Simulating NICE CXone IVR Flow Execution Paths via REST API with Go
  • A Go service that constructs IVR simulation payloads containing DTMF sequences, variable state matrices, and media asset references, then submits them to the CXone Flow Simulator API.
  • An asynchronous job processor that polls simulation status, implements exponential backoff for transient compute unavailability, and retrieves execution traces.
  • A node traversal analyzer that evaluates decision points, detects unreachable branches, calculates journey efficiency scores, and exports structured results to external QA platforms while maintaining audit logs and performance metrics.
  • OAuth 2.0 Client Credentials grant with scopes: flow:simulator:run, flow:simulator:read, flow:read
  • CXone REST API v2 (Flow Simulator and Flow Definitions endpoints)
  • Go 1.21 or later
  • Standard library only (net/http, encoding/json, context, time, sync, log/slog, fmt)
  • Access to a CXone organization with Flow Simulator enabled
CXone uses standard OAuth 2.0 client credentials flow. You must cache the access token and refresh it before expiration. The following implementation uses a thread-safe token manager with automatic expiration tracking.
package main
import (
	"context"
	"crypto/sha256"
	"encoding/json"
	"fmt"
	"log/slog"
	"net/http"
	"sync"
	"time"
type OAuthConfig struct {
	Region      string
	ClientID    string
	ClientSecret string
type OAuthTokenResponse struct {
	TokenType   string `json:"token_type"`
	ExpiresIn   int    `json:"expires_in"`
type TokenManager struct {
	mu      sync.Mutex
	token   string
	expires time.Time
	config  OAuthConfig
	client  *http.Client
func NewTokenManager(cfg OAuthConfig) *TokenManager {
	return &TokenManager{
		config: cfg,
		client: &http.Client{Timeout: 10 * time.Second},
func (tm *TokenManager) GetToken(ctx context.Context) (string, error) {
	tm.mu.Lock()
	defer tm.mu.Unlock()
	if tm.token != "" && time.Now().Before(tm.expires.Add(-30*time.Second)) {
		return tm.token, nil
	payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s",
		tm.config.ClientID, tm.config.ClientSecret)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost,
		fmt.Sprintf("https://api.%s.niceincontact.com/oauth/token", tm.config.Region),
		nil)
	if err != nil {
		return "", fmt.Errorf("failed to create oauth request: %w", err)
	req.SetBasicAuth(tm.config.ClientID, tm.config.ClientSecret)
	resp, err := tm.client.Do(req)
	if err != nil {
		return "", fmt.Errorf("oauth request failed: %w", err)
	defer resp.Body.Close()
		return "", fmt.Errorf("oauth token request failed with status %d", resp.StatusCode)
	var tokenResp OAuthTokenResponse
		return "", fmt.Errorf("failed to decode oauth response: %w", err)
	tm.token = tokenResp.AccessToken
	tm.expires = time.Now().Add(time.Duration(tokenResp.ExpiresIn) * time.Second)
	slog.Info("oauth token refreshed", "expires_at", tm.expires.Format(time.RFC3339))
Step 1: Construct Simulation Request Payloads
The CXone Flow Simulator expects a structured JSON payload containing the target flow identifier, initial DTMF input sequence, variable state matrix, and media asset references. You must map these fields precisely to avoid schema validation failures.
type MediaReference struct {
	AssetID string `json:"assetId"`
	Type    string `json:"type"` // "audio", "tts", "video"
type SimulationRequest struct {
	FlowID              string                 `json:"flowId"`
	DTMFSequence        []string               `json:"dtmfSequence"`
	VariableStateMatrix map[string]interface{} `json:"variableStateMatrix"`
	MediaAssetRefs      []MediaReference       `json:"mediaAssetReferences"`
func BuildSimulationPayload(flowID string, dtmf []string, vars map[string]interface{}, media []MediaReference) SimulationRequest {
	return SimulationRequest{
		FlowID:              flowID,
		DTMFSequence:        dtmf,
		VariableStateMatrix: vars,
		MediaAssetRefs:      media,
Step 2: Validate Schemas Against Complexity Limits
CXone enforces execution limits to prevent simulator timeouts and resource exhaustion. You must validate DTMF length, variable count, and media references against known thresholds before submission. The validator returns a structured error when limits are exceeded.
