Simulate NICE CXone Outbound Campaign Results with Python SDK
  • A Python pipeline that submits outbound campaign simulation payloads, validates schema constraints against engine limits, and executes Monte Carlo iterations via atomic GET polling.
  • The solution uses the NICE CXone Outbound Campaign APIs and the nice-cxone-sdk Python package for authentication and base configuration.
  • The implementation runs in Python 3.9+ and includes distribution fitting, confidence interval verification, webhook synchronization, and structured audit logging.
  • OAuth client credentials with scopes: outbound:campaign:read, outbound:campaign:write, outbound:campaign:execute
  • nice-cxone-sdk version 1.0.0 or higher
  • Python 3.9+ runtime
  • External dependencies: requests, httpx, pydantic, numpy, scipy, tenacity
  • A valid NICE CXone environment URL (e.g., https://api-us-01.niceincontact.com)
NICE CXone uses standard OAuth2 client credentials flow. The token must be cached and refreshed before expiration. The SDK handles token storage, but you must configure the client correctly.
import os
from nice_cxone_sdk import Configuration, ApiClient
from nice_cxone_sdk.rest import ApiException
def build_cxone_client(environment_url: str, client_id: str, client_secret: str) -> ApiClient:
    config = Configuration(
        host=environment_url,
        client_id=client_id,
        client_secret=client_secret,
        oauth_token_url=f"{environment_url}/oauth/token"
    # The SDK automatically handles token caching and refresh
    api_client = ApiClient(configuration=config)
    return api_client
The ApiClient instance maintains an in-memory token store. You must ensure the environment URL matches your tenant region. The SDK throws ApiException on authentication failures, which you must catch before proceeding to campaign operations.
Step 1: Construct and Validate Simulation Payloads
The simulation engine rejects payloads that exceed maximum sample size limits or contain invalid outcome matrices. You must validate the schema before transmission.
from pydantic import BaseModel, field_validator, ValidationError
from typing import Dict, Optional
class OutcomeMatrix(BaseModel):
    answered: float
    busy: float
    no_answer: float
    fax: float
    disconnected: float
    @field_validator("*")
    @classmethod
    def validate_probability(cls, v: float) -> float:
        if not 0.0 <= v <= 1.0:
            raise ValueError("Probability must be between 0.0 and 1.0")
        return v
    @classmethod
    def validate_sum(cls, values: Dict[str, float]) -> Dict[str, float]:
        total = sum(values.values())
        if not abs(total - 1.0) < 1e-6:
            raise ValueError("Outcome matrix probabilities must sum to 1.0")
        return values
class PredictDirective(BaseModel):
    max_abandon_rate: float
    target_agent_efficiency: float
    max_dials_per_minute: Optional[int] = None
class SimulationPayload(BaseModel):
    campaign_id: str
    dialer_type: str
    outcome_matrix: OutcomeMatrix
    predict_directive: PredictDirective
    sample_size: int
    iterations: int = 100
    @field_validator("dialer_type")
    @classmethod
    def validate_dialer(cls, v: str) -> str:
        valid_types = ["predictive", "power", "progressive"]
        if v not in valid_types:
            raise ValueError(f"Dialer type must be one of {valid_types}")
        return v
    @field_validator("sample_size")
    @classmethod
    def validate_sample_limit(cls, v: int) -> int:
        # CXone simulation engine enforces a hard limit of 10000 for standard tenants
        MAX_SAMPLE = 10000
        if v > MAX_SAMPLE:
            raise ValueError(f"Sample size exceeds engine limit of {MAX_SAMPLE}")
        return v
Validation prevents optimistic bias by enforcing realistic probability distributions and respecting engine constraints. The sample_size limit varies by tenant tier, so you should parameterize MAX_SAMPLE for enterprise environments.
Step 2: Execute Monte Carlo Iterations via Atomic GET Polling
Simulation jobs run asynchronously. You must poll the result endpoint until completion. The polling loop must handle rate limits and implement variance reduction triggers when standard deviation exceeds acceptable thresholds.
import requests
import numpy as np
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
def poll_simulation_results(
    base_url: str,
    campaign_id: str,
    simulation_id: str,
    auth_token: str,
    max_variance: float = 0.15
) -> dict:
    endpoint = f"{base_url}/api/v2/outbound/campaigns/{campaign_id}/simulate/{simulation_id}"
    headers = {"Authorization": f"Bearer {auth_token}"}
    @retry(
        stop=stop_after_attempt(10),
        wait=wait_exponential(multiplier=1, min=2, max=30),
        retry=retry_if_exception_type(requests.exceptions.HTTPError)
    def fetch_result():
        response = requests.get(endpoint, headers=headers, timeout=15)
        response.raise_for_status()
        return response.json()
    result_data = fetch_result()
    while result_data.get("status") == "RUNNING":
        time.sleep(5)
    if result_data.get("status") == "FAILED":
        raise RuntimeError(f"Simulation failed: {result_data.get('error_message')}")
    # Variance reduction trigger
    projections = result_data.get("projections", [])
    if projections:
        conversion_rates = [p.get("conversion_rate", 0) for p in projections]
        std_dev = np.std(conversion_rates)
        if std_dev > max_variance:
            result_data["variance_reduction_triggered"] = True
            result_data["recommended_action"] = "Increase iterations or adjust predict_directive constraints"
    return result_data
The tenacity decorator handles 429 rate limit cascades automatically. The variance reduction trigger inspects the standard deviation of projected conversion rates. If the spread exceeds the threshold, the pipeline flags the result for manual review or automatic iteration adjustment.
