Serializing Genesys Cloud Routing Queue Configurations in Go with Validation, Metrics, and Git Sync
A Go service that fetches routing queue configurations, serializes them with reference resolution and depth validation, verifies skill assignments, tracks export latency and success rates, logs audit events, and registers a webhook to synchronize exports to an external Git repository. This tutorial uses the Genesys Cloud Go SDK and REST API. The programming language covered is Go.
  • OAuth2 Client Credentials grant with scopes: routing:queue:read, routing:skill:read, webhooks:webhook:readwrite, platform:webhook:readwrite
  • Genesys Cloud Go SDK v2 (github.com/mypurecloud/platform-client-sdk-go/v2)
  • Go 1.21 or later
  • Standard library packages: encoding/json, sync/atomic, time, context, net/http, log, fmt
  • A Genesys Cloud organization with at least one routing queue and routing skill
Genesys Cloud uses OAuth2 client credentials flow. You must exchange your client ID and secret for an access token before initializing the SDK. The token expires after thirty minutes, so production systems should cache and refresh tokens automatically. The following function handles token acquisition and basic error routing.
package main
import (
	"bytes"
	"encoding/json"
	"fmt"
	"io"
	"net/http"
	"time"
type OAuthTokenResponse struct {
	TokenType   string `json:"token_type"`
	ExpiresIn   int    `json:"expires_in"`
	Scope       string `json:"scope"`
func fetchOAuthToken(clientID, clientSecret, scope string) (OAuthTokenResponse, error) {
	payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s&scope=%s",
		clientID, clientSecret, scope)
	req, err := http.NewRequest("POST", "https://login.mypurecloud.com/oauth/token", bytes.NewBufferString(payload))
	if err != nil {
		return OAuthTokenResponse{}, fmt.Errorf("failed to create oauth request: %w", err)
	resp, err := client.Do(req)
	if err != nil {
		return OAuthTokenResponse{}, fmt.Errorf("oauth http request failed: %w", err)
	defer resp.Body.Close()
		return OAuthTokenResponse{}, fmt.Errorf("oauth failed with status %d: %s", resp.StatusCode, string(body))
	var token OAuthTokenResponse
	if err := json.NewDecoder(resp.Body).Decode(&token); err != nil {
		return OAuthTokenResponse{}, fmt.Errorf("failed to decode oauth response: %w", err)
	return token, nil
Step 1: SDK Initialization and Atomic Queue Fetching with Version Tracking
You initialize the SDK with the acquired token and configure the HTTP client to enforce TLS and retry policies. Genesys Cloud routing queues include a version field that increments on modification. You use this field to trigger version snapshots and avoid redundant serialization. The SDK provides pagination via PageSize and PageToken.
import (
	"context"
	"fmt"
	"net/http"
	"sync/atomic"
	"time"
	platformClient "github.com/mypurecloud/platform-client-sdk-go/v2"
type QueueConfigSerializer struct {
	Client       *platformClient.PlatformClient
	Metrics      ExportMetrics
	AuditLog     []AuditLogEntry
	DepthLimit   int
	VisitedRefs  map[string]bool
	VersionCache map[string]int64
type ExportMetrics struct {
	TotalExports      atomic.Int64
	SuccessfulExports atomic.Int64
	TotalLatencyNs    atomic.Int64
type AuditLogEntry struct {
	Timestamp time.Time
	QueueID   string
	Version   int64
	Status    string
	Details   string
func NewQueueConfigSerializer(token string, depthLimit int) (*QueueConfigSerializer, error) {
	client, err := platformClient.NewPlatformClient()
	if err != nil {
		return nil, fmt.Errorf("sdk initialization failed: %w", err)
	client.SetAccessToken(token)
	client.SetHttpClient(&http.Client{
		Timeout: 30 * time.Second,
		Transport: &http.Transport{
			TLSHandshakeTimeout: 10 * time.Second,
	return &QueueConfigSerializer{
		Client:       client,
		DepthLimit:   depthLimit,
		VisitedRefs:  make(map[string]bool),
		VersionCache: make(map[string]int64),
	}, nil
func (s *QueueConfigSerializer) FetchQueues(ctx context.Context) ([]platformClient.Queue, error) {
	queuesAPI := s.Client.RoutingApi.GetQueues(ctx, 100, nil, nil, nil, nil, nil, nil, nil)
	var allQueues []platformClient.Queue
	for {
		page, resp, err := queuesAPI.Execute()
		if err != nil {
			if resp != nil && resp.StatusCode == 429 {
				time.Sleep(2 * time.Second)
			return nil, fmt.Errorf("queue fetch failed: %w", err)
		if page.Entities != nil {
			allQueues = append(allQueues, *page.Entities...)
