Set Participant Data action dropping custom attributes in IVR flow
I’m trying to pass custom variables through an IVR flow using the “Set Participant Data” action. The goal is to attach a correlation ID from an upstream API call so we can trace the conversation in our OTel pipeline later.
Here is the Data Action JSON mapping I’m using:
 "action": "setParticipantData",
 "inputs": {
 "conversationId": "{{conversation.id}}",
 "participantId": "{{conversation.participants[0].id}}",
 "data": {
 "correlationId": "{{inputs.correlationId}}"
The action succeeds with a 200 OK response. No errors in the trace. But when I hit the next node and try to read {{conversation.participants[0].data.correlationId}}, it’s null.
I’ve checked the participant ID. It’s correct. The input variable correlationId is definitely populated. I even tried using the REST API directly to update the participant data via /api/v2/conversations/{conversationId}/participants/{participantId}/attributes with a PATCH request, and that works fine. The data persists.
Is there a delay in propagation for the Data Action? Or am I missing a specific flag in the JSON payload? I’ve tried adding "overwrite": true but that didn’t help.
Any ideas on why the Data Action isn’t persisting the custom attributes?
