Simulating Genesys Cloud Web Messaging Typing Indicators with Python WebSocket Automation
This tutorial builds a Python automation module that simulates guest typing status in Genesys Cloud Web Messaging by constructing and transmitting structured WebSocket payloads. The implementation uses the official Genesys Cloud Web Messaging WebSocket endpoint and OAuth 2.0 client credentials authentication. The code is written in Python 3.9+ using httpx for REST authentication and websockets for real-time bidirectional communication.
- OAuth Client Type: Confidential client registered in Genesys Cloud with
webchat:guest:sendandconversations:readscopes. - API/SDK Version: Genesys Cloud Web Messaging WebSocket API (
/api/v2/conversations/messaging/websocket) and REST OAuth endpoint (/oauth/token). - Runtime Requirements: Python 3.9 or higher.
- External Dependencies:
pip install httpx websockets pydantic
Genesys Cloud Web Messaging requires a valid bearer token for WebSocket handshakes. The client credentials flow exchanges your client ID and secret for a short-lived access token. You must cache this token and refresh it before expiration to prevent dropped connections.
import httpx
from typing import Optional
class GenesysAuth:
def __init__(self, org_domain: str, client_id: str, client_secret: str):
self.org_domain = org_domain
self.client_id = client_id
self.token_url = f"https://{org_domain}/oauth/token"
self.expires_at: float = 0.0
async def get_access_token(self) -> str:
"""Retrieve or refresh an OAuth 2.0 access token."""
if self.access_token and time.time() < (self.expires_at - 60):
return self.access_token
async with httpx.AsyncClient() as client:
response = await client.post(
self.token_url,
data={
"client_id": self.client_id,
"scope": "webchat:guest:send conversations:read"
headers={"Content-Type": "application/x-www-form-urlencoded"}
response.raise_for_status()
payload = response.json()
self.access_token = payload["access_token"]
self.expires_at = time.time() + payload["expires_in"]
The get_access_token method implements a sliding window refresh strategy. The token refreshes automatically if it expires within sixty seconds, which prevents mid-operation authentication failures. The webchat:guest:send scope is mandatory for transmitting typing indicators and guest messages.
Step 1: Establish WebSocket Connection and Validate Guest Constraints
The Web Messaging WebSocket endpoint requires the access token as a query parameter during the HTTP upgrade request. Before transmitting typing pulses, you must validate guest constraints such as maximum typing duration and conversation state. Genesys Cloud enforces a typical typing indicator timeout of thirty seconds. Exceeding this limit causes the platform to discard the indicator to prevent UI state corruption.
import asyncio
import websockets
from websockets.exceptions import ConnectionClosed
from typing import Dict, Any
class TypingSimulator:
def __init__(self, auth: GenesysAuth, max_typing_duration: int = 30, heartbeat_interval: int = 15):
self.auth = auth
self.ws_url = f"wss://{auth.org_domain}/api/v2/conversations/messaging/websocket"
self.ws: Optional[websockets.WebSocketClientProtocol] = None
self.max_typing_duration = max_typing_duration
self.heartbeat_interval = heartbeat_interval
self.rate_limit_backoff = 1.0
self.metrics: Dict[str, Any] = {"pulses_sent": 0, "pulses_failed": 0, "latency_ms": []}
self.audit_log: list[Dict[str, Any]] = []
async def connect(self) -> None:
"""Establish WebSocket connection with authenticated token."""
token = await self.auth.get_access_token()
ws_endpoint = f"{self.ws_url}?access_token={token}"
self.ws = await websockets.connect(ws_endpoint, ping_interval=None, ping_timeout=10)
self.audit_log.append({"event": "websocket_connected", "timestamp": time.time()})
raise ConnectionError(f"WebSocket handshake failed: {e}")
def validate_guest_constraints(self, conversation_id: str, duration_seconds: int) -> bool:
"""Enforce maximum-typing-duration-seconds limits and guest-matrix constraints."""
if duration_seconds > self.max_typing_duration:
raise ValueError(f"Duration {duration_seconds}s exceeds maximum-typing-duration-seconds limit of {self.max_typing_duration}s")
if not conversation_id:
raise ValueError("Conversation ID is required for guest-matrix validation")
return True
The connect method passes the token via query string, which matches the Genesys Cloud WebSocket authentication pattern. The validate_guest_constraints method enforces the maximum-typing-duration-seconds boundary. This prevents the platform from rejecting stale typing states and ensures the guest matrix remains synchronized with the backend routing engine.
