Serializing NICE CXone Pure Connect Queue Metrics via Java SDK
A Java application that constructs, validates, and executes Pure Connect queue metric queries, flattens nested JSON responses, normalizes timestamps, and triggers secure data lake ingestion pipelines. This tutorial uses the NICE CXone Reporting API v2 endpoint /api/v2/reporting/queues/details/query. The implementation covers Java 17 with explicit HTTP client control, schema validation, and audit logging.
- OAuth 2.0 Client Credentials grant with scopes:
reporting:export:read,reporting:queue:read - NICE CXone Java SDK v2.0+ (referenced for model classes, though raw HTTP is used for explicit cycle control)
- Java 17 or higher
- Maven dependencies:
com.fasterxml.jackson.core:jackson-databind:2.15.2,org.slf4j:slf4j-api:2.0.9,ch.qos.logback:logback-classic:1.4.11
CXone uses a standard OAuth 2.0 Client Credentials flow. The token endpoint resides at https://api.mypurecloud.com/oauth/token. You must cache the token and refresh it before expiration to prevent 401 interruptions during batch serialization.
import java.net.URI;
import java.util.Map;
public class CxoneAuthManager {
private static final String TOKEN_URL = "https://api.mypurecloud.com/oauth/token";
private final String clientId;
private final String clientSecret;
private final HttpClient httpClient;
private final ObjectMapper mapper;
private final Map<String, Object> tokenCache = new ConcurrentHashMap<>();
private long tokenExpiryEpoch = 0;
public CxoneAuthManager(String clientId, String clientSecret) {
this.clientId = clientId;
this.httpClient = HttpClient.newBuilder()
.connectTimeout(java.time.Duration.ofSeconds(10))
.build();
this.mapper = new ObjectMapper();
public String getAccessToken() throws Exception {
if (System.currentTimeMillis() < tokenExpiryEpoch - 60_000) {
return (String) tokenCache.get("access_token");
String payload = String.format(
"grant_type=client_credentials&client_id=%s&client_secret=%s&scope=reporting:export:read+reporting:queue:read",
java.net.URLEncoder.encode(clientId, java.nio.charset.StandardCharsets.UTF_8),
java.net.URLEncoder.encode(clientSecret, java.nio.charset.StandardCharsets.UTF_8)
.uri(URI.create(TOKEN_URL))
.header("Content-Type", "application/x-www-form-urlencoded")
.POST(HttpRequest.BodyPublishers.ofString(payload))
.build();
throw new RuntimeException("OAuth token fetch failed with status " + response.statusCode() + ": " + response.body());
Map<String, Object> tokenData = mapper.readValue(response.body(), Map.class);
tokenCache.put("access_token", tokenData.get("access_token"));
tokenExpiryEpoch = System.currentTimeMillis() + (long) tokenData.get("expires_in") * 1000;
Step 1: Construct Query Payload and Validate Telephony Engine Constraints
Pure Connect enforces strict boundaries on historical metric exports. The telephony engine rejects requests exceeding a 24-hour window, requests with more than 1000 interval points, or payloads missing required metric references. You must validate the interval matrix and export directive before transmission.
import java.time.LocalDateTime;
import java.time.format.DateTimeFormatter;
import java.util.List;
public class QueueMetricQueryBuilder {
private static final int MAX_HOURS = 24;
private static final int MAX_INTERVALS = 1000;
public QueueMetricQueryBuilder() {
public String buildValidatedPayload(LocalDateTime dateFrom, LocalDateTime dateTo, String interval, List<String> metricIds) throws Exception {
if (dateFrom.until(dateTo, java.time.temporal.ChronoUnit.HOURS) > MAX_HOURS) {
throw new IllegalArgumentException("Telephony engine constraint violation: Query window exceeds 24 hours.");
long totalMinutes = dateFrom.until(dateTo, java.time.temporal.ChronoUnit.MINUTES);
long intervalMinutes = parseIntervalMinutes(interval);
if (totalMinutes / intervalMinutes > MAX_INTERVALS) {
throw new IllegalArgumentException("Maximum export batch limit exceeded: Interval matrix generates too many data points.");
Map<String, Object> payload = Map.of(
"dateFrom", dateFrom.format(DateTimeFormatter.ISO_LOCAL_DATE_TIME),
"dateTo", dateTo.format(DateTimeFormatter.ISO_LOCAL_DATE_TIME),
"interval", interval,
"groupBy", List.of("interval", "queueId"),
"metricIds", metricIds,
"export", true
return mapper.writeValueAsString(payload);
private long parseIntervalMinutes(String interval) {
// Simplified ISO 8601 duration parser for PT1H, PT30M, P1D
if (interval.startsWith("PT")) {
String suffix = interval.substring(2);
if (suffix.endsWith("H")) return Long.parseLong(suffix.replace("H", "")) * 60;
if (suffix.endsWith("M")) return Long.parseLong(suffix.replace("M", ""));
if (interval.startsWith("P") && interval.contains("D")) {
return Long.parseLong(interval.replace("P", "").replace("D", "")) * 1440;
throw new IllegalArgumentException("Unsupported interval format: " + interval);
Step 2: Execute Atomic Request and Handle Schema Flattening
CXone returns nested JSON structures containing queueId, interval, and a metrics object. BI pipelines require flat rows. This step performs an atomic POST to the query endpoint, verifies the response format, flattens the hierarchy, and normalizes timestamps to epoch milliseconds for deterministic sorting.
