ServiceNow Webhook Timeout in Architect Flow
Context:
Running into a weird bug with the ServiceNow Data Action webhook inside an Architect flow. The payload includes dynamic variables from the previous script node, but the response consistently times out after 5 seconds with a 504 Gateway Timeout, even though the ServiceNow endpoint responds instantly in Postman.
Question:
Is there a known timeout limitation for outbound webhooks triggered by conversation events in Genesys Cloud, or should I be implementing a retry mechanism within the Data Action configuration?
If I remember right, the 5-second window is a hard limit for synchronous outbound calls in Architect, specifically when handling conversation events that require immediate state updates. This constraint exists to prevent the call leg from hanging while waiting for external systems that may have unpredictable latency.
Cause:
The ServiceNow endpoint, while fast in Postman, likely introduces slight network latency or payload serialization time that pushes the total round-trip time over the 5-second threshold. Genesys Cloud aborts the request to protect the call flow stability.
Solution:
Decouple the webhook from the real-time conversation path. Instead of calling ServiceNow directly from the Data Action, use a Task Router task or a Queue to handle the integration asynchronously.
  1. Create a task in Architect with a low-priority skill.
  2. Post the task to the queue with the ServiceNow payload in the task description.
  3. Use a separate integration (like AppFoundry or a backend service) to poll or consume the task and trigger the ServiceNow API.
This approach bypasses the 5-second timeout entirely and ensures the call flow remains responsive. Check the API rate limits on your ServiceNow instance if you scale this pattern.
TL;DR: Switch to asynchronous processing. The synchronous webhook blocks the conversation thread, causing the 504 timeout.
Ah, this is a known issue with synchronous outbound calls in Architect. The 5-second limit is strict for conversation events. When you send the payload directly to ServiceNow, any minor latency breaks the chain of custody for the recording metadata.
A better approach for legal discovery workflows is to decouple the action. Use a webhook to push the data to an internal queue or S3 bucket first, then trigger a separate job to update ServiceNow. This keeps the call leg alive and ensures the metadata is captured before the conversation ends.
Here is the config structure:
 "action": "create_work_item",
 "queue_id": "service_now_async_queue",
 "payload": "{{conversation_id}}_metadata"
This prevents the gateway timeout and ensures the audit trail remains intact. We see this pattern often in digital channel exports where timing is critical.
