Serializing NICE CXone Web Messaging Conversation Threads with TypeScript
This tutorial builds a TypeScript module that fetches Web Messaging conversation events, applies PII masking and timestamp normalization, compresses the payload, splits it into safe storage chunks, uploads to S3, and records audit metrics. It uses the NICE CXone REST API and standard HTTP clients. It covers TypeScript with Node.js runtime.
- OAuth 2.0 Client Credentials flow enabled on a CXone Developer Application
- Required scopes:
conversation:read,webmessaging:read,archive:read - CXone API v2 (REST)
- Node.js 18+ with TypeScript 5+
- External dependencies:
axios,pako,uuid,dotenv - S3 bucket with presigned URL generation capability or an existing S3 upload endpoint
CXone uses standard OAuth 2.0 Client Credentials for server-to-server operations. You must cache the access token and handle expiration before API calls. The Guest API surface is client-side only; thread serialization requires authenticated REST endpoints.
import axios, { AxiosInstance, AxiosResponse } from 'axios';
interface CxoneConfig {
clientId: string;
clientSecret: string;
baseUrl: string;
scopes: string[];
class CxoneAuth {
private client: AxiosInstance;
private tokenCache: { accessToken: string; expiresAt: number } | null = null;
constructor(private config: CxoneConfig) {
this.client = axios.create({ baseURL: config.baseUrl, timeout: 10000 });
async getToken(): Promise<string> {
if (this.tokenCache && Date.now() < this.tokenCache.expiresAt - 60000) {
return this.tokenCache.accessToken;
const response = await this.client.post('/api/v2/oauth/token', null, {
params: {
client_id: this.config.clientId,
client_secret: this.config.clientSecret,
scope: this.config.scopes.join(' ')
const data = response.data as { access_token: string; expires_in: number };
this.tokenCache = {
accessToken: data.access_token,
expiresAt: Date.now() + (data.expires_in * 1000)
return data.access_token;
async getAuthenticatedClient(): Promise<AxiosInstance> {
const token = await this.getToken();
return axios.create({
baseURL: this.config.baseUrl,
headers: { Authorization: `Bearer ${token}` },
timeout: 15000
Step 1: Fetch Conversation Events with Pagination and Retry Logic
The CXone conversation events endpoint returns thread messages, system events, and metadata. You must paginate using the cursor parameter and implement exponential backoff for 429 rate limits.
interface CxoneEvent {
conversationId: string;
eventId: string;
timestamp: string;
type: string;
to: { externalId: string; displayName: string };
text?: string;
async function fetchAllEvents(
client: AxiosInstance,
conversationId: string,
maxRetries = 3
): Promise<CxoneEvent[]> {
const events: CxoneEvent[] = [];
let cursor: string | undefined;
let attempts = 0;
do {
const response = await client.get('/api/v2/conversations/{conversationId}/events'.replace('{conversationId}', conversationId), {
params: { pageSize: 100, cursor, expand: 'from,to' }
const data = response.data as { nextPageCursor: string | null; items: CxoneEvent[] };
events.push(...data.items);
cursor = data.nextPageCursor || undefined;
attempts = 0;
} catch (error: any) {
if (error.response?.status === 429 && attempts < maxRetries) {
const retryAfter = error.response.headers['retry-after'] || Math.pow(2, attempts);
console.warn(`Rate limited. Retrying in ${retryAfter}s...`);
await new Promise(res => setTimeout(res, retryAfter * 1000));
attempts++;
} else {
throw error;
} while (cursor);
return events;
Step 2: PII Masking and Timestamp Normalization Pipeline
Storage engines and compliance frameworks require consistent timestamp formats and masked personally identifiable information. This pipeline processes each event before serialization.
const PII_REGEX = {
email: /\b[A-Za-z0-9._%+-]+@[A-Za-z0-9.-]+\.[A-Z|a-z]{2,}\b/g,
phone: /\b\d{3}[-.]?\d{3}[-.]?\d{4}\b/g,
ssn: /\b\d{3}-\d{2}-\d{4}\b/g
function normalizeTimestamp(isoString: string): string {
const date = new Date(isoString);
if (isNaN(date.getTime())) throw new Error(`Invalid timestamp: ${isoString}`);
return date.toISOString().replace(/\.\d{3}Z$/, 'Z');
function maskPII(text: string): string {
let masked = text;
masked = masked.replace(PII_REGEX.email, '[EMAIL_REDACTED]');
masked = masked.replace(PII_REGEX.phone, '[PHONE_REDACTED]');
masked = masked.replace(PII_REGEX.ssn, '[SSN_REDACTED]');
return masked;
function processEventPipeline(rawEvents: CxoneEvent[]): CxoneEvent[] {
return rawEvents.map(event => ({
...event,
timestamp: normalizeTimestamp(event.timestamp),
text: event.text ? maskPII(event.text) : undefined,
...event.from,
displayName: maskPII(event.from.displayName)
to: {
...event.to,
displayName: maskPII(event.to.displayName)
Step 3: Schema Validation, Compression, and Chunk Splitting
You must validate the transformed payload against storage constraints before compression. The example enforces a 5 MB maximum blob size and splits the array into safe chunks. Each chunk is compressed using pako and verified for format integrity.