type ComplexityLimits struct {
	MaxDTMFSteps     int
	MaxVariables     int
	MaxMediaRefs     int
	MaxFlowDepth     int
func ValidateSimulationPayload(req SimulationRequest, limits ComplexityLimits) error {
	if len(req.DTMFSequence) > limits.MaxDTMFSteps {
		return fmt.Errorf("dtmf sequence exceeds limit: %d provided, %d allowed",
			len(req.DTMFSequence), limits.MaxDTMFSteps)
	if len(req.VariableStateMatrix) > limits.MaxVariables {
		return fmt.Errorf("variable matrix exceeds limit: %d provided, %d allowed",
			len(req.VariableStateMatrix), limits.MaxVariables)
	if len(req.MediaAssetRefs) > limits.MaxMediaRefs {
		return fmt.Errorf("media references exceed limit: %d provided, %d allowed",
			len(req.MediaAssetRefs), limits.MaxMediaRefs)
	return nil
Step 3: Execute Asynchronous Simulation with Retry Hooks
The simulator operates asynchronously. You submit the payload, receive a simulation identifier, and poll the status endpoint until completion or failure. The implementation includes exponential backoff for 429 and 5xx responses, with a maximum retry count to prevent infinite loops.
type SimulationJob struct {
	SimulationID string `json:"simulationId"`
	Status       string `json:"status"`
	ResultURL    string `json:"resultUrl,omitempty"`
type SimulationResult struct {
	ExecutionPath []NodeExecution `json:"executionPath"`
	Variables     map[string]interface{} `json:"variables"`
	DurationMs    int64                `json:"durationMs"`
	ErrorMessage  string               `json:"errorMessage,omitempty"`
type NodeExecution struct {
	NodeID     string                 `json:"nodeId"`
	NodeType   string                 `json:"nodeType"`
	Input      map[string]interface{} `json:"input"`
	Output     map[string]interface{} `json:"output"`
	Decision   string                 `json:"decision,omitempty"`
func RunSimulation(ctx context.Context, tm *TokenManager, org string, req SimulationRequest) (*SimulationResult, error) {
	payloadBytes, err := json.Marshal(req)
	if err != nil {
		return nil, fmt.Errorf("failed to marshal simulation request: %w", err)
	token, err := tm.GetToken(ctx)
	if err != nil {
		return nil, fmt.Errorf("failed to retrieve oauth token: %w", err)
	httpClient := &http.Client{Timeout: 30 * time.Second}
	submitReq, err := http.NewRequestWithContext(ctx, http.MethodPost,
		fmt.Sprintf("https://api.%s.niceincontact.com/api/v2/flow/simulator", org),
		nil)
	if err != nil {
		return nil, fmt.Errorf("failed to create submit request: %w", err)
	submitReq.Header.Set("Content-Type", "application/json")
	submitReq.Header.Set("Authorization", "Bearer "+token)
	submitReq.Body = http.NoBody
	// Override body with payload
	submitReq.GetBody = func() (io.ReadCloser, error) {
		return io.NopCloser(bytes.NewReader(payloadBytes)), nil
	submitReq.Body = io.NopCloser(bytes.NewReader(payloadBytes))
	resp, err := httpClient.Do(submitReq)
	if err != nil {
		return nil, fmt.Errorf("simulation submission failed: %w", err)
	if resp.StatusCode == http.StatusTooManyRequests || resp.StatusCode >= 500 {
		slog.Warn("simulation submission encountered transient error", "status", resp.StatusCode)
		time.Sleep(2 * time.Second)
		return RunSimulation(ctx, tm, org, req) // Simple retry hook
	if resp.StatusCode != http.StatusCreated && resp.StatusCode != http.StatusOK {
		return nil, fmt.Errorf("simulation submission failed with status %d", resp.StatusCode)
	var job SimulationJob
	if err := json.NewDecoder(resp.Body).Decode(&job); err != nil {
		return nil, fmt.Errorf("failed to decode job response: %w", err)
	return PollSimulationResult(ctx, tm, org, job.SimulationID, httpClient)
func PollSimulationResult(ctx context.Context, tm *TokenManager, org, simID string, client *http.Client) (*SimulationResult, error) {
	maxRetries := 15
	backoff := 1 * time.Second
	for i := 0; i < maxRetries; i++ {
		select {
		case <-ctx.Done():
			return nil, ctx.Err()
		case <-time.After(backoff):
		if err != nil {
			return nil, err
		req, err := http.NewRequestWithContext(ctx, http.MethodGet,
			fmt.Sprintf("https://api.%s.niceincontact.com/api/v2/flow/simulator/%s", org, simID),
			nil)
		if err != nil {
			return nil, err
		resp, err := client.Do(req)
		if err != nil {
			slog.Error("poll request failed", "error", err)
			backoff *= 2
			slog.Warn("rate limited during polling, backing off")
			backoff *= 2
			return nil, fmt.Errorf("poll failed with status %d", resp.StatusCode)
		var result SimulationResult
		if err := json.NewDecoder(resp.Body).Decode(&result); err != nil {
			return nil, fmt.Errorf("failed to decode simulation result: %w", err)
		if result.Status == "completed" {
			return &result, nil
		if result.Status == "failed" {
			return nil, fmt.Errorf("simulation failed: %s", result.ErrorMessage)
	return nil, fmt.Errorf("simulation did not complete within timeout window")
Step 4: Implement Path Analysis and Decision Evaluation
The simulation result contains an ordered list of executed nodes. You must traverse this path to evaluate decision points, detect unreachable branches, and calculate journey efficiency. The analyzer compares the execution trace against expected decision logic and flags dead ends or suboptimal routing.
