: Parse
result.get("trace", [])and filter for entries containing"status": "Error"or"exception"keys. Log thenodeIdandtimestampto locate the exact failure point in the flow canvas.