Step 2: Construct Typing Payloads and Handle Pulse Directive Logic
Genesys Cloud interprets typing indicators as discrete pulse directives. Each pulse must contain a typing-ref reference, a unique message ID, and a UTC timestamp. You must implement atomic WebSocket operations to guarantee format verification before transmission. The pulse validation pipeline checks for disconnected clients, verifies rate limits, and calculates heartbeat intervals to maintain UI state synchronization.
import uuid
async def send_typing_pulse(self, conversation_id: str, guest_id: str, typing_ref: str) -> Dict[str, Any]:
"""Transmit a typing pulse directive with rate-limit verification and latency tracking."""
if not self.ws or self.ws.closed:
raise ConnectionError("Disconnected-client detected. Reconnect required.")
payload = {
"type": "typing",
"id": str(uuid.uuid4()),
"conversationId": conversation_id,
"guestId": guest_id,
"referenceId": typing_ref,
"timestamp": datetime.now(timezone.utc).isoformat()
start_time = time.time()
await self.ws.send(json.dumps(payload))
self.metrics["latency_ms"].append(latency_ms)
self.metrics["pulses_sent"] += 1
self.rate_limit_backoff = 1.0 # Reset backoff on success
"event": "typing_pulse_sent",
"ref": typing_ref,
"latency_ms": latency_ms,
return {"status": "success", "latency_ms": latency_ms}
except websockets.exceptions.ConnectionClosed as e:
self.metrics["pulses_failed"] += 1
self.audit_log.append({"event": "pulse_failed", "error": str(e), "timestamp": time.time()})
raise
raise
The referenceId field maps to your typing-ref requirement. Genesys Cloud uses this to deduplicate rapid typing events and maintain UI state synchronization. The latency tracking captures transmission time for efficiency monitoring. The rate_limit_backoff variable resets on successful transmission, which is critical for preventing cascading 429 responses during high-frequency simulation.
Step 3: Synchronize State, Track Metrics, and Trigger External Webhooks
Production typing simulators must synchronize with external chat engines via callback mechanisms. You will implement a webhook notification pipeline that fires after successful pulse transmission. The heartbeat manager runs concurrently to send keep-alive frames, which prevents idle timeout disconnections during scaling events.
async def notify_external_engine(self, conversation_id: str, guest_id: str, typing_ref: str) -> None:
"""Simulate external-chat-engine synchronization via typing pulsed webhooks."""
webhook_payload = {
"event": "typing_pulse_sync",
"pulse_success_rate": (
self.metrics["pulses_sent"] / max(1, self.metrics["pulses_sent"] + self.metrics["pulses_failed"])
"avg_latency_ms": sum(self.metrics["latency_ms"]) / max(1, len(self.metrics["latency_ms"]))
# In production, replace with actual httpx POST to your webhook receiver
print(f"[WEBHOOK SYNC] {json.dumps(webhook_payload)}")
async def heartbeat_manager(self) -> None:
"""Maintain connection alive via atomic ping operations."""
while self.ws and not self.ws.closed:
await asyncio.sleep(self.heartbeat_interval)
await self.ws.ping()
self.audit_log.append({"event": "heartbeat_sent", "timestamp": time.time()})
except Exception:
break
async def run_simulation(self, conversation_id: str, guest_id: str, duration_seconds: int, pulse_frequency: float = 2.0) -> None:
"""Execute typing simulation with constraint validation and concurrent heartbeat."""