Step 3: Verify Distributions and Confidence Intervals
Raw simulation outputs require statistical validation. You must verify that the projected distribution fits a normal model and that confidence intervals align with operational targets.
from scipy import stats
import json
def validate_simulation_statistics(result_data: dict, confidence_level: float = 0.95) -> dict:
    if not projections:
        raise ValueError("No projection data available for statistical validation")
    metrics = {}
    for proj in projections:
        metric_name = proj.get("metric", "unknown")
        values = proj.get("distribution", [])
        lower_bound = proj.get("confidence_interval_lower")
        upper_bound = proj.get("confidence_interval_upper")
        mean_val = proj.get("mean")
        if not values or mean_val is None:
        # Kolmogorov-Smirnov test for normality
        ks_stat, ks_pvalue = stats.kstest(values, "norm", args=(mean_val, np.std(values)))
        is_normal = ks_pvalue > (1.0 - confidence_level)
        # Confidence interval verification
        ci_valid = lower_bound is not None and upper_bound is not None and lower_bound < upper_bound
        optimistic_bias_detected = lower_bound < 0.05  # Adjust threshold per business SLA
        metrics[metric_name] = {
            "mean": mean_val,
            "is_normal_distribution": is_normal,
            "ci_valid": ci_valid,
            "ci_lower": lower_bound,
            "ci_upper": upper_bound,
            "optimistic_bias_flag": optimistic_bias_detected
    return {"statistical_validation": metrics, "passed": all(m["ci_valid"] for m in metrics.values())}
The validation pipeline prevents optimistic bias by flagging metrics where the lower confidence bound falls below operational thresholds. The Kolmogorov-Smirnov test ensures the Monte Carlo output approximates a normal distribution, which is required for reliable capacity planning.
Step 4: Synchronize Results and Generate Audit Logs
You must synchronize simulation outcomes with external planning tools and maintain governance logs. The pipeline posts results to a configured webhook and writes structured audit records.
import httpx
import logging
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
logger = logging.getLogger("cxone_simulator")
def sync_and_log_results(
    simulation_id: str,
    result_data: dict,
    validation_data: dict,
    webhook_url: str,
    audit_log_path: str,
    start_time: float
) -> None:
    latency_seconds = time.time() - start_time
    success_rate = result_data.get("success_rate", 0.0)
    payload = {
        "simulation_id": simulation_id,
        "status": result_data.get("status"),
        "latency_seconds": round(latency_seconds, 2),
        "success_rate": success_rate,
        "validation_passed": validation_data.get("passed"),
        "timestamp": datetime.now(timezone.utc).isoformat()
    # Synchronize with external planning tool
    async def post_webhook():
                response = await client.post(webhook_url, json=payload)
                logger.info("Webhook synchronized successfully for %s", simulation_id)
                logger.error("Webhook sync failed: %s", e.response.status_code)
    import asyncio
    asyncio.run(post_webhook())
    # Generate audit log
    audit_record = {
        "event_type": "SIMULATION_COMPLETED",
        "latency_seconds": payload["latency_seconds"],
        "predict_success_rate": success_rate,
        "variance_reduction_triggered": result_data.get("variance_reduction_triggered"),
        "optimistic_bias_detected": any(m.get("optimistic_bias_flag") for m in validation_data.get("statistical_validation", {}).values()),
        "logged_at": datetime.now(timezone.utc).isoformat()
    with open(audit_log_path, "a") as f:
        f.write(json.dumps(audit_record) + "\n")
    logger.info("Audit log written for %s", simulation_id)
The webhook synchronization uses httpx for non-blocking delivery. The audit log records latency, success rates, variance triggers, and bias flags. Governance teams use these logs to track simulation efficiency and enforce compliance thresholds.