		if page.NextPage == nil || *page.NextPage == "" {
			break
		queuesAPI.SetPageToken(*page.NextPage)
	return allQueues, nil
Step 2: Payload Construction with Config-Refs, Rule Matrices, and Export Directives
Genesys Cloud configurations rely on ID-based references (config-ref). You must resolve these references into a portable export payload. The export directive bundles the queue definition, resolved references, and a rule matrix (routing overflow and skill priority settings) into a single JSON document. You construct this payload using a custom struct that mirrors the serialization schema.
type ExportDirective struct {
	Metadata    ExportMetadata       `json:"metadata"`
	QueueConfig platformClient.Queue `json:"queue_config"`
	RuleMatrix  RuleMatrix           `json:"rule_matrix"`
	ConfigRefs  map[string]string    `json:"config_refs"`
type ExportMetadata struct {
	ExportedAt time.Time `json:"exported_at"`
	Generator  string    `json:"generator"`
	Version    int64     `json:"version"`
type RuleMatrix struct {
	OverflowSettings map[string]interface{} `json:"overflow_settings"`
	SkillPriority    []string               `json:"skill_priority"`
func (s *QueueConfigSerializer) BuildExportPayload(queue platformClient.Queue) ExportDirective {
	refs := make(map[string]string)
	if queue.WrapUpCode != nil && queue.WrapUpCode.Id != nil {
		refs["wrapUpCode"] = *queue.WrapUpCode.Id
	if queue.OutboundQueue != nil && queue.OutboundQueue.Id != nil {
		refs["outboundQueue"] = *queue.OutboundQueue.Id
	if queue.MemberSkillRequirements != nil {
		for _, req := range *queue.MemberSkillRequirements {
			if req.Skill != nil && req.Skill.Id != nil {
				refs[fmt.Sprintf("skill_%s", *req.Skill.Id)] = *req.Skill.Name
	ruleMatrix := RuleMatrix{
		OverflowSettings: map[string]interface{}{
			"longestIdleRouting": queue.LongestIdleRouting,
			"enableCcd":          queue.EnableCcd,
		SkillPriority: make([]string, 0),
	return ExportDirective{
		Metadata: ExportMetadata{
			ExportedAt: time.Now(),
			Generator:  "genesys-queue-serializer-go",
			Version:    queue.Version,
		QueueConfig: queue,
		RuleMatrix:  ruleMatrix,
		ConfigRefs:  refs,
Step 3: Schema Validation, Depth Limits, Circular Reference Detection, and Skill Conflict Checking
Serialization failures occur when object graphs exceed memory constraints or contain circular references. You enforce a maximum depth limit and track visited IDs to break cycles. You also verify that every skill referenced in the queue exists in the routing skill registry and that no conflicting overflow rules exist. The validation runs before JSON marshaling.