type PathAnalysis struct {
	TotalNodes      int
	DecisionPoints  int
	UnreachableBranches []string
	EfficiencyScore float64
	DetectedCycles    []string
func AnalyzeExecutionPath(result *SimulationResult) *PathAnalysis {
	analysis := &PathAnalysis{}
	visitedNodes := make(map[string]bool)
	pathOrder := make([]string, 0, len(result.ExecutionPath))
	for _, node := range result.ExecutionPath {
		analysis.TotalNodes++
		pathOrder = append(pathOrder, node.NodeID)
		if node.NodeType == "decision" || node.NodeType == "conditional" {
			analysis.DecisionPoints++
		if visitedNodes[node.NodeID] {
			analysis.DetectedCycles = append(analysis.DetectedCycles, node.NodeID)
		visitedNodes[node.NodeID] = true
	// Detect unreachable branches by checking nodes that appear in flow definition
	// but were never traversed. This requires fetching the full flow definition.
	// For this tutorial, we simulate unreachable detection via missing expected nodes.
	expectedNodes := map[string]bool{"start": true, "main_menu": true, "agent_transfer": true, "voicemail": true}
	for nodeID := range expectedNodes {
		if !visitedNodes[nodeID] {
			analysis.UnreachableBranches = append(analysis.UnreachableBranches, nodeID)
	// Calculate efficiency: ratio of decision points to total nodes, penalizing cycles
	if analysis.TotalNodes > 0 {
		baseScore := float64(analysis.DecisionPoints) / float64(analysis.TotalNodes)
		cyclePenalty := float64(len(analysis.DetectedCycles)) * 0.1
		analysis.EfficiencyScore = max(0.0, min(1.0, baseScore-cyclePenalty))
	return analysis
Step 5: Export Results, Track Metrics, and Generate Audit Logs
You must synchronize simulation outcomes with external QA platforms, record execution duration, compute validation accuracy against expected outcomes, and persist structured audit logs for governance compliance. The exporter uses a standard HTTP POST to a hypothetical QA ingestion endpoint.
type QAExportPayload struct {
	TestID          string            `json:"testId"`
	EfficiencyScore float64           `json:"efficiencyScore"`
	AccuracyScore   float64           `json:"accuracyScore"`
	Unreachable     []string          `json:"unreachableBranches"`
	Timestamp       string            `json:"timestamp"`
	AuditCorrelation string           `json:"auditCorrelation"`
func ExportToQAPlatform(ctx context.Context, simID, flowID string, result *SimulationResult, analysis *PathAnalysis, qaEndpoint string) error {
	httpClient := &http.Client{Timeout: 15 * time.Second}
	// Calculate accuracy score based on expected vs actual decision outcomes
	accuracy := 0.95 // Placeholder calculation; replace with actual expected outcome comparison logic
	if len(analysis.DetectedCycles) > 0 {
		accuracy -= 0.1
	if len(analysis.UnreachableBranches) > 0 {
		accuracy -= 0.05
	export := QAExportPayload{
		TestID:          fmt.Sprintf("sim_%s_%d", flowID, time.Now().UnixMilli()),
		SimulationID:    simID,
		FlowID:          flowID,
		DurationMs:      result.DurationMs,
		EfficiencyScore: analysis.EfficiencyScore,
		AccuracyScore:   accuracy,
		Unreachable:     analysis.UnreachableBranches,
		Timestamp:       time.Now().UTC().Format(time.RFC3339),
		AuditCorrelation: fmt.Sprintf("audit-%s-%d", simID, time.Now().UnixNano()),
	payloadBytes, err := json.Marshal(export)
	if err != nil {
		return fmt.Errorf("failed to marshal qa export: %w", err)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, qaEndpoint, nil)
	if err != nil {
		return err
	req.Body = io.NopCloser(bytes.NewReader(payloadBytes))
	resp, err := httpClient.Do(req)
	if err != nil {
		return fmt.Errorf("qa export failed: %w", err)
	if resp.StatusCode < 200 || resp.StatusCode >= 300 {
		return fmt.Errorf("qa export returned status %d", resp.StatusCode)
	// Generate audit log
	slog.Info("simulation audit recorded",
		"simulation_id", simID,
		"flow_id", flowID,
		"duration_ms", result.DurationMs,
		"efficiency", analysis.EfficiencyScore,
		"accuracy", accuracy,
		"unreachable_count", len(analysis.UnreachableBranches),
		"correlation", export.AuditCorrelation)
	return nil
The following module integrates all components into a runnable Go service. Replace the placeholder credentials and endpoints with your CXone organization details.
