Setting no-answer-overflow from strategy?
Hi
Is it possible to set no-answer-overflow from a routing strategy? I would like to avoid setting it on each agent login (We need to have different routepoint for different agents).
I have tried SetCallOption[‘no-answer-overflow’,‘XXXX’] in a function box in the strategy but it does not seems to have any effect. It does not appear in the log files.
We are using SIP server 8.
Try to set them as an Extension data
