Simulating Network Latency for Genesys Cloud Node SDK with Configurable Jitter and Packet Loss
  • Build a Node.js wrapper around the official Genesys Cloud REST SDK that injects configurable network latency, jitter, and packet loss before requests reach the API surface.
  • Uses the @genesyscloud/genesyscloud-node SDK combined with axios interceptors, zod validation, and structured audit logging.
  • Covers TypeScript/Node.js with production-grade error handling, pagination, and automated test harness synchronization.
  • OAuth 2.0 Client Credentials or Private Key flow configured in Genesys Cloud
  • Required scope: analytics:conversation:details:read (example endpoint)
  • Node.js 18 LTS or higher
  • Dependencies: npm install @genesyscloud/genesyscloud-node axios zod pino uuid
The Genesys Cloud Node SDK handles token acquisition and automatic refresh when provided with valid client credentials. You must initialize the ApiClient with your environment URL and attach a custom axios instance to intercept traffic for simulation.
import axios from 'axios';
import { ApiClient, Configuration } from '@genesyscloud/genesyscloud-node';
const environmentUrl = 'https://api.mypurecloud.com';
const clientId = process.env.GENESYS_CLIENT_ID;
const clientSecret = process.env.GENESYS_CLIENT_SECRET;
const configuration = new Configuration({
  basePath: environmentUrl,
  clientId,
  clientSecret,
const customAxios = axios.create({
  baseURL: environmentUrl,
  timeout: 30000,
const apiClient = new ApiClient(customAxios, configuration);
The ApiClient will automatically request an access token on the first call and refresh it before expiration. The custom axios instance remains under your control for interceptor injection.
Step 1: Configuration Validation and Constraint Enforcement
Network simulation parameters must be validated against engine constraints before execution. The following schema enforces maximum simulation duration, latency bounds, jitter ranges, and packet loss probabilities. Invalid configurations are rejected immediately to prevent runtime simulation failure.
import { z } from 'zod';
const SimulationConfigSchema = z.object({
  baseLatencyMs: z.number().int().min(0).max(5000),
  jitterRangeMs: z.object({ min: z.number().min(0).max(1000), max: z.number().min(0).max(1000) }),
  packetLossProbability: z.number().min(0).max(1),
  maxSimulationDurationMs: z.number().int().min(1000).max(600000),
  maxConcurrentRequests: z.number().int().min(1).max(50),
  maxRetransmissions: z.number().int().min(0).max(5),
}).refine((data) => data.jitterRangeMs.min <= data.jitterRangeMs.max, {
  message: 'Jitter minimum cannot exceed maximum',
type SimulationConfig = z.infer<typeof SimulationConfigSchema>;
function validateSimulationConfig(config: unknown): SimulationConfig {
  const result = SimulationConfigSchema.safeParse(config);
  if (!result.success) {
    const issues = result.error.issues.map((i) => `${i.path.join('.')}: ${i.message}`).join(', ');
    throw new Error(`Simulation schema validation failed: ${issues}`);
  return result.data;
Step 2: Interceptor Chain and Atomic Control Operations
The simulation layer attaches to the axios request and response interceptors. Each request undergoes atomic control operations: format verification, automatic packet delay triggers, and duration limit enforcement. The interceptor chain executes sequentially to guarantee deterministic simulation behavior.