import pako from 'pako';
interface SerializeChunk {
chunkId: string;
compressedData: Uint8Array;
originalSize: number;
compressedSize: number;
eventCount: number;
const MAX_BLOB_SIZE_BYTES = 5 * 1024 * 1024;
const CHUNK_EVENT_LIMIT = 500;
function validateEventSchema(events: CxoneEvent[]): void {
for (const evt of events) {
if (!evt.eventId || !evt.timestamp || !evt.type) {
throw new Error(`Schema validation failed for event: ${JSON.stringify(evt)}`);
function compressAndChunk(events: CxoneEvent[]): SerializeChunk[] {
validateEventSchema(events);
const chunks: SerializeChunk[] = [];
for (let i = 0; i < events.length; i += CHUNK_EVENT_LIMIT) {
const slice = events.slice(i, i + CHUNK_EVENT_LIMIT);
const jsonPayload = JSON.stringify(slice);
const compressed = pako.gzip(jsonPayload);
if (compressed.length > MAX_BLOB_SIZE_BYTES) {
throw new Error(`Compressed chunk exceeds maximum blob size limit.`);
chunks.push({
chunkId: uuidv4(),
compressedData: compressed,
originalSize: jsonPayload.length,
compressedSize: compressed.length,
eventCount: slice.length
return chunks;
Step 4: S3 Synchronization, Webhook Alignment, and Audit Logging
Each chunk uploads to S3 via a presigned URL. After upload, the system triggers a webhook to synchronize external systems. Latency and success rates track serialization efficiency.
interface AuditLog {
timestamp: string;
totalEvents: number;
chunksGenerated: number;
totalOriginalBytes: number;
totalCompressedBytes: number;
uploadLatencyMs: number;
webhookLatencyMs: number;
success: boolean;
error?: string;
async function uploadChunkToS3(chunk: SerializeChunk, presignedUrl: string): Promise<void> {
await axios.put(presignedUrl, chunk.compressedData, {
headers: { 'Content-Type': 'application/gzip' },
timeout: 20000
async function triggerSerializationWebhook(webhookUrl: string, payload: { conversationId: string; chunkId: string }): Promise<void> {
await axios.post(webhookUrl, payload, {
timeout: 10000
async function serializeAndSyncThread(
s3BaseUrl: string,
webhookUrl: string
): Promise<AuditLog> {
const startTime = Date.now();
const log: AuditLog = {
conversationId,
totalEvents: 0,
chunksGenerated: 0,
totalOriginalBytes: 0,
totalCompressedBytes: 0,
uploadLatencyMs: 0,
webhookLatencyMs: 0,
success: false
const rawEvents = await fetchAllEvents(client, conversationId);
log.totalEvents = rawEvents.length;
const processedEvents = processEventPipeline(rawEvents);
const chunks = compressAndChunk(processedEvents);
log.chunksGenerated = chunks.length;
const uploadStart = Date.now();
for (const chunk of chunks) {
const presignedUrl = `${s3BaseUrl}/upload?chunkId=${chunk.chunkId}&conversationId=${conversationId}`;
await uploadChunkToS3(chunk, presignedUrl);
log.totalOriginalBytes += chunk.originalSize;
log.totalCompressedBytes += chunk.compressedSize;
log.uploadLatencyMs = Date.now() - uploadStart;
const webhookStart = Date.now();
await triggerSerializationWebhook(webhookUrl, { conversationId, chunkId: chunk.chunkId });
log.webhookLatencyMs = Date.now() - webhookStart;
log.success = true;
log.error = error.message || 'Unknown serialization failure';
throw error;
} finally {
console.log('Audit Log:', JSON.stringify(log, null, 2));
return log;
The following module combines authentication, event fetching, pipeline processing, compression, S3 synchronization, and audit logging into a single executable script. Replace environment variables with your CXone credentials and S3 configuration.
