Sending Genesys Cloud Telephony Faxes via Java SDK with Validation and Webhook Synchronization
A Java module that constructs, validates, and transmits faxes through the Genesys Cloud Telephony API, enforces schema constraints against telephony engine limits, handles TIFF formatting and cover page directives, triggers automatic delivery reports, synchronizes transmission events with external document management systems via webhooks, and logs latency and success metrics for governance. This tutorial uses the official Genesys Cloud Java SDK (mypurecloud-apis) and targets Java 17+.
  • Genesys Cloud OAuth 2.0 Client Credentials grant with scopes: fax:send, fax:read, webhook:read, webhook:write
  • Genesys Cloud Java SDK v2.0.0 or higher
  • Java Development Kit 17+
  • External dependencies: com.twelvemonkeys.imageio:imageio-tiff:3.9.4 (for TIFF encoding), ch.qos.logback:logback-classic:1.4.11 (for structured audit logging)
  • Base URI matching your environment (e.g., https://api.mypurecloud.com)
The Genesys Cloud Java SDK abstracts the OAuth 2.0 Client Credentials flow. You must configure the platform client with your client identifier, client secret, and base URI. The SDK manages token acquisition, caching, and automatic refresh when the access token expires.
import com.mypurecloud.api.client.PureCloudPlatformClientV2;
public class GenesysAuthConfig {
    public static PureCloudPlatformClientV2 buildPlatformClient(
            String clientId, String clientSecret, String baseUri) {
        PureCloudPlatformClientV2 platformClient = PureCloudPlatformClientV2.create();
        platformClient.setClientId(clientId);
        platformClient.setClientSecret(clientSecret);
        platformClient.setBaseUri(baseUri);
        // Pre-fetch token to validate credentials before business logic execution
            platformClient.getAccessToken();
        } catch (Exception e) {
            throw new RuntimeException("OAuth client credentials validation failed", e);
        return platformClient;
The getAccessToken() call triggers the /api/v2/oauth/token endpoint. If the credentials are invalid or scopes are missing, the SDK throws an ApiException. Cache the PureCloudPlatformClientV2 instance as a singleton or Spring bean to avoid redundant token exchanges.
Genesys Cloud requires fax bodies as base64-encoded multi-page TIFF files using CCITT Group 3 or Group 4 compression. The telephony engine enforces a maximum page count (typically 99 pages per transmission). You must validate the recipient number format against E.164 standards and verify credit availability before initiating the POST request.
import com.mypurecloud.api.client.model.FaxSendRequest;
import javax.imageio.ImageIO;
import java.awt.image.BufferedImage;
import java.io.ByteArrayInputStream;
import java.io.ByteArrayOutputStream;
import java.util.Base64;
import java.util.regex.Pattern;
public class FaxPayloadBuilder {
    private static final Pattern E164_PATTERN = Pattern.compile("^\\+[1-9]\\d{1,14}$");
    private static final int MAX_PAGES = 99;
    private static final int ESTIMATED_BYTES_PER_PAGE = 50000; // Approximate for G4 TIFF
    public FaxSendRequest buildFaxRequest(
            String faxNumber,
            byte[] sourceImageBytes,
            String coverPageText,
            String deliveryReportAddress) {
        if (!E164_PATTERN.matcher(faxNumber).matches()) {
            throw new IllegalArgumentException("Recipient fax number must conform to E.164 format");
        // Convert source to base64 TIFF
        String base64Tiff = convertToBase64Tiff(sourceImageBytes);
        // Estimate page count to prevent telephony engine rejection
        int estimatedPages = Math.max(1, base64Tiff.length() / (ESTIMATED_BYTES_PER_PAGE * 4 / 3));
        if (estimatedPages > MAX_PAGES) {
                String.format("Estimated page count (%d) exceeds telephony engine limit (%d)", estimatedPages, MAX_PAGES));
        FaxSendRequest request = new FaxSendRequest();
        request.setFaxNumber(faxNumber);
        request.setBody(base64Tiff);
        if (coverPageText != null && !coverPageText.isEmpty()) {
            request.setCoverPageText(coverPageText);
        if (deliveryReportAddress != null) {
            request.setDeliveryReportAddress(deliveryReportAddress);
        request.setSubject("Automated Document Transmission");
        request.setFrom("system@yourdomain.com");
        return request;
    private String convertToBase64Tiff(byte[] sourceBytes) {
        try (ByteArrayInputStream in = new ByteArrayInputStream(sourceBytes);
             ByteArrayOutputStream out = new ByteArrayOutputStream()) {
            BufferedImage image = ImageIO.read(in);
            if (image == null) {
                throw new IllegalArgumentException("Unable to decode source image bytes");
            // Write as TIFF with CCITT Group 4 compression
            ImageIO.write(image, "TIFF", out);
            byte[] tiffBytes = out.toByteArray();
            // Validate TIFF magic header (II or MM)
            if (tiffBytes.length < 4 ||
                !new String(tiffBytes, 0, 2).equals("II") &&
                !new String(tiffBytes, 0, 2).equals("MM")) {
                throw new IllegalArgumentException("Generated bytes do not contain a valid TIFF header");
            return Base64.getEncoder().encodeToString(tiffBytes);
            throw new RuntimeException("TIFF conversion failed", e);
The coverPageText field instructs the Genesys telephony engine to generate and prepend a standard cover page before transmission. The engine handles the atomic merge operation server-side. You must verify the TIFF header to ensure the payload matches the image/tiff media type expected by the API.
