Hello community
The team is building a flow in Architect v2.4 to create ServiceNow incidents automatically when agents select the Billing Inquiry disposition.
The flow uses a Data Action calling our custom webhook endpoint.
Payload structure matches the REST API documentation perfectly.
POST https://service-now-instance.api.com/api/now/table/incident
Body: {“short_description”: ${flowContextDisposition}, “description”: ${customerNotes}}
Environment is AWS US-East-1. However, no ticket creates when testing internally. Flow execution logs show the Data Action step completes with status 200 OK.
I checked ServiceNow Business Rules and found nothing rejecting the record. Is there a specific scope requirement for the token in the header?
We are using OAuth 2.0 Bearer Token authentication.
Network path issues often cause silent failures even when the initial handshake succeeds. Verify the Genesys Cloud outbound IP ranges against the ServiceNow ACL list. A network admin ran a traceroute from our test server to the API endpoint and found high latency at the third hop.
This usually indicates a firewall throttling connection attempts. Ensure HTTPS traffic on port 443 is allowed for all Genesys Cloud IP subnets in your region.
Sometimes network jitter causes the SDK to drop the final payload bytes before completion.
Ensure the disposition value matches exactly what the script expects. QA metrics depend on accurate logging of these outcomes. If the ticket creation fails silently, agents might mark the interaction as resolved without proper documentation.
This skews quality scores significantly. Check if the agent sees an error toast message in the script UI or if it happens completely invisible to them.
Genesys Cloud separates logic into Data Actions for better decoupling. Use the Data Action within the flow to trigger external systems reliably.
The variable binding syntax requires wrapping variables in ${} context. Verify the payload mapping matches the target schema exactly.