package main
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"io"
	"log/slog"
	"net/http"
	"os"
	"time"
// [Insert all structs and functions from Steps 1-5 here]
func main() {
	ctx := context.Background()
	// Initialize token manager
	tm := NewTokenManager(OAuthConfig{
		Region:       "us",
		ClientID:     os.Getenv("CXONE_CLIENT_ID"),
		ClientSecret: os.Getenv("CXONE_CLIENT_SECRET"),
	// Build simulation payload
	req := BuildSimulationPayload(
		"flow-abc123",
		[]string{"1", "3", "0"},
		map[string]interface{}{
			"customer_id": "cust-998877",
			"priority":    "high",
			"language":    "en-US",
		[]MediaReference{
			{AssetID: "media-001", Type: "audio"},
			{AssetID: "tts-002", Type: "tts"},
	// Validate against complexity limits
	limits := ComplexityLimits{
		MaxDTMFSteps: 50,
		MaxVariables: 100,
		MaxMediaRefs: 10,
		MaxFlowDepth: 200,
	if err := ValidateSimulationPayload(req, limits); err != nil {
		slog.Error("validation failed", "error", err)
		os.Exit(1)
	// Execute simulation
	result, err := RunSimulation(ctx, tm, "us", req)
	if err != nil {
		slog.Error("simulation execution failed", "error", err)
		os.Exit(1)
	// Analyze execution path
	analysis := AnalyzeExecutionPath(result)
	slog.Info("path analysis complete",
		"nodes", analysis.TotalNodes,
		"decisions", analysis.DecisionPoints,
		"cycles", analysis.DetectedCycles)
	// Export to QA platform
	qaEndpoint := "https://qa-platform.example.com/api/v1/test-results"
	if err := ExportToQAPlatform(ctx, result.SimulationID, req.FlowID, result, analysis, qaEndpoint); err != nil {
		slog.Error("qa export failed", "error", err)
	slog.Info("simulation workflow completed successfully")
  • What causes it: Expired or invalid OAuth token, missing Authorization header, or incorrect client credentials.
  • How to fix it: Ensure the token manager refreshes before expiration. Verify the client_id and client_secret match a CXone integration user with flow:simulator:run scope.
  • Code showing the fix: The TokenManager automatically refreshes when time.Now().Before(tm.expires.Add(-30*time.Second)) evaluates to false.
  • What causes it: Exceeding CXone rate limits during simulation submission or status polling.
  • How to fix it: Implement exponential backoff and respect Retry-After headers. The polling loop doubles the sleep interval on 429 responses.
  • Code showing the fix: if resp.StatusCode == http.StatusTooManyRequests { backoff *= 2; continue }
Error: 400 Bad Request
  • What causes it: Invalid JSON schema, missing required fields, or exceeding flow complexity limits.
  • How to fix it: Run ValidateSimulationPayload before submission. Ensure flowId exists and matches an active flow. Verify DTMF sequences contain only valid digits.
  • Code showing the fix: The validator checks array lengths and map sizes against ComplexityLimits before HTTP submission.
Error: 503 Service Unavailable
  • What causes it: CXone simulator compute cluster is temporarily overloaded or undergoing maintenance.
  • How to fix it: Retry with increasing delays. The RunSimulation function includes a transient error retry hook that sleeps and resubmits.
  • Code showing the fix: if resp.StatusCode == http.StatusTooManyRequests || resp.StatusCode >= 500 { time.Sleep(2 * time.Second); return RunSimulation(...) }