self.validate_guest_constraints(conversation_id, duration_seconds)
typing_ref = f"sim-ref-{uuid.uuid4().hex[:8]}"
heartbeat_task = asyncio.create_task(self.heartbeat_manager())
while time.time() - start_time < duration_seconds:
await self.send_typing_pulse(conversation_id, guest_id, typing_ref)
await self.notify_external_engine(conversation_id, guest_id, typing_ref)
await asyncio.sleep(1.0 / pulse_frequency)
self.audit_log.append({"event": "simulation_error", "error": str(e), "timestamp": time.time()})
raise
finally:
heartbeat_task.cancel()
await heartbeat_task
except asyncio.CancelledError:
pass
await self.ws.close()
self.audit_log.append({"event": "simulation_complete", "timestamp": time.time()})
The heartbeat_manager runs concurrently using asyncio.create_task. Genesys Cloud WebSocket connections drop after approximately ninety seconds of inactivity. The heartbeat interval of fifteen seconds guarantees connection persistence without triggering rate limits. The notify_external_engine method calculates pulse success rates and average latency, which satisfies the simulate efficiency tracking requirement.
The following script integrates authentication, WebSocket management, constraint validation, and audit logging into a single executable module. Replace the placeholder credentials with your Genesys Cloud configuration before execution.
import asyncio
import json
import logging
import httpx
import websockets
import uuid
# Configure logging
class GenesysAuth:
self.token_url,
data={
self.auth = auth
self.metrics = {"pulses_sent": 0, "pulses_failed": 0, "latency_ms": []}
self.audit_log = []
logger.info("WebSocket connection established")
return True
async def send_typing_pulse(self, conversation_id: str, guest_id: str, typing_ref: str) -> dict:
payload = {
"type": "typing",
self.audit_log.append({"event": "typing_pulse_sent", "ref": typing_ref, "latency_ms": latency_ms, "timestamp": time.time()})
raise
raise
webhook_payload = {
"pulse_success_rate": self.metrics["pulses_sent"] / max(1, self.metrics["pulses_sent"] + self.metrics["pulses_failed"]),
logger.info(f"[WEBHOOK SYNC] {json.dumps(webhook_payload)}")
except Exception:
break
raise
finally:
pass
logger.info(f"Simulation complete. Metrics: {self.metrics}")
async def main():
ORG_DOMAIN = "your-org.mypurecloud.com"
CLIENT_ID = "your-client-id"
CLIENT_SECRET = "your-client-secret"
CONVERSATION_ID = "active-conversation-id-from-genesis"
GUEST_ID = "guest-session-id"
auth = GenesysAuth(ORG_DOMAIN, CLIENT_ID, CLIENT_SECRET)
simulator = TypingSimulator(auth, max_typing_duration=30, heartbeat_interval=15)
await simulator.connect()
await simulator.run_simulation(
conversation_id=CONVERSATION_ID,
guest_id=GUEST_ID,
duration_seconds=15,
pulse_frequency=1.5
asyncio.run(main())
Error: 401 Unauthorized or Token Expired
What causes it: The access token passed in the WebSocket query parameter has expired, or the OAuth client lacks the webchat:guest:send scope.
How to fix it: Ensure your client credentials request includes both webchat:guest:send and conversations:read. Implement token refresh logic before expiration. The provided GenesysAuth class handles this automatically.
Code showing the fix: The get_access_token method checks time.time() < (self.expires_at - 60) and re-authenticates when the window closes.
What causes it: Exceeding Genesys Cloud WebSocket message rate limits. Typing pulses sent at high frequency trigger platform throttling.
How to fix it: Implement exponential backoff and respect the pulse_frequency parameter. Genesys Cloud typically allows one typing indicator per three seconds per guest.
Code showing the fix: The run_simulation loop uses await asyncio.sleep(1.0 / pulse_frequency). Set pulse_frequency to 1.0 or lower to comply with platform limits.
Error: 1006 Abnormal Closure
What causes it: The WebSocket connection drops due to idle timeout, network interruption, or invalid payload format.
How to fix it: Maintain a heartbeat interval of fifteen to thirty seconds. Validate JSON structure before transmission. The heartbeat_manager coroutine prevents idle drops.
Code showing the fix: The heartbeat_manager sends a WebSocket ping every self.heartbeat_interval seconds, which resets the platform idle timer.
Error: ValueError on maximum-typing-duration-seconds
What causes it: The simulation duration exceeds the platform constraint or the guest matrix validation fails.
How to fix it: Pass a duration_seconds value equal to or less than max_typing_duration. The validate_guest_constraints method enforces this boundary before connection establishment.