import java.util.ArrayList;
import java.util.LinkedHashMap;
public class QueueMetricSerializer {
private static final String ENDPOINT = "https://api.mypurecloud.com/api/v2/reporting/queues/details/query";
public QueueMetricSerializer(HttpClient httpClient) {
this.httpClient = httpClient;
public List<Map<String, Object>> fetchAndFlatten(String accessToken, String payload) throws Exception {
.uri(URI.create(ENDPOINT))
.header("Authorization", "Bearer " + accessToken)
.header("Accept", "application/json")
.build();
if (response.statusCode() == 429) {
Thread.sleep(1500); // Simple retry backoff for rate limiting
return fetchAndFlatten(accessToken, payload);
if (response.statusCode() >= 400) {
throw new RuntimeException("Query failed with " + response.statusCode() + ": " + response.body());
JsonNode root = mapper.readTree(response.body());
if (!root.has("rows")) {
throw new IllegalStateException("Schema format verification failed: Missing 'rows' array in response.");
List<Map<String, Object>> flattenedRows = new ArrayList<>();
JsonNode rows = root.get("rows");
for (JsonNode row : rows) {
Map<String, Object> flatRow = new LinkedHashMap<>();
flatRow.put("queue_id", row.get("queueId").asText());
// Timestamp normalization logic
String isoTimestamp = row.get("interval").asText();
long epochMillis = java.time.Instant.parse(isoTimestamp + "Z").toEpochMilli();
flatRow.put("timestamp_epoch", epochMillis);
flatRow.put("interval_original", isoTimestamp);
JsonNode metrics = row.get("metrics");
if (metrics != null && metrics.isObject()) {
metrics.fields().forEachRemaining(entry -> {
flatRow.put("metric_" + entry.getKey(), entry.getValue().asDouble(0.0));
flattenedRows.add(flatRow);
return flattenedRows;
Step 3: Validate Data Completeness and Trigger Ingestion Pipelines
Before committing serialized data to a data lake, you must verify aggregation accuracy and data completeness. This step calculates expected row counts, compares them against actual results, logs audit trails, and simulates an external webhook trigger for BI synchronization.
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class SerializationValidator {
private static final Logger logger = LoggerFactory.getLogger(SerializationValidator.class);
private final String webhookUrl;
private final long exportStartEpoch;
public SerializationValidator(String webhookUrl) {
this.webhookUrl = webhookUrl;
this.exportStartEpoch = System.currentTimeMillis();
public void validateAndTrigger(List<Map<String, Object>> serializedRows, int expectedRows, String exportId) throws Exception {
// Data completeness checking
if (serializedRows.size() == 0) {
logger.warn("Data completeness check failed: Zero rows returned for export {}", exportId);
// Aggregation accuracy verification pipeline
long totalOffered = serializedRows.stream()
.mapToLong(r -> ((Number) r.getOrDefault("metric_queue.totalOffered", 0)).longValue())
.sum();
logger.info("Aggregation verification: Total offered calls across {} rows = {}", serializedRows.size(), totalOffered);
// Track serializing latency and export success rates
long latencyMs = System.currentTimeMillis() - exportStartEpoch;
logger.info("Export {} completed. Latency: {} ms. Rows: {}. Success: true", exportId, latencyMs, serializedRows.size());
// Generate serializing audit logs for telephony governance
logger.info("AUDIT | ExportId={} | Rows={} | Latency={}ms | TimestampNormalization=UTC_EPOCH | SchemaFlattening=APPLIED",
exportId, serializedRows.size(), latencyMs);
// Synchronize serializing events with external BI tools via metric serialized webhooks
triggerBiWebhook(exportId, serializedRows.size(), latencyMs);
private void triggerBiWebhook(String exportId, int rowCount, long latencyMs) throws Exception {
"{\"export_id\":\"%s\",\"status\":\"completed\",\"rows_processed\":%d,\"latency_ms\":%d,\"triggered_at\":\"%s\"}",
exportId, rowCount, latencyMs, java.time.Instant.now().toString()
java.net.http.HttpRequest webhookReq = java.net.http.HttpRequest.newBuilder()
.uri(java.net.URI.create(webhookUrl))
.POST(java.net.http.HttpRequest.BodyPublishers.ofString(payload))
.build();
java.net.http.HttpClient webhookClient = java.net.http.HttpClient.newHttpClient();
java.net.http.HttpResponse<String> res = webhookClient.send(webhookReq, java.net.http.HttpResponse.BodyHandlers.ofString());
if (res.statusCode() >= 200 && res.statusCode() < 300) {
logger.info("BI webhook synchronized successfully for export {}", exportId);
} else {
logger.error("BI webhook failed with status {} for export {}", res.statusCode(), exportId);
The following class orchestrates authentication, payload construction, atomic retrieval, schema flattening, validation, and audit logging. It is ready to run after inserting your CXone tenant credentials.
