I have been administrating an ICS 6.5 platform for years, but I have never actually witnessed the following scenario until today while building a VRP for a small set of new users. Here is what I have:
Skills based routing with a single skill, single VRP, single strategy. The select object selects targets based on Skill with a statistic of max(StatTimeInReadyState). Three agents log in and enter a Ready state in the following order: Agent1, Agent2, Agent3. When the first email arrives, naturally it is routed to Agent1, who handles it and returns to a Ready state. When the second email arrives, I would expect it to route to Agent2, since that agent’s StatTimeInReadyState should now be the greatest of the three, but instead the second email routes to Agent1 again. 3rd and subsequent emails behave in the same way.
My question: why arent the emails routing in a round-robin fashion based on which agent has been ready the longest as the statistic would imply?
Simple question:
StatTimeInReadyState is measuring Actions or Status. If measuring Actions then would explain it, change it to Status monitoring and should be fine.
Might be URS is available (covering first 3 calls all routed to Agnet1)? Also what is URS version?
StatTimeInReadyState you are using - is that one of predefined statistics in IRD?
I find several instances of the following in URS log:
_M_I_006a02151c2b5086 [smGetStatObject] ask statistic StatTimeInReadyState@StatServer <request= 4756, status= 1> for 099001656
====================== Target Information =====================
Target Name < 099001656 >
Target Location < StatServer >
Target Type < A >
STATE MAPPING INFO - STATISTIC < ##state >:
Stat Server Statistic: NOT available
Modelling Statistic : NOT available
STATISTIC < StatTimeInReadyState >
So it looks as if that statistic is defined in URS but not in StatServer. Any idea what the correct definition should be in StatServer?
