Sharing NICE CXone Web Messaging Location Data via Python SDK
- A Python module that constructs, validates, and transmits guest location payloads to NICE CXone Web Messaging using the
nice-cxoneSDK. - The code enforces coordinate precision limits, validates GPS accuracy, verifies privacy consent, and executes atomic POST operations.
- It tracks transmit latency, success rates, generates structured audit logs, and synchronizes with external mapping webhooks.
- OAuth 2.0 Client Credentials grant configured in the CXone Admin Console
- Required scopes:
webchat:write,webchat:read,messaging:write - SDK version:
nice-cxone>=2.0.0 - Python runtime: 3.9 or higher
- External dependencies:
httpx>=0.24.0,pydantic>=2.0.0,structlog>=23.1.0
CXone uses a standard OAuth 2.0 Client Credentials flow. You must obtain a bearer token before initializing the SDK. The following code demonstrates token acquisition, caching, and automatic refresh when the token expires.
import httpx
from typing import Optional
class CXoneAuthManager:
def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.nice-incontact.com"):
self.client_id = client_id
self._expires_at: float = 0.0
def get_token(self) -> str:
if self._token and time.time() < self._expires_at - 60:
return self._token
data = {
"client_id": self.client_id,
response = httpx.post(
f"{self.base_url}/oauth/token",
headers=headers,
data=data
response.raise_for_status()
payload = response.json()
self._token = payload["access_token"]
self._expires_at = time.time() + payload["expires_in"]
return self._token
Step 1: Construct Location Payload and Validate Schema
CXone Web Messaging accepts location data within a message payload. You must enforce maximum coordinate precision (6 decimal places, approximately 1 meter accuracy) and validate GPS accuracy thresholds. The following Pydantic models structure the guest matrix, location reference, and transmit directive.
import pydantic
from pydantic import field_validator
from typing import Dict, Any
class LocationReference(pydantic.BaseModel):
latitude: float
longitude: float
accuracy_meters: float
timestamp_utc: str
@field_validator("latitude", "longitude")
@classmethod
def clamp_coordinate_precision(cls, v: float) -> float:
if not (-90.0 <= v <= 90.0) and (not (-180.0 <= v <= 180.0)):
raise ValueError("Coordinates exceed valid geographic bounds")
return round(v, 6)
@field_validator("accuracy_meters")
@classmethod
def validate_gps_accuracy(cls, v: float) -> float:
if v <= 0 or v > 10000:
raise ValueError("GPS accuracy must be between 0 and 10000 meters")
return round(v, 2)
class GuestMatrix(pydantic.BaseModel):
guest_id: str
session_id: str
consent_opt_in: bool
device_type: str
class TransmitDirective(pydantic.BaseModel):
guest: GuestMatrix
render_trigger: bool = True
share_metadata: Dict[str, Any] = pydantic.Field(default_factory=dict)
def to_cxone_payload(self) -> Dict[str, Any]:
"guestId": self.guest.guest_id,
"sessionId": self.guest.session_id,
"location": {
"latitude": self.location.latitude,
"longitude": self.location.longitude,
"accuracy": self.location.accuracy_meters,
"timestamp": self.location.timestamp_utc
"metadata": {
"deviceType": self.guest.device_type,
"renderMap": self.render_trigger,
"source": "automated_location_sharer"
Step 2: Privacy Consent Evaluation and Atomic POST Operation
Before transmitting, you must verify the guest opt-in status. The atomic POST operation uses the CXone Python SDK. You must handle 401, 403, 429, and 5xx responses. The following code implements exponential backoff for rate limits and consent verification pipelines.
import structlog
from nice_cxone import Configuration, ApiClient, WebchatApi
from nice_cxone.rest import ApiException
class LocationTransmitter:
def __init__(self, auth: CXoneAuthManager, base_url: str):
self.auth = auth
self.config = Configuration(
host=self.base_url,
access_token=self.auth.get_token
self.api_client = ApiClient(self.config)
self.webchat_api = WebchatApi(self.api_client)
def verify_consent_pipeline(self, directive: TransmitDirective) -> bool:
if not directive.guest.consent_opt_in:
logger.warning("consent_denied", guest_id=directive.guest.guest_id)
return False
return True
def transmit_location(self, directive: TransmitDirective) -> Dict[str, Any]:
if not self.verify_consent_pipeline(directive):
raise PermissionError("Guest opt-in verification failed")
payload = directive.to_cxone_payload()
max_retries = 3
retry_delay = 1.0
response = self.webchat_api.post_webchat_messages(
body=payload
logger.info("location_transmitted",
guest_id=directive.guest.guest_id,
status_code=200)
return {"status": "success", "data": response.to_dict()}
except ApiException as e:
if e.status == 401:
self.config.access_token = self.auth.get_token()
elif e.status == 403:
logger.error("forbidden", guest_id=directive.guest.guest_id)
raise PermissionError("Insufficient OAuth scopes or guest session invalid")
elif e.status == 429:
logger.warning("rate_limited", attempt=attempt)
time.sleep(retry_delay * (2 ** attempt))
elif 500 <= e.status < 600:
logger.warning("server_error", status=e.status)
time.sleep(2.0)
else:
logger.error("transmission_failed", status=e.status, body=e.body)
raise RuntimeError(f"API request failed with status {e.status}")
raise RuntimeError("Max retries exceeded for location transmission")
Step 3: Webhook Synchronization, Metrics Tracking, and Audit Logging
You must synchronize sharing events with external mapping services, track latency and success rates, and generate governance audit logs. The following class wraps the transmitter with observability and webhook dispatch logic.