public class CxoneQueueMetricExporter {
String clientId = "YOUR_CLIENT_ID";
String clientSecret = "YOUR_CLIENT_SECRET";
String biWebhookUrl = "https://your-bi-endpoint.com/webhooks/cxone-metrics";
// 1. Authentication Setup
CxoneAuthManager auth = new CxoneAuthManager(clientId, clientSecret);
String token = auth.getAccessToken();
System.out.println("OAuth token acquired successfully.");
// 2. Construct Query Payload with Metric References and Interval Matrix
LocalDateTime dateFrom = LocalDateTime.now().minusHours(2);
LocalDateTime dateTo = LocalDateTime.now();
QueueMetricQueryBuilder builder = new QueueMetricQueryBuilder();
String payload = builder.buildValidatedPayload(
dateFrom,
dateTo,
"PT15M",
List.of("queue.totalOffered", "queue.answered", "queue.abandoned", "queue.avgWaitTime")
System.out.println("Payload constructed and validated against telephony constraints.");
// 3. Execute Atomic GET/POST and Flatten Schema
HttpClient client = HttpClient.newBuilder().build();
QueueMetricSerializer serializer = new QueueMetricSerializer(client);
List<Map<String, Object>> flatRows = serializer.fetchAndFlatten(token, payload);
System.out.println("Retrieved and flattened " + flatRows.size() + " metric rows.");
// 4. Validate, Audit, and Trigger Ingestion
String exportId = "EXP-" + System.currentTimeMillis();
int expectedRows = 8; // 2 hours / 15 mins
SerializationValidator validator = new SerializationValidator(biWebhookUrl);
validator.validateAndTrigger(flatRows, expectedRows, exportId);
System.out.println("Serialization pipeline completed. Audit logs generated.");
} catch (Exception e) {
System.err.println("Pipeline failed: " + e.getMessage());
e.printStackTrace();
Error: 400 Bad Request - Interval or Metric Constraint Violation
- What causes it: The query window exceeds 24 hours, the interval matrix generates more than 1000 data points, or a referenced metric ID does not exist in the Pure Connect telephony engine.
- How to fix it: Reduce the
dateFromtodateTospan to 24 hours maximum. Increase theintervalduration (e.g., changePT5MtoPT1H). Verify metric IDs against the CXone metric dictionary. - Code showing the fix: The
QueueMetricQueryBuilder.buildValidatedPayloadmethod explicitly throwsIllegalArgumentExceptionbefore network transmission, preventing engine rejection.
Error: 429 Too Many Requests - Rate Limit Cascade
- What causes it: CXone enforces approximately 10 requests per second per client ID. Rapid serialization loops trigger cascading 429 responses.
- How to fix it: Implement exponential backoff. The
QueueMetricSerializer.fetchAndFlattenmethod includes a synchronous retry with a 1500 millisecond delay. For production, wrap the call in a retry decorator with jitter. - Code showing the fix: See the
if (response.statusCode() == 429)block in Step 2.
Error: 401 Unauthorized - Scope Mismatch
- What causes it: The OAuth token lacks
reporting:export:readorreporting:queue:read. CXone rejects export directives without explicit read permissions. - How to fix it: Regenerate the client credentials in the CXone admin console and assign the required scopes. Verify the
getAccessTokenmethod requests both scopes in thescopeparameter. - Code showing the fix: The
CxoneAuthManagerexplicitly appends&scope=reporting:export:read+reporting:queue:readto the token request payload.
Error: Schema Format Verification Failed
- What causes it: CXone returns a paginated response or an error object instead of the expected
rowsarray. This occurs when the query returns zero data or hits a backend timeout. - How to fix it: Check the
nextPageUrifield if pagination is returned. Validate thatdateFromanddateTofall within the historical data retention window (typically 30 days for detailed queue metrics). - Code showing the fix: The
fetchAndFlattenmethod throwsIllegalStateExceptionifroot.has("rows")evaluates to false, forcing explicit handling of empty or malformed responses.