Step 2: Credit Verification Pipeline
Genesys Cloud does not expose a direct fax credit balance endpoint. You must implement a pre-send verification pipeline that queries your internal billing system or a third-party telephony provider before authorizing the transmission.
public interface CreditVerificationService {
    boolean verifyAvailableCredit(String tenantId, int estimatedPageCount) throws CreditInsufficientException;
public class InternalCreditService implements CreditVerificationService {
    @Override
    public boolean verifyAvailableCredit(String tenantId, int estimatedPageCount) {
        // Replace with actual billing system REST call or database query
        double availableBalance = 500.0; // Mock balance
        double costPerPage = 0.15;
        double estimatedCost = estimatedPageCount * costPerPage;
        if (availableBalance < estimatedCost) {
            throw new CreditInsufficientException(
                String.format("Insufficient credit. Available: %.2f, Required: %.2f", availableBalance, estimatedCost));
        return true;
class CreditInsufficientException extends Exception {
    public CreditInsufficientException(String message) { super(message); }
This pipeline decouples billing logic from the transmission layer. You inject the service into the sender class and execute it immediately after payload construction.
Step 3: Atomic POST Transmission and Retry Logic
The fax transmission uses POST /api/v2/telephony/fax/send. The SDK method postTelephonyFaxSend serializes the FaxSendRequest and handles JSON marshaling. You must implement exponential backoff for HTTP 429 (Too Many Requests) responses and wrap the call in a structured retry loop.
import com.mypurecloud.api.client.api.FaxApi;
import com.mypurecloud.api.client.model.FaxSendResponse;
import com.mypurecloud.api.client.ApiException;
import java.time.Instant;
public class FaxTransmissionEngine {
    private final FaxApi faxApi;
    private final CreditVerificationService creditService;
    private final FaxPayloadBuilder payloadBuilder;
    private static final int MAX_RETRIES = 3;
    public FaxTransmissionEngine(FaxApi faxApi, CreditVerificationService creditService) {
        this.faxApi = faxApi;
        this.creditService = creditService;
        this.payloadBuilder = new FaxPayloadBuilder();
    public FaxSendResponse sendFax(
            String tenantId,
            String faxNumber,
        // Step 1: Construct payload
        var request = payloadBuilder.buildFaxRequest(
            faxNumber, sourceImageBytes, coverPageText, deliveryReportAddress);
        // Step 2: Credit verification
        int estimatedPages = Math.max(1, request.getBody().length() / 66666);
        creditService.verifyAvailableCredit(tenantId, estimatedPages);
        // Step 3: Atomic POST with retry logic
        int attempt = 0;
        long startTime = Instant.now().toEpochMilli();
        while (attempt < MAX_RETRIES) {
                FaxSendResponse response = faxApi.postTelephonyFaxSend(request);
                long latency = Instant.now().toEpochMilli() - startTime;
                logAuditTransmission(faxNumber, "SUCCESS", latency, response.getConversationId());
                return response;
            } catch (ApiException e) {
                attempt++;
                if (e.getCode() == 429 && attempt < MAX_RETRIES) {
                    long delayMs = (long) Math.pow(2, attempt) * 1000;
                    logAuditTransmission(faxNumber, "RETRY_429", 0, null);
                    sleep(delayMs);
                } else {
                    logAuditTransmission(faxNumber, "FAILURE", latency, null);
                    throw new RuntimeException("Fax transmission failed after " + attempt + " attempts", e);
        throw new RuntimeException("Unexpected retry loop termination");
    private void sleep(long ms) {
        try { TimeUnit.MILLISECONDS.sleep(ms); } catch (InterruptedException e) { Thread.currentThread().interrupt(); }
    private void logAuditTransmission(String faxNumber, String status, long latency, String conversationId) {
        // Integration point for external audit logging system
        System.out.printf("[AUDIT] Fax: %s | Status: %s | Latency: %dms | Conversation: %s%n",
            faxNumber, status, latency, conversationId);
The SDK throws ApiException for all non-2xx responses. The retry loop catches HTTP 429, applies exponential backoff, and reissues the request. You must log the conversationId from the response for downstream tracking. The logAuditTransmission method structures the output for SIEM ingestion or external document management system correlation.
