We’re hitting a weird issue calling a shared module from multiple inbound flows. The module ID is correct, but the execution jumps straight to the end of the flow without running the shared logic. I’m using the standard Invoke Module node in Architect. No errors in the logs, just silent failure. Is there a specific config needed for module reuse across different flow types? Here’s the JSON config I’m passing to the node.