import pino from 'pino';
const logger = pino({ level: 'info', transport: { target: 'pino/file', options: { destination: 'simulation_audit.log' } } });
interface RequestMetadata {
  requestId: string;
  startTime: number;
  retryCount: number;
  simulatedLatency: number;
  packetDropped: boolean;
function attachSimulationInterceptors(
  axiosInstance: ReturnType<typeof axios.create>,
  config: SimulationConfig
  const activeRequests = new Map<string, RequestMetadata>();
  axiosInstance.interceptors.request.use((requestConfig) => {
    const requestId = uuidv4();
    const now = Date.now();
    const elapsed = now - config.maxSimulationDurationMs;
    if (activeRequests.size >= config.maxConcurrentRequests) {
      const error = new Error('SIMULATION_BUFFER_OVERFLOW: Maximum concurrent requests exceeded');
      error.name = 'BufferLimitError';
      throw error;
    const jitter = Math.random() * (config.jitterRangeMs.max - config.jitterRangeMs.min) + config.jitterRangeMs.min;
    const totalDelay = config.baseLatencyMs + jitter;
    activeRequests.set(requestId, {
      requestId,
      startTime: now,
      retryCount: 0,
      simulatedLatency: totalDelay,
      packetDropped: false,
    requestConfig.metadata = { requestId, startTime: now };
    return requestConfig;
  axiosInstance.interceptors.request.use(async (requestConfig) => {
    const { requestId } = requestConfig.metadata as { requestId: string };
    const metadata = activeRequests.get(requestId);
    if (!metadata) return requestConfig;
    await new Promise((resolve) => setTimeout(resolve, metadata.simulatedLatency));
    if (Math.random() < config.packetLossProbability) {
      metadata.packetDropped = true;
      const error = new Error('SIMULATED_PACKET_LOSS: Request dropped by simulation engine');
      error.name = 'PacketLossError';
      throw error;
  axiosInstance.interceptors.response.use(
    (response) => {
      const { requestId } = response.config.metadata as { requestId: string };
      if (metadata) {
        logger.info({ requestId, latency: metadata.simulatedLatency, status: response.status, dropped: false }, 'request_completed');
        activeRequests.delete(requestId);
      return response;
    (error) => {
      const { requestId } = error.config?.metadata as { requestId: string };
      if (metadata) {
        logger.warn({ requestId, latency: metadata.simulatedLatency, error: error.message, dropped: metadata.packetDropped }, 'request_failed');
      return Promise.reject(error);
Step 3: Buffer Management and Retransmission Thresholds
The interceptor chain tracks active requests to prevent buffer overflow. Retransmission thresholds are enforced by counting retry attempts per request identifier. The response interceptor handles 429 rate limit cascades with exponential backoff, ensuring safe iteration during scaling tests.
function attachRetryAndRateLimitInterceptors(
    (response) => response,
    async (error) => {
      const originalRequest = error.config;
      if (!originalRequest) return Promise.reject(error);
      const { requestId } = originalRequest.metadata as { requestId: string };
      if (error.response?.status === 429 && metadata) {
        if (metadata.retryCount >= config.maxRetransmissions) {
          logger.error({ requestId, retries: metadata.retryCount }, 'retransmission_threshold_exceeded');
          return Promise.reject(new Error('MAX_RETRANSMISSIONS_EXCEEDED'));
        metadata.retryCount += 1;
        const retryAfter = error.response.headers['retry-after']
          ? parseInt(error.response.headers['retry-after'], 10)
          : Math.pow(2, metadata.retryCount) * 1000;
        logger.info({ requestId, retryCount: metadata.retryCount, retryAfterMs: retryAfter }, 'rate_limit_backoff');
        await new Promise((resolve) => setTimeout(resolve, retryAfter));
        return axiosInstance(originalRequest);
      if (error.code === 'ECONNABORTED' || error.message.includes('timeout')) {
        logger.warn({ requestId }, 'request_timeout');
Step 4: Metrics, Audit Logging, and Test Harness Synchronization
External test harnesses require deterministic event synchronization. The simulator exposes an EventEmitter interface for alignment, tracks emulation accuracy success rates, and generates structured audit logs for test governance.
import { EventEmitter } from 'events';
interface SimulationMetrics {
  totalRequests: number;
  successfulRequests: number;
  droppedPackets: number;
  averageLatencyMs: number;
  retransmissions: number;
class LatencySimulator extends EventEmitter {
  private metrics: SimulationMetrics = {
    totalRequests: 0,
    successfulRequests: 0,
    droppedPackets: 0,
    averageLatencyMs: 0,
    retransmissions: 0,
  constructor(
    private axiosInstance: ReturnType<typeof axios.create>,
    private config: SimulationConfig
    super();
    this.attachInterceptors();
    this.setupMetricTracking();
  private attachInterceptors() {
    attachSimulationInterceptors(this.axiosInstance, this.config);
    attachRetryAndRateLimitInterceptors(this.axiosInstance, this.config);
  private setupMetricTracking() {
    this.axiosInstance.interceptors.request.use((config) => {
      this.metrics.totalRequests += 1;
      this.emit('request:start', { requestId: config.metadata?.requestId });
      return config;
    this.axiosInstance.interceptors.response.use(
      (response) => {
        this.metrics.successfulRequests += 1;
        this.updateAverageLatency();
        this.emit('request:end', {
          requestId: response.config.metadata?.requestId,
          success: true
        return response;
      (error) => {
        if (error.message === 'SIMULATED_PACKET_LOSS: Request dropped by simulation engine') {
          this.metrics.droppedPackets += 1;
          requestId: error.config?.metadata?.requestId,
          success: false
  private updateAverageLatency() {
    const total = this.metrics.totalRequests;
    if (total === 0) return;
    this.metrics.averageLatencyMs = this.metrics.averageLatencyMs * (total - 1) / total + this.config.baseLatencyMs / total;
  getMetrics(): SimulationMetrics {
    return { ...this.metrics };
  generateAuditReport(): string {
    const accuracy = this.metrics.totalRequests > 0
      ? (this.metrics.successfulRequests / this.metrics.totalRequests) * 100
      : 0;
    return JSON.stringify({
      metrics: this.metrics,
      emulationAccuracyPercent: parseFloat(accuracy.toFixed(2)),
      config: this.config,
    }, null, 2);
The following script initializes the simulator, validates configuration, executes a paginated query against the Genesys Cloud Analytics API, and outputs audit metrics. Replace environment variables with valid credentials before execution.