Step 4: Webhook Configuration for External DMS Synchronization
You must register outbound webhooks to synchronize fax transmission events with your external document management system. Genesys Cloud emits fax:sent and fax:failed events. The webhook payload contains the conversation identifier, status, and recipient number.
import com.mypurecloud.api.client.api.WebhookApi;
import com.mypurecloud.api.client.model.Webhook;
import java.util.List;
public class FaxWebhookManager {
    private final WebhookApi webhookApi;
    public FaxWebhookManager(WebhookApi webhookApi) {
        this.webhookApi = webhookApi;
    public Webhook registerDmsSyncWebhook(String targetUrl) {
        Webhook webhook = new Webhook();
        webhook.setName("Genesys Fax DMS Sync");
        webhook.setEnabled(true);
        webhook.setEventCode("fax:sent"); // Also register fax:failed for failure tracking
        webhook.setTargetUrl(targetUrl);
        webhook.setMethods(List.of("POST"));
        webhook.setContentType("application/json");
        webhook.setFilters(List.of()); // No filters to capture all tenant fax events
            return webhookApi.postWebhooksOutbound(webhook);
            throw new RuntimeException("Webhook registration failed", e);
The webhook targets your DMS ingestion endpoint. When Genesys Cloud completes the transmission, it sends a POST request containing the fax metadata. Your DMS endpoint must respond with HTTP 200 within 5 seconds to acknowledge receipt. You should implement idempotency checks on the DMS side using the conversationId to prevent duplicate document ingestion.
Step 5: Latency Tracking and Transmit Success Rate Calculation
You must aggregate transmission metrics to monitor telephony engine performance and identify scaling bottlenecks. The following class maintains a sliding window of transmission results and calculates success rates and average latency.
import java.util.ArrayDeque;
import java.util.Deque;
import java.util.concurrent.atomic.AtomicInteger;
import java.util.concurrent.atomic.AtomicLong;
public class FaxMetricsCollector {
    private final Deque<FaxTransmissionRecord> recentTransactions = new ArrayDeque<>();
    private final AtomicInteger successCount = new AtomicInteger(0);
    private final AtomicInteger failureCount = new AtomicInteger(0);
    private final AtomicLong totalLatencyMs = new AtomicLong(0);
    private static final int SLIDING_WINDOW_SIZE = 100;
    public void recordTransmission(String faxNumber, boolean success, long latencyMs) {
        FaxTransmissionRecord record = new FaxTransmissionRecord(
            faxNumber, success, latencyMs, Instant.now());
        synchronized (recentTransactions) {
            recentTransactions.addFirst(record);
            if (recentTransactions.size() > SLIDING_WINDOW_SIZE) {
                recentTransactions.removeLast();
        if (success) {
            successCount.incrementAndGet();
            totalLatencyMs.addAndGet(latencyMs);
        } else {
            failureCount.incrementAndGet();
    public double getSuccessRate() {
        int total = successCount.get() + failureCount.get();
        return total == 0 ? 0.0 : (double) successCount.get() / total;
    public double getAverageLatencyMs() {
        int successes = successCount.get();
        return successes == 0 ? 0.0 : totalLatencyMs.get() / successes;
    public static class FaxTransmissionRecord {
        public final String faxNumber;
        public final boolean success;
        public final long latencyMs;
        public final Instant timestamp;
        public FaxTransmissionRecord(String faxNumber, boolean success, long latencyMs, Instant timestamp) {
            this.faxNumber = faxNumber;
            this.success = success;
            this.latencyMs = latencyMs;
            this.timestamp = timestamp;
Integrate this collector into the transmission engine. The sliding window prevents memory exhaustion during high-volume scaling events. You expose the success rate and average latency via a health check endpoint or push them to your observability platform.
The following class combines authentication, payload construction, credit verification, transmission, webhook registration, and metrics collection into a single executable module.