import os
import asyncio
import requests
import httpx
import numpy as np
import json
import logging
    answered: float
    busy: float
    no_answer: float
    fax: float
    disconnected: float
    @classmethod
        return v
    @classmethod
        return values
    campaign_id: str
    dialer_type: str
    sample_size: int
    @classmethod
        return v
    @classmethod
        MAX_SAMPLE = 10000
        if v > MAX_SAMPLE:
        return v
    return ApiClient(configuration=config)
def get_auth_token(api_client: ApiClient) -> str:
        api_client.refresh_access_token()
        return api_client.configuration.access_token
    except ApiException as e:
        logger.error("Token refresh failed: %s", e.body)
        raise
def submit_simulation(base_url: str, payload: SimulationPayload, auth_token: str) -> str:
    endpoint = f"{base_url}/api/v2/outbound/campaigns/{payload.campaign_id}/simulate"
    headers = {"Authorization": f"Bearer {auth_token}", "Content-Type": "application/json"}
    body = {
        "dialerType": payload.dialer_type,
        "outcomeMatrix": payload.outcome_matrix.model_dump(),
        "predictDirective": payload.predict_directive.model_dump(),
        "sampleSize": payload.sample_size,
        "iterations": payload.iterations
    response = requests.post(endpoint, headers=headers, json=body, timeout=20)
    result = response.json()
    return result.get("id") or result.get("simulationId")
def poll_simulation_results(base_url: str, campaign_id: str, simulation_id: str, auth_token: str, max_variance: float = 0.15) -> dict:
    @retry(stop=stop_after_attempt(10), wait=wait_exponential(multiplier=1, min=2, max=30), retry=retry_if_exception_type(requests.exceptions.HTTPError))
    def fetch_result():
        time.sleep(5)
    if projections:
    return result_data
    if not projections:
    metrics = {}
            "mean": mean_val,
def sync_and_log_results(simulation_id: str, result_data: dict, validation_data: dict, webhook_url: str, audit_log_path: str, start_time: float) -> None:
    payload = {
    audit_record = {
def run_campaign_simulation() -> None:
    env_url = os.getenv("CXONE_ENV_URL", "https://api-us-01.niceincontact.com")
    client_id = os.getenv("CXONE_CLIENT_ID")
    client_secret = os.getenv("CXONE_CLIENT_SECRET")
    campaign_id = os.getenv("CXONE_CAMPAIGN_ID")
    webhook_url = os.getenv("SIM_WEBHOOK_URL", "https://planning.example.com/webhooks/cxone-sim")
    audit_path = os.getenv("AUDIT_LOG_PATH", "simulation_audit.log")
    api_client = build_cxone_client(env_url, client_id, client_secret)
    auth_token = get_auth_token(api_client)
    payload = SimulationPayload(
        campaign_id=campaign_id,
        dialer_type="predictive",
        outcome_matrix=OutcomeMatrix(answered=0.15, busy=0.20, no_answer=0.60, fax=0.03, disconnected=0.02),
        predict_directive=PredictDirective(max_abandon_rate=0.03, target_agent_efficiency=0.85),
        sample_size=5000,
        iterations=100
    start_time = time.time()
    logger.info("Submitting simulation for campaign %s", campaign_id)
    simulation_id = submit_simulation(env_url, payload, auth_token)
    logger.info("Simulation submitted with ID: %s", simulation_id)
    result_data = poll_simulation_results(env_url, campaign_id, simulation_id, auth_token)
    validation_data = validate_simulation_statistics(result_data)
    sync_and_log_results(simulation_id, result_data, validation_data, webhook_url, audit_path, start_time)
    logger.info("Simulation pipeline completed successfully")
Error: 400 Bad Request
  • Cause: The payload violates schema constraints. Common triggers include outcome matrix probabilities that do not sum to 1.0, sample size exceeding tenant limits, or invalid dialer types.
  • Fix: Verify the OutcomeMatrix sum validation. Reduce sample_size if your tenant enforces a lower cap. Check that dialer_type matches one of the allowed values.
  • Code Fix: The SimulationPayload model catches these errors before transmission. Inspect the ValidationError traceback to identify the exact field.
  • Cause: Expired OAuth token or missing scopes. The simulation endpoint requires outbound:campaign:execute in addition to read/write permissions.
  • Fix: Regenerate the token using api_client.refresh_access_token(). Verify your OAuth client configuration includes all three required scopes.
  • Code Fix: The get_auth_token function raises ApiException on refresh failure. Wrap the submission call in a try-except block that logs the scope mismatch and retries token acquisition.
  • Cause: Polling the simulation result endpoint too frequently or submitting multiple simulations in rapid succession.
  • Fix: The tenacity decorator implements exponential backoff. Increase the wait_exponential multiplier if your tenant enforces strict rate limits.
  • Code Fix: Adjust wait=wait_exponential(multiplier=2, min=5, max=60) in the poll_simulation_results function. Monitor the RetryError exception to confirm the backoff strategy.
  • Cause: The simulation engine encountered an unrecoverable state, often due to corrupted campaign configuration or unsupported predict directive parameters.
  • Fix: Validate the campaign status in the admin console. Ensure the campaign is in ACTIVE or PAUSED state before simulation.
  • Code Fix: Catch requests.exceptions.HTTPError with status code 500. Log the campaign ID and payload hash. Retry after a 30-second delay or escalate to platform support.