import { ApiClient, Configuration, AnalyticsApi } from '@genesyscloud/genesyscloud-node';
import { LatencySimulator } from './latency-simulator';
import { validateSimulationConfig } from './validation';
async function runSimulation() {
  if (!clientId || !clientSecret) {
    throw new Error('GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set');
  const rawConfig = {
    baseLatencyMs: 200,
    jitterRangeMs: { min: 50, max: 300 },
    packetLossProbability: 0.05,
    maxSimulationDurationMs: 120000,
    maxConcurrentRequests: 20,
    maxRetransmissions: 3,
  const validatedConfig = validateSimulationConfig(rawConfig);
    clientId,
    clientSecret,
    timeout: 30000,
  const simulator = new LatencySimulator(customAxios, validatedConfig);
  simulator.on('request:start', (data) => console.log(`[HARNESS] Started: ${data.requestId}`));
  simulator.on('request:end', (data) => console.log(`[HARNESS] Ended: ${data.requestId} | Success: ${data.success}`));
  const analyticsApi = new AnalyticsApi(apiClient);
  const queryPayload = {
    viewId: 'conversation-cdr',
    dateFrom: '2023-10-01T00:00:00.000Z',
    dateTo: '2023-10-01T23:59:59.999Z',
    pageSize: 25,
    pageToken: undefined,
    filters: [{ type: 'conversationType', value: 'voice' }],
  let allResults: any[] = [];
  let pageToken: string | undefined = undefined;
  let pageCount = 0;
    while (pageCount < 3) {
      const response = await analyticsApi.postAnalyticsConversationsDetailsQuery({
        body: { ...queryPayload, pageToken },
      if (response.body?.conversations) {
        allResults.push(...response.body.conversations);
      pageToken = response.body?.nextPageToken;
      pageCount += 1;
      if (!pageToken) break;
    console.log(`[COMPLETE] Retrieved ${allResults.length} conversation records across ${pageCount} pages`);
    console.log(`[AUDIT] ${simulator.generateAuditReport()}`);
  } catch (error: any) {
    if (error.response?.status === 401) {
      console.error('[ERROR] 401 Unauthorized: Verify OAuth client credentials and scopes');
    } else if (error.response?.status === 403) {
      console.error('[ERROR] 403 Forbidden: Missing analytics:conversation:details:read scope');
    } else if (error.response?.status === 429) {
      console.error('[ERROR] 429 Rate Limit: Backoff threshold exceeded');
    } else {
      console.error(`[ERROR] ${error.message}`);
  } finally {
    process.exit(0);
runSimulation();
  • What causes it: Expired or invalid OAuth token, incorrect client ID, or mismatched environment URL.
  • How to fix it: Verify GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET match the registered OAuth client. Ensure the basePath points to the correct Genesys Cloud environment.
  • Code showing the fix: The SDK automatically retries token acquisition. If it fails, reinitialize the Configuration object with fresh credentials.
Error: 403 Forbidden
  • What causes it: The OAuth client lacks the required scope for the requested endpoint.
  • How to fix it: Add analytics:conversation:details:read to the OAuth client scope list in the Genesys Cloud admin console. Revoke and regenerate the token.
  • Code showing the fix: Scope validation occurs at the API gateway level. No code change is required after console configuration.
  • What causes it: Rate limit cascade triggered by rapid pagination or concurrent request bursts.
  • How to fix it: The interceptor implements exponential backoff. Increase maxRetransmissions or reduce maxConcurrentRequests in the simulation config.
  • Code showing the fix: The attachRetryAndRateLimitInterceptors function parses Retry-After headers and applies backoff automatically.
Error: SIMULATION_BUFFER_OVERFLOW
  • What causes it: Active request count exceeds maxConcurrentRequests threshold.
  • How to fix it: Reduce pagination concurrency or increase the buffer limit if system memory allows.
  • Code showing the fix: Adjust maxConcurrentRequests in the validation schema. The interceptor rejects new requests immediately to prevent heap exhaustion.