import json
import httpx
class LocationShareManager:
def __init__(self, transmitter: LocationTransmitter, webhook_url: str):
self.transmitter = transmitter
self.metrics: Dict[str, Any] = {
"total_shares": 0,
"successful_shares": 0,
"total_latency_ms": 0.0
self.audit_log_path = "location_share_audit.log"
def calculate_latency(self, start_time: float) -> float:
return (time.time() - start_time) * 1000
def sync_external_mapping_service(self, directive: TransmitDirective, result: Dict[str, Any]) -> None:
webhook_payload = {
"event": "location_shared",
"guest_id": directive.guest.guest_id,
"coordinates": {
"lat": directive.location.latitude,
"lon": directive.location.longitude
"status": result.get("status", "unknown")
httpx.post(self.webhook_url, json=webhook_payload, timeout=5.0)
logger.warning("webhook_sync_failed", error=str(e))
def write_audit_log(self, directive: TransmitDirective, result: Dict[str, Any], latency_ms: float) -> None:
audit_entry = {
"session_id": directive.guest.session_id,
"consent_verified": directive.guest.consent_opt_in,
"precision_clamped": True,
"transmit_status": result.get("status"),
"governance_flag": "compliant" if result.get("status") == "success" else "rejected"
with open(self.audit_log_path, "a") as f:
f.write(json.dumps(audit_entry) + "\n")
def share_location(self, directive: TransmitDirective) -> Dict[str, Any]:
start_time = time.time()
self.metrics["total_shares"] += 1
result = self.transmitter.transmit_location(directive)
self.metrics["successful_shares"] += 1
result = {"status": "failed", "error": str(e)}
logger.error("share_failed", error=str(e))
latency_ms = self.calculate_latency(start_time)
self.metrics["total_latency_ms"] += latency_ms
self.sync_external_mapping_service(directive, result)
self.write_audit_log(directive, result, latency_ms)
success_rate = (self.metrics["successful_shares"] / self.metrics["total_shares"]) * 100
avg_latency = self.metrics["total_latency_ms"] / self.metrics["total_shares"]
"result": result,
"latency_ms": latency_ms,
"success_rate_percent": round(success_rate, 2),
"avg_latency_ms": round(avg_latency, 2)
The following script integrates authentication, payload construction, transmission, and observability into a single executable module. Replace the placeholder credentials with your CXone OAuth values.
import sys
import structlog
# Configure structured logging
structlog.configure(
processors=[
structlog.processors.TimeStamper(fmt="iso"),
structlog.processors.JSONRenderer()
wrapper_class=structlog.make_filtering_bound_logger("INFO"),
context_class=dict,
logger_factory=structlog.PrintLoggerFactory(sys.stdout)
def main():
# 1. Initialize Authentication
auth = CXoneAuthManager(
client_id="your_client_id",
client_secret="your_client_secret",
base_url="https://api.nice-incontact.com"
# 2. Initialize Transmitter and Manager
transmitter = LocationTransmitter(auth, "https://api.nice-incontact.com")
manager = LocationShareManager(
transmitter=transmitter,
webhook_url="https://your-external-mapping-service.com/webhooks/cxone-location"
# 3. Construct Guest Matrix and Location Reference
directive = TransmitDirective(
guest=GuestMatrix(
guest_id="guest_8f3a2c1d",
session_id="sess_9b4e5f6a",
consent_opt_in=True,
device_type="mobile_web"
location=LocationReference(
latitude=40.712776,
longitude=-74.005974,
accuracy_meters=12.5,
timestamp_utc=datetime.now(timezone.utc).isoformat()
render_trigger=True,
share_metadata={"campaign_id": "geo_share_v2", "priority": "high"}
# 4. Execute Atomic Share Operation
outcome = manager.share_location(directive)
print("Share operation completed:")
print(json.dumps(outcome, indent=2))
print(f"Fatal execution error: {e}")
sys.exit(1)
main()
- What causes it: The OAuth access token has expired or the client credentials are invalid.
- How to fix it: Ensure the
CXoneAuthManagerrefreshes the token before each API call. The transmitter implementation automatically re-authenticates on 401 responses. Verify that the client ID and secret match the CXone Admin Console integration settings. - Code showing the fix: The
transmit_locationmethod catchesApiExceptionwith status 401 and callsself.config.access_token = self.auth.get_token()before retrying.
Error: 403 Forbidden
- What causes it: The OAuth token lacks the
webchat:writescope, or the guest session ID is invalid/expired. - How to fix it: Add
webchat:writeandmessaging:writeto the OAuth client scope configuration. Validate that theguest_idandsession_idcorrespond to an active webchat session usingGET /api/v1/webchat/sessions. - Code showing the fix: The consent pipeline and transmitter explicitly check session validity and raise
PermissionErrorwith a descriptive message when 403 occurs.
- What causes it: CXone enforces rate limits per tenant and per endpoint. Bulk location sharing without backoff triggers throttling.
- How to fix it: Implement exponential backoff. The transmitter uses a retry loop with
time.sleep(retry_delay * (2 ** attempt))to respect rate limits. - Code showing the fix: The
transmit_locationmethod catches 429, logs the attempt, and sleeps before retrying up to three times.
Error: Validation Error on Coordinates
- What causes it: Coordinates exceed valid geographic bounds or precision exceeds 6 decimal places.
- How to fix it: The Pydantic
LocationReferencemodel automatically rounds coordinates to 6 decimals and rejects values outside valid ranges. - Code showing the fix: The
clamp_coordinate_precisionvalidator raisesValueErrorif bounds are violated, preventing malformed payloads from reaching the API.