func (s *QueueConfigSerializer) ValidateExport(ctx context.Context, payload ExportDirective) error {
	if err := s.checkDepthAndCirculars(payload, 0); err != nil {
		return fmt.Errorf("depth or circular reference violation: %w", err)
	if err := s.verifySkills(ctx, payload); err != nil {
		return fmt.Errorf("skill validation failed: %w", err)
	if err := s.verifyRuleConflicts(payload); err != nil {
		return fmt.Errorf("rule conflict detected: %w", err)
	return nil
func (s *QueueConfigSerializer) checkDepthAndCirculars(payload interface{}, depth int) error {
	if depth > s.DepthLimit {
		return fmt.Errorf("maximum object depth %d exceeded", s.DepthLimit)
	switch v := payload.(type) {
	case map[string]interface{}:
		for k, val := range v {
			if s.VisitedRefs[k] {
				return fmt.Errorf("circular reference detected at key: %s", k)
			s.VisitedRefs[k] = true
			if err := s.checkDepthAndCirculars(val, depth+1); err != nil {
				return err
			delete(s.VisitedRefs, k)
	case []interface{}:
		for _, item := range v {
			if err := s.checkDepthAndCirculars(item, depth+1); err != nil {
				return err
	return nil
func (s *QueueConfigSerializer) verifySkills(ctx context.Context, payload ExportDirective) error {
	skillsAPI := s.Client.RoutingApi.GetSkills(ctx, 100, nil, nil, nil, nil, nil, nil, nil)
	var validSkillIDs map[string]bool = make(map[string]bool)
	for {
		page, resp, err := skillsAPI.Execute()
		if err != nil {
			return fmt.Errorf("skill fetch failed: %w", err)
			for _, skill := range *page.Entities {
				if skill.Id != nil {
					validSkillIDs[*skill.Id] = true
			break
		skillsAPI.SetPageToken(*page.NextPage)
	for refID := range payload.ConfigRefs {
		if len(refID) > 6 && refID[:6] == "skill_" {
			skillID := refID[6:]
			if !validSkillIDs[skillID] {
				return fmt.Errorf("unassigned or invalid skill reference: %s", skillID)
	return nil
func (s *QueueConfigSerializer) verifyRuleConflicts(payload ExportDirective) error {
	overflow := payload.RuleMatrix.OverflowSettings
	if enableCcd, ok := overflow["enableCcd"].(bool); ok && enableCcd {
		if longestIdle, ok := overflow["longestIdleRouting"].(bool); ok && longestIdle {
			return fmt.Errorf("conflicting routing rules: enableCcd and longestIdleRouting cannot both be true")
	return nil
Step 4: Metrics Tracking, Audit Logging, and Webhook Registration for Git Sync
You track serialization latency and success rates using atomic counters. You append structured audit entries for governance. Finally, you register a Genesys Cloud webhook that triggers on queue updates and POSTs the serialized payload to an external Git repository webhook endpoint. This keeps your local configuration in sync with cloud changes.
func (s *QueueConfigSerializer) RegisterGitSyncWebhook(ctx context.Context, webhookURL string) error {
	webhookAPI := s.Client.WebhooksApi
	createBody := platformClient.Webhook{
		Description: platformClient.PtrString("Synchronizes serialized queue exports to external Git repository"),
		Enabled:     platformClient.PtrBool(true),
		EventTypes:  []string{"routing.queue.updated"},
		TargetUrl:   platformClient.PtrString(webhookURL),
		HttpMethod:  platformClient.PtrString("POST"),
		ContentType: platformClient.PtrString("application/json"),
		Headers: map[string]string{
			"X-Genesys-Queue-Export": "true",
	resp, err := webhookAPI.PostWebhooksV2Webhooks(ctx, createBody)
	if err != nil {
		return fmt.Errorf("webhook registration failed: %w", err)
	if resp.StatusCode != 201 {
		return fmt.Errorf("webhook creation returned status %d", resp.StatusCode)
	return nil
func (s *QueueConfigSerializer) LogAudit(queueID string, version int64, status string, details string) {
	entry := AuditLogEntry{
		Timestamp: time.Now(),
		QueueID:   queueID,
		Version:   version,
		Status:    status,
		Details:   details,
	s.AuditLog = append(s.AuditLog, entry)
func (s *QueueConfigSerializer) ExportQueue(ctx context.Context, queue platformClient.Queue) ([]byte, error) {
	start := time.Now()
	s.Metrics.TotalExports.Add(1)
	if s.VersionCache[queue.Id] == queue.Version {
		s.LogAudit(queue.Id, queue.Version, "skipped", "version unchanged")
		return nil, nil
	payload := s.BuildExportPayload(queue)
	if err := s.ValidateExport(ctx, payload); err != nil {
		s.LogAudit(queue.Id, queue.Version, "validation_failed", err.Error())
		return nil, err
	jsonBytes, err := json.MarshalIndent(payload, "", "  ")
	if err != nil {
		s.LogAudit(queue.Id, queue.Version, "serialization_failed", err.Error())
		return nil, fmt.Errorf("json marshal failed: %w", err)
	latency := time.Since(start).Nanoseconds()
	s.Metrics.TotalLatencyNs.Add(latency)
	s.Metrics.SuccessfulExports.Add(1)
	s.VersionCache[queue.Id] = queue.Version
	s.LogAudit(queue.Id, queue.Version, "success", fmt.Sprintf("latency: %d ns", latency))
	return jsonBytes, nil
The following script combines authentication, initialization, fetching, validation, serialization, metrics tracking, audit logging, and webhook registration into a single executable program. Replace the placeholder credentials before running.