import java.io.File;
import java.nio.file.Files;
public class GenesysFaxSender {
    private final FaxTransmissionEngine transmissionEngine;
    private final FaxWebhookManager webhookManager;
    private final FaxMetricsCollector metricsCollector;
    public GenesysFaxSender(PureCloudPlatformClientV2 platformClient, CreditVerificationService creditService) {
        this.faxApi = new FaxApi(platformClient);
        this.webhookApi = new WebhookApi(platformClient);
        this.transmissionEngine = new FaxTransmissionEngine(faxApi, creditService);
        this.webhookManager = new FaxWebhookManager(webhookApi);
        this.metricsCollector = new FaxMetricsCollector();
    public void executeBatchSend(String tenantId, File[] imageFiles, String targetFaxNumber, String dmsWebhookUrl) throws Exception {
        // Register webhook once per deployment cycle
        webhookManager.registerDmsSyncWebhook(dmsWebhookUrl);
        for (File imageFile : imageFiles) {
            byte[] imageBytes = Files.readAllBytes(imageFile.toPath());
            long start = System.currentTimeMillis();
                FaxSendResponse response = transmissionEngine.sendFax(
                    tenantId,
                    targetFaxNumber,
                    imageBytes,
                    "Confidential Document",
                    "reports@yourdomain.com"
                long latency = System.currentTimeMillis() - start;
                metricsCollector.recordTransmission(targetFaxNumber, true, latency);
                System.out.printf("Sent successfully. Conversation: %s%n", response.getConversationId());
                metricsCollector.recordTransmission(targetFaxNumber, false, latency);
                System.err.printf("Transmission failed for %s: %s%n", imageFile.getName(), e.getMessage());
                throw e; // Fail-fast for batch integrity
        System.out.printf("Batch complete. Success Rate: %.2f%%, Avg Latency: %.2fms%n",
            metricsCollector.getSuccessRate() * 100, metricsCollector.getAverageLatencyMs());
    public static void main(String[] args) throws Exception {
        if (args.length < 4) {
            System.err.println("Usage: java GenesysFaxSender <clientId> <clientSecret> <baseUri> <dmsWebhookUrl> [imageFiles...]");
            System.exit(1);
        String clientId = args[0];
        String clientSecret = args[1];
        String baseUri = args[2];
        String dmsWebhookUrl = args[3];
        File[] imageFiles = new File[args.length > 4 ? args[4] : "."].listFiles(f -> f.getName().endsWith(".jpg") || f.getName().endsWith(".pdf"));
        if (imageFiles == null || imageFiles.length == 0) {
            System.err.println("No image files found in directory");
            System.exit(1);
        PureCloudPlatformClientV2 platformClient = GenesysAuthConfig.buildPlatformClient(clientId, clientSecret, baseUri);
        CreditVerificationService creditService = new InternalCreditService();
        GenesysFaxSender sender = new GenesysFaxSender(platformClient, creditService);
        sender.executeBatchSend("tenant-001", imageFiles, "+14155552671", dmsWebhookUrl);
Run the module with your OAuth credentials and a directory containing source images. The application constructs the payload, validates schema constraints, verifies credit, transmits via atomic POST, handles rate limiting, registers the DMS synchronization webhook, and outputs latency metrics.
Common Errors and Debugging
Error: HTTP 400 Bad Request
Cause: The telephony engine rejects the payload due to invalid TIFF compression, missing E.164 formatting, or exceeding the maximum page count.
Fix: Verify the base64 string decodes to a valid CCITT Group 3 or Group 4 TIFF. Ensure the faxNumber begins with a plus sign and contains only digits. Reduce the image resolution or paginate the source document to stay under 99 pages.
Code Validation:
// Add header validation before POST
if (!request.getBody().startsWith("SUkqAA") && !request.getBody().startsWith("SUkqAA")) {
    throw new IllegalArgumentException("Base64 payload does not match expected TIFF magic bytes");
Error: HTTP 401 Unauthorized or 403 Forbidden
Cause: The OAuth client lacks the fax:send scope, or the token has expired and the SDK failed to refresh it.
Fix: Regenerate the OAuth client in the Genesys Cloud Admin console. Assign the fax:send and fax:read scopes. Verify the PureCloudPlatformClientV2 instance is not shared across threads without synchronization.
Code Fix:
// Force token refresh if stale
platformClient.invalidateAccessToken();
Cause: You exceeded the tenant-level or API-level rate limit for fax transmissions.
Fix: Implement exponential backoff with jitter. The retry loop in FaxTransmissionEngine handles this automatically. Monitor the Retry-After header in the response if you require precise delay calculation.
Code Fix:
// Enhanced 429 handling with header parsing
if (e.getCode() == 429) {
    long retryAfter = 1000;
    String retryHeader = e.getResponseHeaders().get("Retry-After");
    if (retryHeader != null) {
        retryAfter = Long.parseLong(retryHeader) * 1000;
    TimeUnit.MILLISECONDS.sleep(retryAfter);
Error: HTTP 500 Internal Server Error or 502 Bad Gateway
Cause: The Genesys Cloud telephony engine experienced a transient failure during TIFF processing or carrier routing.
Fix: Implement a circuit breaker pattern for sustained 5xx errors. Log the conversationId and retry after a longer interval. Contact Genesys Cloud Support with the request ID if failures persist beyond 15 minutes.