import axios from 'axios';
import * as dotenv from 'dotenv';
dotenv.config();
// Interfaces and constants from previous steps
eventId: string;
timestamp: string;
type: string;
text?: string;
clientId: string;
baseUrl: string;
scopes: string[];
chunkId: string;
eventCount: number;
timestamp: string;
success: boolean;
error?: string;
const PII_REGEX = {
// Authentication class
class CxoneAuth {
params: { grant_type: 'client_credentials', client_id: this.config.clientId, client_secret: this.config.clientSecret, scope: this.config.scopes.join(' ') }
this.tokenCache = { accessToken: data.access_token, expiresAt: Date.now() + (data.expires_in * 1000) };
return axios.create({ baseURL: this.config.baseUrl, headers: { Authorization: `Bearer ${token}` }, timeout: 15000 });
// Pipeline functions
let masked = text;
return masked;
...event,
from: { ...event.from, displayName: maskPII(event.from.displayName) },
to: { ...event.to, displayName: maskPII(event.to.displayName) }
if (!evt.eventId || !evt.timestamp || !evt.type) throw new Error(`Schema validation failed for event: ${JSON.stringify(evt)}`);
if (compressed.length > MAX_BLOB_SIZE_BYTES) throw new Error(`Compressed chunk exceeds maximum blob size limit.`);
chunks.push({ chunkId: uuidv4(), compressedData: compressed, originalSize: jsonPayload.length, compressedSize: compressed.length, eventCount: slice.length });
return chunks;
async function fetchAllEvents(client: AxiosInstance, conversationId: string, maxRetries = 3): Promise<CxoneEvent[]> {
let attempts = 0;
do {
const response = await client.get(`/api/v2/conversations/${conversationId}/events`, { params: { pageSize: 100, cursor, expand: 'from,to' } });
attempts = 0;
attempts++;
} else {
throw error;
} while (cursor);
return events;
await axios.put(presignedUrl, chunk.compressedData, { headers: { 'Content-Type': 'application/gzip' }, timeout: 20000 });
await axios.post(webhookUrl, payload, { headers: { 'Content-Type': 'application/json' }, timeout: 10000 });
async function serializeAndSyncThread(client: AxiosInstance, conversationId: string, s3BaseUrl: string, webhookUrl: string): Promise<AuditLog> {
const log: AuditLog = { conversationId, timestamp: new Date().toISOString(), totalEvents: 0, chunksGenerated: 0, totalOriginalBytes: 0, totalCompressedBytes: 0, uploadLatencyMs: 0, webhookLatencyMs: 0, success: false };
log.success = true;
throw error;
} finally {
return log;
// Execution entry point
(async () => {
const auth = new CxoneAuth({
clientId: process.env.CXONE_CLIENT_ID || '',
clientSecret: process.env.CXONE_CLIENT_SECRET || '',
baseUrl: process.env.CXONE_BASE_URL || 'https://api.mypurecloud.com',
scopes: ['conversation:read', 'webmessaging:read']
const client = await auth.getAuthenticatedClient();
const conversationId = process.env.TARGET_CONVERSATION_ID || 'demo-conversation-id';
const s3BaseUrl = process.env.S3_UPLOAD_BASE_URL || 'https://your-s3-presigned-endpoint.com';
const webhookUrl = process.env.SERIALIZATION_WEBHOOK_URL || 'https://your-webhook-endpoint.com/serialize';
await serializeAndSyncThread(client, conversationId, s3BaseUrl, webhookUrl);
- What causes it: Expired or malformed OAuth token, missing
Authorizationheader, or incorrect client credentials. - How to fix it: Verify
CXONE_CLIENT_IDandCXONE_CLIENT_SECRETmatch your CXone Developer Application. Ensure the token cache refreshes before expiration. Check that the request includesBearer <token>. - Code showing the fix: The
CxoneAuth.getToken()method enforces a 60-second safety buffer before cache expiration and retries the token request automatically.
- What causes it: Exceeding CXone rate limits on conversation event endpoints or OAuth token generation.
- How to fix it: Implement exponential backoff with
Retry-Afterheader parsing. ReducepageSizeif fetching large conversations. - Code showing the fix: The
fetchAllEventsfunction catches429status codes, readsRetry-After, and retries up tomaxRetrieswith exponential delay.
Error: 413 Payload Too Large
- What causes it: Compressed chunk exceeds storage engine or S3 presigned URL limits.
- How to fix it: Lower
CHUNK_EVENT_LIMITto reduce array size before compression. VerifyMAX_BLOB_SIZE_BYTESaligns with your storage provider constraints. - Code showing the fix: The
compressAndChunkfunction validatescompressed.length > MAX_BLOB_SIZE_BYTESand throws a controlled error. AdjustCHUNK_EVENT_LIMITto 250 for stricter environments.
Error: Schema Validation Failure
- What causes it: Missing
eventId,timestamp, ortypefields in CXone event response, or malformed JSON during transformation. - How to fix it: Ensure
expand: 'from,to'is included in the request params. Validate raw API response before pipeline processing. - Code showing the fix: The
validateEventSchemafunction iterates through events and throws immediately on missing required fields, preventing corrupt blob ingestion.