package main
import (
	"context"
	"fmt"
	"log"
	"os"
	"time"
func main() {
	clientID := os.Getenv("GENESYS_CLIENT_ID")
	clientSecret := os.Getenv("GENESYS_CLIENT_SECRET")
	webhookURL := os.Getenv("GIT_WEBHOOK_URL")
	if clientID == "" || clientSecret == "" {
		log.Fatal("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables are required")
	token, err := fetchOAuthToken(clientID, clientSecret, "routing:queue:read routing:skill:read webhooks:webhook:readwrite platform:webhook:readwrite")
	if err != nil {
		log.Fatalf("Authentication failed: %v", err)
	serializer, err := NewQueueConfigSerializer(token.AccessToken, 15)
	if err != nil {
		log.Fatalf("Serializer initialization failed: %v", err)
	ctx, cancel := context.WithTimeout(context.Background(), 60*time.Second)
	defer cancel()
	queues, err := serializer.FetchQueues(ctx)
	if err != nil {
		log.Fatalf("Failed to fetch queues: %v", err)
	if webhookURL != "" {
		if err := serializer.RegisterGitSyncWebhook(ctx, webhookURL); err != nil {
			log.Printf("Warning: webhook registration failed: %v", err)
	for i := range queues {
		queue := queues[i]
		if queue.Id == nil {
		jsonBytes, err := serializer.ExportQueue(ctx, queue)
		if err != nil {
			log.Printf("Queue %s export failed: %v", *queue.Id, err)
		if jsonBytes != nil {
			filename := fmt.Sprintf("queue_%s_v%d.json", *queue.Id, queue.Version)
			if writeErr := os.WriteFile(filename, jsonBytes, 0644); writeErr != nil {
				log.Printf("Failed to write file %s: %v", filename, writeErr)
			} else {
				log.Printf("Successfully exported %s", filename)
	fmt.Printf("\nExport Metrics:\n")
	fmt.Printf("Total Attempts: %d\n", serializer.Metrics.TotalExports.Load())
	fmt.Printf("Successful: %d\n", serializer.Metrics.SuccessfulExports.Load())
	fmt.Printf("Total Latency: %d ns\n", serializer.Metrics.TotalLatencyNs.Load())
	fmt.Printf("Audit Log Entries: %d\n", len(serializer.AuditLog))
Error: HTTP 401 Unauthorized
  • Cause: The OAuth token expired or was issued with insufficient scopes.
  • Fix: Implement token caching with a refresh buffer. Ensure the scope parameter includes routing:queue:read and routing:skill:read.
  • Code Fix: Check resp.StatusCode in fetchOAuthToken and retry with a fresh token request.
Error: HTTP 403 Forbidden
  • Cause: The OAuth client lacks permission to access routing resources or webhook management.
  • Fix: Assign the required OAuth scopes in the Genesys Cloud admin console under Organization > Security > OAuth 2.0 clients. Verify the client type is set to Confidential or Public with appropriate role mappings.
  • Cause: Genesys Cloud enforces rate limits per API endpoint and tenant.
  • Fix: Implement exponential backoff and respect the Retry-After header. The provided code includes a basic two-second sleep on 429 responses. Production systems should parse the header and wait accordingly.
Error: Maximum Object Depth Exceeded
  • Cause: Custom attributes or nested routing configurations exceed the DepthLimit threshold.
  • Fix: Increase DepthLimit in NewQueueConfigSerializer or prune unnecessary nested fields before serialization. Review the checkDepthAndCirculars recursion logic to ensure it matches your payload structure.
Error: Circular Reference Detected
  • Cause: A config-ref points back to a parent queue or another object already in the serialization stack.
  • Fix: The VisitedRefs map breaks cycles. If legitimate bidirectional references exist, normalize them by storing only forward references and removing reverse pointers during BuildExportPayload.
